-   -   AP Warranty work;uninstall first? (http://www.mazdaspeedforums.org/forum/f544/cobb-access-port-warranty-work-uninstall-first-103093/)
Mike@Stratified 01-24-2012 12:49 PM
I have to return my AP to Cobb for a warranty (I hope) issue. If I can, should I uninstall it form the car first so I don't lose the OEM map? If I do that, what repercussions will I face from having an intake and TIH installed with the OEM map?
Thanks,
Mike
AZSPEED3 01-24-2012 01:02 PM
I would just keep the map(stage 1) you have on the car now. No reason to go back to stock map(slow). Also you should be able to load up the saved stock map again when you get your AP back if you need to go to the dealer or sell. If you still have doubt call Cobb and ask them.
fortressofcomfort 01-24-2012 01:06 PM
F safe mode/map (unless you have crap fuel pressure like me). Keep stage1 in if it is running well.
BlueStreak 01-24-2012 01:14 PM
Keep the map.
When COBB returns it to you, all original maps/settings/serial number will come with it.
Mike@Stratified 01-24-2012 02:51 PM
My concern is if they replace my AP with a new one. Is the Stage 0 map that comes with the AP identical to the OEM?
p057 01-24-2012 02:56 PM
why didn't you save it to your computer?
Black Metal 01-24-2012 03:11 PM
Why don't you call Cobb and see what they want you to do?
JS + MS3 01-24-2012 03:42 PM
^ This.
Mike@Stratified 01-24-2012 07:11 PM
They said leave it; I left it. Thanks for the replies.
Page generated in 0.17037 seconds with 11 queries
