Like Tree4Likes
  • 2 Post By Db09ms3
  • 2 Post By Fstrnyou
 Old 04-03-2019, 05:27 PM   #1
Suzkuz's Avatar
Posts: 10   (View Stats)
Suzkuz is an unknown quantity at this point
Default Can anyone tell me what this might be?
I scoping out a 2013 ms3 and noticed what appears to be an orange switch in one of the pictures.
It doesn't look stock and I haven't seen it in any other cars. Usually the spot is vacant.
So anyone know what it is or what aftermarket stuff that spot is commonly used for?
Suzkuz is offline   Reply With Quote
 Old 04-04-2019, 05:35 AM   #2
Police - Grammarhead
Vansquish's Avatar
Groans: 1,862
Time to trace some wires.
 Old 04-04-2019, 09:12 AM   #3
deuce_WI's Avatar
Posts: 232   (View Stats)
deuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond repute
Groaned at 6 Times in 2 Posts
Underglow? Rocket Launcher? Light Bar? General Lee Horn?
deuce_WI is offline   Reply With Quote
The Following 3 Users Say Thank You to deuce_WI For This Useful Post:
Pu Manchu (04-05-2019), Thor Hammer (04-05-2019), whatsabrooklyn (04-04-2019)
 Old 04-04-2019, 09:30 AM   #4
Db09ms3's Avatar
Posts: 380   (View Stats)
Groans: 80
Seat dildo?
monkey.bones.007 and danb like this.
Stockish
 Old 04-04-2019, 09:54 AM   #5
Suzkuz's Avatar
Hahaha thanks for the replies guys. I get that it could be anything. I just want to establish that it definitely isn't stock and maybe if it is part of a common kit for something
 Old 04-04-2019, 11:57 AM   #6
rbarnz's Avatar
rbarnz is an unknown quantity at this point
I put a switch to disable the SWAS in that location.
--2013 MS3-- 17x9 RPF1; CS Full 3.5" Intake; Autotech Internals; Grimspeed 3 Port; JBR SSP+CW; JBR Shifter Bushings; SP63 Breather; JBR OCC; DM OCC VTA; DM PCV Plate; DM Trilogy; ATP Turbo DP+RP (Catless); UR Catback w/ Cobb Hangers; JBR EGR Delete; JBR Hood Vent Insert; SSQV VTA; TR8 w/ JBR Under Route; CS HPSS Fuel Line; CS Adjustable Short Shifter; CS Interior Kit; CS IM & 72mm TB; DO DVC 30 w/ single D14 (50/50); CS Battery Box (ECU Relocate); CS Gauges (Triple A Pillar); BNRS4v3; Cobb IWG Bracket; CPE Exhaust Manifold; Tial MV-R 44mm Screamer; 3 Bar MAP; Cobb AP; STuned on E30
rbarnz is offline   Reply With Quote
 Old 04-04-2019, 05:51 PM   #7
whatsabrooklyn's Avatar
Posts: 78   (View Stats)
whatsabrooklyn is a splendid one to beholdwhatsabrooklyn is a splendid one to beholdwhatsabrooklyn is a splendid one to beholdwhatsabrooklyn is a splendid one to beholdwhatsabrooklyn is a splendid one to beholdwhatsabrooklyn is a splendid one to beholdwhatsabrooklyn is a splendid one to behold
does it have a subwoofer or aftermarket lights
@deuce_WI; or rocket launcher as noted from before..
whatsabrooklyn is offline   Reply With Quote
 Old 04-04-2019, 09:04 PM   #8
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,957   (View Stats)
Groans: 541
no one could tell you exactly what it is cause it's not a kit, and none of us built that car.
but if i had to guess... it's a swas disable, or if you're lucky its an electric cutout.
94 M
06 MS6
 Old 04-05-2019, 10:14 AM   #9
Fstrnyou's Avatar
Posts: 2,383   (View Stats)
It's clearly a ZZB immunity switch.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 04-05-2019, 02:13 PM   #10
Suzkuz's Avatar
I'm going to check out the car tomorrow and the guy told me that there were "no mods". So either it's something innocuous or he's gonna put his arms up and say "Always been there, doesn't seem to do anything".
 Old 04-05-2019, 04:02 PM   #11
Fstrnyou's Avatar
Originally Posted by Suzkuz View Post
"Always been there..."
It does something. My comment stands until proven otherwise. Engine runs, so by some strange association, it's for ZZB prevention.
Other rides:
History:
 Old 04-05-2019, 05:06 PM   #12
rbarnz's Avatar
When you go to check it out, if you start it up and have no lights on the dash then flip that switch and the power steering and DSC lights come on its a SWAS disable.
 Old 04-15-2019, 08:43 AM   #13
crankshaft's Avatar
Posts: 573   (View Stats)
crankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the world
Well it aint the smoke screen...that button is under the throttle pedal.
2012 MS3, CWP
1986 Buick T-Type, square
crankshaft is offline   Reply With Quote
Page generated in 0.32496 seconds with 27 queries
