Like Tree59Likes
 Old 01-02-2012, 04:13 PM   #1
TylerC161's Avatar
Posts: 65   (View Stats)
TylerC161 is a glorious beacon of lightTylerC161 is a glorious beacon of lightTylerC161 is a glorious beacon of lightTylerC161 is a glorious beacon of lightTylerC161 is a glorious beacon of light
Groaned at 65 Times in 10 Posts
Neutral  0 score
Default Is it bad pushing the e-brake button when engaging?
I have a bad habit of trying to be quiet while engaging my e-brake due to my old car. When I engage the brake, I typically hold in the button and release once I've pulled it to the top. Is this bad at all on the brake system?
The reason I ask is because I think I've noticed a difference in the stiffness of the brake. It seems like I'm able to pull it much higher than I originally could. It still works fine to my knowledge (although I havent tried a super steep hill) but seems to pull up easier and goes higher.
Any information/input is appreciated. Thanks guys.
(USER RECEIVED A INFRACTION FOR THIS POST)
TylerC161 is offline   Reply With Quote
The Following 3 Users Say Thank You to TylerC161 For This Useful Post:
aaronc7 (01-17-2012), bmfms3 (01-04-2012), lovehumpin (01-04-2012)
The Following 30 Users Say NO Thank You to TylerC161 For This Un-useful Post:
09Speed3Z (01-05-2012), adlpb (01-03-2012), ASHMS3 (01-03-2012), bigriver (01-07-2012), BobbleHead (01-06-2012), bova (01-17-2012), Chimmike (01-04-2012), ChimmyChong (01-17-2012), doubleflusher (01-05-2012), Easter Bunny (01-03-2012), Eric28243 (02-16-2012), faeker (01-06-2012), Ferg (01-17-2012), gtlaw (01-04-2012), i8urgti (01-06-2012), jack_hammer (01-05-2012), jimmy (01-06-2012), jonspeed3 (01-03-2012), manelscout4life (01-02-2012), Mizzle (01-02-2012), MSFer87 (01-04-2012), mzr0818 (01-04-2012), Neverlift (01-02-2012), Onelovesoccer (01-09-2012), Raider (01-05-2012), Rich-PMS (01-02-2012), Rokusek (01-04-2012), Sid3wayS (01-04-2012), Teethkikr (01-03-2012), TWOptSL0W (01-05-2012)
 Old 01-02-2012, 04:18 PM   #2
jonspeed3's Avatar
Posts: 1,059   (View Stats)
jonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the worldjonspeed3 is the leader of the world
Groans: 58
Groaned at 134 Times in 68 Posts
Please buy an automatic.
kritz, davinspeed3 and lovehumpin like this.
US ARMY
07 True Red MS3 //Fully Bolted-Dizzy Tuned Wife drives the Speed now, I caught the gay, miata for me.
96 Red Miata // Not stock**
Missing home... Florida
jonspeed3 is offline   Reply With Quote
The Following 16 Users Say Thank You to jonspeed3 For This Useful Post:
ASHMS3 (01-05-2012), BeastMS3 (01-04-2012), BobbleHead (01-05-2012), Chimmike (01-04-2012), davinspeed3 (01-03-2012), doubleflusher (01-05-2012), Eric28243 (02-16-2012), JTMS3 (01-05-2012), lovehumpin (01-05-2012), mzr0818 (01-04-2012), NoTraction (06-24-2012), predapio (01-03-2012), Rokusek (01-04-2012), speedms6 (01-03-2012), topset (01-04-2012), Worbit (01-05-2012)
 Old 01-02-2012, 04:26 PM   #3
f-castrillo's Avatar
Posts: 1,342   (View Stats)
I'll be the good samaritan. The button simply disengages the lock on the brake handle. No harm comes to the brakes the way you use it
The ebrake handle pulling higher is because the cable that the handle is attached to is a little loose. There should be a screw or bolt you can tighten under the center console trim that will restore the shorter pull.
Sent from my ADR6400L using Tapatalk
The Following 8 Users Say Thank You to f-castrillo For This Useful Post:
Eric28243 (02-16-2012), JTMS3 (01-05-2012), MZR165 (01-05-2012), Post pwned (01-05-2012), rfinkle2 (01-02-2012), rghispanic88 (01-02-2012), silvapain (01-06-2012), TylerC161 (01-04-2012)
The Following User Says NO Thank You to f-castrillo For This Un-useful Post:
 Old 01-02-2012, 05:07 PM   #4
RIP: November 21, 2012
fortressofcomfort's Avatar
Posts: 862   (View Stats)
Originally Posted by f-castrillo
...No harm comes to the brakes the way you (are) use(ing) it
+1
2012 Black Mica MazdaSpeed3
Street creds:
The Following 4 Users Say Thank You to fortressofcomfort For This Useful Post:
Eric28243 (02-16-2012), f-castrillo (01-02-2012), MZR165 (01-05-2012), TylerC161 (01-04-2012)
 Old 01-02-2012, 09:09 PM   #5
backward_0's Avatar
Posts: 773   (View Stats)
backward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the world
wow
2013 WRX Stock as Fuck.
1997 Eclipse GSX
The Red Rocket, 2011 MS3 Some other bastards problem now.
backward_0 is offline   Reply With Quote
The Following User Says Thank You to backward_0 For This Useful Post:
The Following User Says NO Thank You to backward_0 For This Un-useful Post:
 Old 01-02-2012, 09:14 PM   #6
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
Groaned at 64 Times in 21 Posts
Well, if you hold the e-bake button, while hold down the lighter. Then you are in for big problems. Glad I solved your problem.
2010 Mazdaspeed 3 Black Mica w/ Tech Package - Traded In
2014 Ford F150 FX4 Ecoboost - Current
Dmurray06 is offline   Reply With Quote
The Following User Says Thank You to Dmurray06 For This Useful Post:
The Following 2 Users Say NO Thank You to Dmurray06 For This Un-useful Post:
Easter Bunny (01-03-2012), TylerC161 (01-04-2012)
 Old 01-02-2012, 09:20 PM   #7
bigriver's Avatar
Posts: 1,123   (View Stats)
Why did i read this?
The Following User Says Thank You to bigriver For This Useful Post:
The Following User Says NO Thank You to bigriver For This Un-useful Post:
 Old 01-02-2012, 09:24 PM   #8
Dmurray06's Avatar
Groans: 189
Because it makes you realize that there are people out there dumberer than you.
lovehumpin likes this.
The Following 8 Users Say Thank You to Dmurray06 For This Useful Post:
bmfms3 (01-04-2012), doubleflusher (01-05-2012), HLR Element (01-06-2012), Jhornbrook (01-10-2012), lovehumpin (01-04-2012), Macncheese (01-04-2012), mzr0818 (01-04-2012), Worbit (01-05-2012)
The Following User Says NO Thank You to Dmurray06 For This Un-useful Post:
 Old 01-02-2012, 09:33 PM   #9
Eric28243's Avatar
Posts: 554   (View Stats)
Eric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the world
Groaned at 6 Times in 6 Posts
Hard to tell trolls from tards these days.
'08 Polar White Saturn SKY Redline - "The RAWRmobile"
BorgWarner EFR 6758 + IWG Mani, forge v2 BPV, Energy Full Suspension Bushings, GMPP 3-Bars, Vibrant Racing Catted HiFlow Downpipe, WERKS Boost Tubes, Intake, Power-Steering Relocation Kit, Radiator Hoses, and Race FMIC, Koni Yellows + Eibach Pro-Kit's, RPi GT CBE, HP Tuner SquishyTooned on E40, RK Sport Rotors/Pads, DDMWorks 2-gauge Pillarpod and Armrest, Prosport HALO Electronic Wideband and Boost Gauges, Spec Stage 2+ Clutch + Fidanza Single-Mass FryWhee, XTUNERS Gauge Cluster, GM Roadster.com HID/LED Full Exterior and Interior Light Conversion
Dyno: Uhh... fast as hell?
'08.0 Cosmic Blue MS3 - "The Daily" STOCKED OUT (almost)
COBB SRI/TIP - COBB AP SquishyTooned on E40 - COBB XLE BPV - HKS Hi-Power CBE - ITV22s - Corksport RMM Inserts - JBR Shifter Bushings and SSP - PTP Fuel Pump - PG + Treadstone - 35% Tint - ebaY Double-Penetrator - MS3 Vent Kit Install
Dyno: 319 / 331
CWP_MS3 is my mackdaddy
Eric28243 is offline   Reply With Quote
The Following 16 Users Say Thank You to Eric28243 For This Useful Post:
ASHMS3 (01-03-2012), bmfms3 (01-04-2012), BobbleHead (01-05-2012), darkcherry (01-03-2012), davinspeed3 (01-03-2012), doubleflusher (01-05-2012), lovehumpin (01-04-2012), Macncheese (01-04-2012), mzr0818 (01-04-2012), Raider (01-03-2012), silvapain (01-06-2012), Teethkikr (01-03-2012), tweak120 (01-05-2012), WAHBAM (01-04-2012), wolly6973 (01-04-2012), Worbit (01-05-2012)
The Following User Says NO Thank You to Eric28243 For This Un-useful Post:
 Old 01-02-2012, 09:35 PM   #10
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Well atleast its not in the section for the genp...........
Ahhh Damn it.
TEAM LUXURY
Last edited by Sid3wayS; 01-02-2012 at 09:35 PM. Reason: MSF Database - Automerged Doublepost
Sid3wayS is offline   Reply With Quote
The Following 34 Users Say Thank You to Sid3wayS For This Useful Post:
Abu Zib (01-02-2012), ASHMS3 (01-03-2012), bmfms3 (01-04-2012), BobbleHead (01-05-2012), Ferg (01-17-2012), i8urgti (01-06-2012), J'sSpeed3 (01-04-2012), JTMS3 (01-05-2012), Kamaril (01-04-2012), lovehumpin (01-04-2012), Macncheese (01-04-2012), mazdafreak (01-02-2012), mdl3v8 (01-02-2012), mzr0818 (01-04-2012), Neverlift (01-02-2012), Nliiitend1 (01-05-2012), NoTraction (06-24-2012), predapio (01-03-2012), Raider (01-03-2012), rfinkle2 (01-04-2012), RhoadBlock (01-03-2012), Rokusek (01-04-2012), ScarMS3 (01-03-2012), sick_role (01-06-2012), silvapain (01-06-2012), SleeperHatch (01-03-2012), Teethkikr (01-04-2012), tweak120 (01-05-2012), Vader (01-03-2012), WAHBAM (01-04-2012), WhoIsJeremy (01-05-2012), wolly6973 (01-04-2012), Worbit (01-05-2012), zpele (01-02-2012)
The Following User Says NO Thank You to Sid3wayS For This Un-useful Post:
 Old 01-02-2012, 10:01 PM   #11
captain slow's Avatar
Posts: 5,559   (View Stats)
captain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the world
Groans: 398
Groaned at 50 Times in 34 Posts
Wow. Any other questions mr. mensa?
Sent from my DROIDX using Tapatalk
2007 MS3 Silver. Intake bits, exhaust bits, FMIC bits, freektuned, loved, cherrished, SOLD!!!
2014 5.0 Gotta Have It Green w/Track Pack
captain slow is offline   Reply With Quote
The Following User Says Thank You to captain slow For This Useful Post:
The Following User Says NO Thank You to captain slow For This Un-useful Post:
 Old 01-02-2012, 11:07 PM   #12
zpele's Avatar
Posts: 1,654   (View Stats)
zpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the worldzpele is the leader of the world
Groans: 354
Groaned at 213 Times in 109 Posts
Ahhh Damn it.
Made me lol and my gf doesn't understand why....
2012 Shelby GT500 - Roush Axleback ~ JLT Oil Separator ~ JLT 123mm intake ~ Ngauge ~ Lund Tuned ~ smaller pulley ~ xpipe (loud as fuck now)
2007 Mazdaspeed6 (SOLD) - COBB SRI ~ Gutted Stock Midpipe ~ HKS BPV ~ JBR RMM ~ AWR PMM ~ AWR TMM ~ Juggernaught Rear Diff Mount ~ Dreadnaught Rear Diff Mount ~ ACT Stage 2 Clutch ~ ITV22s ~ AP(self fucking tuned in a week fuckers) ~ Autotech Internals ~ eBay Downpipe ~ Poke Sub thingy
zpele is offline   Reply With Quote
The Following 7 Users Say Thank You to zpele For This Useful Post:
ASHMS3 (01-03-2012), Ferg (01-17-2012), mzr0818 (01-04-2012), Sid3wayS (01-02-2012), SleeperHatch (01-03-2012), Teethkikr (01-04-2012), Worbit (01-05-2012)
The Following User Says NO Thank You to zpele For This Un-useful Post:
 Old 01-03-2012, 12:56 AM   #13
Vinnie's Avatar
Posts: 714   (View Stats)
Vinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the world
Groans: 76
yeah i'm sick of my loud e-brake too... i dont even use it anymore i just leave the car in gear. I also plugged my exhaust pipe cuz that was making far too much noise. and i rarely turn the car on in the first place, without earplugs in.
'12 speed 3 CWP w/tech: DIZZY Tuned by Phate!,cobb AP,Autotech internals, cp-e nano, cp-e TIP, JBR 88 dogbone, JBR SSP/bushings, JBR rear sway bar, UR test pipe
RIP '08 speed 3 silver cp-e 75 duro RMM, cp-e intake, cp-e TIP, Jbarone SSP and bushings.
Vinnie is offline   Reply With Quote
The Following 2 Users Say Thank You to Vinnie For This Useful Post:
Kamaril (01-04-2012), Raider (01-03-2012)
The Following User Says NO Thank You to Vinnie For This Un-useful Post:
 Old 01-03-2012, 01:07 AM   #14
ArcticSpeed3's Avatar
Posts: 543   (View Stats)
ArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the worldArcticSpeed3 is the leader of the world
Damnit....another genpu owner strikes again!
2006 MS6 BCM
"Fully Bolted, DSS Rear Axles, Soon GTX3076R, SB Stg 3 Drag Clutch, 6th Port" (DRAG CAR)
2009 Chevy TBSS AWD 3SS
"Full Exhaust, Intake, Tune" (MAN VAN)
1997 Lexus SC300 Black/Black
"2JZGTE, BW S366 @15psi" (SOLD)
2011 MS3 CBM
"Fully Bolted" (Parted Out and Sold)
ArcticSpeed3 is offline   Reply With Quote
The Following 8 Users Say Thank You to ArcticSpeed3 For This Useful Post:
bmfms3 (01-04-2012), BobbleHead (01-05-2012), Chimmike (01-04-2012), doubleflusher (01-05-2012), Macncheese (01-04-2012), mzr0818 (01-04-2012), Rokusek (01-04-2012), Worbit (01-05-2012)
The Following User Says NO Thank You to ArcticSpeed3 For This Un-useful Post:
 Old 01-03-2012, 02:01 AM   #15
GODspeed7's Avatar
Posts: 3,456   (View Stats)
You know it's posts like this that make genpu mothers eat their young. FFS why did I buy a genpu?!?! Now I am automatically a fucking retard by association. OP just pull as hard as you can on your e-brake handle until it comes off, then forcefully shove it up your own ass!
Kamaril, Jhornbrook and lovehumpin like this.
2012 Mazdaspeed3 Black Mica
The Following 11 Users Say Thank You to GODspeed7 For This Useful Post:
BobbleHead (01-05-2012), doubleflusher (01-05-2012), f-castrillo (01-03-2012), Jhornbrook (01-10-2012), Kamaril (01-04-2012), kunfu (01-04-2012), lovehumpin (01-05-2012), Macncheese (01-04-2012), mzr0818 (01-04-2012), Raider (01-03-2012), Worbit (01-05-2012)
The Following User Says NO Thank You to GODspeed7 For This Un-useful Post:
 Old 01-03-2012, 02:59 AM   #16
surebOOst's Avatar
Posts: 1,795   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groaned at 61 Times in 40 Posts
Y buy a speed it u dont even know the answer to this question. Trade for a civic and start in gaymans land...
surebOOst is offline   Reply With Quote
The Following User Says NO Thank You to surebOOst For This Un-useful Post:
 Old 01-03-2012, 03:23 AM   #17
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Lolol.
Case in point....Lolol
What a lovable bunch we are!!
The Following User Says Thank You to predapio For This Useful Post:
xfeejayx (01-04-2012)
The Following User Says NO Thank You to predapio For This Un-useful Post:
 Old 01-03-2012, 06:03 AM   #18
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
just when i thought the questions couldn't get any more dumb. at least it's not another oil thread.
Tadweezy likes this.
The Following User Says NO Thank You to bova For This Un-useful Post:
 Old 01-03-2012, 09:52 AM   #19
lovehumpin's Avatar
Posts: 145   (View Stats)
lovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond repute
I'm fucking offended.
2012 CWP MS3 w/ Tech package, 18x7.5 Enkei RPF-1, H&R springs, Corkport SRI w/ TIP, Ultimate racing CBE. SOLD
2014 Ice Silver STI, Cobb AP stage one, Cobb intake and CBE.
LETS GO CAPS!
lovehumpin is offline   Reply With Quote
The Following User Says NO Thank You to lovehumpin For This Un-useful Post:
 Old 01-03-2012, 08:19 PM   #20
got.zoomzoom's Avatar
Posts: 47   (View Stats)
got.zoomzoom has much to be proud ofgot.zoomzoom has much to be proud ofgot.zoomzoom has much to be proud ofgot.zoomzoom has much to be proud ofgot.zoomzoom has much to be proud ofgot.zoomzoom has much to be proud ofgot.zoomzoom has much to be proud ofgot.zoomzoom has much to be proud ofgot.zoomzoom has much to be proud of
Default Clicking Noise
I dont mean to hi-jack this thread but since you all are talking about e-brakes. When I lift up on mine to engage it, it makes a clicking noise. I have taken it to the dealer three times and they havent found the cause. Since I own a gen2(pu) I thought it might be related to the OPs issue. Any ideas?
I have Zoom Zoom and know how to use it.
got.zoomzoom is offline   Reply With Quote
The Following 3 Users Say Thank You to got.zoomzoom For This Useful Post:
ASHMS3 (01-04-2012), BobbleHead (01-05-2012), CJM (01-08-2012)
 Old 01-03-2012, 08:28 PM   #21
jonspeed3's Avatar
Groans: 58
Mazda please kill the ms3, I can't fathom how fucking stupid the gen3 fags will be. Make the value of Gen 1 go up.
Fuck pu's..
US ARMY
 Old 01-03-2012, 08:35 PM   #22
speeed's Avatar
Posts: 2,999   (View Stats)
speeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the world
Groaned at 50 Times in 17 Posts
The problem when you leave the car in gear would be if somebody crash your car will damage the tranny.... that's why is better to leave on neutral with e-brake...
Scoobs likes this.
2012 LSM MS3
Some mods, No list, too much "zapos".
speeed is offline   Reply With Quote
 Old 01-03-2012, 08:35 PM   #23
vrspeed10's Avatar
Posts: 1,035   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
I try not to be to much of a dick sometimes but this is just to much of a fail to explain.
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 BT and getting my DRANK on!!!
vrspeed10 is offline   Reply With Quote
 Old 01-04-2012, 01:27 AM   #24
TylerC161's Avatar
Neutral  -2 score
Fucking Christ, were 90% of you here born out the back of a hatch or what? Excuuuuuuuse me for asking what I THOUGHT was a harmless question seeing as I've only put 5000 miles on the car. I've owned 4 cars and NEVER had to tighten a single one, so why would a new car need it done? My bad habit from my old cars terribly obnoxious ebrake was my only possible explanation.
You all talk so much shit how the questions 'never cease to amaze you'; well how do you think people like myself feel about answers like yours? Fuck, the question was answered kindly and simply in several posts. Instead, ya'll actually seem to care to go out of your way to talk down on someone. Its fucking weak and it REALLY makes this site shit. Way to contribute to the community.
Carry on the flame war, I got what I needed and have no reason to come back to visit anyones replies.
The Following 13 Users Say NO Thank You to TylerC161 For This Un-useful Post:
adlpb (01-04-2012), BobbleHead (01-05-2012), bova (01-17-2012), Chimmike (01-04-2012), doubleflusher (01-05-2012), Easter Bunny (01-04-2012), Eric28243 (02-17-2012), faeker (01-06-2012), mzr0818 (01-04-2012), p057 (01-04-2012), predapio (01-04-2012), Sid3wayS (01-04-2012), zpele (01-04-2012)
 Old 01-04-2012, 05:47 AM   #25
ASHMS3's Avatar
Posts: 1,362   (View Stats)
ASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the world
Groans: 126
LOL....bye.
'09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE
ASHMS3 is offline   Reply With Quote
The Following 7 Users Say Thank You to ASHMS3 For This Useful Post:
BobbleHead (01-05-2012), Eric28243 (02-17-2012), mzr0818 (01-04-2012), predapio (01-04-2012), Teethkikr (01-04-2012), Worbit (01-05-2012), zpele (01-04-2012)
 Old 01-04-2012, 05:47 AM   #26
Posts: 7,290   (View Stats)
Mods,Please close this thread!
Nator is what it does.
 Old 01-04-2012, 07:05 AM   #27
GODspeed7's Avatar
Dude, grow a set. You asked a question that can be answered by anyone that has driven a manual car and you just stated this is your 4th so don't act dumb. Let's start with the obvious...
1. You havent donated. So in my opinion you shouldn't have any right to make a new thread except for a new member welcome.
2. If you are driving a car and don't know the simple operation of a ratchet system you should probably look into that.
3. To answer your question so we don't find you hanging by your belt from your shower rod due to lack of answers, no. You aren't hurting anything by pushing or not pushing the button while applying the e-brake. It's a ratchet system only and the click is just to ensure it is fully engaged on the next notch. Pushing the button only releases the catch mechanism so it doesn't get hung up on any of the notches when releasing the brake.
4. Please grow a set and act like a man. This is the Internet machine. Not preschool.
The Following 4 Users Say Thank You to GODspeed7 For This Useful Post:
speeed (01-04-2012), Teethkikr (01-04-2012), Vader (01-04-2012), Worbit (01-05-2012)
 Old 01-04-2012, 07:19 AM   #28
lovehumpin's Avatar
You're a fag
LETS GO CAPS!
The Following 4 Users Say Thank You to lovehumpin For This Useful Post:
ASHMS3 (01-04-2012), BobbleHead (01-05-2012), Chimmike (01-04-2012), Eric28243 (02-17-2012)
 Old 01-04-2012, 07:21 AM   #29
bigriver's Avatar
In b4 closed thread.
OP - read the owners manual, ask your dealer or use the Mazda roadside assistance app.
Btw - i like this site and all the bashing of dumb questions. I've been on other sites where stupid questions have to be tolerated because of the site sponsors and pussy mods.
kritz and lovehumpin like this.
 Old 01-04-2012, 07:24 AM   #30
Got Troll?
 Old 01-04-2012, 07:34 AM   #31
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
This is not spam as reported, but it is GenPu.
OP, read the FAQ, do some searching, and most importantly, you will need a little thicker skin to survive here if you post this kind of stuff.
Fail thread is fail.
kritz likes this.
The Following 8 Users Say Thank You to Raider For This Useful Post:
ASHMS3 (01-04-2012), bmfms3 (01-04-2012), GLORIFIEDBOZO (01-17-2012), predapio (01-04-2012), silvapain (01-06-2012), SLOWHATCH (01-04-2012), Teethkikr (01-04-2012), Worbit (01-05-2012)
 Old 01-04-2012, 07:41 AM   #32
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I would have left this open for the continued genPOO comedy.
I nominate this for the first official dumb thread of 2012
Rokusek, lovehumpin and Tadweezy like this.
07 MS3
The original Genpoo Hater
The Following 4 Users Say Thank You to Chimmike For This Useful Post:
ASHMS3 (01-04-2012), BobbleHead (01-05-2012), Rokusek (01-05-2012), Worbit (01-05-2012)
 Old 01-04-2012, 07:43 AM   #33
Raider's Avatar
Groans: 856
Yeah, I could use a laugh. Reopened.
Chimmike and lovehumpin like this.
The Following 15 Users Say Thank You to Raider For This Useful Post:
ASHMS3 (01-05-2012), BobbleHead (01-05-2012), Cataphract_40 (01-04-2012), Chimmike (01-04-2012), lovehumpin (01-04-2012), Macedawg (01-04-2012), mzr0818 (01-04-2012), predapio (01-04-2012), rfinkle2 (01-04-2012), RhoadBlock (01-04-2012), silvapain (01-06-2012), SLOWHATCH (01-04-2012), Stwok240 (01-05-2012), Teethkikr (01-04-2012), Worbit (01-05-2012)
 Old 01-04-2012, 07:50 AM   #34
lovehumpin's Avatar
You sir, are the greatest mod to ever live. Thank you for this <3
LETS GO CAPS!
The Following 3 Users Say Thank You to lovehumpin For This Useful Post:
mzr0818 (01-04-2012), SLOWHATCH (01-04-2012), Worbit (01-05-2012)
 Old 01-04-2012, 07:52 AM   #35
Domino81's Avatar
Posts: 5,081   (View Stats)
I thought that was the NOS button?
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 01-04-2012, 07:57 AM   #36
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Optimistic nomination considering this is only 1/4/2012.
kritz likes this.
 Old 01-04-2012, 07:59 AM   #37
Crarrs's Avatar
Posts: 1,662   (View Stats)
Groans: 98
Thanks for stopping by. And thank you for your contributions to the community as well.
2004 MSM TiGrey
The Following User Says Thank You to Crarrs For This Useful Post:
 Old 01-04-2012, 08:02 AM   #38
Rokusek's Avatar
Posts: 5,551   (View Stats)
TROGDOR STRIKES AGAIN!!!
The Following 3 Users Say Thank You to Rokusek For This Useful Post:
lovehumpin (01-04-2012), RhoadBlock (01-04-2012), taf0422 (01-17-2012)
 Old 01-04-2012, 08:02 AM   #39
Will fuck up ur day
Chimmike's Avatar
Groans: 433
That may be so, but sometimes the first impression is the best.
07 MS3
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
kritz (01-04-2012), mzr0818 (01-04-2012), rfinkle2 (01-04-2012)
 Old 01-04-2012, 08:06 AM   #40
This thread is making my eyes hemorrhage!
The Following 2 Users Say Thank You to kritz For This Useful Post:
daafisch (01-04-2012), mzr0818 (01-04-2012)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f544/bad-pushing-e-brake-button-when-engaging-101116/
MSF: the new 24/7 | SpeedForums.org This thread Refback 01-05-2012 11:17 AM
No sound when engaging turn signals or blinkers? Jym CX-7 > Issues & Troubleshooting 19 08-31-2011 02:37 PM
Hawk HPS brake pads & Goodridge brake lines in stock for the 07-11 MS3. Chris@Xtreme Mazdaspeed3/6 General Discussion 3 08-06-2011 08:56 PM
clunk when engaging reverse SB.MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 06-04-2011 05:39 PM
REPORT: Bored Bulgarians engaging in Russian Road Roulette Haltech Automotive News 0 11-02-2009 05:00 PM
Hawk Pads, Racing Brake Lines, and ATE Brake Fluid! Race Roots Mazdaspeed3/6 General Discussion 11 09-25-2009 02:04 PM
Page generated in 0.62383 seconds with 48 queries
