Like Tree9Likes
 Old 08-10-2011, 12:28 PM   #41
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
DONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the world
Groans: 266
Groaned at 83 Times in 60 Posts
Originally Posted by NinjaT1985 View Post
It's not that I didn't read what I wanted to. I guess it kinda gets on my nerves that Mazda knew that enthusiasts were going to "mod" this car and yet they went cheap on the some of the most important parts that make modding possible. I know its to be "cost effective" and such and that is why these cars are very reasonably priced for what you get... but still
dude you bought a 22k dollar car, what do expect from it. I believe mazda did a pretty good job with the amount of power and handling we get stock. If you want to keep whinning 247----> cause no one here wants to hear it. Modding cost money and the further you go the it gets more expensive. Are you going to whine cause a bt is 1600 bucks?
Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next.
DONOTBUGME is offline   Reply With Quote
The Following 2 Users Say Thank You to DONOTBUGME For This Useful Post:
Ckmazdaspeed3 (08-12-2011), manelscout4life (08-11-2011)
 Old 08-10-2011, 12:40 PM   #42
Karmat's Avatar
Posts: 1,179   (View Stats)
Karmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the world
Could have bought a gti and would have needed a fuel pump to make less power. Have to pay to play.
Sent from my DROIDX using Tapatalk
2007 Mazdaspeed 6 (Velocity Red)
2002 Corvette Z06 (Black)
2001 Mazda Millenia S (Brilliant Black) - GONE
Karmat is offline   Reply With Quote
The Following User Says Thank You to Karmat For This Useful Post:
G26 (08-11-2011)
 Old 08-10-2011, 02:10 PM   #43
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
i don't think catless exhaust is compatible with 8000k HIDs.
it's fun to do bad things
 Old 08-11-2011, 06:48 AM   #44
MS3G35's Avatar
Posts: 1,536   (View Stats)
MS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the world
Groans: 80
If you wanted your car to be loud you should of bought a honda with a fart can on it.
CS SRI, TIP, SBT & BPH, BPV, SECBE/CP-e RMM, Catted-DP, TMIC/JBR SSP s2, RSB, TMM/AT Internals/Cobb AP/H&R springs/NGK plugs/SPC camber arms/MB Weapon rims/Pending install: Sure TIGS
285whp/321wtq-93
E85 tune in progress
MS3G35 is offline   Reply With Quote
 Old 08-11-2011, 07:13 AM   #45
f-castrillo's Avatar
Posts: 1,342   (View Stats)
DP will throw a CEL, regardless of what fuel pump you're running. When you have an upgraded downpipe installed, logged fuel pressure dropping under 1600 psi is your main concern. The Gen2's ECU logic causes fuel pressure to drop even more if it dips under 1600 psi. When at WOT, you ideally want fuel pressure to hold at 1700-1800 psi. Some people's fuel pumps are able to hold on with full bolt-ons, while others give out early in the mod process.
 Old 08-11-2011, 07:15 AM   #46
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
Not all gen2 DP's throw CEL's. I have a Cobb DP and zero CEL issues.
The Following User Says Thank You to adlpb For This Useful Post:
f-castrillo (08-11-2011)
 Old 08-11-2011, 07:37 AM   #47
TRex's Avatar
Posts: 3,139   (View Stats)
TRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the worldTRex is the leader of the world
Groaned at 106 Times in 69 Posts
i will buy the DP from you once you blow....send me a pm when you do
TRex is offline   Reply With Quote
 Old 08-11-2011, 08:49 AM   #48
punisherB273's Avatar
Posts: 181   (View Stats)
punisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond reputepunisherB273 has a reputation beyond repute
Groaned at 9 Times in 7 Posts
i have been on this forum for less than 2 months and i knew the answer to this question as soon as i read the title. there is a thread that talks about it being dangerous to run a test pipe and intake on stock tune and cdfp. why would a downpipe be ok? the people that tell you it will be ok are the srt4 drivers that run blow off valves and pvc intakes
punisherB273 is offline   Reply With Quote
 Old 08-11-2011, 09:15 AM   #49
I stand corrected. DPs may or may not trigger CELs, but they are, more often than not, related to catalytic inefficiency, unplugged sensor harnesses, and the secondary O2 being too far out of the exhaust stream. I've never heard of a HPFP-related CEL with a new DP.
 Old 08-11-2011, 09:17 AM   #50
adlpb's Avatar
Groans: 669
Right, pretty much any catless DP will throw CEL's on a gen2. The only 2 DP's that I've heard of not throwing CEL's are Cobb and cp-e, which also happen to be the 2 most expensive.
 Old 08-11-2011, 09:21 AM   #51
Just curious, are you running a map based on a COBB Stage2 map? I believe their OTS Stage2 maps have the "inefficient catalytic converter" CEL disabled by default, so that might be the reason you're not seeing a CEL.
With the price you pay for them, I would hope that the COBB and CP-e DPs would be CEL free though, without having to disable it via ATR.
 Old 08-11-2011, 09:27 AM   #52
adlpb's Avatar
Groans: 669
I am running the stage2 OTS map, but I ran it for a few hours with only the stage1 map right after installing the DP and I still got no CELs
 Old 08-11-2011, 09:55 AM   #53
I see, COBB definitely made a good piece then. I wonder if the secondary O2 bung location is a major factor in whether or not the ECU will throw the "innefective cat" CEL, or if it's the product of a higher-flowing cat by itself. I have the CEL disabled on my setup, because supposedly the CEL will show up on cold starts occasionally.
 Old 08-11-2011, 10:11 AM   #54
NinjaT1985's Avatar
Posts: 551   (View Stats)
NinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the worldNinjaT1985 is the leader of the world
Groaned at 33 Times in 10 Posts
ok...
have you guys not read every post and seen that I decided against it and moving on to suspension, oh excuse me... I guess yall just read the posts putting me down and figured yall would chime in as well and be a bunch of followers
2012 Toyota Tacoma
NinjaT1985 is offline   Reply With Quote
The Following User Says Thank You to NinjaT1985 For This Useful Post:
MS3G35 (08-11-2011)
 Old 08-11-2011, 10:54 AM   #55
Groans: 549
aw, come on big guy! we're having fun here, no?
f-castrillo likes this.
The Following User Says Thank You to jack_hammer For This Useful Post:
f-castrillo (08-12-2011)
 Old 08-11-2011, 10:32 PM   #56
iracer7's Avatar
Posts: 329   (View Stats)
iracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond repute
I've never hit fuel cut and I've got a dp and Hypertech tune. No cel either....
You'll probably do it eventually anyway....just buy the stuff all at once vs 3 separate times and maybe your gf won't be so mad.
Cobb AP, CPE SRI, Cobb Turbo Inlet, Turbosmart Dual-Port BOV, ETS 3.5" TMIC, TRZ Rear Motor Mount, TurboXS Race Pipe, TWM Shifter Bushings, Dabears2k 35W 6000k HID's, Luminiacs 2500k halogen fogs, Putco brake light led bulbs, CPE tow plate, Cobb Springs, OZ Racing Ultraleggara Gold Wheels, weapon r torque damper
iracer7 is offline   Reply With Quote
 Old 08-12-2011, 05:09 AM   #57
NinjaT1985's Avatar
you right... I found the HP for $347 shipped. Now I know that there is not as much to it as an AP but honestly. I don't know a lot about that stuff so the less I can mess up the better lol. Hypertech seems to allow just enough tuning without the chance of the user messing anything up.
2012 Toyota Tacoma
 Old 08-12-2011, 11:15 AM   #58
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
O god, not another hypertech.
The Following User Says Thank You to G26 For This Useful Post:
adlpb (08-12-2011)
 Old 08-12-2011, 03:26 PM   #59
Groans: 549
no he got the hyperpech. it's totally different.
Bucker (08-12-2011)
 Old 08-12-2011, 03:42 PM   #60
adlpb's Avatar
Groans: 669
Is that the version that comes with the stickers that yield 15whp?
 Old 08-12-2011, 04:36 PM   #61
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
ok so no DP for me... I'm not doing all that. Changing FP internals and $500+ for AP. I guess I'm done with engine mods if this is all I can do without going through all that. On to more suspension...
Thanks for those of you who aren't assholes and actually want to help... and offer good advice. Maybe I'll spring for the Hypertech eventually, a lot less and I'm sure I'd be happy with an OTS tune
HT isn't the solution, jackass. The comments above still apply. If you go DP and HT its the same effect, you most likely will need pump internals.
403whp/451ft/lb Dry Shot
 Old 08-12-2011, 05:18 PM   #62
clowncar's Avatar
Posts: 994   (View Stats)
clowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the worldclowncar is the leader of the world
Groaned at 23 Times in 15 Posts
Why is this guy so mad?
I drive an old RX-7 because I like breaking down a lot.
clowncar is offline   Reply With Quote
Page generated in 0.42288 seconds with 31 queries
