Like Tree3Likes
 Old 01-30-2013, 03:43 PM   #41
Oliverms3's Avatar
Posts: 1,632   (View Stats)
Oliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the world
Originally Posted by 90210 View Post
Great to hear of some high mileage ones!
Debadged it. TOok about one hour. The mazdaspeed was easy, the "3" was difficult. My Mazda5 and MSM were so easy, then again they were new, this has been outside a while, used.
Car looks stock everywhere, no mods that I could find. Looked around a good bit
Only on the outer plastic of the intercooler where the trim of the hood meets, seems like there is some "scratches/rubbing" not sure if this is normal?
Wonder if the thread title can be changed?
Some pics
that's normal... our stock rear motor mounts are very soft and the engine moves a lot. so you definitely need to replace that RMM asap.
2010 BM MS3 - Cobb AP||3gal corn||Autotech Internals||ETS TMIC||Forge BPV||Denso Iridium ITV22||TurboXS DP||ARK exhaust||CP-E Nano SRI||PG TIP||JBR RMM||JBR PMM||TRZ TMM||NRG ETD||DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs||JB Heavy Knob||JB SSP||ST Coilovers w/ Eibach rear Camber Kit(made by SPC)||17x9 +28 Drag DR31 (track) RPF1 18x8 +35 (DD)||HKS TT Type 0||Clarion EQ||MB Quarts speakers||Pioneer amps and 10" Competition Sub.
346hp 392lbs of sexyness
Oliverms3 is offline   Reply With Quote
 Old 01-30-2013, 04:00 PM   #42
90210's Avatar
Posts: 271   (View Stats)
90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world
OH MAN..wasn't thinking of doing anything for a while...but looks like I need to get to that
90210 is offline   Reply With Quote
 Old 01-30-2013, 04:28 PM   #43
Alexander's Avatar
Posts: 841   (View Stats)
Alexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the world
Groaned at 43 Times in 16 Posts
even if you dont want to do any mods, rmm and shifter bushings will make the car 10 times better. look into them
2011 Mazdaspeed 3
Cobb v3 AP | Autotech CDFP | JBR Sri | JBR Balance Shaft Delete | JBR Rear Sway Bar | JBR 88 duro RMM | M2 Testpipe | Corksport Tip | Corksport Short Shifter | Corksport SSP | Corksport Shifter Bushings | Cobb Counterweight | H&R Lowering Springs | Joseph Koni Shocks/Struts | SPC Rear Camber Arms
Alexander is offline   Reply With Quote
 Old 01-30-2013, 04:50 PM   #44
90210's Avatar
Definitely will look into it, now that you guys mention it. I value the experience you guys have .
When I base line all the fluids in a few weeks, will do it then.
 Old 01-30-2013, 05:08 PM   #45
Chuthor's Avatar
Posts: 435   (View Stats)
Chuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the worldChuthor is the leader of the world
Shifting was waaaaaaaaaaay better after swapping out the RMM. Plus its cheap and will take you about 20 mins to swap.
Chuthor is offline   Reply With Quote
 Old 01-30-2013, 05:54 PM   #46
90210's Avatar
^^ You guys are funny.
I would spend some time this weekend, reading and familiarizing myself with the info you guys provided.
I thank you
INSURANCE just got my full coverage insurance. $500 deductible. 63$/month. Went up 20$/month from the Miata.
They listed it as "Mazda Protege Mazdaspeed 2010 model"
 Old 01-30-2013, 06:02 PM   #47
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
I don't know why insurance companies aren't hip to the products Mazda puts out but I am ok with that.
Going from my MSM to the MS6 my insurance went up $12.
They wanted $130 more a month for an AP2.
Past Mazdas & Speeds
 Old 01-30-2013, 06:09 PM   #48
90210's Avatar
I have to see waht the rates on my 07 AP2 was, can't remember. I bought my AP1 new, put 163K miles on. Spa Yellow. Traded it for a 07 Rio Yellow AP2, loved the car.
The Elise replaced the AP2. Miss the quality of the AP2, though not all the people who want to steal it.
Almost bought a 2013 Civic Si this time, was lusting after the quality. Got swayed by the MS3 color, my first non red/non yellow car
Velocity red MSM gone to a good home.
 Old 01-30-2013, 06:11 PM   #49
snOhio's Avatar
Posts: 330   (View Stats)
snOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the worldsnOhio is the leader of the world
yeah man, the foam on the inside of the hood is supposed to make contact with it. idea being that the air coming in gets channeled right into the intercooler.
Sold: 2011 Black Mica MS3 - JBR 80d RMM, SSP, Anchors, Mudflaps, SRI/TIP
2008 Toyota 4Runner SR5 V6 4WD
2004 Aprilia Tuono - Beowulf exhaust, Gabro chip
1993 Suzuki GS500E - K&N drop in, Supertrapp strap on
snOhio is offline   Reply With Quote
 Old 01-30-2013, 06:26 PM   #50
VulgarKyle's Avatar
Posts: 1,137   (View Stats)
VulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the worldVulgarKyle is the leader of the world
i just replace the battery in my fob and it was 2025 i think all you need is a small screwdriver and you split the 2 halves(it took me a bit to figure this out lol)
VulgarKyle is offline   Reply With Quote
 Old 01-30-2013, 06:55 PM   #51
Neverlift's Avatar
Groans: 1,143
What about the CB NB or the white NA?
Oh yeah, FYHN...
 Old 01-30-2013, 07:31 PM   #52
90210's Avatar
yah just didn't realize that the foam can scratch the ic plastic .
dealer said to stop by Sat they will so it for free. Also they forgot my 30$ free Starbucks card lol.
Oh yeah, FYHN...
TheForumWars.tv Ep. 5 Honda Civic SI VS Mazda Speed 3 - YouTube
I don't consider either of those really cars in the stable. Too short term ownership
So just did the commute home. Car drove great. I make sure not to lug the engine so the car is not boosting under 3 k. Thus requires more shifting than a na car.
It is quite a big/wide car. Gotta get used to that.
The handbrake in up position seems to contact the armrest in front position, need to check it tomorrow.
Other than that drove great, kid loves the blue, all in all good day.
I will keep track of two tanks of gas and report what I am finding.
Last edited by 90210; 01-30-2013 at 07:31 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-30-2013, 07:43 PM   #53
VulgarKyle's Avatar
that is even better.
dont even bother tracking fuel milage i had my average up at 23mpg for about 100 miles but im unable to contol my foot i guess i cant seen to get back out of 18mpg
 Old 01-30-2013, 08:44 PM   #54
90210's Avatar
More for recording purpose, rather than to hypermill the car .
 Old 01-30-2013, 09:11 PM   #55
stuntz89's Avatar
Posts: 169   (View Stats)
stuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the worldstuntz89 is the leader of the world
Greatt deal.. congrats on the purchase... warning tho
you will not escape the bug for very long
VulgarKyle likes this.
#3527. On genpus for winter >=)
5zigen Hyper 5ZR for summer
Magnaflow CBE, CPE Catted DP, Corksport stage 2 SRI w/Corksport TIP, Turbosmart Dual Port BOV, 8000k HID Foglights,Block8head Vent pod w/52mm Prosport Boost Gauge, AWR RMM, AWR Passenger Side MM, JBR TMM, Bilstein HD Shocks Rear, Koni Sport Shocks Front, H&R Sport Springs, STI front lip, 35%Tint all around, Cobb AP, ACT 6 Puck Disc w/ ACT prolite Flywheel, Motul M300 Trans Fluid,PTP CDFP internals, Whiteline RSB, Corksport Rear Diff Mount, JDMGOODIE OEM Vent Visors, Mirimoto Mini HD Bixenon Projectors, ETS TMIC, Tuned by boost_creep ...
Tune in progress 8)
im on my way
h
stuntz89 is offline   Reply With Quote
 Old 01-31-2013, 11:30 AM   #56
90210's Avatar
LOVING THE CAR SO FAR
Two quick issues:
1) When I am making a left turn (only noticed in my office garage) there is a kinda of a whine noise. Not a rubbing noise. It isn’t like the electronic steering noise, which our mazda5 has. It isn’t making the noise making a left turn (need to pin down this weekend). Noise is very faint.
2) At 85 steering wheel has a good amount of shake to it. Car has all 4 new tires. Passenger front wheel seems like it has NO weight on it (will double check again in a bit), and drivers side does. Wonder if fronts need to be rebalanced
 Old 01-31-2013, 11:42 AM   #57
nindoja's Avatar
Posts: 2,395   (View Stats)
@90210; definitely get the wheels rebalanced. The car steering wheel shouldn't shake at 85mph.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 01-31-2013, 11:59 AM   #58
90210's Avatar
Will take it in this weekend and have it done
 Old 01-31-2013, 12:08 PM   #59
90210's Avatar
Front driver wheel weight has two weights marked "1/2" each
Passenger front wheel has only one "1/2" weight.
Don't know enough about wheel weights .
 Old 01-31-2013, 09:42 PM   #60
CorkSport's Avatar
Posts: 3,416   (View Stats)
CorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the world
Could just be a careless wheel mounting tech who balanced it or worst case a bent wheel.
-Derrick
WWW.CORKSPORT.COM
CorkSport is offline   Reply With Quote
 Old 01-31-2013, 10:00 PM   #61
Code Monkey's Avatar
Posts: 7,681   (View Stats)
Mine is listed as a "2006 Mazda Mazdaspeed Protege", go figure.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
 Old 01-31-2013, 10:06 PM   #62
90210's Avatar
-Derrick
derrick
You think I should swap the wheels front to back and see or get all re balanced ? I will go to dealer sat for new remote battery, I may ask if they will check it, if not no big deal I will take to tire place.
I guess protege better than 323 or 929 lol
P.s
Found ex owner. He is willing to ship th e cargo cover and the maintenance records
Last edited by 90210; 01-31-2013 at 10:06 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to 90210 For This Useful Post:
Neverlift (02-01-2013)
 Old 01-31-2013, 11:06 PM   #63
CorkSport's Avatar
derrick
That would be an easy way to narrow it down.
-Derrick
WWW.CORKSPORT.COM
 Old 01-31-2013, 11:10 PM   #64
ms3rick's Avatar
Posts: 2,959   (View Stats)
2nd blue in the socal nator crew...
Sold:
2010 MS3 siLver.
Official 60-100mph Times
Official Video battles
Official Youtube Channels
 Old 02-01-2013, 10:17 AM   #65
90210's Avatar
Where are most of the so cal people? I keep saying things far inland. Any people in West La area?
 Old 02-01-2013, 12:33 PM   #66
Neverlift's Avatar
Groans: 1,143
There are quite a few people in West LA, but when the monthly NATOR gatherings/install days are held, they are done so inland.
 Old 02-01-2013, 12:45 PM   #67
90210's Avatar
Thanks. I will see if I can find some WEST LA people.
Yeah still trying to figure out what this NATOR thing is and then there all these other So Cal separate forums. Going to take some time to figure out to navigate, I suppose.
Looking forward to meeting you sometime
 Old 02-01-2013, 12:47 PM   #68
The Nut's Avatar
Posts: 1,571   (View Stats)
The Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the worldThe Nut is the leader of the world
Groaned at 38 Times in 20 Posts
I paid $22,000 for my 2012. $26,000 OTD (tax, title, reg., dest. charge, etc. took 4 months to get a dealer to agree to my price. But if a dealer has plenty in stock, they eventually cave. Besides, it's not like they didn't make a couple $$ off the sale.
Anyway, be sure everything checks out on her. Ask to see the spark plugs. If everything looks cool, $16,500 is a good deal. It's funny, I looked up my car on Kelley Blue Book, and with the miles I have on it, it's still worth more than I paid for it almost a year ago. Viva la resale value!
2012 BLACK MICA w/TECH
Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches
Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18
Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob
Stereo: Full Custom Mobile Audio/Video Entertainment System
91 & Corn diagnostics by:
The Nut is offline   Reply With Quote
 Old 02-01-2013, 12:54 PM   #69
90210's Avatar
Already bought it and have been driving it. Your 2012 sounds like a good deal
I am on Mazda #9 , all I know is, resale value have never been their strong suit Only time they have been good deals (FOR ME), is when I bought my new MSM for 18250$ cuz the dealers were blowing them out.
 Old 02-02-2013, 12:41 PM   #70
90210's Avatar
Dealer took care of remote battery and proper wheel balancing.
Spent 4.5 hours of claying and waxing, and it looks exactly like a few nights ago when I brought it home
Lol
 Old 02-08-2013, 10:41 AM   #71
90210's Avatar
UPDATE:
Loving the car. It is driving great, and servicing my purpose. Been debating a rear seat cover, due to kid.
Balanced the wheels/tires. Ordered new floormats, and installed new wipers.
Looking at suspension mods (learning about it on the forum), before pulling the trigger on some parts.
ONLY ISSUE: I am having is it is incredibly hard to get it into reverse. Gear 1-6 perfect. I will do the FOrd gear oil soon, but reverse is almost impossible. Clutch out, try again, still almost impossible.
 Old 02-25-2013, 02:44 AM   #72
Quickbluems3's Avatar
Posts: 63   (View Stats)
Quickbluems3 is a glorious beacon of lightQuickbluems3 is a glorious beacon of lightQuickbluems3 is a glorious beacon of lightQuickbluems3 is a glorious beacon of lightQuickbluems3 is a glorious beacon of lightQuickbluems3 is a glorious beacon of light
@90210 Just so you know, you got a great deal @$16,500 if the car was clean. I just got offered $18,000 for my car at a reputable location for my 2010 Celestial Blue Mica with 24,000 miles.
Quickbluems3 is offline   Reply With Quote
 Old 02-25-2013, 07:49 AM   #73
90210's Avatar
Thank you kindly. I ended up paying 16250$ due to it missing floormats and the rear cargo cover . It is one owner all stock.
I located the original owner, who is in his 50 s and ended up mailing me all the maintenance record along with the cargo cover he had at home.
Why are you selling yours ?
 Old 02-25-2013, 10:09 AM   #74
I really liked the car a lot-but I came from an Evo 8 and I really miss the all wheel drive. I'm at a point where the MS3 was just a weekend car and the used car market is pretty hot right now, so I figured I would get what I can for it and eventually go with an Evo X or see what comes out next year. I really babied my car too-24,000 miles on the Original Dunlop tires and they were listed as "good condition" in my appraisal . Enjoy your car, I'll really miss the color and driving it!
 Old 02-25-2013, 10:57 AM   #75
90210's Avatar
^^ Sounds like you babied it.
For me, it is my commuter car. My weekend cars are too harsh, and all 2 seaters, so I needed something for the family. I considered the WRX/STi route, but having owned Subaru before, I wanted to try something a little different, since around here STi/WRX seem to be a dime a dozen. Also I don't need the AWD at all, so that wasn't a consideration for me.
I absolutely love the color, and my commute has been a joy. I am used a 2 seater commute, so was really hating the 4 door/backseat commute, but it has been great so far.
My only wish is it was lighter (given my normal mode of transport is 1800-2400lbs), but it is something I can live with, for the moment.
Also when I go to Cotstco, now people don't stare me, watching me take all the papertowels out of the packaging and stuff them in my car one at a time.
 Old 03-03-2013, 06:28 PM   #76
Shad's Avatar
Posts: 53   (View Stats)
Shad is a splendid one to beholdShad is a splendid one to beholdShad is a splendid one to beholdShad is a splendid one to beholdShad is a splendid one to beholdShad is a splendid one to beholdShad is a splendid one to behold
Thanks. I will look at th VIP thing you mentioned.
Package tray around 230$ is what I expected, so the $250 dealer gave me will get used for that, unless I can find a used one.
Says 180$ here, but I don't even know how many speakers I got. During test drive, and driving this morning, forgot to turn on stereo. Not sure if it even works LOL
2012 Mazda3 Package tray Parts
Fully Bolted -hey don't give me any ideas. I am trying to play a grown up in real life
*must not mod*
*must not mod*
*must not mod*
Its commuter car, for the kiddies, *must not mod*
I've got front mats from 2012 MS3- had them in about 4 months they still look fresh- PM me if interested. Mod- is this okay to post, or should they've on Classifieds? Very lazy right now...
2012 CWP w/ Tech- 15% tint, nothing else.....yet!
Seriously OP, as Silva pointed out, being a cheap ass and buying regular is fucking retarded. Its like buying a pet t-rex and feeding it broccoli; its gonna die.
Shad is offline   Reply With Quote
 Old 03-03-2013, 06:41 PM   #77
Southernace76's Avatar
Posts: 91   (View Stats)
Southernace76 has a brilliant futureSouthernace76 has a brilliant futureSouthernace76 has a brilliant futureSouthernace76 has a brilliant futureSouthernace76 has a brilliant futureSouthernace76 has a brilliant futureSouthernace76 has a brilliant futureSouthernace76 has a brilliant futureSouthernace76 has a brilliant futureSouthernace76 has a brilliant futureSouthernace76 has a brilliant future
Something sounds fishy man. Check under the hood, do the bolts to your fender or hood have marks like someone took a wrench to them? Did you verify autocheck/carfax history by matching the vin on paper to the car?
I'm not saying its impossible to get a great deal but being one that works in the industry, usually a good deal comes at a price of the car having significant prior repairs or a bad title history.
Based on Manheim (largest auction system in country) these cars are easily doing 16g with those miles. It wouldnt make sense for a dealer to let it go that cheap unless he paid less for one with an announcement such as rollback or frame damage.
Seriously, do your homework fast, take it to a reputable place that wouldn't sell a car with frame damage or knows how to find aftermarket welds and damage. You generally have a short amount of time to get out of the car if its not disclosed.
2010 MS3:
Southernace76 is offline   Reply With Quote
 Old 03-04-2013, 10:19 AM   #78
90210's Avatar
Sorry mate, already bought new set
 Old 03-04-2013, 10:25 AM   #79
90210's Avatar
Morning,
I am sure the deal can sound fishy, but at the end of the day you don't know if the dealer gave the guy 10K on a trade in, or overcharged him 5K on the new car he bought, so they might have had some room.
Couple of other forum members here helped checked the car out for me. You have to understand the location of the dealer, and the inventory they carry, to put into context. Also the car started at 24K. It was 20K in Dec, and didn't sell, as they weren't negotiating.
Sometimes cash money helps
Car is completely stock. It hasn't been painted. I tracked the original owner down, who is a older man at a pretty prestigious job, who was nice enough to mail me all records of the car, some pictures of him and his wife with it, and even sent me the rear parcel shelf free of charge.
As we found out more about the story, chatting with him (since I thought the dealer was BSing me initially), he was out in CA on a 3 month project. Dealer had a used R8, and the guy traded it in on that. I asked him how does he go from MS3 to R8, and the story I got was, this was his daily (makes sense on the miles accumulation in a short time), and he now CFO, and not commuting with his personal car anymore. She he got a R8 to complement his Spyker and 911 Turbo. Prior to the MS3, his daily was a STI from 07-10.
PPI was done on the car. it came back clean. ALl original, no frame damage, no repaint, no issues.
I am happy with it. Given this is car #43 for me, I have had some experience buying and selling some cars
Buying A 2010 Speed3 PoisenSpeed3 Gen2 MS3 General Discussion 13 01-27-2012 04:42 PM
WANTED 2010 MS3 for RSB REVIEW!!! Race Roots Mazdaspeed3/6 General Discussion 1 02-04-2010 08:53 PM
WANTED: 2010 MS3 for Race Roots Prototyping Race Roots Mazdaspeed3/6 General Discussion 14 01-05-2010 06:17 AM
Inside Line editors pick their 'Most Wanted' for 2010 - do you agree? Haltech Automotive News 1 12-03-2009 08:27 PM
Page generated in 0.59893 seconds with 36 queries
