-   -   CS CBE Issues (http://www.mazdaspeedforums.org/forum/f544/cs-catback-exhaust-issues-83535/)
Airman3454 06-15-2011 06:33 PM
CS CBE Issues
I installed the CBE today and while trying to put the racepipe on, I noticed that the included gasket does not seem to seem against the stock downpipe. Am I missing something or will this gasket crush to form to the downpipe? I ordered the 80mm Racepipe from CS.
I ended up leaving the cat on for the time being and will install it when I get my HPFP in.
The CBE sounds mean btw!
manelscout4life 06-15-2011 06:35 PM
seem to seam*
CorkSport 06-15-2011 07:06 PM
Give me a call tomorrow, sounds like something is not correct there.
360-260-2675
-Derrick
Airman3454 06-15-2011 07:37 PM
Will do Derrick. It was strange cuz it didnt look like it would seat correctly.
trf5000 06-15-2011 07:39 PM
Where you located? You might have to bend the hangars on the racepipe considerably to get it to fit correctly.
Airman3454 06-15-2011 11:09 PM
The hangers arent the problem. Its the actual gasket..
Airman3454 06-16-2011 03:30 PM
Talked to Derrick at CS today. Informed me that I needed to put the shim onto the DP before I slid the stock gasket back on.
Hopefully I understood this correctly..Derrick if you see this am I correct?
rfinkle2 06-16-2011 05:01 PM
@CorkSport...
Page generated in 0.17096 seconds with 11 queries
