 Old 11-08-2019, 01:26 PM   #1
Sonofnothing's Avatar
Posts: 32   (View Stats)
Sonofnothing is on a distinguished road
Default Any opinions on this noise?
I'm fully mounted by corksport and I definitely hear the gears spinning at idle, when the clutch is engaged. When I disengage it, the noise goes away. I've read that's normal for fully mounted cars.
However, this may or may not be linked. When I shut the car down, there's a noise that follows the same pattern. Thusly, I always disengage the clutch before turning the key off. Otherwise, you'll hear this sound.
https://youtu.be/V5kkInCvA6c
Sent from my Pixel 3 using Tapatalk
'13 ms3 * 72k * FREEKtuned * Accessport v3 * COBB SRI/TI * Autotech HPFP * ETS TMIC * CS fully mounted * CS short shift plate/bushings * Goodyear Eagle F1 Asymmetric 3 * dash designs suede * weather tech floor mats.
Sonofnothing is offline   Reply With Quote
 Old 11-08-2019, 01:48 PM   #2
ABOSWORTH's Avatar
Posts: 466   (View Stats)
ABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the world
I always depress the clutch pedal as well when I shut my car off because it sounds like a bag of smashed assholes if I don't. Yours sounds a bit different than mine but I've never tried held my ear up to the engine bay when shutting my car off. I'm always inside the car. My car also makes the funny noise when it's in neutral idling. Everything I've read says these noises are normal on these cars.
2012 Speed3 - Velocity Red Mica
Current Mods
JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob
ABOSWORTH is offline   Reply With Quote
The Following User Says Thank You to ABOSWORTH For This Useful Post:
Sonofnothing (11-08-2019)
Throttle noise/ engine noise under28world 2010 MS3 - Engine, Transmission & Driveline 9 05-04-2015 06:25 PM
bearing noise vs wheel noise? drag0nfire Mazdaspeed3/6 General Discussion 14 06-20-2012 07:32 PM
Need opinions on engine noise soaringeagle129 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 31 10-27-2011 03:47 AM
Lotus and Harman partner on noise-cancelling, noise-creating tech Haltech Automotive News 0 04-16-2009 05:00 PM
Need opinions on my AFR.... ONLYA6 MazdaSpeed 3/6 - ECU Computer Tuning 0 10-29-2008 08:23 AM
Page generated in 0.23412 seconds with 21 queries
