CAT BACK? witch cat back makes the least noise? |
stock |
lol. Other than stock Magnaflow or perhaps Cobb. |
cat-back = ~no performance gain. edit: wrong quote @m249saw. ment for @miamispeed3 |
You can always weld a resonator into any CBE to keep it quiet. But, since the airflow restriction is not in the CBE, but further upstream, the only reason to get an aftermarket CBE is for the ricey sound. There are slim to no performance gains to be had. To spend money on a CBE and then muffle the sound kindof defeats the purpose: no net change, but you're out a pile of cash. Spend the money on a good DP instead. Sent from my DROID2 using Tapatalk 2 |
The Magnaflow is actually quieter at higher RPM's than stock, and has a great tone down low. Happy with mine. |
Open downpipe |
That's all very well and good, but why bother with a CBE when it doesn't give you any performance gain and you can't have the car much louder than stock anyway? |
just do the second cat delete. That's supposed to yield some gains, the rest is going to be a waste of cash flow. |
Catless dp, tp, and res delete. Fucking win. |
i took my car to an exhaust shop and had them weld 3" pipe between the stock downpipe and stock muffler. $150 and sounded amazing, no drone but when you got on it it growled like crazy, it was great. |
I can only speak from the experience that I had with my shop, but it is a road that I would not take again unless I was in a pinch. Sent from my iPhone using Fapatalk. |
95 db, HA i cant wait to get a screamer pipe |
There is no point at all in doing a quiet cat-back because you lose your money, you get no performance and for autox it would hurt you even more because it would take you out of DS (stock class) so now you've modded your car for nothing and gonna have to run a different class against guys with a lot more in there cars. Good thing about the MS3 though for AutoX is that they're a lot of different classes you can enter into when doing even small mods. I ran mine in 4 different classes and won them all. |
A good muffler shop will have the right equipment, not some crappy muffler shop that specializes in minivan mufflers though. Sent from my DROID BIONIC using Tapatalk 2 |
Im sure that for a stock turbo it flows just fine. But at the end of the day my mandrel bent SS catback only cost me $330, so its really not that much of a premium (compared to an $800 exhaust). |
3 Attachment(s) Now, i originally tried just measuring with a ruler to show the diameter of the pipe but just the awkward angles under the car were making that difficult. What i did was cut a piece of wire to the OD of the 3" pipe as showed in picture one. I then proceeded to show how much OD was lost in the two main bends, being the two going around the gas tank, by showing the amount of over lap in the wire. Overlap = OD lost during bending, and as you can see about half an inch was lost at each of those two bends, with the shallower bends towards the rear of the car being less. Now we all know that the stock 2.5" piping flows enough for the stock turbo because a full catback will yield just a few horsepower, and i may be eating my words here next week when i go big turbo but right now im hard pressed to say i wasted my money. For the absolute die hards i will even post my dyno sheet to show how power comes on. Again, my point is not that mandrel bent does not yield more power, just that on this platform, in this application it is marginal and my exhaust going to the stock muffler sounded DAMN good, i just wanted it louder. Sorry for the fuzzy pics, i scratched my phones camera lens a while back, also it seems my dyno pic didnt post and im not going to add another response just for that photo. @Dr. Speed @voltron |
@Voltwings fwiw I just measured mine and the ID of the most pinched section was about 2.6" and your diameter should be around 2.8" based of what you said. So that's not a bad drop in diameter. |
^^ +1 |
| All times are GMT -7. The time now is 04:39 AM. |
