Like Tree2Likes
  • 1 Post By Elusivellama
  • 1 Post By DONOTBUGME
 Old 07-24-2011, 03:39 PM   #1
JD80's Avatar
Posts: 14   (View Stats)
JD80 is an unknown quantity at this point
Default Blown Turbo
I just wanted to give you guys another data point on this issue and perhaps get some advice.
I just got my car back from the dealer. I stocked out beforehand (except for the fuel pump – I just removed the sticker) and fortunately I didn't pay a dime to have my turbo replaced. The mods I was running:
Cobb intake, Cobb DP, CPE Fuel Pump, CPE RMM, AP with stage2 tune, 1 step colder plugs.
The first indication that there was a problem was quite obvious. After about 4 hard pulls in a row, as soon as I stopped at a stoplight, my exhaust started shooting out clouds of white smoke. Not just a little – it was billowing out. KiddMnky was right beside me so we turned into a parking lot to take a look. There appeared to be some smoke leaking out past the exhaust manifold, since we could see a bit of smoke coming out around the heat shield.
I limped the car home and started trying to troubleshoot. I bought new exhaust manifold bolts and gasket and made sure no exhaust leaks were occurring. I also installed a bnoon bolt. At first, the bnoon bolt seemed to cure the smoke, but after a few WOTs, the smoke was back nearly as bad as before. Not only that, but at this point I started hearing a suspicious sound when accelerating that sounded like a bearing being tortured. I also noticed that boost was not getting anywhere close to targets (12 PSI in 2nd gear, for instance)
At this point I gave up, stocked out, and took it to the dealer.
Now the question is:
Is installing a downpipe on these cars playing with fire? Or did I screw up the install somehow that led to this problem? I'm guessing the stock turbo doesn't like the reduced back pressure, but even more so if there is an exhaust leak.
The way I see it, I have 4 options:
1. Leave the car stock, sell my parts.
2. Go back to intake, tune and leave the exhaust stock.
3. Get the turbo reworked, or big turbo.
4. Sell my car and get something else that won't blow up the turbo with exhaust mods (if such a thing exists).
Any thoughts or suggestions would be massively appreciated...
JD80 is offline   Reply With Quote
 Old 07-24-2011, 03:55 PM   #2
Metal409's Avatar
Posts: 316   (View Stats)
Metal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the worldMetal409 is the leader of the world
I say keep the car and enjoy it. It's your call when it comes to throwing all the parts back on or not, if it was me, i'd go back to stage 2. It's a car and shit happens, even new cars have things break. And regardless of if you sell the car and switch to something else, you're going to find out that it will also have problems and known issues all it's own. Just my 2cents.
2016 Ford Focus ST
2013 Ford Fusion Titanium AWD - Sold
2009 Mazdaspeed 3 GT - Sold
Metal409 is offline   Reply With Quote
 Old 07-24-2011, 03:58 PM   #3
essejkcamraw's Avatar
Posts: 922   (View Stats)
essejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the worldessejkcamraw is the leader of the world
Groans: 47
Groaned at 25 Times in 19 Posts
keep mods. keep car. drop k04. pick up 3071 and have some fun blowing money like the rest of us.
From built & Big turbo to Miata Gheys
essejkcamraw is offline   Reply With Quote
The Following 2 Users Say Thank You to essejkcamraw For This Useful Post:
AJ713 (07-25-2011), IshiKage (07-25-2011)
 Old 07-24-2011, 04:02 PM   #4
2010Speed3's Avatar
Posts: 607   (View Stats)
2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world
My story is very similar. I blew my turbo with SRI/TIP, race pipe, KMD internals, catback exhaust, 1 step colder plugs, RMM, stage 2 tune. I had initial smoking after I got fuel cut during a 1st gear launch. Month later, I had shaft play, stocked out (except RMM, internals, and catback exhaust), and took it to the dealer.
Now I'm running the new turbo with everything I had on before except the race pipe. I've been trying to get my tune down before I go Stage 2 again. The car works perfectly fine, if that's what you're worried about. As for your choices, it really depends on what your plans are with the car and how much disposable income you have.
Good luck.
SOLD on 08/2013
2010 Black Mica MazdaSpeed3
Performance: BNR S3 - Sure Full 3" Aeros - Bosch 3 Bar Map - DDM HID Kit 6k 35w - Hella Super Tones - CorkSport LED Light Kit - Cobb Knob (Red) - VG Sharkfin Antenna - Sure Anchors - Jbarone 88duro Dog Bone RMM - Black CorkSport SRI/TIP (Powder Coated Black) - Ultimate Racing Race Pipe & CBE - KMD Internals - CorkSport Cold Air Box w/ Carbon Fiber Top - Turbosmart SU Blacked Out BPV - Cobb AccessPort Stage 2 (Nataphen Tuned) - JBarone RSB - CP-E TMIC
2010Speed3 is offline   Reply With Quote
The Following User Says Thank You to 2010Speed3 For This Useful Post:
rfinkle2 (07-26-2011)
 Old 07-24-2011, 04:10 PM   #5
JD80's Avatar
I'm really kidding myself that I will keep this car (or my next one) stock. How boring is that?
One thing I know I am doing for sure is getting a daily driver. I can't afford to be screwing with my car and possibly leave myself without transportation to get to work. This time around I borrowed a car from a family member and had it for an entire month while I was troubleshooting and then waiting for the dealership to fix it, but I can't always count on that, nor do I want to.
At the risk of committing a grave act of blasphemy, I have been looking into STis recently. But I'm having trouble justifying the extra 12k or more to get one.
 Old 07-24-2011, 04:53 PM   #6
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
This is the 2nd blown gen2 turbo thread in one day. Not good...looks like we're in for the same issues as gen1's.
Good side is 3071 may come sooner than I expected
 Old 07-24-2011, 05:02 PM   #7
JD80's Avatar
I'm a little weary of going big turbo, but its not out of the question. I basically shed my newb card doing the downpipe install (and uninstall), although I had some help. The big turbo installs I've heard about so far sound pretty horrible.
 Old 07-24-2011, 05:06 PM   #8
Elusivellama's Avatar
Posts: 351   (View Stats)
Elusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the worldElusivellama is the leader of the world
^ STI? Ringlands busting will be your new nightmare-in-waiting.
Elusivellama is offline   Reply With Quote
The Following User Says Thank You to Elusivellama For This Useful Post:
 Old 07-24-2011, 05:07 PM   #9
Sig_Nasty's Avatar
Posts: 272   (View Stats)
Sig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the world
Groaned at 4 Times in 1 Post
i blew my turbo on a stock car with 4.5k on it this past monday. had the turbo and gasktes replaced under warrenty thank god. had all the same symptoms as you.
Sig_Nasty is offline   Reply With Quote
 Old 07-24-2011, 05:10 PM   #10
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
DONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the world
Groans: 266
Groaned at 83 Times in 60 Posts
Wow a whole 2 today....Look any product anyone makes are going to have a percentage fail. A good comparison would be your friend john (kid) he has put his ko4 @ 22psi for how long now and last time I talked to him it was fine. To bad you werent logging maybe be you spiked to some high ass number with the ots tune.
Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next.
DONOTBUGME is offline   Reply With Quote
The Following User Says Thank You to DONOTBUGME For This Useful Post:
 Old 07-24-2011, 05:17 PM   #11
rghispanic88's Avatar
Posts: 3,131   (View Stats)
rghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the worldrghispanic88 is the leader of the world
Groans: 263
Groaned at 73 Times in 43 Posts
this car is fun, so you should keep it.
shit is bound to happen.
if you sell it, i call dibbs on ur DP
2010 Black Mica
2004 EVO 8 Green Monster The "7up"
rghispanic88 is offline   Reply With Quote
 Old 07-24-2011, 05:46 PM   #12
JD80's Avatar
I guess it's possible I was boost spiking or something...but every time I went WOT when I was monitoring boost it was too low if anything. At the time I was more concerned about knock, which was better at stage 2 than stage 1 actually.
I may end up selling this DP even if I do keep the car. I'll keep you in mind.
 Old 07-24-2011, 05:49 PM   #13
DONOTBUGME's Avatar
Groans: 266
Moral of the story is...Get a perm tune (DJ) or your turbo will blow
 Old 07-24-2011, 06:07 PM   #14
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
Do #2!! LOL
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline   Reply With Quote
 Old 07-24-2011, 07:17 PM   #15
kmac's Avatar
Posts: 1,792   (View Stats)
Just get a big turbo and get rid of the ko4. The turbo by nature is pure fail. It's working to had to make the power.
The Following User Says Thank You to kmac For This Useful Post:
 Old 07-25-2011, 05:21 PM   #16
CobraStarVIII's Avatar
Posts: 63   (View Stats)
CobraStarVIII is a splendid one to beholdCobraStarVIII is a splendid one to beholdCobraStarVIII is a splendid one to beholdCobraStarVIII is a splendid one to beholdCobraStarVIII is a splendid one to beholdCobraStarVIII is a splendid one to beholdCobraStarVIII is a splendid one to beholdCobraStarVIII is a splendid one to behold
I just had the same thing happen and felt the same way, thinking about trading this car in after the repair, but it's a lot of fun to drive, thats why I bought it over other cars in the first place.
CobraStarVIII is offline   Reply With Quote
 Old 07-25-2011, 05:24 PM   #17
manelscout4life's Avatar
Posts: 1,781   (View Stats)
manelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the worldmanelscout4life is the leader of the world
Groans: 661
Groaned at 45 Times in 33 Posts
wow, gen2's are blowing turbos like no tomorrow.
GenWON > genPU
manelscout4life is offline   Reply With Quote
 Old 07-25-2011, 08:23 PM   #18
2010Speed3's Avatar
Any mods when you blew it up?
SOLD on 08/2013
 Old 07-26-2011, 10:18 AM   #19
I found this... interesting read on the K04
K04 TURBO REPORT FROM NEUSPEED
The Following 2 Users Say Thank You to Elusivellama For This Useful Post:
2010Speed3 (07-27-2011), Pu Manchu (07-26-2011)
 Old 07-26-2011, 10:39 AM   #20
adlpb's Avatar
Groans: 669
K04 users should always bring their vehicle to a complete stop and allow the engine to idle prior to shutting down the engine. Recommended idle times vary from 1 minute after mild driving, to 5 minutes after aggressive driving. The idle-down procedure circulates fresh oil and coolant through the turbocharger, allowing it to cool gradually, prior to shut-down.
That's interesting...5 minutes seems like a lot. Definitely not 30 seconds as recommended
 Old 07-26-2011, 12:25 PM   #21
Did you see the viscosity of recommended oil? 20W50 in summer, 10W40 in winter.
I can believe 5 mins for aggressive driving and with a ton of boost, but 1 min after mild driving? The turbo must be spinning even during mild driving?
 Old 07-26-2011, 12:43 PM   #22
adlpb's Avatar
Groans: 669
Yea that viscosity issue is a little to general. Winter in North Dakota is a lot different than winter here in Florida.
I leave it on for 30 seconds. I don't usually full-boost to my parking lot anyway. I'm usually stuck at a red light after going WOT.
 Old 07-26-2011, 01:06 PM   #23
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
@ least is the turbo and not the motor?
DONOTBUGME (07-26-2011)
 Old 07-27-2011, 08:23 PM   #24
gbassrace's Avatar
Posts: 40   (View Stats)
gbassrace will become famous soon enoughgbassrace will become famous soon enough
I'm next GD it!!! 3 good runs from 3k-6k and HUGE smoke out the rear. Warranty replaced but a huge hassle. WTF!!! Trying to figure it all out.........No mods other than AP Stg 1 93.
BTW - Christian says it's the PCV system like Gen 1 not the K04. Nice Mazda!
Last edited by gbassrace; 07-27-2011 at 08:23 PM. Reason: MSF Database - Automerged Doublepost
gbassrace is offline   Reply With Quote
MazdaSpeed 2.3L DISI Turbo Blown Engine Resource Thread JimmyMac MazdaSpeed 3 - Engine, Transmission & Driveline 1439 05-11-2019 07:47 PM
2010 blown turbo?? CobraStarVIII 2010 MS3 - Engine, Transmission & Driveline 45 08-07-2011 09:48 AM
blown turbo h0rsies MazdaSpeed 3/6 - Turbo Induction 1 07-07-2010 05:42 AM
missfire? and also blown turbo? wisniaPl MazdaSpeed 3/6 - Troubleshoot/Diagnostics 28 05-04-2009 02:55 PM
Page generated in 0.48758 seconds with 34 queries
