Like Tree2Likes
  • 1 Post By Jake_MS3
  • 1 Post By mr6
 Old 04-12-2012, 04:32 PM   #1
Clifford's Avatar
Posts: 4   (View Stats)
Clifford has a little shameless behaviour in the past
Default cold air intake
just getting started on my ms3 and was curious if the 09 cold air from cobb would work on my 2012? dont bite my head off for this lol. i have een looking mainly at cobb tuning and found no actual cold air intakes for the 10-12 just the short ram. anything helps thanks
Clifford is offline
The Following User Says NO Thank You to Clifford For This Un-useful Post:
Don06speed6 (04-12-2012)
 Old 04-12-2012, 04:42 PM   #2
Mortose's Avatar
Posts: 2,441   (View Stats)
Mortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the world
Groans: 39
You REALLY need to do some more homework.
2008.5 Metropolitan Grey Mica: Sold
99 miata: sold
2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel
TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat"
Mortose is offline
 Old 04-12-2012, 04:46 PM   #3
Clifford's Avatar
that helps..
Clifford is offline
adlpb (04-18-2012)
 Old 04-12-2012, 04:47 PM   #4
Jake_MS3's Avatar
Posts: 859   (View Stats)
Jake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the world
Since when does COBB make a COLD air intake?
2009 Mazdaspeed 3
Jake_MS3 is offline
The Following User Says Thank You to Jake_MS3 For This Useful Post:
 Old 04-12-2012, 04:48 PM   #5
kpacker51's Avatar
Posts: 1,522   (View Stats)
kpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the world
Groans: 59
Go head over to the GEN 2 section...they have a whole long thread on intakes. And you WILL find different answers.
My advice? I would go with an intake specifically designed for Gen 2. But that's just me.
-Abraham Lincoln
kpacker51 is offline
 Old 04-12-2012, 04:49 PM   #6
Mortose's Avatar
Groans: 39
ok, here is a bone.
Cobb does not make a CAI, only SRI.
and if you look on Cobb's site, you will see that the part numbers for both gen1 and genpu are the same.
99 miata: sold
Mortose is offline
The Following User Says Thank You to Mortose For This Useful Post:
Pseud0logik (04-12-2012)
 Old 04-12-2012, 04:55 PM   #7
Clifford's Avatar
i appreciate the help and advice.
just soaking this up lol
Last edited by Clifford; 04-12-2012 at 04:55 PM. Reason: MSF Database - Automerged Doublepost
Clifford is offline
 Old 04-12-2012, 05:34 PM   #8
Stingray69's Avatar
Posts: 1,197   (View Stats)
Groans: 48
Good Golly..............................
Stingray69 is offline
 Old 04-12-2012, 06:03 PM   #9
Jake_MS3's Avatar
OP can't even spell his location right. Its Clearwater, FL. No space. The fail is great in this one!
Get a Corksport SRI/TIP. If I had to do it all over again, I'd go with this combo just for the price value.
davinspeed3 likes this.
2009 Mazdaspeed 3
Jake_MS3 is offline
ASHMS3 (04-13-2012)
 Old 04-12-2012, 10:19 PM   #10
RdotQelo's Avatar
Posts: 422   (View Stats)
RdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the worldRdotQelo is the leader of the world
I concur. Corksport for the muh fuckin win.
2011 Mica MS3 - AP/Autotech Internals/NGK step colder plugs/UR TBE/CS FMIC/Forge BPV/CS SRI-TIP/JBR RMM 88a/JBR SSP w Bushings/JBR RSB/JBR OCC/Sonic Tuning S3 Coilovers/JBR Camber Arms
RdotQelo is offline
 Old 04-13-2012, 02:55 AM   #11
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
get a corksport cold air box if you are concerned about underhood temps.
and the CS SRI/TIP.
CAI = possible hydrolock = is a motherfucker.
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline
 Old 04-13-2012, 03:38 AM   #12
ASHMS3's Avatar
Posts: 1,362   (View Stats)
ASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the world
Groans: 126
+1 on Corksport
'09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE
ASHMS3 is offline
 Old 04-13-2012, 04:56 AM   #13
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Corksport sri/tip combo, cobb sri, sure aeros sri. Any of these will work. CAI on these cars is a waste, as figured out from my own experiences.
G26 is offline
 Old 04-13-2012, 05:19 AM   #14
mr6
mr6's Avatar
Posts: 67   (View Stats)
mr6 has much to be proud ofmr6 has much to be proud ofmr6 has much to be proud ofmr6 has much to be proud ofmr6 has much to be proud ofmr6 has much to be proud ofmr6 has much to be proud ofmr6 has much to be proud ofmr6 has much to be proud ofmr6 has much to be proud of
and the CS SRI/TIP.
i have an injen cai on my '12. the injen filter curves and points upward at the fender. i'd have to submerge the front end in 4ft of water to hydrolock! add to that impossibility the water repelling "sock" option and the cai = win.
mr6 is offline
 Old 04-13-2012, 06:52 AM   #15
MS3G35's Avatar
Posts: 1,536   (View Stats)
MS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the world
Groans: 80
How is it a win exactly? It doesn't do anymore then the SRI. Either way you look at it the air has to go threw the HOT turbo...
CS SRI, TIP, SBT & BPH, BPV, SECBE/CP-e RMM, Catted-DP, TMIC/JBR SSP s2, RSB, TMM/AT Internals/Cobb AP/H&R springs/NGK plugs/SPC camber arms/MB Weapon rims/Pending install: Sure TIGS
285whp/321wtq-93
E85 tune in progress
MS3G35 is offline
 Old 04-13-2012, 07:18 AM   #16
Rich990's Avatar
^ this, also there is the added chance of hydrolock.
that water repelling sock is still gonna suck up water if its fully submerged.
MSF in South Africa
Rich990 is offline
 Old 04-13-2012, 07:45 AM   #17
SlickDevil's Avatar
Posts: 265   (View Stats)
SlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the worldSlickDevil is the leader of the world
i have been reading a lot here on the forums and for these cars its not worth worrying about hydro lock. just get a SRI + TIP and ull be fine man
2012 CWP | 15% Tint | White Led License Plate Lights | DDM HID 6K | 3K Yellow Fogs | White Ralley Armor Mudflaps | AT Internals |
SlickDevil is offline
 Old 04-18-2012, 05:04 AM   #18
mr6
mr6's Avatar
CAI...COLD air intake. air drawn from the fender well is colder than air drawn from the engine bay. i'm sure some will argue it's not muh of a difference but i'm also sure none of the naysayers have actually bothered measuring the air temp to compare.
at any rate, cold air from the fender well is denser than hot air from the engine bay. denser air means more oxygen per a given volume which equals more power. some feel the increase is not worth the hydrolock risk. if you're stupid enuff to fully submerge the front of your car in 3-4 feet of water then ur dumb ass deserves to hydrolock. otherwise, pay attention to giant lakes of standing water and u'll never have a problem. i've been running CAI's on every car i've owned for the last 20 years and NEVER HAD A SINGLE ISSUE. So, throwing the threat of hydrolock out of the window, CAI is superior in damn near every application. it's simple science. once again, colder air = denser air = more power. is it a huge difference? most times no but considering how power hugry most of us are, i say take every drop we can get. A CAI achieves that...
and as far as HOT turbo...it is not the temp of the turbo that is responsible for most of the air temp increase for the intake charge. this an oversimplified explanation, but the temp increase is a result of compressing the air, exciting the air molecules creates the heat. with a CAI, the air starts off cooler in he first place. therefore, the ultimate temp of the air would be lower after compression when compared to the already hot air drawn by a SRI. again, not a HUGE difference but without actual temp measurement of both systems on the same car on the same day, any guess would be a shot in the dark. but it stands to reason that air IS colder in the fender well vs the stinking hot engine bay.
riddle me this...Is ur car pullin harder in the winter??? Would u agree it's due to air temps????? if so, buy CAI!
durhamsr3407 likes this.
mr6 is offline
 Old 04-18-2012, 05:11 AM   #19
leon78's Avatar
Posts: 2,595   (View Stats)
Meth!
2013 Scion FR-S (Whiteout)
Less parking more racing
leon78 is offline
The Following User Says Thank You to leon78 For This Useful Post:
deadlandxtreme (04-18-2012)
 Old 04-18-2012, 09:38 AM   #20
RIP: November 21, 2012
fortressofcomfort's Avatar
Posts: 862   (View Stats)
Where's that popcorn.... ah yes
Sit back, enjoy the show!
2012 Black Mica MazdaSpeed3
Street creds:
fortressofcomfort is offline
 Old 04-18-2012, 10:18 AM   #21
Darth_Nuruodo's Avatar
Posts: 2,775   (View Stats)
Groans: 88
Honestly, I wouldn't be surprised if no one rises to the bait, this has be ran around over and over and over again, most people are so done with the CAI debate...
Darth_Nuruodo is offline
 Old 04-18-2012, 10:45 AM   #22
mr6
mr6's Avatar
You're absolutly right! I only responded cuz i was directly asked. In the end there's really no debate. Some swear there is no power difference but these guys have no data to back it. To some, the power increase is just not worth it (for cost or hydro). And to some, the science speaks for itself even if the butt dyno feels nothing...to each their own. The End.
oh and no post around here is complete without............SEARCH!
mr6 is offline
 Old 04-18-2012, 01:14 PM   #23
TheRealDefman's Avatar
Posts: 532   (View Stats)
TheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the world
I can't speak for the Cobb, but putting the Injen CAI off of my '08 onto my '12 was a piece of cake... don't even need to remove the front bumper like on the '08.
2012 Black Mica with Tech package.
Chock full of goodies and Dizzy tuned
TheRealDefman is offline
 Old 04-18-2012, 01:21 PM   #24
mzr0818's Avatar
mzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the worldmzr0818 is the leader of the world
Groans: 221
Stirring the pot.....
CAI > SRI
I was ok until 4500 rpm and then Jeff Raped my face
EMWNM 2013
Beating Black women one 5.0 at a time...
2008 mazdaspeed 3 true red
Tuned by Nishan
, 33% E85, GTX3067r Boost?, Yeah I got some., Port and polish manifold, XS power Tubular Exhaust Manifold, Wiesco pistons, K1 rods, L19 head studs, ARP crank studs, Cobb three port EBCS, Forge BPV, CXRacing FMIC with TR8 core, cobb AP V2, EBC redstuff full, DBA 4000 rotors 6x6 slotted, HTP 3" full intake, JBR 88d rmm, JBR 80d pmm, JBR 80d tmm, CNT catted DP, Magnaflow CBE, KMD internals, Koni Yellows, Moog endlinks, Moog lower control arms, OZ ultraleggera 18x8, Mich Pilot Super Sports 235/40/18, Hotchkis RSB, NGK step colder plugs.
Build in progress. Track whore in the making.
mzr0818 is offline
 Old 04-18-2012, 01:22 PM   #25
bigriver's Avatar
Posts: 1,123   (View Stats)
Stock airbox
bigriver is offline
 Old 04-18-2012, 01:23 PM   #26
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
SofaKingAwesome is offline
 Old 04-19-2012, 01:05 PM   #27
mr6
mr6's Avatar
ditto. just pulled half the fender liner off and that was that.
mr6 is offline
Cold air intake vs short ram intake knarfies MazdaSpeed 3/6 - Turbo Induction 3 04-27-2010 04:15 PM
Page generated in 0.47582 seconds with 38 queries
