Like Tree3Likes
 Old 06-17-2013, 03:40 PM   #1
[R]usty's Avatar
Posts: 2,204   (View Stats)
[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world
Groans: 79
Default Cleaned my intake valves at 40K miles
Thought I should share my results from the valve cleaning I did this weekend on my pu. Car had 40,000 miles. The cleaning was the biggest pain in the ass item I've done to my speed . Job took 7 hours all said and done. I also cleaned the entire intake manifold and throttle body. They were pretty dirty especially around the butterfly valves. I highly recommend you clean them while they're off. I used nylon engine brushes, a makita drill, shop vac, carburetor cleaner, and chemtool valve cleaner. If you don't have a drill go buy one, it will easily take you double the time without it. If you can, clean the valves with the walnut media, it gets the valves cleaner and requires less work.
Recommendation: Try getting nylon engine brushes that are a little bigger than the intake opening, they clean a lot better.
Tadweezy likes this.
[R]usty is offline   Reply With Quote
The Following 7 Users Say Thank You to [R]usty For This Useful Post:
Dahouse702 (06-17-2013), GARRETHEXTREME (10-24-2013), jack_hammer (06-17-2013), makjur (06-17-2013), Pointless (06-17-2013), SeeMeGovan (06-17-2013), Tadweezy (06-19-2013)
 Old 06-17-2013, 04:42 PM   #2
SeeMeGovan's Avatar
Posts: 945   (View Stats)
SeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the world
Now is a good time to put in a meth kit. :thumbup:
Also, I've heard people express concern about using any sort of brush when doing this for fear of a bristle falling off and later ending up in your engine. Perhaps nylon would just burn up?
Crappatalking on my big-ass phone.
NATOR-WA 'GOVAN'
'07 Sunlight Silver Mica MS3 GT
JBR SRI + TIP + 88a RMM + SSP + SSB + Giant red knob + Reverse lock-out guide
Michelin Pilot Sport A/S 3 215/45 R18 | Damond OCC | ebay Catless TP
Defi Red Racer 52mm boost gauge | Torque Pro Android App Dash Install
ebay All white LED bulbs + Custom LED strip hatch lights | 15% Tint + 5% Visor
Pending installs: JBR EGR Delete + TB TIG | Stealthbox w/ Kicker & amp | Ford magical tranny jizz
SeeMeGovan is offline   Reply With Quote
 Old 06-17-2013, 05:02 PM   #3
[R]usty's Avatar
Groans: 79
Saw some bristles fall off but I got all of them out. Valves provided a good seal so I'm confident nothing went through. I think nylon would burn up if it did end up in the motor. I sprayed each valve entry with carb clean a couple times over then sucked them dry with my vac. Didn't see anything left over after inspection.
The Following User Says Thank You to [R]usty For This Useful Post:
 Old 06-17-2013, 05:44 PM   #4
pmartz16's Avatar
Posts: 1,140   (View Stats)
pmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the worldpmartz16 is the leader of the world
Groaned at 18 Times in 4 Posts
Notice any driveability changes? I'm getting ready to do mine once I get my powder coated intake manifold and valve cover back.
2008.5 Mazdaspeed 3 BM - Built BT Realgib3 Tuned
2014 Mz3 MG
pmartz16 is offline   Reply With Quote
 Old 06-17-2013, 05:54 PM   #5
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Agent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the world
Groans: 665
Groaned at 76 Times in 40 Posts
Damn right...I needs to get one of them walnut pistols!
Agent_Orange is offline   Reply With Quote
 Old 06-17-2013, 05:57 PM   #6
JgamB's Avatar
Posts: 2,566   (View Stats)
I'm hoping that getting on the corn at 3.5k miles will remove this from my future to-do list.
 Old 06-17-2013, 06:02 PM   #7
Voltwings's Avatar
Posts: 3,713   (View Stats)
It wont change anything, theres still not any fuel passing over the valves on a DI set up. You'll need some sort of Aux system, be it meth or a 5/6 port.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following User Says Thank You to Voltwings For This Useful Post:
CWP_MS3 (06-18-2013)
 Old 06-17-2013, 06:02 PM   #8
SLOWHATCH's Avatar
Posts: 2,461   (View Stats)
Groans: 274
Voltwings beat me to it and explained better. I'm curious to see what mine look like when i do them again, after cleaning them around 30k and spraying meth from a d07 nozzle. I plan to do them at 50k or sooner.
The Following User Says Thank You to SLOWHATCH For This Useful Post:
Voltwings (06-17-2013)
 Old 06-17-2013, 06:03 PM   #9
Voltwings's Avatar
Originally Posted by SLOWHATCH View Post
Ugh, e85 wont change the way your engine gets it's fuel.
Ninja'd
Past:
-Sold-
-Sold-
Current:
SLOWHATCH (06-17-2013)
 Old 06-17-2013, 06:08 PM   #10
JgamB's Avatar
Lol - we'll just forget I ever said that. I was thinking solvent properties and fuel injectors.
The Following User Says Thank You to JgamB For This Useful Post:
 Old 06-17-2013, 06:10 PM   #11
[R]usty's Avatar
Groans: 79
The valves were not that dirty compared to others I've seen so the differences is not substantial. Idle is the biggest difference, it's a lot smoother than before. My MPG has gone up as well. Pull feels similar but my MAF is showing more airflow and my boost is coming a bit quicker. Throttle response is better as well. Probably freed up 5-10 HP.
Polishing those intake inlets would probably free up way more, as you can see that surface is rough as hell.
 Old 06-17-2013, 06:12 PM   #12
mg446's Avatar
Posts: 276   (View Stats)
mg446 has a reputation beyond reputemg446 has a reputation beyond reputemg446 has a reputation beyond reputemg446 has a reputation beyond reputemg446 has a reputation beyond reputemg446 has a reputation beyond reputemg446 has a reputation beyond reputemg446 has a reputation beyond reputemg446 has a reputation beyond reputemg446 has a reputation beyond reputemg446 has a reputation beyond repute
I would love to get this done as my car has about 60k and is most likely much worse. Some mechanic tried selling me on the motorvac thing and I laughed in his face.
2008 Mazdaspeed3 Sport
| Cobb AP | JBR Dogbone RMM | Corksport Stage 2 SRI+TIP | JBR Shortshift plate | Corksport Shifter Bushings | Mazdaspeed cat-back exhaust | Cobb Access Port stage1+SF+TIH 93 v231 map | H&R Coilovers /w Whiteline endlinks/RSB |
SOLD
mg446 is offline   Reply With Quote
 Old 06-17-2013, 06:13 PM   #13
SLOWHATCH's Avatar
Groans: 274
Pretty sure the ports are rough for a reason.
 Old 06-17-2013, 06:21 PM   #14
Voltwings's Avatar
Voltwings beat me to it and explained better. I'm curious to sew what mine look like when i do them again, after cleaning them around 30k and spraying meth from a d07 nozzle. I plan to do them at 50k or sooner.
You wont need to. I sprayed for like 3k miles (2 gallons of straight meth) before my motor build (motor was built at 55k miles with no previous valve cleaning) and the valves were damn near spotless when the motor was pulled apart.
Past:
-Sold-
-Sold-
Current:
The Following 2 Users Say Thank You to Voltwings For This Useful Post:
SLOWHATCH (06-18-2013), speed23 (06-17-2013)
 Old 06-17-2013, 06:43 PM   #15
speed23's Avatar
Posts: 1,480   (View Stats)
What nozzle size were you runnning? and I assume this was before the direct port setup? Maybe I can avoid a cleaning by spraying more meth...
 Old 06-17-2013, 06:47 PM   #16
Voltwings's Avatar
D07, and since i was on my 3071 at that point, i had the meth start spraying at like 15 psi so i could brake boost. On a stock turbo when the spray start can be as low as 5 - 7 psi and you hit that shit daily driving it probably would take even less time.
Past:
-Sold-
-Sold-
Current:
 Old 06-17-2013, 06:50 PM   #17
mg446's Avatar
So forget the valve cleaning I could just spray meth over a certain period of time and it would clean them out? Certainly much cheaper and preventative for the future.
SOLD
 Old 06-17-2013, 06:53 PM   #18
Voltwings's Avatar
I dont know about cheaper, but yeah im a believer in meth after seeing mine after such a short time, not to mention the performance benefits of methanol. i tuned a local guy and we ran his D07 nozzle wide open just to see what we could do with 100% denatured alcohol, his BAT's went to 20* below ambient (~60* outside, BAT's logged 42*).
Past:
-Sold-
-Sold-
Current:
 Old 06-17-2013, 08:24 PM   #19
Switters's Avatar
Posts: 126   (View Stats)
Switters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond reputeSwitters has a reputation beyond repute
Mine were really bad at 80k on my genwon. I soaked them overnight and then soaked them for another couple hours and it still took forever to get them nice and shiny. Car did run great afterwards. I installed the JBR tigs while I had the tb and im off.
13 BM MS3 Tech-current
JBR
07 CBM MS3 GT-traded
JBRTRMotorsportCorksportHTPTRZDashhawk
fierce invalids home from hot climates.
Switters is offline   Reply With Quote
 Old 06-17-2013, 09:48 PM   #20
mg446's Avatar
Unfortunately I do not have access to the tools/knowledge required to clean the valves so I am trying to look at alternatives as the guy i go to is saying like $2500 to do a valve cleaning which is a travesty. I know it is definitely something that needs to be done on our cars though so somehow I will get it done.
SOLD
 Old 06-17-2013, 10:57 PM   #21
[R]usty's Avatar
Groans: 79
It's not that bad **Boston accent**. Honestly you are just taking bolts off and cleaning pieces of metal. All it is, is a pain in the ass. You could do this whole thing for 150 bucks. All you need is a lot of time and a few tools. I could list everything you need if you want.
 Old 06-17-2013, 11:16 PM   #22
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Wishful thinking. That along with a catch can and blocking off the EGR might help delay the inevitable but the intake valves still get dirty.
If you are not careful you could make things worse.
I have been trying to find a mechanic in the Greater Los Angeles area to do it and my search has come up empty. I would rather pay some ahole $400 rather than doing that again.
Sent via blown passenger side speakers.
Pickles Tune in progress
 Old 06-17-2013, 11:57 PM   #23
Colin1337's Avatar
Posts: 1,330   (View Stats)
Colin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the worldColin1337 is the leader of the world
I need to get around to doing this soon. 74k miles of gunk is in there I'm sure.
Sent via banana
2005 CTS-V
KCCO
2006 Mazdaspeed6 SOLD
COBB AP /|\ 3' Magnaflow CBE /|\ Autotech FPI /|\ COBB SF Intake /|\ NGK plugs /|\ RMM /|\ Megan springs /|\ GReddy RS BOV /|\ Strapped diff /|\ eGay catless DP /|\ BSD 'kit" /|\ PTP oil pan baffle /|\ Custom FMIC /|\ Spin on oil filter conversion
1995 Miata SOLD
Tokiko Illumina Adjustables | FM springs | HardDog M2 rollbar w/Single diagonal | GV rep front lip | Flyin' Miata rear shock mounts.
Colin1337 is offline   Reply With Quote
 Old 06-18-2013, 08:14 AM   #24
mg446's Avatar
Absolutely, I font mind spending a Saturday to do it just let me know what I would need.
SOLD
 Old 06-18-2013, 06:28 PM   #25
Switters's Avatar
There's a how to on the site. It's a great write up listed with everything you need.
JBR
 Old 06-18-2013, 06:30 PM   #26
[R]usty's Avatar
Groans: 79
I've never searched, is there one without the walnut media? Sounds like this guy does not have compressed air.
 Old 06-18-2013, 06:31 PM   #27
Switters's Avatar
I think there are two, one with walnut media and another guy used a drill and wire brushes.
JBR
 Old 06-18-2013, 06:41 PM   #28
Switters's Avatar
how to: clean your valves vol 2
Here's the link to the walnut-less cleaning.
JBR
 Old 06-18-2013, 06:55 PM   #29
SLOWHATCH's Avatar
Groans: 274
After participating in the valve cleaning of a couple 1st gen cars and I feel like this is a much easier task on 2nd gen. Much easier.
 Old 06-18-2013, 08:01 PM   #30
SeeMeGovan's Avatar
After participating in cleaning valves on a couple 1st gen cars, I feel like this is a much easier task on 2nd gen. Much easier.
Is there anything that ISN'T easier on the pu? I know cabin air filters are downright ridiculous on my juan.
NATOR-WA 'GOVAN'
The Following User Says Thank You to SeeMeGovan For This Useful Post:
 Old 06-18-2013, 08:10 PM   #31
93silvergt's Avatar
Posts: 554   (View Stats)
93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world93silvergt is the leader of the world
Groaned at 18 Times in 11 Posts
downright ridiculous? You're doing it wrong then....
Took less than 30 minutes first time ever doing it. Theres a video on exactly how to do it each and every bolt...
2009 Mazdaspeed3 GT
Cobb SRI E4P Short Throw shifter
93silvergt is offline   Reply With Quote
 Old 06-18-2013, 08:13 PM   #32
SLOWHATCH's Avatar
Groans: 274
I would consider the 1st gen cabin filter replacement a PITA for sure. But that's relative compared to other cars. 2nd gen does make it much easier.
SeeMeGovan (06-18-2013)
 Old 06-18-2013, 08:15 PM   #33
soul.survivor's Avatar
Posts: 335   (View Stats)
soul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the worldsoul.survivor is the leader of the world
Groaned at 7 Times in 6 Posts
Mine has 93k on it and has never been cleaned. I figure that's why my idle is a tad bit rough when cold. I've got a box of walnut and a speed blaster waiting for a free Saturday though. I thought about doing TIGs, is it worth it?
2008 CBM MS3
CP-E RMM | JBR 3.5" WP | GTX3071R | JBR OCC + IM TIG | SU TMIC | Turbosmart Compact BPV | Autotech Internals | Cobb AP + TBE + EBCS | NGK 1 Step Colder | TWM Shifter | Hotchkis Sways | Bilstein Sports | Swift SPEC-Rs | SPC Camber Arms | Freektune
soul.survivor is offline   Reply With Quote
 Old 06-18-2013, 08:26 PM   #34
SLOWHATCH's Avatar
Groans: 274
If you are removing the manifold, go ahead and pick up the manifold tig. It's going to give you the most benefit. Then just do the coolant bypass mod on the tb. IMO the throttle body tig is not necessary, since the temperature sensor is located in the manifold anyways.
This should help keep your BAT's noticeably cooler which will help make more hp. So yes, they're worth it.
 Old 06-18-2013, 08:56 PM   #35
Switters's Avatar
They are reusable as well.
JBR
The Following User Says Thank You to Switters For This Useful Post:
SLOWHATCH (06-20-2013)
 Old 06-19-2013, 07:18 PM   #36
RamiLP's Avatar
Posts: 85   (View Stats)
RamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond reputeRamiLP has a reputation beyond repute
Groaned at 10 Times in 2 Posts
i should be doing this on my next oil change, im at 43k miles so far on the car and never cleaned the valves yet, i just need to find the right time to do this job.
2011 Velocity Red MS3 W/Tech
"Technically Fully Bolted" CS sir/tip, Racing Beat CBE, CS TP, UR catted DP, CP-e TMIC, AutoTech HPFP, 1 step colder NGK plugs, Cobb AP stage 2 (+ self tune), Forge V1 BPV, JBR solid shifter bushings, SU RMM, NRG Torque Dampener, DDM 35w 3000k Fogs, LED rear bumper marker, aluminum Polished factory MS3 wheels, replaced stock wimpy horn with a set of Mazda6 dual horn setup.
RamiLP is offline   Reply With Quote
 Old 06-19-2013, 07:42 PM   #37
SeeMeGovan's Avatar
Do you know anybody that stacks multiple tigs?
NATOR-WA 'GOVAN'
 Old 06-19-2013, 07:54 PM   #38
himurax13's Avatar
Groans: 255
Might as well install those TIGs and coolant bypass. I know a few people who would pay for thay service, haha.
 Old 06-19-2013, 09:09 PM   #39
RamiLP's Avatar
lets do it when i finish school, still got 2 more months to go.
 Old 06-20-2013, 12:16 PM   #40
SLOWHATCH's Avatar
Groans: 274
The jbr is able to be stacked but I personally don't know of anyone. If you have the $$ I say go for it.
Cleaned my intake valves polysynth MazdaSpeed 3 - Engine, Transmission & Driveline 154 08-01-2013 07:42 AM
My intake valves on Genpu with 72k miles ztnedman1 Gen2 MS3 General Discussion 9 08-05-2012 04:43 PM
cleaned valves and egr car won't start tddvrrn MazdaSpeed 3/6 - Troubleshoot/Diagnostics 49 06-18-2012 08:15 AM
intake valves with 82k miles, no catch can mrkdspd MazdaSpeed 6 - Engine, Transmission & Driveline 10 04-08-2011 08:55 AM
Page generated in 0.58917 seconds with 35 queries
