Did Mazda beef up the rods in 2010-13 speed 3s? I'm looking hard at a BNR S4 but can't afford both that and swapping out the rods. I seem to be seeing more cases of guys running over 400whp and comparable torque (and no boom boom), without going to an after market set of rods. That said, I was wondering if by some slim chance Mazda might have strengthened them on their later models of the speed3. My goals are a bit over the 400 mark. Thanks. |
Tuners and the community now know to bring on boost gradually and/or later rather than spooling to large pressures quickly/early down low. Large boost pressures and too much timing down low translate to more stress on the rods. It's all about managing torque down low. Some of the issues now are large thermal concentrations (too much heat) at the ringlands at higher power levels for stock pistons, and running out of fueling. You can combat the heat issue by running E to get better in-cylinder cooling, but you'll eat up IDC headroom. You can combat running out of fuel by running WMI or port injection. |
Adding Meth does help was well. sent from my Nexus 6P |
I dont thunk in tank meth plays a part in cooling. I could be wrong. |
Latent heat of vaporization for methanol: 1103 kJ/kg Latent heat of vaporization for ethanol: 840 kJ/jg Latent heat of vaporization for gasoline: 350 kJ/kg |
Just to try and answer the original question. Did mazda improve the rods? I don't think so. I bent one with not much hp, albeit partial throttle at low rpm in 6th.... should have known better. Tuning can make them survive, but you may not be totally happy with the power output I run Meth in tank (2 gallons) and it is almost impossible to knock. I also spray a D07. I'm sure they both help the engine survive by overall cooling and knock protection |
| All times are GMT -7. The time now is 02:23 AM. |
