 Old 03-12-2019, 10:12 AM   #1
Sergiospeed3's Avatar
Posts: 9   (View Stats)
Sergiospeed3 is an unknown quantity at this point
Default Big headache, help.
About 1 month ago my cel came on with the code p0171 system too lean and within the same week my car started, what I felt was, overboosting (my rev and boost would climb up quickly while barely pressing the throttle). I assume this was because the system lean so a leak existed. Checked everything and found nothing loose or cracked. I bought the car used and the previous owner had a blow off valve and cobb intake with turbo inlet hose. I put the stock bypass valve on and the code went away, but my ltft remained at about +12. And the overboosting remained. I took it to the dealer and they said since no cel they have no diagnostics they can do. But a mechanic drove my car and he said the overboosting I felt might actually be the clutch slipping. And they said the car running lean could be due to the cobb intake and inlet hose. So today I bought an accessport and did some logs. One at idle and driving on the street and the other at 4th gear wot that I've attached. After I did the wot log I was driving home and I noticed my car would shake a bit if I revved high. I got scared and I haven't moved it since I got home. My car has also been emitting a burning smell for the past few days. Did I mess up the engine, or is that due to the clutch been almost done? Also anything abnormal in my logs that can explain my lean code or any other issue? Kind of inexperienced so bare with me if I'm stating obvious fixes.
Here's a video of the my revs jumping: https://youtu.be/7cpcUt_qEpU
Sergiospeed3 is offline   Reply With Quote
 Old 03-12-2019, 03:27 PM   #2
thatguyinms's Avatar
Posts: 31   (View Stats)
thatguyinms has disabled reputation
didn't look at logs but that looks like clutch slip to me, especially with the burnt smell.
2013 Mazdaspeed 3
91k miles and counting
Freektuned since 17k at 21psi
Power:
HTP 3.5" intake - TR8 - CX piping - Snow Stage 2 @ 100% meth at 625mL/min- UR catless DP - UR testpipe - Corksport axleback - Turbosmart Dual port on recirc
Supporting:
Corksport HPFP - fresh blasted valves- 3Bar MAP+pigtail - Damond EGR full delete - Damond Trio - TB Coolant bypass - 51r battery w/box - Corksport shift bushings -
Known Fails:
Florida Heat - stock k04 - OEM Midpipe - shitty ebay catchcan
thatguyinms is offline   Reply With Quote
 Old 03-12-2019, 04:28 PM   #3
Fstrnyou's Avatar
Posts: 2,422   (View Stats)
Curious what phenomenon gave you the inclination that it was overboosting?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 03-12-2019, 07:05 PM   #4
First and foremost, I'm relatively inexperienced. I've only been been driving for 4 years and this is my second car, my first being a complete bucket. I assumed it was overboosting because of the lean coming in within a day or two of the boost climbing too fast. So I thought because of the lean code that too much air was getting in which was causing the overboosting.
 Old 03-13-2019, 11:24 AM   #5
Fstrnyou's Avatar
What was the boost going up to?
Other rides:
History:
 Old 03-13-2019, 11:42 AM   #6
Jeff23spl's Avatar
Posts: 1,950   (View Stats)
12psi in the log isn't overboosting.....if RPM and boost raise faster than it should especially in higher gears....Either someone installed nitrous during your sleep and forgot to tell you or...your clutch is slipping...
Don' forget we have a dual mass FW that isn't easy to be machined...The selected clutch kit must include a solution for this....
and your cel is another different thing related to a leak or a larger intake bringing the maf reading too low for what the ecm is programmed for (Maf cal) and O2 report a system too lean after trying to raise fuel amount....
On the log, we can see your AFR being close to 13 under boost and this usually mean the maf reading is too low. this bring knock condition that is also seen in the log...and all that can end up by the need of a new engine.
this need to be solved asap.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Pu Manchu (03-14-2019)
 Old 03-14-2019, 06:18 AM   #7
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,967   (View Stats)
Groans: 546
the clutch is slipping so bad that it prolly can't even hit enough load to boost past 12psi
and like he said, you have a legitimate air/fuel issue that is bad enough to ruin your pistons/valves.
94 M
06 MS6
The Following User Says Thank You to Pu Manchu For This Useful Post:
Kellerspeed3 (03-15-2019)
 Old 03-14-2019, 07:38 PM   #8
So it's likely that the lean part is the maf and not a leak? How do I fix that issue?
 Old 03-15-2019, 09:00 AM   #9
Jeff23spl's Avatar
No it isn'T what i said.
A leak is possible but it would need to be between MAF and turbo entry side, like a disconnected TIH or anything that can let the turbo suck air that isn't measured with the maf.
And the lean condition under boost may not be the same lean condition that triggered your cel.....Being lean in vaccuum isn't a big issue but being lean under boost is catastrophic. The only way to solve this after making sure it is not a leak, is to have an accurate maf calibration in the tune that match the intake you have on the car.
But prior to have it tuned for this, you need to fix the car because if you update the tune with a leak, it will need to start again and again and again
+ you need a clutch that hold torque to make wot datalogs to validate the maf cal. ...
So basically, you shouldn't use your speed or at least avoid to boost with it until you replace the clutch and you correct the lean condition. The other option is to beat the shit out of it until you vent the bloc and either say speed is garbage or fix everything at once while replacing the engine...
Wife drive 2010 CX7
Report: Trademark trolls cause headache for Tesla in China Haltech Automotive News 0 08-09-2013 10:50 AM
How a blogger can cause Audi a headache over Green Police Super Bowl ad [w/video] Haltech Automotive News 0 02-01-2010 02:40 PM
Page generated in 0.30712 seconds with 25 queries
