 Old 05-12-2019, 07:50 PM   #1
modusoperandi's Avatar
Posts: 309   (View Stats)
modusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond repute
Exclamation Car Sat For 2 Years. Tips?
Basically car sat for 2 years and I am currently barely getting it up and running. Had some issues with the motor and life took over for the worst and wound up not getting any love and just sat in my garage. Now it is running I'm doing all of the fluid changes (oil, trans, brake, ps, etc.) in the next couple of days to get this sucker back on the road after its hiatus. We did a compression test and it all checks out and have been looking at the motor and everything seems in shape. Suspension ride seems like it has not degraded in any way either. Any suggestions on what to possibly check before going balls out again?
modusoperandi is offline   Reply With Quote
 Old 05-14-2019, 07:03 AM   #2
Carskick's Avatar
Posts: 311   (View Stats)
Do you know how much Ethanol was in the gas that was left in it? Ethanol bringing water in would be a potential concern. May be worth draining the tank and refilling with fresh fuel to be sure.
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
 Old 05-14-2019, 08:53 PM   #3
Not even a full tank. 1/4 tank.
Tips For Buying An ATV That's Right For You Haltech Automotive News 0 10-30-2011 04:40 PM
Painting tips? jman46 Wheels & Tires - BLACK 10 03-08-2011 07:56 PM
tips zumin Drag Racing 4 02-19-2011 12:29 AM
SU TP tips..... ZoomByU MazdaSpeed 3 - Engine, Transmission & Driveline 12 09-03-2009 10:20 AM
Page generated in 0.22877 seconds with 21 queries
