Like Tree143Likes
 Old 09-05-2013, 11:32 AM   #1
Gringo East's Avatar
Posts: 198   (View Stats)
Gringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the worldGringo East is the leader of the world
Default Corksport Lightweight Lug Nut Failure
This past weekend CCSCC held a two day autocross event on Sunday and Monday. This is what happened on my fourth run on Sunday.
I figured that would be a good introduction to the issue. This post isn't intended to burn CS, but warn anyone with a similar setup. I consider myself very lucky that the car didn't suffer anything more than the apparent damage, and most importantly that no one was hurt.
I like most was stoked when my CS custom UPS box arrived (08/22/13), and even more so when I got the lugs out and into my hands. I think I bragged to everyone I talked to about them, and after reading the directions and some posts. I went right to the local Sears store to pick up a 3/8 ft lb torque wrench(08/23/13). This was a huge leap forward for me. My first set of aftermarket wheels (Konig Illusions 18" x 8") with some really bad ass lugs. I installed my wheels and followed the torquing instructions to the letter (65 ft-lbs and check torquing after 50mi).
I than decided to order a set of JBR 5mm spacers, which arrived the Friday before the event (08/30/13), and I installed them the night before (08/31/13). Now before everyone starts going "why are you running spacers," why not? Is my reply. JBR markets his 5mm spacers just like that other company that shell not be named (SURELY you know who I'm talking about) as not needing extended studs to run them.
Once again I followed CS torquing instructions (65lbs),as well as JBR recommendations for the mileage for re-torquing (i.e. 5,10,15,etc). When I arrived at the event I checked the torquing on the lugs, and then again after my first two runs. It was the forth run that lugs snapped sending my tire flying (again I am very thankful no one was hurt).
So, were does that leave us now...
Well, I'm now going to try and provide you all as much information as I can.
The broken lugs:
The last photo I believe is extremely important. It shows were the weak point is in the two piece lug design. The conical part has a cylindrical shaft of the aluminum with threads in it. This is the piece that snapped from the rest of the lug allowing the wheel to become free.
Now before everyone gets crazy... I did some measurements today through the open end of the lugs with and without spacers using a set of calipers.
From measuring the depth we can then find out how much stud is actually being threaded into the lug. By then using the outside jaws we can get a good visualization of this by deductive reasoning.
Without spacer:
With spacer:
Some other information I can provide (due to Jamie asking if I knew) is the difference in the amount of turns with the lugs. I went a step further, I did it with and without spacers, as well as, the same test on a stock gen pu wheel.
Stock Gen 2 Wheel using Corksport Lightweight Lugs:
Without Spacer: 8 1/2 Turns
With Spacer: 5 1/2 Turns
Konig 18" x 8" Illusion Wheel using Corksport Lightweight Lugs:
Without Spacer: 7 1/2 Turns
With Spacer: 4 1/2 Turns
I believe that information speaks for itself, and I wish I would have noticed how low the turns were with the spacer. I also think it would be unsafe to run these lugs with a stock wheels and spacers. Just my .02. Anyway, the rest of my vehicles suspension is stock and has been so the life of the vehicle (yes I am the first and only owner).
Some other photos I think some would like to see:
Without Spacer:
With Spacer:
In my opinion I believed Corksport should warn its customers of using the lugs with 5mm spacers without using extended studs.
What I've learned:
1. Don't use aluminum lugs.
2. Seriously don't use aluminum lugs.
3. Don't use spacers without extended studs period (my opinion as of now).
Just to give a little after story:
The car was jacked up and we stole a lug from each of the other three wheels. I drove it to the pits, made some adjustments to the damaged wheel well, and drove to a local auto store to get some steel lugs.
When my wife and I got home this is what we did:
And we went back out the next day:
I did remove the rest of the lugs and spacers from the car, and it will stay that way for now.
I hope someone finds this information useful so it doesn't happen to someone else.
Monotonous ONE and rfinkle2 like this.
Gringo East is offline
The Following 68 Users Say Thank You to Gringo East For This Useful Post:
12blkms3 (09-05-2013), adlpb (09-05-2013), Agent_Orange (09-05-2013), alien_sporez (09-05-2013), amggilly305 (09-05-2013), BigRedSpecial (09-05-2013), bob^3 (09-06-2013), breakfstincluded (09-05-2013), cabrone (09-05-2013), cghms3 (09-06-2013), chaser27 (09-05-2013), Chief_Wiggum (09-06-2013), Crarrs (09-05-2013), CWP_MS3 (09-05-2013), Deldran (09-05-2013), donjohnk (09-05-2013), dubdiaz (09-05-2013), Easter Bunny (09-05-2013), El_Diablo (09-05-2013), Fatpig78 (09-05-2013), Hush (09-05-2013), i8urgti (09-09-2013), J'sSpeed3 (09-05-2013), JgamB (09-05-2013), jm211 (09-05-2013), Johnny_Law (09-06-2013), JTMS3 (09-05-2013), jtt (09-05-2013), KCi (09-05-2013), Keko (09-05-2013), KiwiFlavor (09-05-2013), Koke382 (09-06-2013), KusteLokal (09-06-2013), Kyle Undefined (09-05-2013), lilred (09-05-2013), maisonvi (09-05-2013), Masterofnone (09-06-2013), MattJackson86 (09-06-2013), Mauro_Penguin (09-06-2013), MazdaAtenza604 (09-08-2013), mazdaspeeding (09-05-2013), Monotonous ONE (09-05-2013), montyspeed388 (09-05-2013), MS3johanna (09-05-2013), Ms3_Miami (09-05-2013), Nliiitend1 (09-05-2013), nycMS3 (09-06-2013), phate (09-05-2013), Poohster (09-05-2013), rfinkle2 (09-06-2013), ricknm (09-05-2013), robertof (09-05-2013), robry (09-05-2013), SarcasticOne (09-07-2013), Sid3wayS (09-05-2013), silvapain (09-05-2013), smoogs12 (09-05-2013), SpeedRebirth (09-06-2013), Switters (09-05-2013), Sycoa (09-06-2013), TiGraySpeed6 (09-05-2013), uncorked11 (09-06-2013), Voltron (09-05-2013), warlord (09-06-2013), YABBAMZR (09-08-2013), zenit (09-05-2013), ZetaDrift (09-06-2013), [R]usty (09-05-2013)
 Old 09-05-2013, 11:34 AM   #2
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
@Haltech;
07 MS3
The original Genpoo Hater
Chimmike is offline
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
Gringo East (09-05-2013), phate (09-05-2013), rfinkle2 (09-06-2013)
 Old 09-05-2013, 11:38 AM   #3
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Damn, these lugs reduce weight on a whole new level.
Did you sip the potion before you hit the 3 wheel motion?
SofaKingAwesome is offline
The Following 29 Users Say Thank You to SofaKingAwesome For This Useful Post:
abelardo (09-05-2013), Agent_Orange (09-05-2013), Angr-E1 (09-05-2013), CWP_MS3 (09-05-2013), Darth_Nuruodo (09-06-2013), derek13p (09-05-2013), Don06speed6 (09-05-2013), doubleflusher (09-05-2013), Easter Bunny (09-05-2013), El_Diablo (09-05-2013), Gringo East (09-05-2013), gtlaw (09-05-2013), Hanzodurrr (09-06-2013), itzjustme407 (03-26-2014), lilred (09-05-2013), MonstaSpeed6 (09-05-2013), MS3inDC (09-06-2013), MZRSPEED (09-05-2013), nortigid (09-06-2013), Palms (09-05-2013), PatrickInPgh (09-05-2013), Playaj (09-06-2013), Pu Manchu (09-05-2013), pzr2874 (09-05-2013), rfinkle2 (09-06-2013), rwelsh (09-05-2013), Sid3wayS (09-05-2013), Stingray69 (09-05-2013), superskaterxes (09-05-2013)
 Old 09-05-2013, 11:40 AM   #4
Is that why it wouldn't fly... I knew I forgot something.
The Following User Says Thank You to Gringo East For This Useful Post:
SofaKingAwesome (09-05-2013)
 Old 09-05-2013, 11:42 AM   #5
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
I saw all this carnage.
Nice write up gringo. I was glad to see you out the next day.
Did you get into MSM hopefully the fender isn't to much from them to get replaced
Sent from my XT1080 using Tapatalk 4
Damond Built Speed 6
Deldran is offline
The Following 5 Users Say Thank You to Deldran For This Useful Post:
Easter Bunny (09-05-2013), Gringo East (09-05-2013), MS3johanna (09-05-2013), phate (09-05-2013), rfinkle2 (09-06-2013)
 Old 09-05-2013, 11:43 AM   #6
England15j's Avatar
Posts: 1,910   (View Stats)
England15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the worldEngland15j is the leader of the world
3 of mine failed the exact same way but I was Installing my wheels.
Blacked Out 2010 Black Mica MazdaSpeed 3
Performance: Speed Performance 10.6:1 Built motor, CP-e Exhaust Mani, GTX3071, Tial MVR EWG, JBR 3.5" SRI, Cobb AP V3, Autotech HPFP, Guardian Angel,
eBay Downpipe, CP-E Triton CBE, Treadstone TR8L Intercooler, CX Racing FMIC Piping Kit, JBR Crashbar, NGK Plugs, PNP Intake Manifold, CoolingMist WMI system w/failsafe, DM Throttle Body Spacer with Dual D07 Nozzles,
England15j is offline
The Following 11 Users Say Thank You to England15j For This Useful Post:
bob^3 (09-06-2013), ChimmyChong (09-05-2013), Easter Bunny (09-05-2013), El_Diablo (09-05-2013), Gringo East (09-05-2013), Keko (09-05-2013), Koke382 (09-06-2013), MS3johanna (09-05-2013), phate (09-05-2013), rfinkle2 (09-06-2013), ZetaDrift (09-06-2013)
 Old 09-05-2013, 11:44 AM   #7
Code Monkey's Avatar
Posts: 7,681   (View Stats)
Wow, that sucks balls.
I thought it was common knowledge though to run extended studs with spacers.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
Code Monkey is offline
The Following 5 Users Say Thank You to Code Monkey For This Useful Post:
2k4_8 (09-05-2013), Easter Bunny (09-05-2013), Javi (09-05-2013), MS3inDC (09-06-2013), Raider (09-05-2013)
 Old 09-05-2013, 11:45 AM   #8
bhamitgeek's Avatar
Posts: 362   (View Stats)
bhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the worldbhamitgeek is the leader of the world
@nindoja Did yours break going down the road or were you taking off the wheels?
bhamitgeek is offline
The Following 8 Users Say Thank You to bhamitgeek For This Useful Post:
chaser27 (09-05-2013), CWP_MS3 (09-05-2013), El_Diablo (09-05-2013), JgamB (09-05-2013), Kyle Undefined (09-05-2013), Little John (09-05-2013), Nliiitend1 (09-05-2013), rfinkle2 (09-06-2013)
 Old 09-05-2013, 11:46 AM   #9
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Only over 5mm I thought
pzr2874 is offline
The Following 2 Users Say Thank You to pzr2874 For This Useful Post:
Darth_Nuruodo (09-06-2013), El_Diablo (09-05-2013)
 Old 09-05-2013, 11:47 AM   #10
usgiorgi's Avatar
Posts: 649   (View Stats)
usgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the world
Groaned at 44 Times in 10 Posts
Holy shit this is scary.... I wonder how much of it had to do with faulty design and how much of it is not having extended studs..
2009 Nissan 370Z. Turbo and BOV sounds made by the driver via mouth.
SOLD: 2011 Speed3. Black mica w/tech package Cobb SRI, COBB AP, AT internals, OBX racepipe, Corksport RMM, LOUDASS STRAIGHTPIPE CPE TIP
usgiorgi is offline
 Old 09-05-2013, 11:49 AM   #11
I heard anything over 3mm.
usgiorgi likes this.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 09-05-2013, 11:51 AM   #12
Its on my list of things to do. From what I'm seeing online the fenders are at most a couple hundred. The real expense will be the paint.
 Old 09-05-2013, 11:52 AM   #13
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Groans: 261
christ I'm glad you came out fine,
I'm sure CS will do something about this.
I wanted to rock some nice black nuts like the CS ones but went with Mcgard's because from amazon they fit my budget better.
Is the conical part a rotating washer like mcgard's thats meant to prevent scratches?
breakfstincluded is offline
The Following 2 Users Say Thank You to breakfstincluded For This Useful Post:
Gringo East (09-05-2013), rfinkle2 (09-06-2013)
 Old 09-05-2013, 11:53 AM   #14
usgiorgi's Avatar
That's what I've also heard also 7+ turns for the nuts/bolts.
usgiorgi is offline
The Following 2 Users Say Thank You to usgiorgi For This Useful Post:
Code Monkey (09-05-2013), SLOWHATCH (09-05-2013)
 Old 09-05-2013, 11:54 AM   #15
Deldran's Avatar
Groans: 118
Hard to tell a mix of both I would think. Also that turn where the wheel came of was one of the fastest in the course. It was was on a bit of a down slope. And you end up doing a bit a breaking through that corner, at least I did. Which put a lot of weight and force on the outside front tire.
Its hard to tell on the pics but the threads pretty much got ripped out of the lugs.
Deldran is offline
The Following 2 Users Say Thank You to Deldran For This Useful Post:
 Old 09-05-2013, 11:56 AM   #16
naoandlater's Avatar
Posts: 655   (View Stats)
naoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the worldnaoandlater is the leader of the world
Holy shit. @nindoja; your lucky this didnt happen to you at gingerman.
Sent from my DROID RAZR
07 True Red Mazdaspeed 3 GT - Totaled 2/7/2015
15 Soul Red Mazda3s GT HB
naoandlater is offline
The Following 4 Users Say Thank You to naoandlater For This Useful Post:
chaser27 (09-06-2013), Kyle Undefined (09-05-2013), Little John (09-05-2013), Nliiitend1 (09-05-2013)
 Old 09-05-2013, 11:57 AM   #17
Deldran's Avatar
Groans: 118
If you plan on doing any autocross or tracking please don't. Edge sells some nice looking steel lugs go with those. Aluminum is just to soft for me to trust holding all of that force.
Also if you have a shop do any wheel and tire work for you I would bet they will over torque them which will also cause a lot of problems
Deldran is offline
The Following 4 Users Say Thank You to Deldran For This Useful Post:
Agent_Orange (09-05-2013), Easter Bunny (09-05-2013), Gringo East (09-05-2013), MS3johanna (09-05-2013)
 Old 09-05-2013, 11:57 AM   #18
maisonvi's Avatar
Posts: 3,490   (View Stats)
maisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the world
Groans: 75
Hell of a write up man. Good luck getting it sorted out.
Franken Turbo, built motor, meth.
DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more.
"Your signature should just say, I'm the shit." -LynzeC
maisonvi is offline
The Following 3 Users Say Thank You to maisonvi For This Useful Post:
 Old 09-05-2013, 11:58 AM   #19
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I'm interested to hear what @CorkSport; had to say about this. Their site doesn't mention anything about spacers or thread engagement length. Since it's not a steel lug, I'm not sure the old 1.5x stud diameter applies.
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
Deldran (09-05-2013), Easter Bunny (09-05-2013), Gringo East (09-05-2013), MS3johanna (09-05-2013), rfinkle2 (09-06-2013)
 Old 09-05-2013, 11:59 AM   #20
Sideswipe Magnet
Kyle Undefined's Avatar
Posts: 3,378   (View Stats)
Kyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the worldKyle Undefined is the leader of the world
Groans: 332
Groaned at 99 Times in 71 Posts
@nindoja;
I would love to change the world, but they won't give me the source code. // Logic never changes, just the syntax. // To be the best, you've got to beat the best.
Black Mica 2008.5 Mazdaspeed 3 GT // Totaled by 18 wheeler // rfinkle2 pump toon 309 HP - 327 TQ // E85 toon 336 HP - 357 TQ // Too many mods to list
Emerald Green 2002 Miata
Mods:
Koyo 37mm Radiator // Tein Street Flex Coilovers // Flyin' Miata Front and Rear Sway Bars // 949 Racing Endlinks up front // 15x8 949racing 6UL Wheels // Toyo R1R tires // Hard Dog Roll Bar
Waiting list:
Full vinyl wrap
Events:
EMWNM '13'14 // MME '13'14 // MNM '14 // NATOR FL BBQ '13'14
LynzeCs bottom bitch.
I shall call LynzeC my sloot and she will be mine and she shall be my sloot. Come on, sloot. Come on, little sloot.
Kyle Undefined is offline
 Old 09-05-2013, 12:01 PM   #21
Posts: 7,290   (View Stats)
Contacted @CorkSport;
Nator is what it does.
kritz is offline
The Following 12 Users Say Thank You to kritz For This Useful Post:
chaser27 (09-06-2013), Easter Bunny (09-05-2013), El_Diablo (09-05-2013), Gringo East (09-05-2013), Kyle Undefined (09-05-2013), lilred (09-05-2013), Little John (09-05-2013), MazdaBoy2.3 (09-05-2013), nindoja (09-05-2013), rfinkle2 (09-06-2013), silvapain (09-05-2013), smoogs12 (09-05-2013)
 Old 09-05-2013, 12:03 PM   #22
Groans: 261
I haven't had the opportunity yet but, would you trust the stock lug nuts for tracking?
I would have either used stock lug nuts if I had a set of track shoes or like you said looked around at edge, so that's good to know.
And don't worry, I'm from MSF so I use a torque wrench, and I don't let shops touch my car (:
 Old 09-05-2013, 12:04 PM   #23
How much total thread in terms of length was inside the lugs? How much of that were you threading into/was engaged with the spacers?
There are cars that run OEM aluminum lugs such as my 944T but they are a single piece.
Glad no one was hurt.
Lex is offline
The Following 7 Users Say Thank You to Lex For This Useful Post:
Easter Bunny (09-05-2013), El_Diablo (09-05-2013), Gringo East (09-05-2013), Johnny_Law (09-06-2013), lilred (09-05-2013), phate (09-05-2013), rfinkle2 (09-06-2013)
 Old 09-05-2013, 12:04 PM   #24
[R]usty's Avatar
Posts: 2,204   (View Stats)
[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world[R]usty is the leader of the world
Groans: 79
Sorry this happened to you. Glad I didn't go aluminum.
2010 Mazdaspeed3 w/tech
Cobb AP V3JBR Tru 3" Wide PathJBR Boost Tubes & BPV HoseCobb XLE BPVCP-E TMIC ║ UR Racepipe ║ Magnaflow CBEAutoTech InternalsGrimmSpeed EBCS ║ JBR RSBSPC Camber ArmsKW V3 CoiloversJBR IM+TB TIGs & TB BypassJBR SSPE - Focus RMMStopTech Slotted Rotors and EBC Yellow Stuff PadsTechna-Fit SS Brake Lines
[R]usty is offline
The Following User Says Thank You to [R]usty For This Useful Post:
 Old 09-05-2013, 12:05 PM   #25
pwdunmore's Avatar
Posts: 368   (View Stats)
pwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the worldpwdunmore is the leader of the world
I think this has more to do with the lugnut design and materials then spacers, but lets not rule that out of the question.
The size and spacing of aftermarket lug nuts plus the threading type + type of material have a lot to do with the outcome.
I have a feeling the light weight aluminum expanded while on the track due to excessive heat and the fact that there was less thread for it to hang onto with the spacer on helped the lug nut dislodge itself.
The thermal expansion in the light weight aluminum plus the reduced threading probably had something to do with it. All of that would hinder the frictional force holding the lug nut to the wheel stud. Then one hard corner with the weight over that wheel and pop!
pwdunmore is offline
The Following 4 Users Say Thank You to pwdunmore For This Useful Post:
Deldran (09-05-2013), Gringo East (09-05-2013), phate (09-05-2013), rfinkle2 (09-06-2013)
 Old 09-05-2013, 12:05 PM   #26
Deldran's Avatar
Groans: 118
Oh I do to but I can't mount my own tires. And the shop in town I work with always over tighten shit drives me nuts. I have used stock logs nuts for a year auto crossing now. No issues
Deldran is offline
The Following User Says Thank You to Deldran For This Useful Post:
 Old 09-05-2013, 12:11 PM   #27
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
It really sucks you're having problems with your nuts.
No man likes to hear that.
this forum serves 2 purposes
Dash08 is offline
The Following 24 Users Say Thank You to Dash08 For This Useful Post:
3Gee Tee (09-05-2013), 802MS3 (09-05-2013), bob^3 (09-06-2013), breakfstincluded (09-05-2013), Deldran (09-05-2013), dugedug (09-05-2013), Easter Bunny (09-05-2013), El_Diablo (09-05-2013), Gringo East (09-05-2013), jseams (09-05-2013), krazycoble (09-05-2013), KusteLokal (09-06-2013), Kyle Undefined (09-05-2013), lilred (09-05-2013), Little John (09-05-2013), MazdaBoy2.3 (09-05-2013), phate (09-05-2013), pwdunmore (09-05-2013), pzr2874 (09-05-2013), Raider (09-05-2013), rfinkle2 (09-06-2013), smoogs12 (09-05-2013), Stingray69 (09-05-2013), ZetaDrift (09-06-2013)
 Old 09-05-2013, 12:16 PM   #28
Just got off the phone with Joel. He told me about how 3mm spacers on stock studs were the max, about how there is away to measure the width to get how much of the stud needs to enter the lug so it won't break, as well that 5mm spacers + stock studs with steel lugs would have failed as well, also that they have sold hundreds of sets with zero problems, and that if I would like to get another set when they come back in stock that I could get a deal on them.
Hey, I'm done it is what it is.
The Following 11 Users Say Thank You to Gringo East For This Useful Post:
breakfstincluded (09-05-2013), bstover17 (09-05-2013), Deldran (09-05-2013), Easter Bunny (09-05-2013), El_Diablo (09-05-2013), Kyle Undefined (09-05-2013), Mauro_Penguin (09-06-2013), MS3johanna (09-05-2013), phate (09-05-2013), rfinkle2 (09-06-2013), silvapain (09-05-2013)
 Old 09-05-2013, 12:16 PM   #29
Groans: 261
Even black nuts got problems
The Following 6 Users Say Thank You to breakfstincluded For This Useful Post:
Dash08 (09-05-2013), dugedug (09-05-2013), Easter Bunny (09-05-2013), El_Diablo (09-05-2013), Kyle Undefined (09-05-2013), p057 (09-05-2013)
 Old 09-05-2013, 12:18 PM   #30
usgiorgi's Avatar
I'm not sure if this was on the site before this thread, but this is what it states now.
WARNING: DO NOT USE WHEEL SPACERS OR ANY WHEEL THAT ALLOWS FOR LESS THAN 11mm OF THREAD ENGAGEMENT, DOING SO WILL VOID YOUR WARRANTY AND COULD CAUSE FAILURE.
I'd like to add that if this wasn't on the website when you got these, they are liable. If you followed their instructions to the fullest, it is not your fault. I know the air tools part was on there because I was looking into these a few weeks ago, but I'm not sure about the spacers/minimum thread depth.
usgiorgi is offline
The Following 11 Users Say Thank You to usgiorgi For This Useful Post:
bstover17 (09-05-2013), chaser27 (09-06-2013), Easter Bunny (09-05-2013), El_Diablo (09-05-2013), Gringo East (09-05-2013), Mauro_Penguin (09-06-2013), MS3johanna (09-05-2013), phate (09-05-2013), rfinkle2 (09-06-2013), smoogs12 (09-05-2013), superskaterxes (09-05-2013)
 Old 09-05-2013, 12:21 PM   #31
daafisch's Avatar
Posts: 3,553   (View Stats)
Groans: 58
I've been running 5mm spacers with stock studs and gorilla lugs for over a year and half. Over that time I've done 4 track events and probably 20 autocross events. Not a single issue.
daafisch is offline
The Following 29 Users Say Thank You to daafisch For This Useful Post:
3Gee Tee (09-05-2013), bob^3 (09-06-2013), brandonf (09-05-2013), breakfstincluded (09-05-2013), chaser27 (09-06-2013), Easter Bunny (09-05-2013), El_Diablo (09-05-2013), Gringo East (09-05-2013), helmetface (09-05-2013), KusteLokal (09-06-2013), Kyle Undefined (09-05-2013), Mauro_Penguin (09-06-2013), MazdaBoy2.3 (09-05-2013), Micha (09-05-2013), Mike@Stratified (09-05-2013), MS3johanna (09-05-2013), Ms3_Miami (09-05-2013), nindoja (09-05-2013), Nliiitend1 (09-05-2013), nycMS3 (09-06-2013), PapaSmurf (09-05-2013), phate (09-05-2013), rfinkle2 (09-06-2013), rgz (09-05-2013), silvapain (09-05-2013), SLOWHATCH (09-05-2013), smoogs12 (09-05-2013), superskaterxes (09-05-2013), Tokay444 (09-05-2013)
 Old 09-05-2013, 12:24 PM   #32
I believe I lost about three threads with the 5mm spacers + 1mm for the non-stock wheel. Like I said it had 4 1/2 full turns with spacer. I'm not sure if I answered your question or not Lex sorry...
The Following 3 Users Say Thank You to Gringo East For This Useful Post:
Nliiitend1 (09-05-2013), phate (09-05-2013), rfinkle2 (09-06-2013)
 Old 09-05-2013, 12:24 PM   #33
[R]usty's Avatar
Groans: 79
I just noticed these lugs sell for $100 . Got my gorilla's for $25, they look just as good and are probably a lot stronger.
[R]usty is offline
 Old 09-05-2013, 12:25 PM   #34
pwdunmore's Avatar
I don't think the stock ones would have failed since steel doesn't have the same thermal exapansion coeffecient... you need more information to make that statement that the stock ones would have failed.
Mainly because I run 5mm spacers + RPF1's + stock nuts... taking it out to have some fun, wheels + brakes were hot = no issues at all when going around hard corners.
The Following User Says Thank You to pwdunmore For This Useful Post:
 Old 09-05-2013, 12:27 PM   #35
That was definitely not there, and he pretty much told me "sorry I can't be more of a help."
He did not say stock lugs in that comment, he just mentioned any steel lugs.
Last edited by Gringo East; 09-05-2013 at 12:27 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Gringo East For This Useful Post:
El_Diablo (09-05-2013), rfinkle2 (09-06-2013)
 Old 09-05-2013, 12:28 PM   #36
Eth Fiend
phate's Avatar
It wasn't, I have a screen shot of it. Not impressed.
-06 MS6
phate is offline
The Following 31 Users Say Thank You to phate For This Useful Post:
adlpb (09-05-2013), Agent_Orange (09-05-2013), ArmanRus (09-05-2013), bob^3 (09-06-2013), bstover17 (09-05-2013), chaser27 (09-06-2013), CWP_MS3 (09-05-2013), daafisch (09-05-2013), Deldran (09-05-2013), Easter Bunny (09-05-2013), El_Diablo (09-05-2013), Gringo East (09-05-2013), Hush (09-05-2013), KusteLokal (09-06-2013), Kyle Undefined (09-05-2013), lilred (09-05-2013), Little John (09-05-2013), LumberJack (09-05-2013), Mauro_Penguin (09-06-2013), Micha (09-05-2013), mrmonk7663 (09-05-2013), MS3johanna (09-05-2013), ms3rick (09-05-2013), Ms3_Miami (09-05-2013), Nliiitend1 (09-05-2013), pzr2874 (09-05-2013), rfinkle2 (09-06-2013), Sid3wayS (09-05-2013), silvapain (09-05-2013), smoogs12 (09-05-2013), superskaterxes (09-05-2013)
 Old 09-05-2013, 12:30 PM   #37
usgiorgi's Avatar
Well then, they should compensate the damages... They'll fight it, obviously because they sold product which can fail under the instructions they previously provided. If it does not specifically state to not use with aftermarket wheels, then you can use them.
Yes, people will argue common sense, but that's not how our justice system is set up. For better or for worse. And spacers are definitely a foreseeable possibility and their use/lack of use should have been stated in their instructions or warning section.
Especially aftermarket wheels should have been referenced. Since offset is just like using spacers.
usgiorgi is offline
 Old 09-05-2013, 12:30 PM   #38
CorkSport's Avatar
Posts: 3,416   (View Stats)
CorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the worldCorkSport is the leader of the world
I have talked to the OP and hopefully sorted things out. I'll do my best to answer most of the questions I've seen in the last few minutes here.
Based on my measurements:
Stock Wheel thickness (at the hub face): 11.4mm
Stock Wheel Stud thickness ( from rotor face) 24.0mm
Stock Wheel Stud Diameter: 11.8mm
Typically, you want a 1 to 1 ratio for the stud diameter to thread engagement. In this case, that would be 11.8mm
Based on the math, that leaves you approx 0.8mm of wiggle room on a stock wheel with stock lugnuts.
The OP had a wheel approx 1.5mm thicker than the OE giving him approx 11.1mm of thread engagement which is below spec but probably plenty safe (as it has been for the literally hundreds of other customers running our lugnuts). When you add in the 5mm wheel spacer you are now left with only 6.1mm of thread engagement for the lugnuts.
The factory wheel studs are a 1.5mm thread pitch so you would then be left with just 4.0666 threads on which to keep your wheels on. With a steel lugnut and a factory wheel, Mazda would not consider that safe and neither would I.
However, I am very interested to hear what anyone else thinks as I want to be as fair as possible and certainly want to treat people the way I would wish to be treated so please, let me know your thoughts.
Cheers,
Joel
WWW.CORKSPORT.COM
CorkSport is offline
The Following 2 Users Say Thank You to CorkSport For This Useful Post:
Da6d (09-06-2013), Easter Bunny (09-05-2013)
 Old 09-05-2013, 12:33 PM   #39
Deldran's Avatar
Groans: 118
That's to bad out of all the vendors on here I at least expected CS to man up and help out in someway. Maybe not anything monitary but at least an investigation and some more testing on there lugs
Deldran is offline
chaser27 (09-06-2013), El_Diablo (09-05-2013), Gringo East (09-05-2013), Mauro_Penguin (09-06-2013)
 Old 09-05-2013, 12:33 PM   #40
shpeedtree's Avatar
Posts: 52   (View Stats)
shpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud ofshpeedtree has much to be proud of
Hopefully they won't have to recall all these nuts, and people will realize the risk of using spacers, I have seen posts on stance forums that say you're safe with four turns on the lug nuts.
shpeedtree is offline
The Following User Says NO Thank You to shpeedtree For This Un-useful Post:
Hamilton69 (09-06-2013)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f544/corksport-lightweight-lug-nut-failure-154473/
Bullsh*t thread - Page 1016 - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Refback 05-27-2015 10:42 AM
Offical latest automotive purchase thread This thread Refback 01-03-2014 10:51 PM
CORKSPORT LUGNUTS (FAIL) - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Refback 10-31-2013 05:43 AM
CORKSPORT LUGNUTS (FAIL) - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 09-06-2013 11:34 AM
Product Release! ? CorkSport Lightweight Extended Lug Nuts CorkSport CorkSport 26 09-10-2013 10:40 AM
OCC mount failure (help from Corksport?) bigmike CorkSport 6 06-30-2013 01:54 PM
Looking for lightweight bronze wheels Doberman MazdaSpeed 3/6 - Wheels & Tires 19 09-20-2012 12:18 PM
Lightweight 2 peice rotors PDXImportRacer MazdaSpeed 3/6 - Suspension & Brakes 8 09-08-2008 09:10 AM
Page generated in 0.66929 seconds with 42 queries
