![]() | | #1 | ![]() |
![]() Join Date: Mar 2014 Location: Atlantic Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 205
__________________ Built |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score I'm not seeing where it says not for stock blocks, just that NVH will be increased. You should be fine on a stock engine, but why do you want to remove it? The main reason I used it was I went with studs on the main and the balance shaft assembly only works when using main bolts.
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
I intended to remove it for the weight (18ish lbs.) and moving weight factors. From what I've read, it allows the engine to take it's revs quicker. Could you explain this " The main reason I used it was I went with studs on the main and the balance shaft assembly only works when using main bolts", a little more for me. This is beyond my pay grade which is why it's going to an engine shop.
__________________ Built | |
![]() | | #4 | ![]() |
(Thread Starter) | Not Ranked : 0 score I just got off the phone with a CorkSport rep. He says they use the expression "stock block" to refer to any engine that hasn't been modified internally. For instance, if you've changed rods and/or pistons etc. then they no longer consider that to be a stock block. That isn't my understanding of a stock block but that did explain what they meant. Now I'm trying to figure out what the earlier post by shamie" meant where he says it doesn't work with studs, only main bolts. "shamie", can you clarify that please. Thanks.
![]() | | #5 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm going with main bolts on my build. I'm guessing length differences on the main studs makes them a no-go with the BSD kit.
![]() | | #6 | ![]() |
![]() Join Date: Mar 2016
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score i went with main studs, since its reusable vs tty bolts for main bolt when i removed mines. dont really see why you cant use it with tty bolts tho, it doesnt interfere, unless i could be wrong. |
![]() | | #7 | ![]() |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score I used Studs on mine and had them shortened so the balance shaft could still be fitted.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
![]() | | #8 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for the feedback guys.
![]() | | #9 | ![]() |
| Not Ranked : 0 score without the balance shaft i cant use any of my mirrors and seems like all my bolts just decides to "get loose baby" sometimes but the chair massage is nice btw |
![]() | | #10 | ![]() |
| Not Ranked : 0 score The studs, as they came from ARP, were too long for the BS - and I wasn't interested in shortening them.
![]() | | #11 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm having the engine balanced and am hoping that'll help off-set the vibration. I've already got fairly stiff motor mounts so ... fingers crossed.
![]() | | #12 | ![]() |
| Not Ranked : 0 score yeah i got mines balance too, but with stiffer mounts you will feel alot of vibes. mostly under 3500rpm, above that, all mirrors are usable. although most people say they cant feel any difference on faster rpm, i felt mine with ACT light weight flywheel, pretty sure with fidanza 11lbs flywheel its faster to go up RPM tho BSD+lightweight flywheel= good combo |
| looking for a engine block for a ms3 help | 03scgt | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 03-09-2010 03:51 PM |
| ENGINE BLOCK????? | VM1 | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-27-2009 11:21 PM |
| Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's | Haltech | Automotive News | 0 | 03-13-2009 03:30 PM |
