Like Tree59Likes
 Old 01-05-2012, 09:32 AM   #121
GODspeed7's Avatar
Posts: 3,456   (View Stats)
the cologne is what's fucking your skin up man. Put cologne on the back of your neck, not teh front.
No man the damage is already done before the cologne is put on. And besides everyone knows that you apply cologne to pulse points on the body because it makes a little go a long way because it radiates. Front of the neck over the arteries, on the wrists, and on the chest over the heart.
Rokusek and lovehumpin like this.
Rokusek (01-05-2012)
 Old 01-05-2012, 09:39 AM   #122
Rokusek's Avatar
Posts: 5,551   (View Stats)
i see you know your shit...
HEY HE KNOWS HIS SHIT!!!
The Following 3 Users Say Thank You to Rokusek For This Useful Post:
Chimmike (01-05-2012), Ferg (01-17-2012), mzr0818 (01-05-2012)
 Old 01-05-2012, 09:41 AM   #123
lovehumpin's Avatar
Posts: 145   (View Stats)
lovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond reputelovehumpin has a reputation beyond repute
This man is on top of his cologne game. Do oyu rise face off with hot water before you shave? it seems to work for me. Here are some handy tips I found! Please make note of Warm-water prep.
Shaving Methods
Wet Shaving
Wet shaving as described below refers to shaving done with a disposable razor or a safety razor. These rules also apply if you happen to be using a straight razor, but there are additional specifics to consider regarding straight razors (click here to read about straight razors).
Throughout the wet shaving section, you'll find exceptions and tips noted for men who suffer from razor bumps and ingrown hairs. There is an additional section devoted to this topic as an addendum to the wet shaving section. If you suffer from razor bumps or ingrown hairs, be sure to read both sections, as the combination of proper wet shaving technique plus the use of special sensitive skin products and tips will often clear up the problem.
Keep in mind that much of the advice for wet shaving does not apply to those using electric shavers; see the section on electric shavers for specific advice on that topic.
Before you shave: waking up the skin
When you first wake up in the morning, your skin tends to be puffy and swollen. If you shave in the mornings, wait until at least 20 minutes after you have woken up before you begin your shave to let the puffiness go down. When your skin has reached its normal tautness, the hairs will be closer to the surface and easier to shave.
Pre-shave cleansing
Some skin care experts recommend cleansing your face with a facial soap before shaving to help remove dead skin and excess dirt and oil, thus freeing up any ingrown hairs and preventing the clogging of your razor. If you do cleanse your face before shaving, don't wash with ordinary soap, as it will dry your skin. Use warm water and a facial soap or cleansing scrub designed for men's skin.
If you have problems with ingrown hairs or razor bumps, and you may wish to use a pre-shave cleansing product specifically designed to prevent those problems (see the section on "Sensitive Skin" for more tips on avoiding razor bumps and ingrown hairs).
Warm water prep
Even if you choose to skip the pre-shave wash, be sure to use warm water to thoroughly wet your face before applying your shaving cream or gel. Massaging your face with warm water makes the skin more pliable and opens the pores, plus it helps soften your whiskers. Soft, wet whiskers tend to be easier to shave.
You can easily accomplish this task by showering before you shave. Avoid using extremely hot water, as it might dry out your skin.
Applying a warm, wet towel or washcloth to your face for a few minutes can also help soften your hair and open your pores. For men with very coarse whiskers, you may want to apply the hot towel a few times in succession to really loosen things up.
If you're really intrigued, check out Hudson's Guide: All About Shaving
2012 CWP MS3 w/ Tech package, 18x7.5 Enkei RPF-1, H&R springs, Corkport SRI w/ TIP, Ultimate racing CBE. SOLD
2014 Ice Silver STI, Cobb AP stage one, Cobb intake and CBE.
LETS GO CAPS!
lovehumpin is offline   Reply With Quote
 Old 01-05-2012, 09:42 AM   #124
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
Looks like we have a new sticky in the genpu section
lovehumpin likes this.
 Old 01-05-2012, 09:51 AM   #125
bigriver's Avatar
Posts: 1,123   (View Stats)
Subbed for shaving tips.
Rokusek, BobbleHead and lovehumpin like this.
The Following 2 Users Say Thank You to bigriver For This Useful Post:
lovehumpin (01-05-2012), Rokusek (01-05-2012)
 Old 01-05-2012, 10:17 AM   #126
wankular's Avatar
Posts: 4,343   (View Stats)
I don't shave my face anymore.
But the technique I use when doing my balls is to stretch the scrotum between my thumb and index finger to smooth out the wrinkles. And I use a Mach 3. And then vitamin E oil after the shower. I'll post pics if someone makes this NSFW.
2009 MS3 sport MGM
 Old 01-05-2012, 10:44 AM   #127
mzr0818's Avatar
mzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the world
Groans: 221
I dip my balls in warm water befor shaving them. Then pull the skin tight for best results.
I was ok until 4500 rpm and then Jeff Raped my face
EMWNM 2013
Beating Black women one 5.0 at a time...
2008 mazdaspeed 3 true red
Tuned by Nishan
, 33% E85, GTX3067r Boost?, Yeah I got some., Port and polish manifold, XS power Tubular Exhaust Manifold, Wiesco pistons, K1 rods, L19 head studs, ARP crank studs, Cobb three port EBCS, Forge BPV, CXRacing FMIC with TR8 core, cobb AP V2, EBC redstuff full, DBA 4000 rotors 6x6 slotted, HTP 3" full intake, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, Moog lower control arms, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.
Build in progress. Track whore in the making.
mzr0818 is offline   Reply With Quote
 Old 01-05-2012, 11:09 AM   #128
RhoadBlock's Avatar
Posts: 793   (View Stats)
RhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the worldRhoadBlock is the leader of the world
Groaned at 7 Times in 4 Posts
I like it when guys know their shit about little shit like this. Reminds me that there are some men left to help maintain some dignity in this faggy Twilight/Jersey Shore generation. And I'm only 23. I hate my generation.
This is probably the most informative GenPu thread ever created, no?
2007 MS6 - broked & gone
2006 MS6 - less broked
rhoadblock- the ms6 that will never run again
RhoadBlock is offline   Reply With Quote
The Following User Says Thank You to RhoadBlock For This Useful Post:
Ferg (01-17-2012)
 Old 01-05-2012, 11:11 AM   #129
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
I just dry shave my balls using a disposable razor, then wrap the sack in a towel to absorb the 1/2 gallon of blood. soak in water...whatever.
The Following 2 Users Say Thank You to Raider For This Useful Post:
ASHMS3 (01-05-2012), Teethkikr (01-06-2012)
 Old 01-05-2012, 11:20 AM   #130
bigriver's Avatar
Re-subbed for ball shaving tips.
Never tried it. Does it itch when theres stubbles? I wear boxer briefs.
 Old 01-05-2012, 11:22 AM   #131
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
nowhere for the ballsweat to go, probably gotta use baby powder or something to decrease friction.
07 MS3
The original Genpoo Hater
bigriver (01-05-2012)
 Old 01-05-2012, 11:26 AM   #132
adlpb's Avatar
Groans: 669
Summary of topics this thread in a specific order:
e-brake
Trogodor the dragon
Someone thinking his wife was in an avatar
Race to change avatar to said wife
Listerine Zero
"come at me bro" references
Tips on shaving
Tips on shaving balls
The Following 12 Users Say Thank You to adlpb For This Useful Post:
ASHMS3 (01-05-2012), BobbleHead (01-06-2012), Cataphract_40 (01-05-2012), Crarrs (01-05-2012), Ferg (01-17-2012), mzr0818 (01-05-2012), Onelovesoccer (01-09-2012), Raider (01-05-2012), Sid3wayS (01-05-2012), Teethkikr (01-06-2012), Vader (01-06-2012), wankular (01-05-2012)
 Old 01-05-2012, 11:27 AM   #133
wankular's Avatar
The sweat just collects at your taint and no the stubble doesn't make balls itch any more than they normally do.
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
 Old 01-05-2012, 11:29 AM   #134
lovehumpin's Avatar
Gold Bond FTMFW
LETS GO CAPS!
The Following 3 Users Say Thank You to lovehumpin For This Useful Post:
ASHMS3 (01-05-2012), bigriver (01-05-2012), Chimmike (01-05-2012)
 Old 01-05-2012, 11:44 AM   #135
Domino81's Avatar
Posts: 5,081   (View Stats)
Baby powder ftw. I also just switch from boxers to boxer briefs. That helps, too.
2008 CosmicBlue Mazdaspeed3
294whp/335wtq - Stock K04
370whp/370wtq - BNR stage 3
 Old 01-05-2012, 11:54 AM   #136
bigriver's Avatar
Thanks guys! Best forum ever! Almost done with my mods and learned how to shave my balls.
Domino81 (01-05-2012), wankular (01-05-2012)
 Old 01-05-2012, 01:06 PM   #137
Rokusek's Avatar
e-brake
Trogodor "The Burninator"
Listerine Zero
Tips on shaving
Fixed
First, trim with clippers that have a guard on them, preferably not the same clippers you would use anywhere else on your body.
Tip: shaving balls is simple yet complicated... must be cautious to not cut the sack... IT SUCKS specially on hot days and the sweat runs in the cut
Second: Be sure to take your time and go slow, spread the sack as if your showing someone your batwings, helps get the hard spots, i also only do this in the shower. (cleans up real easy and it makes it an ease to get the batwing going)
dont trim to close to the thigh and if you do, dont go down to far, it looks a little funny, normally i only "Shave" the sack and the shaft down the crack as far as i feel comfortable (this changes from time to time) The rest is normally just trimmed real low, using the same clippers as before.
Last edging: i have found that girls like this... A FUCK TON, so if you have to buy new clippers get some that are good at cutting close without cutting you... bit must have
as far as the Undies go:
i wear under armour boxer briefs in the winter (helps keep the boys warm and prevents the sweaty balls problem by pushing the sweat out)
And usually plain white boxer shorts in the summer, the under armour causes to much sweat ( we need good air circulation when its hot outside to limit the amount of sweaty balls/crack we have), The white boxer shorts are cheap as fuck so if they get nasty you can trash em and buy more (i usually only wear them 3-4 times before i trash)
comments/opinions?
EDIT: i never use powder, in case i meet a chick and want to fuck, that gives them yeast infections and the women tend to not come back for seconds or thirds after something like that. I know this from personal experience
The Following 4 Users Say Thank You to Rokusek For This Useful Post:
adlpb (01-05-2012), Downmented (01-17-2012), Ferg (01-17-2012), wankular (01-05-2012)
 Old 01-05-2012, 01:10 PM   #138
Domino81's Avatar
Only if I go down to bare skin. I use my trimmer to take it down to about a quarter of an inch. I have to pull my sack and my dick in such a way to avoid cuttin' em with the trimmer. It's a touchy process, but can be done easily with technique.
 Old 01-05-2012, 01:10 PM   #139
Will fuck up ur day
Chimmike's Avatar
Groans: 433
dude srsly. new subject: shaving yer woman's snatch: how-to
07 MS3
adlpb (01-05-2012)
 Old 01-05-2012, 01:13 PM   #140
Domino81's Avatar
Lawnmower.
Next?
 Old 01-05-2012, 01:13 PM   #141
Rokusek's Avatar
damn, never had that opportunity they all get waxed...
*thinks to self: wish i had girl who let me shave her snatch*
 Old 01-05-2012, 01:13 PM   #142
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Lawnmower.
Next?
Sounds like a pesonal problem
07 MS3
 Old 01-05-2012, 01:15 PM   #143
adlpb's Avatar
Groans: 669
I just did last weekend. Not too complicated if you asked me. Used my electric razor and then a 2nd hand with the razor they use to shave their legs. But I'd say waxing yields better results.
 Old 01-05-2012, 01:17 PM   #144
wankular's Avatar
I have to do mine at the sink. I can barely see my wang with my glasses on, let alone blind in the shower. I've cut my junk worse with clippers than with the razor. Those teeth....
haha batwings.
EDIT: whoops, didn't know we started talking about females. What are those?
2009 MS3 sport MGM
 Old 01-05-2012, 01:21 PM   #145
adlpb's Avatar
Groans: 669
This thread has ADD
The Following 2 Users Say Thank You to adlpb For This Useful Post:
lovehumpin (01-06-2012), mzr0818 (01-06-2012)
 Old 01-05-2012, 01:21 PM   #146
Rokusek's Avatar
i concur, still wouldnt mind shavin the snatch... so i can be like...
"i trimmed/shaved that cunt you better let me have some of her!"
 Old 01-05-2012, 01:23 PM   #147
BobbleHead's Avatar
Posts: 2,237   (View Stats)
BobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the world
Groans: 186
Groaned at 33 Times in 25 Posts
hey I can't turn my ebrake off. I keep pushing down on it and nothing happened. Will that button on the end of it help at all?
lolz
2012 BM MS3 w/ tech. Cobb AP V2b: Autotech CDFP internals: JBR 88d RMM: SURE 3" Aeros full intake: Ebay test pipe: Corksport TMIC: Turbosmart BPV: Bridgestone Potenza 235/40 tires: self tuned
BobbleHead is offline   Reply With Quote
 Old 01-05-2012, 01:24 PM   #148
adlpb's Avatar
Groans: 669
lolz
You're late for the party. We're talking about shaving balls and vaginas.
 Old 01-05-2012, 01:24 PM   #149
Rokusek's Avatar
lolz
thats your boost button brah!
 Old 01-05-2012, 01:25 PM   #150
Will fuck up ur day
Chimmike's Avatar
Groans: 433
haha batwings.
LMFAO @ blind @wankular trying to shave his junk
07 MS3
The Following 2 Users Say Thank You to Chimmike For This Useful Post:
adlpb (01-05-2012), wankular (01-05-2012)
 Old 01-05-2012, 01:26 PM   #151
Rokusek's Avatar
ASHMS3 (01-05-2012)
 Old 01-05-2012, 01:37 PM   #152
mikesms3's Avatar
Posts: 342   (View Stats)
mikesms3 is the leader of the worldmikesms3 is the leader of the worldmikesms3 is the leader of the worldmikesms3 is the leader of the worldmikesms3 is the leader of the worldmikesms3 is the leader of the worldmikesms3 is the leader of the worldmikesms3 is the leader of the worldmikesms3 is the leader of the worldmikesms3 is the leader of the worldmikesms3 is the leader of the world
shavin snatch is tricky also they get them random hairs just on the inside of the lips so you have to pull them open and shave gently down the lip.... kinda like your nut sack but its on a differant person so you have to be more cautious...... pretty much leads into messing around in the shower..... maybe even choking a little when your trying to eat that shit and the water runs down her back into your mouth...... i was coughing so hard my eyes started watering....
07' MS3 True Red
mikesms3 is offline   Reply With Quote
The Following 3 Users Say Thank You to mikesms3 For This Useful Post:
bigriver (01-05-2012), Chimmike (01-06-2012), Ferg (01-17-2012)
 Old 01-05-2012, 03:37 PM   #153
ASHMS3's Avatar
Posts: 1,362   (View Stats)
ASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the world
Groans: 126
I fucking love this forum.
'09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE
ASHMS3 is offline   Reply With Quote
 Old 01-05-2012, 03:41 PM   #154
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
hey dustin brought it up to my attention. for all the non asians here, are your pubes curly? my pubic hair is straight like troll doll hair, im under the impression everyone is the same way?
The Following 5 Users Say Thank You to dooderek For This Useful Post:
BobbleHead (01-06-2012), Chimmike (01-06-2012), Easter Bunny (01-17-2012), Ferg (01-17-2012), Rokusek (01-06-2012)
 Old 01-05-2012, 03:53 PM   #155
Oliverms3's Avatar
Posts: 1,632   (View Stats)
Oliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the world
wow!... just read the whole 4 pages. man!
1. OP you're such a dumb ass!
2. Now I know how to shave my balls correctly
3. This is why I laugh at work, then my boss tells me to shut up.. lol
2010 BM MS3 - Cobb AP||3gal corn||Autotech Internals||ETS TMIC||Forge BPV||Denso Iridium ITV22||TurboXS DP||ARK exhaust||CP-E Nano SRI||PG TIP||JBR RMM||JBR PMM||TRZ TMM||NRG ETD||DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs||JB Heavy Knob||JB SSP||ST Coilovers w/ Eibach rear Camber Kit(made by SPC)||17x9 +28 Drag DR31 (track) RPF1 18x8 +35 (DD)||HKS TT Type 0||Clarion EQ||MB Quarts speakers||Pioneer amps and 10" Competition Sub.
346hp 392lbs of sexyness
Oliverms3 is offline   Reply With Quote
The Following User Says Thank You to Oliverms3 For This Useful Post:
 Old 01-05-2012, 03:59 PM   #156
UnknownSuperhero's Avatar
Posts: 2,462   (View Stats)
UnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the world
This is how I work teh balz. Just pinch, pull and away you go.
UnknownSuperhero is offline   Reply With Quote
 Old 01-05-2012, 05:00 PM   #157
bigriver's Avatar
Good thing this is not in the NSFW section.
 Old 01-06-2012, 07:08 AM   #158
Rokusek's Avatar
My pupes are super curly, makes it difficult to trimm properly sometimes...
 Old 01-06-2012, 08:13 AM   #159
Originally Posted by Sid3wayS View Post
Alright im full of shyt I actually havnt shaved in like 2 months, im tryn to get an epic beard like @silvapain. But honestly thou have you guys considered an electric trimmer like barbers use?
Why the fuck did you have to bring me into this thread? My head is spinning trying to figure out what the fuck is going on in here. I'm more confused than when I was 8 years old and I walked in on my uncle wearing high heels, a bra, and panties and singing 'you make me feel like a woman' to himself in front of a mirror.
 Old 01-06-2012, 08:30 AM   #160
mikesms3's Avatar
how'd we get back on shavin balls?????
i thought we were talking about SNATCH
07' MS3 True Red
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f544/bad-pushing-e-brake-button-when-engaging-101116/
MSF: the new 24/7 | SpeedForums.org This thread Refback 01-05-2012 11:17 AM
No sound when engaging turn signals or blinkers? Jym CX-7 > Issues & Troubleshooting 19 08-31-2011 02:37 PM
Hawk HPS brake pads & Goodridge brake lines in stock for the 07-11 MS3. Chris@Xtreme Mazdaspeed3/6 General Discussion 3 08-06-2011 08:56 PM
clunk when engaging reverse SB.MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 06-04-2011 05:39 PM
REPORT: Bored Bulgarians engaging in Russian Road Roulette Haltech Automotive News 0 11-02-2009 05:00 PM
Hawk Pads, Racing Brake Lines, and ATE Brake Fluid! Race Roots Mazdaspeed3/6 General Discussion 11 09-25-2009 02:04 PM
Page generated in 0.61554 seconds with 37 queries
