  • 1 Post By 802MS3
 Old 04-16-2019, 03:33 PM   #1
Shiftit's Avatar
Posts: 2   (View Stats)
Shiftit is an unknown quantity at this point
Default Coolant?
Ok so I bought a 10 ms3 I know it says fl22 coolant which is blue. It looks like it's just water in there tho? No color and now that it's getting hotter out i notice I'm creeping up in temp especially when at a stop. Has anyone heard of just putting water in? I need to obviously add some coolant but I'm not sure if it's just straight water or some type of extremely light performance coolant or what. I tried searching the forums but wasn't able to actually type into the search and kind of tight on time to look thru all of it. Trying to sell this beast tonight. So just need to know what yalls expierence with coolants or just water. I don't want yo just put the fl22 in and f*** something up.
Shiftit is offline   Reply With Quote
 Old 04-16-2019, 03:41 PM   #2
Db09ms3's Avatar
Posts: 380   (View Stats)
Groans: 80
When in doubt, flush it out.
Zerex Asian (racist) is common here or any 'green' coolant. 50/50 mix is the bee's knees item 9!
P.S. Touch yourself for not searching you lazy ass!
Stockish
 Old 04-17-2019, 05:27 AM   #3
rabble rabble
802MS3's Avatar
Posts: 5,315   (View Stats)
Groans: 221
you can run the majority of fluid as distilled water if you want, might actually handle heat better, but you need some coolant for lubricating the system. I wouldn't run less than 25% water/75% coolant.
+1 to zerex asian coolant, should be available at most auto parts stores.
Db09ms3 likes this.
'08 CWP MS3 w/ T3 3071r
Coolant? Jcjdm37 Gen2 MS3 General Discussion 12 08-30-2014 10:10 AM
Where us my coolant going koston33 MazdaSpeed 3 - Engine, Transmission & Driveline 6 12-02-2012 11:10 AM
Coolant boiling over exhaust in coolant bcmurphy87 MazdaSpeed 6 - Engine, Transmission & Driveline 12 12-15-2010 01:39 PM
coolant phillyb MazdaSpeed 3 - Engine, Transmission & Driveline 26 03-13-2010 05:24 PM
Page generated in 0.24176 seconds with 22 queries
