Like Tree18Likes
 Old 02-23-2012, 05:01 AM   #41
Acedelgado's Avatar
Posts: 39   (View Stats)
Acedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud ofAcedelgado has much to be proud of
Clutch and CV boots aren't covered.
Tappin her? Tapatalk how?
2012 LSM Non-tech
Kensun 6000k HID / SURE 70a RMM \Cobb AP/ Autotech Internals\ Corksport SRI + TIP/ Synchronic BOV
Interior:
AppRadio 2 + ARLiberator + ScanTool Bluetooth OBDII Reader + Torque Pro = Win.
Acedelgado is offline   Reply With Quote
 Old 02-23-2012, 07:23 AM   #42
Dr. Speed's Avatar
Posts: 610   (View Stats)
So how likely is it that your claim will be denied if you stock out before going, but you've reflashed with an AP?
 Old 02-23-2012, 07:35 AM   #43
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Originally Posted by Noodlesincup View Post
I called my dealership
ANY after market mods would void my warrenty
This makes he hesitant since I only have 2k miles on my car.
Sri/tip is easy to stock out but the other things would be a pain...
You guys with the fairly new ms3 did you just say f it and mod?
100k miles is a long time not to mod
Sent from my SGH-T959V using Tapatalk
If you gave them your name/VIN or they know who you are, chances are you're already flagged.
 Old 02-23-2012, 07:40 AM   #44
COCKSTRONG
Groans: 890
If you put everything back the way it was, you should have no problem. I've done it a couple of times. I uninstall my AP a few days before a dealer visit and put some miles and ignition cycles on the car so everything appears normal.
 Old 02-23-2012, 08:00 AM   #45
Noodlesincup's Avatar
Posts: 298   (View Stats)
Noodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the world
Groaned at 37 Times in 9 Posts
^boss right there
Ill have to remember that
2012 CWP Mazdaspeed3 Current Mods: Cobb Turbo Back|Cobb Sri/Tip|Cobb XLE|Cobb Ap|Jbr Heavy Shit Knob|AutoTech Internals|JBR Short Shifter Plate/Brushings|Corksport Tmic|
Noodlesincup is offline   Reply With Quote
 Old 02-23-2012, 08:04 AM   #46
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
deadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the worlddeadlandxtreme is the leader of the world
Groans: 82
Dead on! Just have to make sure everything is back to stock so they have no reason to question anything. On mine, they just took some pictures and sent it to corp, an hour later I was approved for a new engine. lol
2010 Mazdaspeed3- Installed Mods:- GT 3071 (Ported,polished, and coated by Grimmspeed) Polished and coated throttle body (Grimmspeed)TWM Performance Full Replacement Short Shifter Kit, Corksport FMIC (Upgraded size and coated by Calico Coatings), HTP 4" SRI, Forge V2 BPV, Corksport coolant hoses, NGK Iridum, COBB AP, Full Race DP (ceramic coated), Corksport hangers,JBR EGR block off, Autotech HPFP internals. Glowshift triple gauge pod, Aeroforce Interceptor dual gauges, STRI Imperial boost gauge.Stratified EBCS.RSB and Rear Camber Arms ( JBR ). Tein EDFC kit - Tein Super Street Coilovers . Enkei Racing RPF1 .GTSPEC bracing (front to rear)Corksport FSB..StopTech SS Brake Lines-SportStop Cross Drilled and Slotted Rotors-StopTech Street Performance Brake Pads.. Stratified Boost dial and Guardian Angel. JMF Intake manifold. Full Race Exhaust Manifold (ceramic coated). Damond Motorsports CC. SSP CC. PERM PCV Plate. 3bar MAP. , CP-E Triton full exhaust(Tuning provided by Stratified Tuning)
deadlandxtreme is offline   Reply With Quote
 Old 02-23-2012, 09:28 AM   #47
Dr. Speed's Avatar
Sounds good. I'll probably only do intake, AP, and race pipe... there are a couple people that just posted results from the Dizzy tunes on another thread with just these mods. Both had around 310whp and 370-380tq. It's nice because that's a LOT of power for basically 2 bolt-ons that are easy to remove.
 Old 02-23-2012, 09:49 AM   #48
narezzaspeed3's Avatar
Posts: 171   (View Stats)
narezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the worldnarezzaspeed3 is the leader of the world
Groaned at 5 Times in 1 Post
They can't void warranty as long as it falls in a specific category.
Example: <--just an example, get your dicks out of your asses, i know this is unlikely to happen.
if you install after market HID's.. and you're electrical system fails because your HID's decided it needs more power so it can haz brighter output.
Dealership, will have to have proof that whatever part of your electirical system that failed, like for example the alternator went bad because of the 'after market' HID part that you installed, then YES, they can say, we're denying you warranty replacement for that part. Otherwise, you can sue them if they say, "oh, we're not going to warranty the bannana peel in your engine because you have coil overs"
narezzaspeed3 is offline   Reply With Quote
 Old 02-23-2012, 12:51 PM   #49
mike16241's Avatar
Posts: 46   (View Stats)
mike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of lightmike16241 is a glorious beacon of light
the dealer i bought my ms3 off of is a authorized racing beat dealer. said i can talk to their mechanic about mods while still keeping everything under warranty. he's running 450whp and still fully warantied
mike16241 is offline   Reply With Quote
 Old 02-24-2012, 04:53 PM   #50
Bosox's Avatar
Posts: 328   (View Stats)
Bosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the worldBosox is the leader of the world
Groaned at 33 Times in 13 Posts
I always laugh when people bring up the Mag/Moss Act. Yes you can use the law to protect you, but who is going to get them to follow the law? This isn't a criminal matter, it is a civil matter. Meaning YOU would have to hire an attorney to bring litigation. That would likely cost you more than the repair. Yes you could try to get attorney fees as part of the settlement or judgement, but who really can afford to risk losing?
When I had my Spec V I had I/H/E/MM/P/S and other shit, but my dealership always did warranty work. Maybe because I bought A $50k Armada there too. But if I knew they would not have done the warranty work, and I couldnt find another dealership to do it, I would have returned my shit to stock if anything major would have happened.
Bosox is offline   Reply With Quote
 Old 02-24-2012, 04:56 PM   #51
Matx's Avatar
Posts: 1,681   (View Stats)
DONT BE BEACH! MOD THAT FUCKER!
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
 Old 02-24-2012, 09:14 PM   #52
JustanotherMS3's Avatar
Posts: 268   (View Stats)
JustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the worldJustanotherMS3 is the leader of the world
Groaned at 45 Times in 11 Posts
just rolled over 9000 kms and i have all the mods in my sig plus h&r springs, JBR SSB, are on the way, have had most of these parts since day 4 of ownership
so when you put miles on it and cycle the key what excatly does it do? remove all the data from the ap?
i hear lots of horror stories of going in for warrenty work, they send the comp to mazda USA ,and it comes back with diff paramaters and limitations caused by an AP and no more warrenty work.
true or false?
Currently own:
2012 Sunburst Orange Civic SI Coupe W/Tech package
Basically stock with an Injen SRI (much thanks to madspd6)
wheels will be here in a week or so: 18x9 +25 Fast Hayaku powder coated White (basically TE37 knockoffs)
Previous car... 2011 Velocity Red MS3 W/Tech
-Engine/Power Mods:
FREEK TUNE IN PROGRESS/UR CBE/UR Race Pipe/Injen SRI/COBB AP/AutoTech HPFP Internals/Stage 2 Driver Mod/Turbo Smart Duel Port/JBR SSP/JBR SSB/Razo Weighted Shift Knob/
-Wheels and suspension:
Lowered on H&R Springs
18x8.5 +30 offset XXR 522 in Gold.
Last edited by JustanotherMS3; 02-24-2012 at 09:14 PM. Reason: MSF Database - Automerged Doublepost
JustanotherMS3 is offline   Reply With Quote
 Old 02-25-2012, 01:59 PM   #53
Wildfire's Avatar
Posts: 86   (View Stats)
Wildfire has much to be proud ofWildfire has much to be proud ofWildfire has much to be proud ofWildfire has much to be proud ofWildfire has much to be proud ofWildfire has much to be proud ofWildfire has much to be proud ofWildfire has much to be proud ofWildfire has much to be proud of
I would love to start modding my 3. I have about 4k mi on the car. I think I will wait. I really don't want to deal with fighting the dealer. Yes, I know that they have to prove what was wrong, but for the most part, they like to say no first. There's a lot more to it than we think. Mod friendly dealers are the way to go, but if it weren't for bad luck, I'd have no luck at all. If ya'll lived my life, you wouldn't mod the car too.
When warranty is up, watch out world!
Wildfire is offline   Reply With Quote
 Old 03-01-2012, 12:32 AM   #54
2011speed's Avatar
Posts: 1,497   (View Stats)
2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world
Originally Posted by gitarpik View Post
Only thing i can think of that wouldnt be covered by warranty is anything consumable, break pads, tires and shit like that... What else would not be considered a warranty issue?
thats pretty much it, or if they can say its ur fault its somethings broken
2013 Velocity red Mazdaspeed 3 tech. BT
2011 Velocity red Mazdaspeed 3-SOLD.
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
How many miles on your CX-7? bscar CX-7 > General Lounge + New Member Welcome 71 02-20-2012 02:11 AM
Poor gas mileage from 260-280 miles on a tank down to 200-220 miles per tank? Matrix311 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 18 08-27-2011 07:59 PM
How Many Miles... NinjaT1985 2010 MS3 - Suspension & Brakes 5 07-28-2011 10:04 AM
40k miles atomicms3 Mazdaspeed3/6 General Discussion 7 02-01-2009 05:03 PM
Page generated in 0.36136 seconds with 32 queries
