![]() | | #1 | ![]() |
![]() Join Date: May 2015 Location: NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 67
(Thread Starter) | Not Ranked : 0 score Started her up, idled her for a bit, then did a couple small pulls. The LTFT's are shit because I've driven 100+ miles on a leak, but the boost peaked at 18.17 (surprisingly) and the STFT's look good. AFR's though...wtf? Does this indicate there's still a leak somewhere? And thankfully.....HPFP looks good Only mods are JBR CAI, JBR TIH, Cobb AP v2, S-OTS tune. Thanks err'body
__________________ RIP 2006 MS6:: CP-E CAI // 3" CP-E TIP // SU Turbosmart BPV // M2 3" Catless DP // Cobb AP v2 //CP-E Rear Motor Mount // JBR SSP //JBR OCC // 1" Springs // EGR Unplugged // JBR Coolant Bypass // JBR TIG 2010 Genpu:: JBR SRI // JBR TIH // SU Turbosmart Full Recirc BPV // Cobb AP v2 // S-OTS Tuned // RallyArmor UR |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
Groans: 79
| Not Ranked : 0 score Did you unhook the battery after fixing the leak to reset the trims?
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines |
| The Following User Says Thank You to [R]usty For This Useful Post: | tmaiorca (09-29-2016) |
![]() Join Date: Mar 2011 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| Not Ranked : 0 score Didn't see the log
__________________ Max Bolted and Built Stock K04 |
![]() | | #4 | ![]() |
![]() Join Date: Mar 2015 Location: Norcross, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 45
| Not Ranked : 0 score *looking for a log* where it at doe??
__________________ I'm stock bro. |
![]() | | #5 | ![]() |
(Thread Starter) | Not Ranked : 0 score For the logs purposes, no and I should have. I reset the battery / ecu after the log unfortunately. Yep...im retarded. Didn't upload it and Im at work atm. Will post when i get home. Or even a new one since i reset the ecu / battery after unhooking it to reset trims.
__________________ RIP 2006 MS6:: CP-E CAI // 3" CP-E TIP // SU Turbosmart BPV // M2 3" Catless DP // Cobb AP v2 //CP-E Rear Motor Mount // JBR SSP //JBR OCC // 1" Springs // EGR Unplugged // JBR Coolant Bypass // JBR TIG 2010 Genpu:: JBR SRI // JBR TIH // SU Turbosmart Full Recirc BPV // Cobb AP v2 // S-OTS Tuned // RallyArmor UR Last edited by tmaiorca; 09-29-2016 at 09:01 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #6 | ![]() |
![]() | | #7 | ![]() |
![]() Join Date: Oct 2013 Location: Fort Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 976
Groans: 438
| Not Ranked : 0 score Considering your LTFT's are still staying around +20 after the reset, I would say you still have a leak.
__________________ All good things must come to an end... |
| The Following User Says Thank You to g00s3y For This Useful Post: | tmaiorca (09-30-2016) |
![]() | | #8 | ![]() |
![]() Join Date: Sep 2011 Location: New York City
Rep Power: 916 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 442
Groans: 93
Groaned at 27 Times in 16 Posts
| Not Ranked : 0 score You need to log many more parameters (throttle pedal position, timing, WGDC, load, etc) so that we can really know what's going on, but none of this seems terribly unusual for part-throttle driving. Slight changes in commanded throttle will lead to big changes in AFR along with other potential factors like A/C compressor kicking on, etc. It's possible something's wrong, but it's just as likely everything is fine. Posting your map might help shed some light so we can compare actual AFR to commanded AFR.
__________________ TOTS 2012 Mazdaspeed3, CWP, Tech Package. COBB AccessPort V3, AUTOTECH HPFP Internals, JBR 3" Wide-path SRI+TIP, CP-E TMIC, UR 3" Test Pipe, CP-E Triton CBE, FORGE V2 BPV, DENSO ITV22 Plugs, JBR RMM 88a, JBR OCC, JBR RSB Kit, JBR Solid Shifter Bushings, CP-E Tow Plate, CorkSport ECU Relocation, TSW Nurburgring Bronze 18x7.5 ![]() alphasaur: "Fuck I just beat it to surprise tranny porn. Saw the dick right when I came fml" |
| The Following User Says Thank You to ANITIX87 For This Useful Post: | tmaiorca (09-30-2016) |
![]() | | #9 | ![]() |
__________________ RIP 2006 MS6:: CP-E CAI // 3" CP-E TIP // SU Turbosmart BPV // M2 3" Catless DP // Cobb AP v2 //CP-E Rear Motor Mount // JBR SSP //JBR OCC // 1" Springs // EGR Unplugged // JBR Coolant Bypass // JBR TIG 2010 Genpu:: JBR SRI // JBR TIH // SU Turbosmart Full Recirc BPV // Cobb AP v2 // S-OTS Tuned // RallyArmor UR Last edited by tmaiorca; 09-30-2016 at 11:59 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #10 | ![]() |
(Thread Starter) | Not Ranked : 0 score Could it possibly be my Purge Valve? I've been reading different threads and some mention that as a possible cause. Any way to test to see if it's bad?
![]() | | #11 | ![]() |
![]() Join Date: Jun 2008 Location: Bowling Green, Kentucky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 909
Groaned at 54 Times in 43 Posts
| Not Ranked : 0 score MAF harness has an issue with some cars. Wiggle the black ground wire on the harness and listen for idle change and monitor for AFR/LTFT fluctuations. New MAF sensor also would need to be re-calibrated.
__________________ EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14 ____________________________________________Dragon Slayer _________________________________________________ |
![]() | | #12 | ![]() |
![]() Join Date: Jun 2015 Location: Santa Cruz, CA.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,006
Groans: 211
| Not Ranked : 0 score MAF sensors themselves do not require calibration. Changing intake size diameter does. Maybe that's what you meant?
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles |
![]() | | #13 | ![]() |
Since its the powerpath intake from JBR, to my knowledge and searching it does not need a MAF calibration. As people have mentioned it, it is not required for this setup, which leads me to believe I've still got a leak/problem somewhere.
__________________ RIP 2006 MS6:: CP-E CAI // 3" CP-E TIP // SU Turbosmart BPV // M2 3" Catless DP // Cobb AP v2 //CP-E Rear Motor Mount // JBR SSP //JBR OCC // 1" Springs // EGR Unplugged // JBR Coolant Bypass // JBR TIG 2010 Genpu:: JBR SRI // JBR TIH // SU Turbosmart Full Recirc BPV // Cobb AP v2 // S-OTS Tuned // RallyArmor UR | |
![]() | | #14 | ![]() |
Groans: 93
| Not Ranked : 0 score Every intake needs a MAF calibration. However, if the JBR was on back when your AFRs and fuel trims were fine, then it won't need a change. Can't hurt to clean the MAF sensor and make sure it's tight (along with all other intake clamps/connections).
| Report: Nissan's Ghosn urges Japan's new PM to stabilize yen, patch things up with China | Haltech | Automotive News | 0 | 01-03-2013 05:00 PM |
| Jaguar Land Rover profit margins stabilize amid slowing sales, Tata says | Haltech | Automotive News | 0 | 08-09-2012 12:10 PM |
| Auto market will stabilize in 2010, Moody's says | Haltech | Automotive News | 0 | 11-04-2009 02:10 PM |
| Farley: Ford brand share could stabilize | Haltech | Automotive News | 0 | 01-18-2009 10:10 PM |
| Gasoline prices stabilize; oil continues to rise | Haltech | Automotive News | 0 | 06-27-2008 01:30 PM |
