do i need CDFP? Hello, I currently have a Corksport intake on my 2010 speed3, and want to get the corksport exhaust, testpipe and downpipe, as well as corksport tmic to totally utilize horsepower/torque but was wondering if I would need a internals CDFP. Im hoping I dont because I dont know how to install nor do I want to have it installed. Also for those that have the downpipe, it says that it will display CELs. I do have a accessport and know that I can turn off the light with that, but will the downpipe hurt the car. Why does the CEL come on. Thanks, Josh |
Alright, posting this up multiple times in multiple sections is not going to help your cause. SEARCH. |
answer. |
OP, you will need a HPFP, but I think you need to invest in a monitoring device before you even think of going any further with your car. Edit: saw you have an AP already, disregard the second half of my post. |
http://www.mazdaspeedforums.org/foru...daspeed-77762/ And this http://www.mazdaspeedforums.org/foru...closely-69969/ And this http://www.mazdaspeedforums.org/foru...first-faqs-62/ I could go on |
Hey, Josh, use the fucking search button. I actually hear the genpu has a good fuel pump and wont need to be upgraded til you go BT.... Sent from my DROIDX using Tapatalk |
boost past a certain level, your hpfp becomes unreliable @ best. |
1. SEARCH 2. take logs 3. review logs and ask for input on them 4. Find a friend to slap you for being lazy and not searching |
if you dont have one you need one simple enough? |
no dude, you don't need it. just go for it! |
If you take out a cat (i.e. testpipe), your're at stage 2. Stage 2 requires upgraded cdfp Theres your answer! |
... at least he donated... did one thing right... |
5. ????? 6. Profit |
Vtec |
HPFP and CDFP, are they the same thing? |
anyone close to jersey that could help with the install of a cpe fuel pump? |
Man cpe pump is about the easiest thing ive ever done, seriously it takes as long as an oil change |
http://www.mazdaspeedforums.org/foru...install-76252/ |
| All times are GMT -7. The time now is 03:58 AM. |
