Like Tree8Likes
 Old 08-13-2017, 10:23 AM   #1
attomica's Avatar
Posts: 170   (View Stats)
attomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond reputeattomica has a reputation beyond repute
Groaned at 14 Times in 5 Posts
Default Dammit! Cleaned valves, now car won't run.
You may have seen my previous threads relating to my valve cleaning process. Yes, it's been a long time from the beginning, but I'm doing it between work and other life shit. I thought I would finish it up this morning and start it up. All I had to do was install the JBR OCC and the intercooler and then button it up.
I was very careful to put each component back where it belongs. I went back over everything before I even connected the battery. Then I got in, pushed the start button and it started. I got out and went to the back of the car to see if it was smoking (little puff at first, then none). It ran a little rough for about a minute, then it start to stutter, so I rushed back to give it some gas. It died before I could. Now, it just cranks and won't run. FUCK!
What would MSF do?
While I was doing the valve cleaning, I installed a JBR EGR Block kit (not the delete) and the mentioned JBR OCC. Could these be contributing to this problem?
MAXIMUM FRUSTRATION!
2013 CWP w/Tech Package
Performance Autotech HPFP internals / AP v3 / JBR TIP / JBR Powerpath Intake / JBR RMM / JBR shifter bushings / JBR OCC
Sound System Audio Control LC7i / Alpine PDX-V9 / Alpine SPR-60C / Alpine SPR-68 / Alpine SWR-T10 Install thread: http://bit.ly/1o6hf2Z
attomica is offline   Reply With Quote
 Old 08-13-2017, 10:25 AM   #2
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
Try turning car to on a few times to let it prime up. Any codes?
Sent from my SM-N930P using Tapatalk
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
 Old 08-13-2017, 10:30 AM   #3
attomica's Avatar
Nope, no codes. It'll just crank and crank. I don't wanna burn the starter up or run the battery down.
 Old 08-13-2017, 10:32 AM   #4
tmillner's Avatar
No, cycle the key to on a few times. Let it sit at on for 30 seconds or so then do it again
 Old 08-13-2017, 10:42 AM   #5
Djohns's Avatar
Posts: 3,944   (View Stats)
Groans: 112
Maybe your maf sensor needs a good cleaning?
2010 black mica speed3
Soon:built motor
 Old 08-13-2017, 10:43 AM   #6
attomica's Avatar
Cycled to ON, but still no start.
I changed the spark plugs in this process too. I expected it to fire right up.
How do you clean it?
Last edited by attomica; 08-13-2017 at 10:43 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-13-2017, 10:44 AM   #7
Djohns's Avatar
Groans: 112
What did you gap those at? Check coil plug harnesses and make sure they're clean and on all the way.
With maf cleaner. Buy it at any auto parts store.
Soon:built motor
Last edited by Djohns; 08-13-2017 at 10:44 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-13-2017, 10:54 AM   #8
attomica's Avatar
I made sure everything with the plugs was clean and in good shape. I used NGK's Iridium IX LTR7IX-11 and gapped them to .027.
MAF sensor looks clean. Is a visual inspection enough or can it be dirty and you can't tell?
Last edited by attomica; 08-13-2017 at 10:54 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-13-2017, 10:57 AM   #9
Djohns's Avatar
Groans: 112
Yes. There's two spots that need to be cleaned on it. I have a feeling youre looking at the temperature sensor.
Soon:built motor
 Old 08-13-2017, 11:05 AM   #10
attomica's Avatar
Temperature sensor? No, the MAF sensor in the intake duct, right by the SRI air filter is what I looked at.
The car was starting and running fine before I did the valve cleaning process. It doesn't seem like the MAF sensor would cause the no-start condition I'm facing now.
 Old 08-13-2017, 11:51 AM   #11
Jonb82's Avatar
Posts: 416   (View Stats)
Jonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the worldJonb82 is the leader of the world
Groaned at 24 Times in 9 Posts
No. You can leave your MAF unplugged and start the car. It will start but will die out after a couple seconds
Sent while probably pooping
CS TIP/SRI CS RMM CS Sexy Steering Wheel CS Springs & Struts CS Shirt Throw Shifter CS Shifter Bushings CS TBE CS Boost Tubes CP-e TMIC HKS BOV in resirc DM Vented OCC DM TMM DM PMM DM SSP Autotech Internals Custom E33 Freaktune
Jonb82 is offline   Reply With Quote
 Old 08-13-2017, 12:12 PM   #12
attomica's Avatar
Can these cars get flooded? I just checked the spark plugs and they seemed pretty dirty for being in there just for this short period of time and not even running. They smelled heavily of gas too. I brushed them off lightly with a paper towel and tried starting again. It caught for a few seconds, then back to just cranking, but not running.
 Old 08-13-2017, 01:25 PM   #13
Djohns's Avatar
Groans: 112
He said it ran then bogged down and died, could easily be a maf.
There's a temp sensor in the maf sensor as well, it reads the temp of incoming air.
Soon:built motor
Last edited by Djohns; 08-13-2017 at 01:25 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-13-2017, 01:37 PM   #14
attomica's Avatar
I dunno. I have a hard time thinking the MAF sensor is the culprit, but I guess it can't hurt anything to clean it. So, I just get that cleaner and spray it all over the thing in all the little cavities and shit?
 Old 08-13-2017, 01:41 PM   #15
Djohns's Avatar
Groans: 112
Yes so the temp sensor on that is a little piece of metal with what looks to be a little bulb like object at the end, the actual maf sensors are further up the little crevice, you can see them if you look down in the sensor. It might not be the cause but you never know. It's dying and spark plugs smell like gas because it's running extremely rich.
Your next step should be a boost leak test.
Soon:built motor
Last edited by Djohns; 08-13-2017 at 01:41 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-13-2017, 01:49 PM   #16
attomica's Avatar
All I did was clean the valves and install new plugs, EGR block, and OCC. What makes you think a boost leak test is indicated? Is my expectation that it would fire right up and run like a top unreasonable? I'm not ranting at you, brother, just frustrated as hell. I appreciate your thoughts on my issue here.
Bexar likes this.
 Old 08-13-2017, 01:53 PM   #17
tmillner's Avatar
This will Sound insulting but it happened to me before. Start checking fuses. I did an evaporator in an avalon, never ever do this if you don't have to. Had battery disconnected, put everything back together, ecu1 fuse blew somehow.
 Old 08-13-2017, 02:28 PM   #18
PapaBruno's Avatar
Posts: 942   (View Stats)
PapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the world
This.
Turn the ignition on and off about 8 times to let the fuel lines fill.
Sent from my SAMSUNG-SM-G900A using Tapatalk
2012 Crystal White Pearl MS3 - http://i.imgur.com/duln01Z.png
JBR 88 Durometer RMM, Autotech HPFP Internals, COBB Accessport V3, CS Hood Strut Kit, CS Underhood LED Kit, CS Eyelids (painted), BFG CS2s with JBR 5mm spacers, Password JDM Gurney Flap, FREEKTUNE e-Tune, Full Race FMIC, RÄZO RA138 Shift Knob, RÄZO 270mm Convex Rear View Mirror, Rally Armor Limited Ed. Flaps, JBR Stage 2 Short Shifter, NGK One Step Colder Plugs, Ultimate Racing: V3 Down Pipe (w/ Metal Substrate Core), Straight Test Pipe, and CBE, Go Fast Bits Respons TMS Blowoff Valve, CS Injector Seals, DM Stage 1 OCC + VTA, DM EGR Delete Kit, DM PMM, HTP 3.5" Intake, BNR S4, Grimmspeed EBCS, CS 3.5 Bar MAP, Prosport 52"mm Premium Evo Boost Gauge, RÄZO RP81 and RP85 Sports Competition Pedals, AEM Water/Meth Injection Kit, DM TB Spacer, Koyorad Racing Radiator V-Series Core
PapaBruno is offline   Reply With Quote
 Old 08-13-2017, 02:50 PM   #19
attomica's Avatar
Okay, I cleaned the MAF sensor, I checked all the fuses (all are good), and I cycled the ignition to prime several times. Still no start.
 Old 08-13-2017, 02:53 PM   #20
Jonb82's Avatar
Is it flooded?
 Old 08-13-2017, 03:11 PM   #21
attomica's Avatar
Is it flooded?
I've wondered. How can you tell if it is or not?
 Old 08-13-2017, 03:12 PM   #22
tmillner's Avatar
You can always take the plugs out push the clutch in and floor the accelerator like your doing a compassion check. Whatevers in there won't be for long! Put some rags down
Sent from my SM-T587P using Tapatalk
The Following User Says Thank You to tmillner For This Useful Post:
cyclist20 (08-14-2017)
 Old 08-13-2017, 03:13 PM   #23
Jonb82's Avatar
So I'm guessing that it's turning over? Mine got flooded once. Pull the fuse in the engine bay and crank her. Replace fuse and start her up. Don't remember off hand which one it was
 Old 08-13-2017, 03:19 PM   #24
Jonb82's Avatar
Fuck you photobucket btw
 Old 08-13-2017, 03:36 PM   #25
attomica's Avatar
Just pulled fuse, cranked twice for about 10 seconds each, then replaced fuse and tried to start. Same thing...crank, but no run.
 Old 08-13-2017, 04:02 PM   #26
Djohns's Avatar
Groans: 112
I want to say there must be a leak somewhere on the manifold that's letting it run too rich.
Soon:built motor
 Old 08-13-2017, 04:08 PM   #27
Djohns's Avatar
Groans: 112
Or something was left unplugged.
Soon:built motor
 Old 08-13-2017, 04:17 PM   #28
attomica's Avatar
I dunno. I forgot to mention that I used a JBR TIG (thermal intake gasket), so I'm not sure what to think about that suggestion. Arent those TIGs supposed to be good?
 Old 08-13-2017, 04:18 PM   #29
Djohns's Avatar
Groans: 112
Yes those are good, check the vcts box that sits on top of the manifold. There's a little grommet that sits on the bottom post, make sure it's still there.
Soon:built motor
 Old 08-13-2017, 04:19 PM   #30
Jonb82's Avatar
Unless you're at higher power levels. After time they start to fray. These symptoms will not happen unless if user error. Not being disrespectful btw. I've done shit as well
 Old 08-13-2017, 04:21 PM   #31
Djohns's Avatar
Groans: 112
Maybe try to start your car with the gas petal all the way down. It won't start, but that helps prime the system. Plus you may be able to throw a code that way to have a direction figuring this out.
Soon:built motor
 Old 08-13-2017, 04:51 PM   #32
attomica's Avatar
All good things to look at. I'm so grateful for you guys' help, but I gotta let go of this for the day. I'll check the grommet and do the pedal thing and get back to this thread soon, hopefully. This forum's the best and you guys have been great.
Jonb82 likes this.
 Old 08-13-2017, 05:11 PM   #33
PapaBruno's Avatar
Did you plug the MAP sensor back in?
 Old 08-13-2017, 07:34 PM   #34
attomica's Avatar
Of course.
 Old 08-14-2017, 09:40 AM   #35
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Not to get off topic but I had (what I think is) a grommet fall when changing plugs. Small, metal, had no clue if important or where it goes.
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 08-14-2017, 10:42 AM   #36
cyclist20's Avatar
Posts: 636   (View Stats)
cyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the worldcyclist20 is the leader of the world
I assume the OCC valve is closed? Just an easy check and I and a many others have left it open before.
Also, did you get any b12 or whatever you used in the chambers when you cleaned? I got some in mine, did the plugs out, gas down start to blow the liquid out.
Also, is the plastic arm the VCTS intact, cracked, broken, etc. I would think it would throw a code but maybe not.
2013 LSM Speed BNR S3v3
AP V3
Corksport: HPFP Internals, Injector Seals, bpv, battery box, intake manifold
Full Race: Exhaust Manifold, ceramic coated for lovliness
CNT:Catted DP
Treadstone TR8 with Cobb piping
CP-e: Stage II RMM
HTP:3" intake
Stratified: 3port, Guardian Angel
JBR RSB, Shifter Bushings, EGR Delete/Blockoff
Matt Damond:OCC, PMM, TMM
UR Axleback
Rice: Corksprt CF Hoodscoop & Spoiler // 12mm spacers // Bayson R lip // Bayson R GV grill // Okiefam powercoated VC, coil, and HPFP covers
Tuned by PURPLE DRANK
cyclist20 is offline   Reply With Quote
 Old 08-14-2017, 10:49 AM   #37
Djohns's Avatar
Groans: 112
Couldn't tell you. The grommet I'm talking about is rubber and sits under the VTCS box which you wouldn't have touched.
Soon:built motor
The Following User Says Thank You to Djohns For This Useful Post:
Bexar (08-14-2017)
 Old 08-14-2017, 06:03 PM   #38
attomica's Avatar
Thanks for your suggestions. Yep, OCC is closed. I used denatured alcohol, not B-12, but I didn't get any in the cylinders either way. The VCTS set-up is all intact and in good shape.
The Following User Says Thank You to attomica For This Useful Post:
 Old 08-14-2017, 06:07 PM   #39
Djohns's Avatar
Groans: 112
Did you try removing the spark plugs and starting it to ensure the cylinders are clear?
Soon:built motor
 Old 08-14-2017, 06:33 PM   #40
attomica's Avatar
No, I haven't done that. You think it'll make a difference?
VAlves cleaned car wont start now Jdraps13 2010 MS3 - Troubleshoot/Diagnostics 51 01-17-2015 09:18 PM
Cleaned my intake valves polysynth MazdaSpeed 3 - Engine, Transmission & Driveline 154 08-01-2013 07:42 AM
cleaned valves and egr car won't start tddvrrn MazdaSpeed 3/6 - Troubleshoot/Diagnostics 49 06-18-2012 08:15 AM
cleaned valves and egr car won't start tddvrrn MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 06-16-2012 05:03 PM
Page generated in 0.55602 seconds with 26 queries
