Bixenon HID level cutoff Can someone please post a picture of their speed3's low beam and a picture of the high beam? I want to compare my low beam and high beam. I think my HID cutoff is kinda screwd up for some reason and the brightness is starting to decrease. Thanks |
Driver's side is lower to not blind oncoming traffic. And if headlight plastic is fading, that coud be why. Since you want help, first you post pics. |
2 Attachment(s) Here are my low and high beams. From what I've seen from other bixenon headlights, its suppose to make a trapezoid-ish pattern when the high beams are on. There are two yellowish pattern at the very top. What are those two yellow beam patterns at the very top? Is this normal? |
Normal for a GenPu. You are fine. High beam is not HID. |
I see. The HID might be a lower bulb intensity. Looks normal to me. |
| All times are GMT -7. The time now is 05:11 AM. |
