Like Tree5Likes
 Old 09-22-2014, 11:38 AM   #81
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
The PSS hook really well in dry and even wet conditions. I've driven pretty hard on them when it was raining out and they are very confidence inspiring. They are also very smooth to drive it.
The only thing that I don't like is their soft sidewalls, even the stock dunlops felt better and more responsive when shooting into a turn. As far as performance, despite the soft feel they still handle a lot better than the dunlops. The other downside is they are expensive, but should get some great life out of them.
 Old 09-22-2014, 11:42 AM   #82
Sergeant_M's Avatar
Posts: 504   (View Stats)
Sergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the worldSergeant_M is the leader of the world
I didn't get much life out of the PSS which is why I went with the cheaper DW since I was gonna burn through em anyways. The PSS did have stronger sidewalls than the DW, but the softer sidewalls do make for a more comfortable ride during regular driving conditions.
Sergeant_M is offline   Reply With Quote
 Old 09-22-2014, 11:44 AM   #83
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Softer sidewall helps with traction though. Even with a good compound, a stiff sidewall wouldn't grip as well as if it had some flex to it.
JgamB likes this.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 09-22-2014, 11:50 AM   #84
JgamB's Avatar
Posts: 2,566   (View Stats)
DW + air bags gave me my car back - 2nd gear is dialed down to 22.5psi and hooks most of the time, 3rd gear tapers up to 24.5psi and does great. Rigid sidewall tires were spin city and very frustrating.
The Following User Says Thank You to JgamB For This Useful Post:
Sergeant_M (09-22-2014)
 Old 09-22-2014, 02:46 PM   #85
cuethenoise's Avatar
Posts: 136   (View Stats)
cuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the worldcuethenoise is the leader of the world
Groaned at 6 Times in 2 Posts
Originally Posted by ArmanRus View Post
Either you have wrong tire sizes, or you need to learn how to drive more carefully. I had 225-40s on 8.5-in wheel and never curbed them once. I have 245-40s DW now on the same wheels and the tires definitely bulge out further than the lip.
Yeah I don't know. I have 225 40s on them. The wheel is flush with the tire there is like no lip on them at all. I should have been more careful as well. I only have done it once.
2012 Mazdaspeed3 w/ tech package
Stage 1 Stratified OTS
JBR Powerpath Stage 2
JBR 88a RMM
HPFP internals.
cuethenoise is offline   Reply With Quote
 Old 09-22-2014, 03:26 PM   #86
nilashish's Avatar
Posts: 468   (View Stats)
nilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the worldnilashish is the leader of the world
Originally Posted by Sergeant_M View Post
Does keeping the pressure the same in all wheels allow for a neutral steer?
Yeah with the rsb I prefer to keep the tire pressure the same all around because it gives the car a more neutral feel...to be honest there is no correct answer for the tire pressures its what the driver prefers
nilashish is offline   Reply With Quote
Michelin Pilot Super Sports or Continental Extreme DW? GODspeed7 2010 MS3 - Wheels & Tires 64 01-13-2014 01:44 AM
Extreme Contact DW or Ventus V12? TegRacer324 MazdaSpeed 3/6 - Wheels & Tires 28 06-18-2012 12:21 PM
Continental Conti Extreme DWS pharoh 2010 MS3 - Wheels & Tires 14 02-11-2010 03:10 PM
Page generated in 0.28192 seconds with 25 queries
