Like Tree2Likes
  • 1 Post By MS3Shadow
  • 1 Post By nekret
 Old 03-20-2017, 07:56 PM   #1
eliwwjd's Avatar
Posts: 488   (View Stats)
eliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond reputeeliwwjd has a reputation beyond repute
Groaned at 61 Times in 34 Posts
Default Cabin air filter question
I was reading through an old thread on cabin filters and I realized that my car has 60K miles and never have changed the cabin air filters. Do you guys recommend sticking with oem mazda part or is there any aftermarket brands you would recommend? Fram,purolator,ecoguard?
I want the best option so price is no problem. If oem is the best way to go, than that's what will do. Thanks in advance for your opinions.
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//CS RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 225/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
eliwwjd is offline   Reply With Quote
 Old 03-20-2017, 08:00 PM   #2
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 281
I got some cabin filter on Amazon. They work good and about $10.
Sent from my Pixel XL
speed3okie likes this.
 Old 03-20-2017, 08:04 PM   #3
nekret's Avatar
Posts: 419   (View Stats)
nekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the worldnekret is the leader of the world
The fram fresh breeze is pretty nice and I'm running one right now. Be prepared to get grossed out at what you've been breathing lol
Sent from my SM-G920V using Tapatalk
Nailedit187 likes this.
2011 Mazdaspeed3 non-tech package
Drivetrain
CorkSport 3.5" MAF & TIP | CP-E FMIC | Synapse BPV | CorkSport EBCS (Interrupt) | Bosch 3 bar MAP | CorkSport HPFP Internals | CP-E Catted Downpipe | CP-E Triton 3" CBE | JBR Stage 2 OCC | Kozmic Primary EGR Delete | JBR Secondary EGR delete | NGK 6510 | TB coolant Bypass | JBR IM & TB Gaskets | Damond RMM, PMM, & TMM | JBR light shift weight | TWM Full Replacement Shifter | Cobb AccessPort V3 | FreekTune
Chassis
JBR Front & Rear Sway Bars | JBR Billet Rear Sway Bar Brackets | Whiteline Adjustable Front&Rear sway bar links | JBR Coilovers | Corksport BBK | Corksport Lower Tie Bar | Corksport Mid Chasis Brace
Rice
LED bumper reflectors | Morimoto LED Fog lights | VLEDs LED Highbeams | Independent Fogs | AP Engine & HPFP cover | CorkSport Pulleys | Corksport Leather Shift Knob | Corksport Steering Wheel | Damond front plate mount | Lukas LK-9750 2ch dashcam | Eonon GA7163 | thespeedline.com blue mirrors | thespeedline.com hood dampers
nekret is offline   Reply With Quote
 Old 03-20-2017, 08:25 PM   #4
Bingo's Avatar
Posts: 698   (View Stats)
Groaned at 9 Times in 7 Posts
I forked out $45 for my "revised" filter from Mazda as part of a TSB. Gen won ftw...
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Moog endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges.
 Old 03-20-2017, 08:28 PM   #5
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 281
Aren't you cool with your fancy mazda cabin filter.
 Old 03-20-2017, 09:08 PM   #6
Bingo's Avatar
It added 20 hp on Vdyno and 2 hot women to the backseat. 8/10 would buy again.
The Following 3 Users Say Thank You to Bingo For This Useful Post:
KiwiFlavor (03-21-2017), MS3Shadow (03-21-2017), WAMBUSHHHH! (03-22-2017)
 Old 03-20-2017, 09:32 PM   #7
Djohns's Avatar
Posts: 3,910   (View Stats)
Groans: 105
I stuck with OEM since it's cheap on Amazon.
2010 black mica speed3
Soon:built motor
 Old 03-21-2017, 01:47 AM   #8
Spectrix's Avatar
Posts: 294   (View Stats)
Spectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the worldSpectrix is the leader of the world
Groaned at 7 Times in 3 Posts
I notice there are activated carbon filters available now too, they are said to remove mould spores and some smoke residues.
I can't attest to how well they perform but they're still cheaper than OEM.
Gen1 -
https://www.amazon.com/Champion-CCF1...bin+air+filter
Gen 2 -
2008 Gen1 MS3
Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires.
Self tuned on E85
Spectrix is offline   Reply With Quote
 Old 03-21-2017, 07:55 AM   #9
crankshaft's Avatar
Posts: 557   (View Stats)
crankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the world
meh, picked mine up at NAPA.
It's a cabin filter for a car, not a dyalysis machine.
2012 MS3, CWP
1986 Buick T-Type, square
crankshaft is offline   Reply With Quote
The Following 2 Users Say Thank You to crankshaft For This Useful Post:
 Old 03-21-2017, 10:23 AM   #10
Varomnia's Avatar
Posts: 387   (View Stats)
Varomnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the world
This is what I have now in my speed 3. Good luck on the install, it can be a pita.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar
Varomnia is offline   Reply With Quote
 Old 03-21-2017, 03:02 PM   #11
mawsdang's Avatar
Posts: 41   (View Stats)
mawsdang is a splendid one to beholdmawsdang is a splendid one to beholdmawsdang is a splendid one to beholdmawsdang is a splendid one to beholdmawsdang is a splendid one to beholdmawsdang is a splendid one to beholdmawsdang is a splendid one to beholdmawsdang is a splendid one to behold
It looks like he has a Gen 2. Way easier than a Gen 1. Should only take 5 minutes.
2013 Gray MS3
COBB AP, JBR OCC Stg. 2, CS SRI/TIP, CS HPFP, CS RMM(70d), CS BPV, CS TMIC, CS Test Pipe, CS RSB, FreekTune OTS+
mawsdang is offline   Reply With Quote
The Following User Says Thank You to mawsdang For This Useful Post:
Varomnia (03-21-2017)
 Old 03-21-2017, 03:10 PM   #12
Varomnia's Avatar
OOOOOOOOH...... yeah. Mine was NOT fun. Cousin has a gen 2 and says the same time, hour later.... still working on my cabin air filter, meanwhile he's replaced 9 at the shop fml.
 Old 03-22-2017, 07:05 AM   #13
hutch13's Avatar
Posts: 7   (View Stats)
hutch13 is an unknown quantity at this point
Guess I got lucky dealership had them for $10.00. They wanted to do the install for more $$ and did it myself.
hutch13 is offline   Reply With Quote
 Old 03-22-2017, 06:24 PM   #14
sheston's Avatar
Posts: 1,844   (View Stats)
I still thought it was a pain to do the GenPu. So everything I took off to get to the filter, stayed off. Weight savings because racecar. At least next time it will be easy to do :-)
The Following User Says Thank You to sheston For This Useful Post:
Varomnia (03-22-2017)
 Old 03-22-2017, 06:42 PM   #15
Varomnia's Avatar
^ Exactly what motivated me to say "fuck it, because racecar" and started stripping all of the interior, purchased a 2nd vehicle for daily and legit is track racecar. Damn cabin air filter, look at what you've turned out to become.
 Old 03-23-2017, 05:15 PM   #16
sheston's Avatar
It's a lot easier to take things off, then to get them back on correctly :-)
 Old 04-05-2017, 08:35 AM   #17
ABOSWORTH's Avatar
Posts: 452   (View Stats)
ABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the world
I've got to do mine as well. I've got 74k on my 2012 and it has never been changed. I took the filters out once and vacuumed them off a couple years ago. Lol. The only reason I didn't replace it was because none of the part stores in my area had them in stock. I meant to order them online but forgot all about it. I'm gonna give my girl a spring cleaning this weekend so I'll do it then. She's pretty dirty right now.
2012 Speed3 - Velocity Red Mica
Current Mods
JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob
ABOSWORTH is offline   Reply With Quote
 Old 04-05-2017, 10:10 AM   #18
KiwiFlavor's Avatar
Posts: 2,413   (View Stats)
Who doesn't like a dirty girl?
2012 NASA Spaceship Gray MS3
ABOSWORTH (04-06-2017)
 Old 04-05-2017, 06:24 PM   #19
downs's Avatar
Posts: 60   (View Stats)
downs is a jewel in the roughdowns is a jewel in the roughdowns is a jewel in the rough
Someone had did my Gen 1 before me. Left out some key screws that made it much easier. I've changed a few cabin filters on newer cars. Definitely stick to the OEM change intervals, cause those things gets dirty as hell, as for brand. Eh pick one. I picked one up from Autozone and it fit fine.
2008 MS3 (stock)
2004 Suzuki VSTROM 650 (the "HMMWVSTROM")
downs is offline   Reply With Quote
 Old 04-05-2017, 08:41 PM   #20
Varomnia's Avatar
When there's two of them... in a cup.
The Following User Says Thank You to Varomnia For This Useful Post:
KiwiFlavor (04-06-2017)
How to Change your CX-7 Cabin Filter Raider CX-7 > How-To's 10 01-04-2015 08:33 AM
Stupid Cabin Air Filter Question damianinpa MazdaSpeed 6 - How-To's 20 05-29-2010 08:23 AM
anybody install cabin air filter yet? gsrtype1 MazdaSpeed 3 - How-To's 46 03-11-2010 07:29 AM
Page generated in 0.39484 seconds with 33 queries
