 Old 08-13-2019, 12:43 PM   #1
tripppleP's Avatar
Posts: 89   (View Stats)
tripppleP is a glorious beacon of lighttripppleP is a glorious beacon of lighttripppleP is a glorious beacon of lighttripppleP is a glorious beacon of lighttripppleP is a glorious beacon of lighttripppleP is a glorious beacon of light
Groaned at 10 Times in 7 Posts
Default Current CXRacing FMIC opinions
I am researching FMIC. I have recently read several threads on this and still learning the ropes. I see a local deal for a used CXRacing FMIC with pipes for a very reasonable price, $150
Here is a link to the item for sale but used.
Ive read specific threads on this from 2011-16. It sounds like this is a FMIC that works well with stock turbo and the usual SRI, TIP, HPFP upgrades. However, it kind of sounds like there are possibly better options for similar price with protege pipe kits and core on ebay. Also the CX pipes might block the oil dip stick while the protege does not.
I wanted to hear current opinions on the CXRacing FMIC and pipes?
Can I order something closer to $200 total for a FMIC and decent pipes?
Example:
Cheap Core
tripppleP is offline   Reply With Quote
 Old 08-14-2019, 02:17 PM   #2
tripppleP's Avatar
I take it no one uses these any longer.
 Old 08-14-2019, 02:38 PM   #3
Police - Grammarhead
Vansquish's Avatar
Groans: 1,906
If you're going for an aftermarket intercooler, there's very little reason to get a FMIC over an upgraded TMIC unless you're actually drag racing on the regular.
Vansquish is online now   Reply With Quote
 Old 08-14-2019, 02:40 PM   #4
Db09ms3's Avatar
Posts: 500   (View Stats)
Db09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the world
Groans: 96
Stockish
 Old 08-14-2019, 04:04 PM   #5
Bertospeed3's Avatar
Posts: 142   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
My opinion: use the cx racing pipes with a quality core. dont buy that $60 core.
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
 Old 08-14-2019, 08:04 PM   #6
tripppleP's Avatar
Maybe I'm looking into this stuff too much. Idk. It seems they pretty much provide similar benefits with a slight lead to the FMIC. I guess it would be much easier to do a TMIC.
I have heard the pipes are of decent quality. The core from the CX kit seems to be bolt on with no cutting of the crash bar.
And that core I found from someone else on the site's thread but I can't find the thread to see his outcome any longer.
I am in no rush to do an intercooler, but I see deals come and go and love a good deal. If I had the money a few weeks ago I would have bought a Street unit TMIC on eBay but I grabbed a couple other items instead.
Last edited by tripppleP; 08-14-2019 at 08:13 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-14-2019, 10:06 PM   #7
treadstone tr6 should also fit under stock crash bar and it won't have a crazy pressure drop and will flow better.
CP-e TMIC
JBR 88 Duro RMM
 Old 08-16-2019, 11:26 AM   #8
tegxsi's Avatar
Posts: 1,251   (View Stats)
Groans: 87
I feel that there's an inherent flaw in the MS TMIC design. It's just sits too close to the valve cover and restricts the air flow exiting the core. Upgraded TMIC is still an improvement over stock but I always felt it should be performing better given the size of the upgraded cores.
A good FMIC will blow away TMIC. The additional piping creates a little lag but I've accepted that trade-off.
That is my two cents.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 08-16-2019, 01:09 PM   #9
for what its worth, im very happy with the performance of my upgraded tmic
but a fmic for $150 is a no brainer.
CP-e TMIC
JBR 88 Duro RMM
 Old 08-16-2019, 03:33 PM   #10
Varomnia's Avatar
Posts: 459   (View Stats)
Varomnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the world
From what I've looked into, $150 for even a CX racing FMIC+piping is a steal of a deal. I would much rather have a TR6, TR8c/TR8, or TR10 depending on my end game goals but for that price its hard to say no to.
Alternatively, the next cheapest deal I have found would be $300 for TR8 and undersided piping. I think that guy was desperate. Usually can find that for $400+
ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar
Varomnia is offline   Reply With Quote
 Old 08-16-2019, 09:51 PM   #11
tripppleP's Avatar
Well I offered to buy the CXRacing FMIC. We will see what happens. If I don't like it or find its not what I wanted I could always sell it for the same price I guess.
 Old 08-18-2019, 07:15 PM   #12
tripppleP's Avatar
To follow up. I was unable to purchase the FMIC. The girl selling it was communicating with me until I offered to buy it from her. Sometimes buying items online is great and other times it sucks.
 Old 08-24-2019, 06:37 AM   #13
Revolv0's Avatar
Posts: 104   (View Stats)
Revolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud ofRevolv0 has much to be proud of
Just my .02, I’ve ran the cxracing FMIC for 70,000 miles with no issues at all, and I’ve had a freektune for around 60. Great product for the money. I was doing some stop and go traffic and was afraid of tMIC heat soak.
Revolv0 is offline   Reply With Quote
 Old 08-28-2019, 10:58 AM   #14
Dahouse702's Avatar
Posts: 487   (View Stats)
Dahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the worldDahouse702 is the leader of the world
@tripppleP I ran the CXRACING FMIC for a few years as well, im still using the CXRACING piping with my COBB Front Mount Core.
2007 MS3 Black Mica-Totaled @98500 on 09/2014
Current Car...
2009 MS3 Black Mica GT JBR TRU 3.0 Widepath full intake, BNR S3 v1, GS EBCS, 3 BAR , Forge BPV V2, Autotech internals , Denso Itv22, CNT Downpipe, CX-Racing piping with Cobb v2 core, Cobb AP v2, JBR RMM, JBR PMM, JBR TMM, JBR Oil Catch Can, EGR Delete, JBR TIG, Toyota Seals, HTP battery tray, DashHAWK
Zoom Zoom
Dahouse702 is offline   Reply With Quote
CXRacing FMIC Installed MS3_65 MazdaSpeed 3/6 - Turbo Induction 92 02-24-2011 05:51 PM
CXRacing FMIC dkspeed MazdaSpeed 3/6 - Turbo Induction 10 11-16-2010 03:10 AM
Cxracing custom FMIC bcmurphy87 MazdaSpeed 6 - Engine, Transmission & Driveline 11 05-03-2009 10:24 PM
Page generated in 0.33688 seconds with 27 queries
