 Old 12-09-2013, 06:08 PM   #41
a turbo bird's Avatar
Posts: 14   (View Stats)
a turbo bird can only hope to improve
Originally Posted by Spencer@CorkSport View Post
You can run the Stock or OTS maps for Stage I and our HPFP without issue. I've been doing it for over 3000miles.
Now for Stage II you should be running our specific maps, HERE: CorkSport Mazdaspeed Accessport Maps
Thanks for that!
Mazdaspeed 3 2010: CAI K&N Typhoon / Cobb TIH / Autotech HPFP internals / Corksport race pipe / Stage 1+ (K&N SRI Intake + TIH) / JBR Chrome-Molly RMM
a turbo bird is offline   Reply With Quote
 Old 12-09-2013, 09:04 PM   #42
shamie's Avatar
Posts: 952   (View Stats)
@Spencer@CorkSport; Do you have a link for gen one maps?
 Old 12-10-2013, 11:26 AM   #43
SpencerC's Avatar
Posts: 2,159   (View Stats)
SpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the worldSpencerC is the leader of the world
http://www.corksport.com/corksport-2007-2009-mazdaspeed-3-stage-2-accessport-maps.html
Also
MS6 Maps
SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount -
CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit
1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights
Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3?
SpencerC is offline   Reply With Quote
 Old 12-10-2013, 11:56 AM   #44
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
Wait...
stage 1 doesn't need a special map but stage 2 does, just because of the internals? How does that work? With more flow mods the pump is actually pushing more fuel than with less flow mods? Please get this one explained, I'm not following. The only reason I can think of for that is you're raising the demand pressure in which case you'll need to release a corksport relief valve very soon too.
I'm genuinely curious, I've run autotechs for 30,000 miles and have never had an issue with pressure or flow being off because of flow mods. I mean, you'll need to do a maf cal of course but that should take care of any issue that arises and is just standard tuning practice on these cars anyway.
Blue Pu.
 Old 12-10-2013, 12:14 PM   #45
abiezerf's Avatar
Posts: 725   (View Stats)
abiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the world
Groans: 46
I don't understand why all these brownies take the trouble of wasting $300+ on intake and test pipe but don't even bother to do fuel pump internals. Do they think that the fuel will just flow magically? It's like they are trying all they can to avoid it by saying "It was running fine until now".
Current Build:
Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly
JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune
PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs
Sold:
2008.5 Black Mica GenWon - Fully Bolted
abiezerf is offline   Reply With Quote
The Following User Says Thank You to abiezerf For This Useful Post:
Koenig (12-10-2013)
 Old 12-10-2013, 12:18 PM   #46
vtekken's Avatar
Posts: 737   (View Stats)
vtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the world
Because VTEC.
2011 MazdaSpeed 3
RichTuned | Cobb SRI | Cobb TIH | SU TMIC | CS Racepipe | CS Downpipe | CS TMM Insert | KMD 2.1 | CPE Stage 2 RMM | ITV 22's |
Sent using VTEC
vtekken is offline   Reply With Quote
 Old 12-10-2013, 12:36 PM   #47
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
HawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the world
Lol at the shit storm that this created. Stop being a shit head OP.
Silver 2007 Speed3 GT
Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power.
Titanium Grey Mazdaspeed6 GTX3071, DD
HawkeyeGeoff is offline   Reply With Quote
The Following 3 Users Say Thank You to HawkeyeGeoff For This Useful Post:
a turbo bird (12-10-2013), chaser27 (12-10-2013), WAMBUSHHHH! (12-10-2013)
 Old 12-10-2013, 01:14 PM   #48
SpencerC's Avatar
Wait...
Let me see if I can get you any answer that is more technical than, "well it worked for me!"
Wouldn't basic logic say, more power and more boost = more fuel required. So a stage II map that is not from us would not take full advantage of our fuel amounts and either give too much possibly, or too little?
A stage I would not matter as much because even a stock pump should be able to keep up, and our pump won't be putting out less than that, and shouldn't be asked to give to much since it's just stage I.
I'm no COBB MAP expert though so maybe I'm backwards. That just seems simple to me, but let me see if I can find more info.
 Old 12-10-2013, 01:34 PM   #49
shamie's Avatar
@Spencer@CorkSport; Is there a way I can navigate to this link through your web site? I'm only able to get there with this link directly.
 Old 12-12-2013, 04:43 PM   #50
SpencerC's Avatar
Wait...
So I chatted with my coworkers who understand this more and the answer is this:
The Maps were designed specifically to match our parts with the our pump. Now the Stage I Cobb OTS maps are roughly 5% off from what we have seen, so there would be no huge benefit to creating our own, unless we had a LOT of interest, but seeing as the majority of people upgrading their HPFP plan on going stage II anyway, they should be fine.
Likely, in the future, we will be releasing more maps, but probably not for awhile. It just isn't necessary.
We don't have a direct link from the site currently. We should soon.
 Old 12-12-2013, 05:24 PM   #51
anavrinIV's Avatar
Groans: 63
Okay then. I understand that the maps match the parts, what part of the map is changed? MAF cal, HPFP tables, injector tables, AFRs?
@atvfreek; @rfinkle2; @ms3blackmica; @Lex; @RichieRichness; anyone done map comparisons COBB OTS to Corksport OTS? I'm genuinely curious about the differences here, I can't wrap my head around it and don't my my way around ATR well enough to figure this out quickly.
Blue Pu.
RichieRichness (12-13-2013)
 Old 12-12-2013, 05:29 PM   #52
oOfactoryOo's Avatar
Posts: 107   (View Stats)
oOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond reputeoOfactoryOo has a reputation beyond repute
Groaned at 6 Times in 1 Post
I think I can answer that. People who mod their cars seem to be split into different categories. There are probably several degrees of each group, but basically there are those with knowledge, and those with none.
I am one of those people with no knowledge. All my life (I am 42) I have always stayed away from wrenching on my cars. Never really had one worth doing it too. I had friends however, who were big into 1/4 mile racing. They all owned Shelby Chargers, or Shelby Lancers etc...They added mod after mod, and more often then not, returned from the strip on the back of a flatbed with holes in their blocks. They would then just rebuild it and go again. There was talk of chips, intakes, and straight pipes. I think everyone in this category is under the impression that these are the go fast parts that will make their car the king of the road. We don't understand, or have never learned, that these mods can affect anything else in our cars.
My first purchase was a SRI with TIP. Never thought about the consequences to a fuel pump. Didn't even know I had one. Then I started to read, and my world began to expand. I still know next to nothing, and still belong in the group of people with no knowledge. But thanks to this site, and to you guys who belong to the group of people who have knowledge, I am slowly beginning to understand how my car works.
tl:dr Because some of us are ignorant, while others are smart
2013 CWP MS3 with Tech package
Cobb V3 // JBR 88RMM // Corksport SRI with TIP // Autotech Internals // UR Test Pipe
oOfactoryOo is offline   Reply With Quote
 Old 12-12-2013, 05:43 PM   #53
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Sorry anavrinIV.
I'm not of any help here.
The maps appear to be created using AccessTuner Pro which I cannot open.
My guess would be reduced HPFP targets to keep the actual HPFP pressure stable and prevent pressure creep.
Contact CorkSport to speak with the calibrator of the maps for more info.
www.tunedbynishan.com
 Old 12-12-2013, 06:14 PM   #54
Gr33ntumb's Avatar
Posts: 348   (View Stats)
Gr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond reputeGr33ntumb has a reputation beyond repute
I'm glad my drunken ramble generated some cool discussion. The more info the better.
Awaiting the release to see results
Sent from my SGH-I317M using Tapatalk 2
CS 3inch intake, CS FP internals, CS Test pipe, Forge V2, AP v3, JBR 88a RMM and mud flops
Gr33ntumb is offline   Reply With Quote
 Old 12-12-2013, 09:01 PM   #55
rdguindon's Avatar
Posts: 37   (View Stats)
rdguindon has a spectacular aura aboutrdguindon has a spectacular aura aboutrdguindon has a spectacular aura about
Flash back to a stage 0 map and dont do any WOT's until you get fp internals.
2013 MazdaSpeed 3
COBB AP/ COBB RMM
JBR 3.5" Whale PeePee
AutoTech HPFP Internals
"I was recommended to port and polish the intake and exhaust. We found out they used abrasive material to do it like gritty sand. So I got with my friend that tunes Hondas and we decided to try it ourselves. We got a bag of sandblasting sand and hooked up into the intake and started the car. We had to hold the gas so it would run. He wanted to let the engine suck in the sand through the intake so it would port it out and then push it out the ehxaust so it would port the exhaust manifold.
I was worried that it might cause problems but he figured it'd be OK as long as we didn't make boost and it get sucked in the turbo. After running the car and letting it suck in sand we got about half way through a 25 lb bag. The check engine light was on and the engine was bucking and kicking and sounding really weird. We stopped and hooked the car back up normal and took off the sand supply. We tried to start it again and it was really hard. Once started it couldn't idle and kept making weird noises. We took it out and drove it and it started to make scraping and knocking noises."
rdguindon is offline   Reply With Quote
 Old 12-12-2013, 09:12 PM   #56
rdguindon's Avatar
Flash back to a stage 0 map and dont do any WOT's until you get fp internals. With the colder weather you will see more boost which requires more fuel. I was trying to run the JBR 3.5" intake and with the winter weather my fuel pressure was dropping into the 1500's so I flashed back to a stage 0 until i get my internals.
2013 MazdaSpeed 3
COBB AP/ COBB RMM
Report: Ford F-150 EcoBoost in NHTSA probe for acceleration issue Haltech Automotive News 0 05-28-2013 02:40 PM
Acceleration issue dMuze 2010 MS3 - Troubleshoot/Diagnostics 15 11-20-2012 04:37 PM
Toyota's recalls fail to address extent of acceleration issue, study says Haltech Automotive News 0 02-07-2010 10:10 PM
REPORT: Toyota may 'shorten' gas pedals to fix unintended acceleration issue Haltech Automotive News 0 11-19-2009 08:40 AM
Creaking noise on acceleration...Possible Medieval MM Issue? Element MazdaSpeed 3 - Engine, Transmission & Driveline 3 05-06-2009 12:48 AM
Page generated in 0.39348 seconds with 31 queries
