 Old 03-05-2014, 10:39 AM   #1
Syrza's Avatar
Posts: 64   (View Stats)
Syrza is a name known to allSyrza is a name known to allSyrza is a name known to allSyrza is a name known to allSyrza is a name known to allSyrza is a name known to all
Default Disable buttons on steering wheel?
Hi,
I've searched the forum for this topic, but wasn't able to find an answer. I'm very new to autocross, but one thing that I've come to discover that almost every run, I would push the "talk-to-command" button on my steering wheel. So my question is, is there anyway to temporarily disable some of these buttons, to prevent it from getting activated.
Another option I was thinking of, was to have some sort of cover on it.
Any help is appreciated, thanks.
Syrza is offline   Reply With Quote
 Old 03-05-2014, 10:48 AM   #2
usgiorgi's Avatar
Posts: 649   (View Stats)
usgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the worldusgiorgi is the leader of the world
Groaned at 44 Times in 10 Posts
Not sure if there's a fuse for it, but you could just put masking tape over the buttons. It will not leave any residue and should have enough tension to not let you depress the buttons. Add a few layers if you have to.
2009 Nissan 370Z. Turbo and BOV sounds made by the driver via mouth.
SOLD: 2011 Speed3. Black mica w/tech package Cobb SRI, COBB AP, AT internals, OBX racepipe, Corksport RMM, LOUDASS STRAIGHTPIPE CPE TIP
usgiorgi is offline   Reply With Quote
The Following User Says Thank You to usgiorgi For This Useful Post:
Syrza (03-05-2014)
 Old 03-05-2014, 11:19 AM   #3
ABOSWORTH's Avatar
Posts: 467   (View Stats)
ABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the world
There is a thread about disabling the SWAS and the TS pulled the wrong clip and it disabled the buttons on the steering wheel. I'm too lazy to dig it up again but you'll be able to find it with a quick search for "SWAS."
ABOSWORTH is offline   Reply With Quote
 Old 03-05-2014, 11:40 AM   #4
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
WAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the worldWAMBUSHHHH! is the leader of the world
this is just my .02 here but if OP is just autox-ing on the weekends or whatever...it's probably just easier to put some tape on it like previously mentioned and just go that route...not saying pulling the cover to get the to the fuses is difficult but being a lazy asshole I'd rather just get some tape and slap it on there.
2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017
2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned
2004 Yamaha R6 - Micron Ricer Pipe / PC
2005 Honda CBR 600 F4i - R.I.P. 10/29/13
WAMBUSHHHH! is offline   Reply With Quote
The Following User Says Thank You to WAMBUSHHHH! For This Useful Post:
Syrza (03-05-2014)
 Old 03-05-2014, 11:42 AM   #5
Syrza's Avatar
Yea, I found the thread and i'm more than likely not going to disable the SWAS....I think tape will be my solution. Thanks guys.
'13 Black Mica MS3
CS Stage II Intake, CS RMM, CS RSB, CS Short Shift Plate, Cobb AP, CS Lowering Springs, Cobb DP. Freektuned
How do I disable the steering angle sensor, to prevent power cut in 2nd gear at track. FreeFlyFreak MazdaSpeed 3 - Engine, Transmission & Driveline 30 08-30-2014 05:30 PM
MS3 steering wheel in MS6 Mattsy Mazdaspeed3/6 General Discussion 4 06-23-2012 04:11 PM
Steering wheel question demonspeed MazdaSpeed 3/6 - Appearance 8 02-13-2010 08:59 AM
Steering wheel TSB. Demi MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 11-15-2008 04:03 PM
Page generated in 0.26387 seconds with 23 queries
