-   -   That clunking thunking noise 1st to 2nd (http://www.mazdaspeedforums.org/forum/f544/clunking-thunking-noise-1st-2nd-138718/)
Limeybastard 02-21-2013 09:39 PM
So I normally launch from a dig like a Roo Paul , I generally baby 1st to 2nd gear. However on a couple of occasions if I rev over 3k and then shift to 2nd it sounds as if my engine or tranny fell out the car, a massive bang noise. MY13 owned since new and have driven stick nearly all my life so not a noob. Im thinking perhaps the mounts are loose or too much play in the drive shaft ? Your thoughts appreciated.
Deslin 02-21-2013 09:41 PM
When you say you rev over 3k and shift to 2nd do you mean a hard shift? Sounds like you may need to upgrade your RMM - its the motor hitting the firewall.
Limeybastard 02-21-2013 09:54 PM
Not really hard per Se. 1st upto or around 3- 3.5K rpm then press down clutch pedal and shift to 2nd then bang. I think the noise occurs even before I release the clutch pedal up.
jseams 02-21-2013 09:58 PM
What is a Roo Paul?
... and yes, before I upgraded my RMM and I had just bought the car I was trying to show off and tried to do a "rolling burnout" in 1st and I thought my engine had fallen out. lol
The bang was unmistakable and I replaced the mount a week later and haven't had anything like it since.
Fatguy729 02-21-2013 10:20 PM
Fuck you op. Get a rmm.
Limeybastard 02-21-2013 10:37 PM
Thanks for your constructive post Darling. However I don't fancy a fuck from an aids infested red neck like you tonight. But thanks for asking. ....{sigh}
jtt 02-21-2013 11:32 PM
He was rather harsh in his response, but your question was answered
Buy a RMM and you engine won't be slapping your firewall anymore.
ocmazda3 02-21-2013 11:55 PM
For sure go with the RMM, and the rolling burn out in first gear before the JBR dogbone was a horrible sound
boosted_out 02-22-2013 04:57 AM
That's because you Granny shifting, not double clutching like you should ;)
dsb_chicago 02-22-2013 05:41 AM
Like everyone else is saying, change out the RMM. I drove one with the JBR RMM and the difference was like night and day.
Limeybastard 02-22-2013 07:36 AM
Thanks. But I don't believe the engine slams or even hits the firewall. It's a myth ;-)
Either way will buy a rmm probably the pussy soft one. Or even pussier inserts.
I think you are onto something with the above response. Although there was no wheel spin when the bang occurs.
JBR 02-22-2013 07:41 AM
In before he buys a soft motor mount, destroys it launching the car, and blames the vendor.
PPD369Speed3 02-22-2013 07:42 AM
Don't be a pussy and get a a real motor mount.
Rear Motor Mount 88a Durometer [MZ3MS3MollyRMM] - $100.00 : James Barone Racing, Custom Fabrication
All you need to do it push order. Also this same topic has been covered a good amount of times. So search por favor.
kritz 02-22-2013 07:44 AM
Get these>Trilogy Mount Package 88 Durometer [MZ3MS3TRILOGY8088] - $430.00 : James Barone Racing, Custom Fabrication
And hold on to your bollox!
PPD369Speed3 02-22-2013 07:46 AM
Originally Posted by kritz (Post 1909235)
If he is talking about getting bushings and not even a mount, I don't think his mangina can handle the trilogy.
Easter Bunny 02-22-2013 07:52 AM
Stop making gay threads. And thanks for covering a topic that has been covered a million times. Seriously the i shifted and heard a bad threads are worse than the which bov should I buy threads.
@Raider; isn't there a way to ban op from starting threads? Or changing his interface so clicking start thread sends him to m247?
kritz 02-22-2013 07:57 AM
@Raider; it is time to do that voodoo that you do...
Raider 02-22-2013 08:09 AM
I already trolled the OP when he joined.
It is the rear motor mount.
This OP might suck, buy at least he is not like the brownies in Tampa claiming to be NATOR when they never donated or supported the Hurricane Sandy collections.
Page generated in 0.19768 seconds with 11 queries
