-   -   88+ random miss fires (http://www.mazdaspeedforums.org/forum/f544/88-random-miss-fires-127247/)
jlsspeed4 10-12-2012 04:38 PM
Hey guys,
So I have a 2012 MS3 with 17k miles, all stocks, no mods. I was merging on traffic last week and got on it 3rd gear and shift at around 5krpm. Engine light came on. Went to dealer this Monday and service guy said they had a similar case with random miss fires (100+), they ended replaced the flywheel for the other guy (no idea what flywheel has to do with it).
So they clear the code and asked me to come back if it happens again since he said i only have like 2 or 3 miss fires.
Today on the highway doing 70mph and the light came on again, went to the dealer and he said it has like 88 random miss fires. THey gave me a loaner and they said they gonna replace the plugs.
Anyone have this type of experience?
motherfnmonsta 10-12-2012 06:01 PM
this is new on me man, I have yet to have any speeds come in the dealership for this issue.
But I got one question. When the cel came on was it a steady light or a blinking light. Steady light is ok, blinking light means shit is broke and damage can possibly be done to the engine if you let that light keep blinking.
keep us updated I am going to see if any tsb's are out for this.
jlsspeed4 10-12-2012 06:17 PM
Funny that you asked. The first time when it came on, it was steady first, then it started to flash and never seen it again. BUT today, it's different story, it was flashing every 5 seconds for about 5 to 6 times. I know it wasn't a good sign when I saw it flashes that many times, so I made the call and ask to come in right the way.... they gonna have my car until next week.
I really don't think changing the spark plugs would solve it, I don't have knowledge to back it up but the only thing I can explain is when the engine light started to flash, the car rides fine, no strange noise or lost of power, even when parked there wasn't any hesitation; that's why I don't think it'd be the spark plugs.
tddvrrn 10-12-2012 11:58 PM
do you know what the code was? random misfire or cylinder specific?
could be an injector or coil going out brussel sprout.
jlsspeed4 10-13-2012 07:40 AM
I believe it was p0300, any thoughts?
Shadow 10-13-2012 08:13 AM
Sounds to me like bring it to the dealer and let them hash it out. Misfire could be like 20 things and more on a boosted car.
Edit: flashing engine light means the car shut down a cylinder to prevent cat damage. Flashing engine light is bad news.
Sent from my ADR6400L using Tapatalk 2
tddvrrn 10-13-2012 02:13 PM
man, that's random misfire, i believe. which is the hard one to figure out..
looks like the dealer's gonna have to sort this one for you. i don't even know where to begin..
although you could go VIP, then download the shop manual for the car. there are diagnostic flowcharts in there, could be useful.
motherfnmonsta 10-13-2012 07:25 PM
you do not want to see the diag flow chart for this, it is a nightmare. hate to say this but shits broke.
And tddvrn love the little gif thing you got going on that shit is funny
itg3rl 10-13-2012 08:07 PM
Um, somethings not right here and I'm also not sure what the flywheel has to do with misfires...pretty much nothing.
Ask for the codes and the definitions. The CPU will tell you where the misfires are happening. It's actually very specific.
IDK @ 17K you wouldn't need plugs until at least 30k-45k. Ask them to do an induction service and check the fuel pump at 30k. not now. (which covers cleaning the fuel injectors) Seriously, start off here. For the speed 3's theres not many problems but at the fuel pump, suspension, and clutch, and turbo. I'll look monday for TSB's for the speed3. the only open recall I know of is for the VVT.
Be persistent and easy going they'll be eating out of your hand.
BTW. Check you gas cap dude.
motherfnmonsta 10-13-2012 08:24 PM
i all ready looked there are no tsb for misfires or anything along that line.
itg3rl 10-13-2012 08:49 PM
Didn't think so, but I wanted to make sure. If you've already checked...thank you.
motherfnmonsta 10-13-2012 09:14 PM
ya np I looked just the diag tree for random miss fire is a bitch
jlsspeed4 10-13-2012 10:12 PM
ahh, that's just great. So that's pretty much what they're gonna do. Change the plugs, clear the code. Few days later, light comes back on; bring car back to the dealer, and try something else, process elimination ahhhh, i see a long road ahead.
motherfnmonsta 10-13-2012 11:53 PM
There is a reason that your car has just suddenly done this. Spark plugs and coil packs do not just go bad unless you own a RX8 and that is a different beast in its self. When the cel came on was the car bucking, sputtering acting like it had loss of power
Zoomspeed 10-14-2012 12:45 AM
Maybe your V- Tech solenoid is going out
jlsspeed4 10-14-2012 08:31 AM
Not at all, both times. There wasn't any lost of power, hesitation, bucking and sputtering... nothing that I can feel or tell, I even parked my car and let it run and opened up the hood to hear, but it ran pretty normal...
Shadow 10-14-2012 09:21 AM
Does our crank position sensor read the flywheel? If so that's why flywheel matters. Crank position sensor is what checks for misfires by watching crank rotation speed and steadiness.
If not, it could also be a flywheel balance issue cause a misfire, more than likely its something else. I would just go to the dealer.
Tell em I don't want it back til it's fixed.
At fiat we have a guy lemon law a car over something stupider
Also gas cap throes a p0440-444. Not a misfire
silvapain 10-14-2012 10:36 AM
The tone ring for the CKP is on the crank pulley.
blakkat 10-14-2012 11:18 AM
we have a dual mass flywheel. if parts are damaged inside of it then yes it can cause a false misfire reading
just one example
Trouble shooting misfire codes - Rennlist Discussion Forums
itg3rl 10-14-2012 03:11 PM
I know what the gas codes are dude. Just being funny about the guys situation. Just never heard of a flywheel causing a false reading. That will be Interesting to me.
Let us know what it is. I'm curious.
jlsspeed4 10-17-2012 05:33 PM
Well guys, a little update from the "service advisor", he called today and said they changed out the plugs and still have couple of miss fires (I knew it)! So they sent out fuel sample and awaiting for the result. arrggg, did I got a lemon? :sad:
fortressofcomfort 10-17-2012 09:27 PM
a "fuel sample?" sounds like he's buying time and has no idea. It is a tough problem to sort out but keep in mind it could be a very simple and harmless fix so don't lose faith yet. Once they get enough eyes on the car (or throw enough parts at it) it'll run good again.
BobbleHead 10-17-2012 09:31 PM
have you tried a different gas station?
jlsspeed4 10-17-2012 09:42 PM
Yea, if they keep on replacing parts, I might end up with a whole new car :) @Harvey, I've been using the same two gas station since I bought the car, I doubt it'd be the gas... I guess we'll see the result is tomorrow.. can't wait what they gonna tell me. If they can't still figure it out, should I take the car back? He said the engine light didn't come up anymore but some how they can still see it has miss fires, couple of them.
blakkat 10-18-2012 08:48 AM
They're testing the volatility of your fuel to make sure you don't have summer blend low volatility fuel in your vehicle, which could cause poor atomization and subsequent misfires in colder weather
BobbleHead 10-18-2012 01:05 PM
no, dont take it back if it's not fixed
blakkat 10-19-2012 11:52 AM
They're ruling out spark and fuel problems. Sounds like routine misfire diag to me.
DuoofDeath1 10-19-2012 12:19 PM
Mine had random misfires and my check engine light was flashing the one afternoon. I had an aftermarket intake and the breather hose was loose on the intake side. They didn't even check my plugs. That happened at about 17K miles. I assume they would check all the intake connections. I tightened up that hose and haven't had any problem since them. They didn't tell me how many misfires i had but the car drove fine when the light was flashing.
dead-zone 10-19-2012 12:29 PM
Isn't it better, for example, if they try to fix the car but it just does not work to try a different dealer. Sometimes you never know who works at those places.
AzS13 10-19-2012 04:46 PM
My car is currently in the dealership for this same reason. Purchased a little over two weeks ago, the first friday the light came on and I changed the plugs. Light went off after a few miles on new plugs and didnt come back on until last friday. It had basically the same thing, light on and absolutely no loss in performance or drivability. I took it in on monday and they have yet to actually find out what is causing the misfires. Anything I can suggest to them to maybe give them ideas they haven't tried?
BTW car is 06 MS6 with 81k
jlsspeed4 10-19-2012 06:16 PM
Ok guys, I finally got my car back, I kinda like driving automatic... I've been driving manual for 14 years and it's weird feeling to drive auto cuz I feel like I don't have to do anything but just drive.
Anyway, so I'm gonna write up what they have done, apparently this is the 2nd case for them. Just a reminder, the other case, the guy had like 100+ miss fires in one cylinder, and he had a 12' Speed as well.
1. When the light first came on, they clear the code and asked me to come back if it happens because it had only two miss fires.
2. The engine came back on after a week, but this time the car had like 88 miss fires in cylinder 3 and couples in cylinder 4. Changed all the plugs and still had like couple of miss fires here and there.
3. Then, they changed the steering sensor? Still have miss fires
4. So, they swapped the coils around from cylinder to cylinder, from 2 to 1, 3 to 2, 4 to 3, 1 to 4, and still didn't work.
5. Finally changed the flywheel and apparently that solved the problem.
I was the second case the dealer had to change the flywheel.
blakkat 10-19-2012 06:33 PM
It's the damn dual mass flywheel. Those guys are pretty good to catch that
Caveman4684 10-21-2012 08:08 PM
Thanks for posting. This will likely come up again and a dealer might have trouble finding the solution. In that case a little research here will point them in the right direction.
When I thought that my 2005 STi had a broken piston ringland the dealer did not know it was common problem. After talking to the service writer for a long time I left and came back and caught him on the NASIOC forums lol.
motherfnmonsta 10-25-2012 06:19 PM
thanks for the update, I will keep this in mind for sure if a car happens to comes in for a massive amount of misfires.
makjur 10-26-2012 10:02 PM
good on ya for sharing this
i always think coils when i hear missfire since i had a 1.8t GTI for a while...
ktms3 10-29-2012 02:04 AM
Originally Posted by jlsspeed4 (Post 1678374)
Hey guys,
Happened to me. They replaced my coil pack, pcv valve, spark plugs, injectors, and they took my intake manifold off and cleaned it as much as they could. No problems since!
Page generated in 0.19501 seconds with 11 queries
