  • 1 Post By Suzkuz
 Old 06-17-2019, 11:06 AM   #1
ABOSWORTH's Avatar
Posts: 467   (View Stats)
ABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the world
Default Annoying, clicking clutch 2012 Speed3
Not sure if anyone else has had this problem, but I've been plagued by an annoying popping/clicking sound when depressing the clutch for the past 3 years. I tried using lithium grease on the contacts and return spring on the clutch pedal a couple years ago to no avail. Today I decided enough was enough. I spent about an hour on my back fucking around under the dash and I found out what was causing it.
There is a plastic rod that goes that clips into the pedal and goes into the floor board which I assume goes into the master cylinder. I found that when I pressed the clutch almost to the floor, the clip on the rod was clicking against the pedal. I shoved a thin screw driver in the hole and it stopped. Anyway this is a total ghetto fix but I put a small screw I had in the hole and now it does not click anymore. Hard to explain but I have a couple pics. The prevents the plastic from popping around in the seating.
Figured I'd post in case anyone else has this annoying clicking clutch. There are no problems with the clutch and it is the original with 102k miles. Close up pic came out shitty but should help you see where the screw is located in the first pic.
2012 Speed3 - Velocity Red Mica
Current Mods
JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob
ABOSWORTH is offline   Reply With Quote
The Following 2 Users Say Thank You to ABOSWORTH For This Useful Post:
Db09ms3 (06-21-2019), MSMS3 (06-21-2019)
 Old 06-20-2019, 07:38 PM   #2
Suzkuz's Avatar
Posts: 10   (View Stats)
Suzkuz will become famous soon enough
Big props for posting a solution, most people would just fix something like this and then go about their day. Good stuff!!
ABOSWORTH likes this.
Suzkuz is offline   Reply With Quote
The Following User Says Thank You to Suzkuz For This Useful Post:
ABOSWORTH (10-08-2019)
 Old 10-08-2019, 03:53 AM   #3
Matrix33Speed3's Avatar
Posts: 6   (View Stats)
Matrix33Speed3 is an unknown quantity at this point
First off just wanted to say this forum has been very helpful. Ive found most of the answers to my questions on here so i havent really posted much but today i noticed my clutch was slightly creaking so i decided to put some white lithium grease on that plastic rod that goes into the firewall and it stopped the slight creak but now im getting this dam clicking sound you mentioned. It happens when i push the clutch in almost all the way down. It now clicks every time i engage the clutch to shift. I have a 2011 genpu and i dont even see a hole to put the screw in. It wasnt making any clicking noises before the lube job. Idk what else to do its so annoying to drive. Would replacing the clutch master cylinder fix it? It was fine before the lube job and there is no problem shifting or anything just 1 annoying click every time i hit the clutch even when the car is off... any help would be appreciated.
Matrix33Speed3 is offline   Reply With Quote
 Old 10-08-2019, 04:24 AM   #4
ABOSWORTH's Avatar
If it's the same issue as I was having (and it sounds like it is) replacing the master cylinder won't fix the clicking. You'd have to replace the pedal. It's not an obvious place to put a screw. You have to get right under and look almost where the top of the pedal touches the floor. Push it in slowly and look where my pic is and you should be able to hear and see the click where I stuck the screw.
Current Mods
 Old 10-08-2019, 02:03 PM   #5
Thanks for the reply. It doesnt seem like many ppl here have this problem.. just spent 30 mins down there lookin for a spot to put that screw but there isnt any on the 2011 model. I thought the clutch assembly would be identical. I pushed the clutch in and looked around for a spot to stick a screw in but its all solid no holes or gaps. Is it possible to put more grease on that plastic rod? Im afraid to try because thats how the clicking started... do you think grease down in there could mess things? Also i feel like the sound is more towards the end of that plastic rod and maybe not where it slides behind the pedal. This is driving me nuts i might have to take it to a mechanic. Crazy how almost everything on this car is a simple diy except for this stupid clutch clicking sound :/
 Old 10-08-2019, 03:54 PM   #6
ABOSWORTH's Avatar
If you can find it somewhere else, by all means, go for it. In my case, this is where it was coming from. There is no screw hole. There was a very small gap and I just stuck a screw in to keep the plastic from shifting. It took me forever to pinpoint where the noise was coming from. First I stuck a thin screwdriver in and depressed the clutch and the noise was gone so I put the screw in. Haven't heard a peep from it since. Are you having trouble figuring out where I put the screw because of the pictures? I know they aren't the greatest but it's hard to take good pics in that tight space.
Current Mods
 Old 10-08-2019, 05:47 PM   #7
I believe the gap you are referring to is right under the white tabs that locks the plastic rod into the clutch pedal/arm correct? I tried to put a screw there it still clicks. Actually took it to 2 local mechanics earlier and they both say its fine as long as it isnt having any problems going in and out of gears. I dont get why adding lube down there would make it click. The mechanic said theres no way lubing it would cause that click so idk.. do you know anyone on here that would have another solution? I might have to just live with the click at this point. Ugh a wise man once told me dont fix what aint broke.. shoulda listened. this is beyond frustrating especially in Cali traffic. Last resort is to take it to the dealer n hope to not get ass raped by their BS.
 Old 10-08-2019, 07:46 PM   #8
Was reading around through forums and came across a youtube vid that showed someone replacing the master cylinder and rod. Seems like an easy enough job just sucks theres barely any room down there. I might give it a try if this click continues and drives me nuts. Im pretty sure the click's from within the cylinder. I think its worth a try, and maybe upgrade to one with a metal rod instead of that cheap plastic one. What do you think?
 Old 10-15-2019, 07:02 AM   #9
ABOSWORTH's Avatar
Yeah I think that is the right spot. Mine was operating properly but drove my absolutely insane for like 2 years before I finally fixed it. I wish I could check your car out to see if it is the same sound that I have.
Current Mods
09 Speed3 - Annoying Vibration / Rumble maxam1001 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 16 06-02-2017 03:16 PM
Clutch clicking ukjimbow 2010 MS3 - Engine, Transmission & Driveline 9 04-08-2015 09:27 PM
Creak/clicking clutch release in reverse lk250f 2010 MS3 - Troubleshoot/Diagnostics 12 11-04-2013 08:38 AM
Clutch pedal clicking noise Cujo 2010 MS3 - Troubleshoot/Diagnostics 25 01-26-2013 08:32 AM
Clicking from clutch pedal IMASA MazdaSpeed 3 - Engine, Transmission & Driveline 3 09-05-2011 09:42 PM
Page generated in 0.30975 seconds with 22 queries
