-   -   AP2 stage 1 93 hpfp? (http://www.mazdaspeedforums.org/forum/f544/ap2-stage-1-93-hpfp-154956/)
SoFloms3 09-11-2013 05:21 PM
What's up I recently installed cobb's stage 1 sf 93 tune and was wondering whats the max psi on stock fp? I hit 1788psi at wot in third gear and held psi over 1600. I bought the car used and don't know if the fp internals were upgraded. Sorry for the newb question. I did search and all I found was as long as your fp holds 1600 psi and over you should be good.
theurgy 09-11-2013 05:37 PM
As long as you don't go stage 2 or have a downpipe without HPFP upgrade you should technically be good to go.
SoFloms3 09-11-2013 06:18 PM
Thanks I know that once I get a downpipe or racepipe I need internals. I'm in the process of ordering them before zzb but just wanted some feedback.
lk250f 09-11-2013 06:26 PM
I was going to say to make sure to log again in the winter and monitor closely, but you're in FL so it shouldn't matter (Lucky!). It could be any day that the pump could start becoming ineffective so it is good you're ordering those. Good luck!
Page generated in 0.16014 seconds with 11 queries
