HEY HE KNOWS HIS SHIT!!! |
Shaving Methods Wet Shaving Wet shaving as described below refers to shaving done with a disposable razor or a safety razor. These rules also apply if you happen to be using a straight razor, but there are additional specifics to consider regarding straight razors (click here to read about straight razors). Throughout the wet shaving section, you'll find exceptions and tips noted for men who suffer from razor bumps and ingrown hairs. There is an additional section devoted to this topic as an addendum to the wet shaving section. If you suffer from razor bumps or ingrown hairs, be sure to read both sections, as the combination of proper wet shaving technique plus the use of special sensitive skin products and tips will often clear up the problem. Keep in mind that much of the advice for wet shaving does not apply to those using electric shavers; see the section on electric shavers for specific advice on that topic. Before you shave: waking up the skin When you first wake up in the morning, your skin tends to be puffy and swollen. If you shave in the mornings, wait until at least 20 minutes after you have woken up before you begin your shave to let the puffiness go down. When your skin has reached its normal tautness, the hairs will be closer to the surface and easier to shave. Pre-shave cleansing Some skin care experts recommend cleansing your face with a facial soap before shaving to help remove dead skin and excess dirt and oil, thus freeing up any ingrown hairs and preventing the clogging of your razor. If you do cleanse your face before shaving, don't wash with ordinary soap, as it will dry your skin. Use warm water and a facial soap or cleansing scrub designed for men's skin. If you have problems with ingrown hairs or razor bumps, and you may wish to use a pre-shave cleansing product specifically designed to prevent those problems (see the section on "Sensitive Skin" for more tips on avoiding razor bumps and ingrown hairs). Warm water prep Even if you choose to skip the pre-shave wash, be sure to use warm water to thoroughly wet your face before applying your shaving cream or gel. Massaging your face with warm water makes the skin more pliable and opens the pores, plus it helps soften your whiskers. Soft, wet whiskers tend to be easier to shave. You can easily accomplish this task by showering before you shave. Avoid using extremely hot water, as it might dry out your skin. Applying a warm, wet towel or washcloth to your face for a few minutes can also help soften your hair and open your pores. For men with very coarse whiskers, you may want to apply the hot towel a few times in succession to really loosen things up. If you're really intrigued, check out Hudson's Guide: All About Shaving |
Looks like we have a new sticky in the genpu section |
Subbed for shaving tips. |
I don't shave my face anymore. But the technique I use when doing my balls is to stretch the scrotum between my thumb and index finger to smooth out the wrinkles. And I use a Mach 3. And then vitamin E oil after the shower. I'll post pics if someone makes this NSFW. |
I dip my balls in warm water befor shaving them. Then pull the skin tight for best results. |
I like it when guys know their shit about little shit like this. Reminds me that there are some men left to help maintain some dignity in this faggy Twilight/Jersey Shore generation. And I'm only 23. I hate my generation. This is probably the most informative GenPu thread ever created, no? |
I just dry shave my balls using a disposable razor, then wrap the sack in a towel to absorb the 1/2 gallon of blood. soak in water...whatever. |
Re-subbed for ball shaving tips. Never tried it. Does it itch when theres stubbles? I wear boxer briefs. |
nowhere for the ballsweat to go, probably gotta use baby powder or something to decrease friction. |
Summary of topics this thread in a specific order: e-brake Trogodor the dragon Someone thinking his wife was in an avatar Race to change avatar to said wife Listerine Zero "come at me bro" references Tips on shaving Tips on shaving balls |
The sweat just collects at your taint and no the stubble doesn't make balls itch any more than they normally do. |
Baby powder ftw. I also just switch from boxers to boxer briefs. That helps, too. |
Thanks guys! Best forum ever! Almost done with my mods and learned how to shave my balls. |
Tip: shaving balls is simple yet complicated... must be cautious to not cut the sack... IT SUCKS specially on hot days and the sweat runs in the cut Second: Be sure to take your time and go slow, spread the sack as if your showing someone your batwings, helps get the hard spots, i also only do this in the shower. (cleans up real easy and it makes it an ease to get the batwing going) dont trim to close to the thigh and if you do, dont go down to far, it looks a little funny, normally i only "Shave" the sack and the shaft down the crack as far as i feel comfortable (this changes from time to time) The rest is normally just trimmed real low, using the same clippers as before. Last edging: i have found that girls like this... A FUCK TON, so if you have to buy new clippers get some that are good at cutting close without cutting you... bit must have as far as the Undies go: i wear under armour boxer briefs in the winter (helps keep the boys warm and prevents the sweaty balls problem by pushing the sweat out) And usually plain white boxer shorts in the summer, the under armour causes to much sweat ( we need good air circulation when its hot outside to limit the amount of sweaty balls/crack we have), The white boxer shorts are cheap as fuck so if they get nasty you can trash em and buy more (i usually only wear them 3-4 times before i trash) comments/opinions? EDIT: i never use powder, in case i meet a chick and want to fuck, that gives them yeast infections and the women tend to not come back for seconds or thirds after something like that. I know this from personal experience |
dude srsly. new subject: shaving yer woman's snatch: how-to |
Lawnmower. Next? |
*thinks to self: wish i had girl who let me shave her snatch* |
Sounds like a pesonal problem |
I have to do mine at the sink. I can barely see my wang with my glasses on, let alone blind in the shower. I've cut my junk worse with clippers than with the razor. Those teeth.... haha batwings. EDIT: whoops, didn't know we started talking about females. What are those? |
This thread has ADD |
"i trimmed/shaved that cunt you better let me have some of her!" |
hey I can't turn my ebrake off. I keep pushing down on it and nothing happened. Will that button on the end of it help at all? lolz |
shavin snatch is tricky also they get them random hairs just on the inside of the lips so you have to pull them open and shave gently down the lip.... kinda like your nut sack but its on a differant person so you have to be more cautious...... pretty much leads into messing around in the shower..... maybe even choking a little when your trying to eat that shit and the water runs down her back into your mouth...... i was coughing so hard my eyes started watering....:biggthumpup: |
I fucking love this forum. |
hey dustin brought it up to my attention. for all the non asians here, are your pubes curly? my pubic hair is straight like troll doll hair, im under the impression everyone is the same way? |
wow!... just read the whole 4 pages. man! 1. OP you're such a dumb ass! 2. Now I know how to shave my balls correctly 3. This is why I laugh at work, then my boss tells me to shut up.. lol |
http://bloximages.chicago2.vip.townn...ed63.image.jpg This is how I work teh balz. Just pinch, pull and away you go. |
Good thing this is not in the NSFW section. |
how'd we get back on shavin balls????? i thought we were talking about SNATCH |
| All times are GMT -7. The time now is 04:58 AM. |
