 Old 10-07-2018, 02:46 PM   #1
Montrix's Avatar
Posts: 3   (View Stats)
Montrix is an unknown quantity at this point
Default Boost Issue
So for about a week now, I haven't been able to hit as much boost as I did before. I'm Freektuned for a few months now, and haven't had any issues. I was hitting from 20-21 and now am hitting 18 if It's a good day. Usually it's hitting 16 or so. I've tried checking for boost leaks, and found none. I also tried reflashing an older revision and had the same issue. Would tightening the spring on my BPV help?
I attached a log I sent to Justin, where I was hitting in the 20's and a log from today. I'd appreciate any help.
Freektuned '13 Speed 3
Cobb - RMM, Intake, TIP, Downpipe, XLE BPV
Autotech - Internals
Ultimate Racing - Catback
Montrix is offline
 Old 10-07-2018, 05:41 PM   #2
Fstrnyou's Avatar
Posts: 2,205   (View Stats)
Don't touch anything until you hear back from your tuner.
Tightening the wastegate spring will only solve the symptom, not the problem.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
Fstrnyou is offline
 Old 10-09-2018, 05:55 PM   #3
Montrix's Avatar
Problem solved, had to re-lube the piston in my BOV, it wasn’t fully closing
Montrix is offline
Boost issue Rob84 MazdaSpeed 3 - Engine, Transmission & Driveline 2 01-01-2015 03:22 PM
Over Boost Issue, Boost leak? vincentspeed3gogh MazdaSpeed 3/6 - ECU Computer Tuning 23 12-27-2014 02:31 AM
Boost issue Moosheep Gen2 MS3 General Discussion 6 07-26-2013 07:04 AM
Need Help with a possible Boost Cut issue??? EddyV1987 MazdaSpeed 3/6 - Big Turbo Builds 7 04-24-2013 04:24 PM
Boost issue sriser66 MazdaSpeed 3/6 - Turbo Induction 4 03-19-2013 10:40 PM
Page generated in 0.24137 seconds with 22 queries
