corksport SRI filter replacement Hi everyone, its time to replace my filter and im looking to get a k&N replacement.. does anyone know the replacement model number? there are so many sizes i dont want to order the wrong one. Also, anyone have any recommendations for replacement other then K&N? model numbers/links? Thanks so much Haig |
I'm sure you know you just wash and re-oil it right? |
Corksport's filter is a dry flow filter. You could just order another one from them. |
My cs filter was messed up from rubbing in the engine bay, so picked up an amsoil filter. Non washable, but I can clean it with a vacuum |
Pick up an AEM dryflow one, better quality and still a dry filter. Advance Auto Parts: Search Results for aem dryflow If you search I post coupon codes for them occaisionally. |
I pretty sure the filter that comes with the CS intake is an AEM already. |
1 Attachment(s) |
Just get the K&N dry filter and clean it.. Or order a new one from corksport.. It ships to you in 2-3 days. |
-Derrick |
Clean it and re use it. It's FAR superior to k and n. Be smart ffs. Aem dryflow is known as one of if not the best air filters on the market. Also of note is that oil fucks your maf sensor. If given the option (especially with what we flow through that relatively small intake), you should avoid an oil requiring media. |
Cleaned mine today,dirty filter was dirty. BTW it is a CS (AEM) dish soap in a bucket of hot water let soak agitated a few times rinsed and set in the sun to dry. Second time it has been done good as new. |
3 Attachment(s) Quote:
Sent from my EVO using Tapatalk 2 |
Never noticed it says hybrid k&n till now. Sent from my EVO using Tapatalk 2 |
-Derrick |
| All times are GMT -7. The time now is 02:33 AM. |
