-   -   CS DP(no cat) (http://www.mazdaspeedforums.org/forum/f544/cs-downpipe-no-cat-117593/)
Illusion 06-29-2012 01:28 AM
CS DP(no cat)
hey mazda community
was considering attaching a CS or other downpipe (catless) with racepipe, to my ark exhaust.
I know running catless triggers a cel which i will turn off with the AP
and i have autotech hpfp internals
my questions are........
will it burn it out the turbo?
do i need a special tune or will ots work until i get a special/dyno tune?
do i still need a little backpressure?
will it effect my mpg?
thank you guys in advance for the input i tried searching for this in perticular but had no luck.
Pseud0logik 06-29-2012 02:03 AM
http://www.mazdaspeedforums.org/foru...-thread-99627/
The OTS tune is designed for the COBB downpipe which has one high flow cat, so a custom tune is recommended for a catless downpipe. You do run a greater risk of your turbo smoking with a catless downpipe because of the decreased backpressure, there are a few "fixes" for this like increasing idle, 5w-40 oil, bnoon bolt, or just getting a manly fucking BT. Your MPGs won't negatively suffer, in fact, they will probably improve.
SpdDemon89 06-29-2012 02:19 AM
Originally Posted by Illusion (Post 1485551)
hey mazda community
MY MPG ACTUALLY IMPROVED WITH THE DP AND TP.:love:
surebOOst 06-29-2012 01:28 PM
I run catless down pipe to straight pipe back exhaust and have never had a CEL light from it. If your going to get a DP you might aswell throw out another $100 for a tune to get the max gains from the mods you have! Talk to this guy, he will hook you up! @RichieRichness
Voltron 06-29-2012 09:52 PM
I have it, no problems whatsoever. Once you get a dp, that's when the fun begins.
Page generated in 0.17597 seconds with 11 queries
