View Poll Results: How often do you WOT during your daily commute?
0 Times 15 15.79%
1-2 Times 53 55.79%
3-10 Times 25 26.32%
11+ Times 2 2.11%
Voters: 95. You may not vote on this poll
Like Tree9Likes
 Old 07-23-2015, 09:46 PM   #41
rolliepollie07's Avatar
Posts: 817   (View Stats)
rolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond reputerolliepollie07 has a reputation beyond repute
Sho. You give me hope. I'm at 133k and I would like bt.
rolliepollie07 is offline   Reply With Quote
The Following User Says Thank You to rolliepollie07 For This Useful Post:
sho (07-24-2015)
 Old 07-23-2015, 10:36 PM   #42
CMajor's Avatar
Posts: 65   (View Stats)
CMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond reputeCMajor has a reputation beyond repute
A) 34 miles
B) 6-7, depends on traffic on my way to work. Leaving there's no on the highway at 3 in the morning
C)Just under 20K
CMajor is offline   Reply With Quote
 Old 07-23-2015, 10:44 PM   #43
DVM17's Avatar
Posts: 1,283   (View Stats)
DVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the worldDVM17 is the leader of the world
Groaned at 25 Times in 6 Posts
A.) 1.8 miles. Lol
B.) 2 times to and from work. (I let it warm up before I leave so she's prepared)
C.) 127k miles (last 40k on e85) stock engine, gen pu k04
2006 Mazdaspeed 6 (Titanium Gray) : Built, gtx2867r Purple Drank tuned
12.07 @ 116 on 205 snow tires
hunting for 11's on 245's
DVM17 is offline   Reply With Quote
 Old 07-24-2015, 05:51 AM   #44
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Groans: 29
I have a 3076 on stock block with 138k.
 Old 07-24-2015, 06:01 AM   #45
I'm Telly tempted to go bt but I always get nay say. I may do a compression test and go from there.
 Old 07-24-2015, 07:03 AM   #46
Evan9999's Avatar
Posts: 75   (View Stats)
Evan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud ofEvan9999 has much to be proud of
A) 20-25 miles
B) About 4-8
C) 144k
2009 True Red Mazdaspeed3 GT
Mazdaspeed Coilovers, Cobb AP V2, Corksport SRI w/ TIP, Autotech HPFP, Red Line MT-90, TWM Big Type-R Shift Knob,
DBA 4000 T3 Rotors, Carbotech AX6 Brake Pads, Corksport SS Brake Lines, Wilwood EXP 600 Brake Fluid, Synapse BPV,
CXRacing FMIC, JBR Trilogy Mounts (80 duro), JBR .250 Competition Rear Sway Bar, JBR Short Shift Plate
Evan9999 is offline   Reply With Quote
 Old 07-24-2015, 07:25 AM   #47
mazda_axela's Avatar
Posts: 68   (View Stats)
mazda_axela is a splendid one to beholdmazda_axela is a splendid one to beholdmazda_axela is a splendid one to beholdmazda_axela is a splendid one to beholdmazda_axela is a splendid one to beholdmazda_axela is a splendid one to beholdmazda_axela is a splendid one to behold
A.) 2 miles
B.) 0 during that commute to work
C.) Car has 146,000, Motor has 12,000
2007 mazdaspeed3, HPFP, AP V3, CAI, TIH, CBE, JBR RMM.... Oh and a brand new engine cause I went zoom zoom 💣💣💣💣
mazda_axela is offline   Reply With Quote
 Old 07-24-2015, 03:56 PM   #48
Cheapspeed's Avatar
Groans: 29
Fuck compression. I have low compression in cylinder 3 and still reeled in an srt8 challenger the other morning. And I'm the slowest out of the dfw group of BT's.
rolliepollie07 likes this.
The Following 2 Users Say Thank You to Cheapspeed For This Useful Post:
rolliepollie07 (07-24-2015), sho (08-04-2015)
 Old 07-26-2015, 11:08 PM   #49
tgilly3's Avatar
Posts: 110   (View Stats)
tgilly3 is a glorious beacon of lighttgilly3 is a glorious beacon of lighttgilly3 is a glorious beacon of lighttgilly3 is a glorious beacon of lighttgilly3 is a glorious beacon of lighttgilly3 is a glorious beacon of light
A) 6 miles
B)1-2 times
C) 38k miles
I'm all for the Fail Wheel Drive life.
2013 CWP w/ Tech Package, Purple Drank Tuned for 21psi on 91 & E85, stock K04, Intake, HPFP, JBR RMM, Forge v2, TIP, JBR boost tubes, AP v3, Cobb FMIC, Muffler and resonator delete, M2 catless DP, Varrstoen ES2 18x9.5 +22 offset w/ 4cm clinched flares all the way around
tgilly3 is offline   Reply With Quote
 Old 08-06-2015, 10:56 PM   #50
ThOrZwAr's Avatar
Posts: 43   (View Stats)
ThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud ofThOrZwAr has much to be proud of
Groaned at 4 Times in 2 Posts
A) 40 mi round trip
B) 0-1 ish, I'll go 70-80% maybe once and only WOT when logging or at the track
C) 45k
She's babied. I know it.
2012 MS3 - FreekTuned - 93 tune: 332/310 - E25 tune: 377/356
CS Stage II SRI/TIP // CS Turbo // CS EBCS // CS 3.5 MAP // CS HPFP // CS BPV // CS OCC // SU TMIC // ATP Catless Long DP // JBR 88 Duro RMM // Damond PMM/TMM // CS Front Strut Bar // CS Rear Sway Bar // EBC Redstuff Pads // EBC Rotors // Cobb V3 AccessPort // NGK Plugs (step colder)
ThOrZwAr is offline   Reply With Quote
 Old 08-07-2015, 07:50 PM   #51
makjur's Avatar
Posts: 1,313   (View Stats)
Daily driven 2010
A). 10 miles each direction currently
B). 0-2 times.
C). 50k and climbing
°(ಠೆಒಠಿ)°
 Old 09-24-2015, 04:10 PM   #52
motoman's Avatar
Posts: 118   (View Stats)
motoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond repute
A) 65 give or take
B) 4 on average
C) 75k
Cars are made to be driven, in my opinion. The next time I baby a car will be when I'm too fucking old to drive.
Black Mica 2010 Mazdaspeed 3
motoman is offline   Reply With Quote
 Old 09-24-2015, 05:29 PM   #53
superman's Avatar
Posts: 288   (View Stats)
superman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond repute
A) 60 miles one way (this week)
B) 2-5
C) 84k
Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff
superman is offline   Reply With Quote
 Old 10-14-2015, 12:55 PM   #54
EnixStorm's Avatar
Posts: 108   (View Stats)
EnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond reputeEnixStorm has a reputation beyond repute
Groaned at 3 Times in 1 Post
A- 96 round trip
B- 3-5 to 6k
C- 99,111
Cobb SRI :|: Cobb TIP :|: CPE Stg 2 RMM :|: JBR 70 PMM :|: AutoTech Internals :|: AP V3
EnixStorm is offline   Reply With Quote
 Old 10-17-2015, 04:04 AM   #55
shavir's Avatar
Posts: 3   (View Stats)
shavir is an unknown quantity at this point
2010 daily driver
a) 250km
b) 4-5, sometimes more, usually if im running late
c) 130k
shavir is offline   Reply With Quote
Poll: Can Fiat's sexy new ads score during the Super Bowl? [w/poll] Haltech Automotive News 0 12-03-2012 06:50 PM
Poll: Is Dodge smart for dusting off the Dart name? [w/poll] Haltech Automotive News 1 12-12-2011 02:32 PM
Poll: Should Cadillac make the CTS-V go "Supersonic"? [w/poll] Haltech Automotive News 0 07-12-2011 11:10 AM
BPV AND BOV POLL 2010 MS3 2010 MS3 - Turbo Induction 32 02-18-2010 10:37 PM
CAI Poll zamdam MazdaSpeed 3/6 - Turbo Induction 60 08-19-2009 06:32 PM
Page generated in 0.35832 seconds with 33 queries
