-   -   Boost leak checker ? (http://www.mazdaspeedforums.org/forum/f544/boost-leak-checker-79023/)
vatordoc 04-26-2011 08:37 PM
While I was putting my IM back on I figured I'd check for a leak. I'm capped off at the cold pipe hose and hear no leaks but quickly fall from 20 psi in less than 5 seconds. Using my cigarette at the tail pipe I'm clearly loosing it through an/the exhaust valve(s).
Normal?
rigor 04-26-2011 08:46 PM
yup normal!
soap down your pipe connections, also it doesn't test your intake, it is building pressure against your TB!
then trickling into the intake were valves are open/ closed so no pressure!
their you will have to do a running test, and use either to spray down the intake connections to check for leaks, as this is the only part in a vacuum!
good luck!
speed23 04-26-2011 08:47 PM
I seem to recall that I could not hold pressure for very long either when I did a boost leak test.
vatordoc 04-26-2011 08:58 PM
Originally Posted by rigor (Post 826968)
yup normal!
good luck!
Should have mentioned that I'm holding the TB butterfly open with a wine bottle cork. So I should just open my valve enough to keep it at 10-20 psi and check it with soap water?
Thanks!
Ziggo 04-26-2011 09:04 PM
Sounds to me like you just got unlucky and one of the cylinders is at BDC between the exhaust/intake strokes. You should be able to bump the engine and get it to a place where the intake and exhaust valves are not open. Leave it in gear to keep it from turning the engine over.
rigor 04-26-2011 09:05 PM
huh i guess you could shove a big potato in the tail pipe, and soap everything lol including the exhaust!
Page generated in 0.17076 seconds with 11 queries
