Like Tree7Likes
 Old 12-15-2011, 06:06 AM   #1
Noodlesincup's Avatar
Posts: 298   (View Stats)
Noodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the world
Groaned at 37 Times in 9 Posts
Default Down Shift or Neutral
When slowing down to a complete stop,
Also when downshifting whats the thumb rule of when to?
Every time i downshift my car jerks even when im at ~1500 rpms any help is appreciated
Thanks guys
Noodlesincup is offline   Reply With Quote
 Old 12-15-2011, 06:11 AM   #2
Cujo's Avatar
Posts: 1,192   (View Stats)
Cujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the worldCujo is the leader of the world
Groaned at 6 Times in 4 Posts
double clutch or rev match
2012 Mazdaspeed3 Black Mica
Cobb AP // Stratified S-OTS+ Stage 2 Tune // Autotech Internals // CorkSport 3" Intake // CX Racing FMIC // NGK Iridium One Step Colder Plugs // JBR Throttle Body Gasket Kit & Coolant Bypass // SURE Return (w/ Dremel mod) // GFB Respons BOV // UR V2 Metal Catted DP // SURE Flow M3 // UR Catback Exhaust // StopTech Front Slotted Rotors + Performance Brake Pads // TWM Phantom Shift Knob // TWM Leather Shift Boot // CorkSport Adjustable Shortshifter // SURE Anchors // Tanabe NF210 Springs // JBR Tru-Torsion.125 Rear Sway Bar // Tanabe Sustec Tower Strut Bar // Tanabe Sustec Front Under Brace // JBR 88a RMM // Rally Armor Mudflaps // CorkSport Hood Scoop // CorkSport Battery Box // CorkSport LED Light Kit // CorkSport LED Fogs // GTA Car Kits iPod Adapter // Weathertech Floor Mats // Motorcraft Unicorn Tranny Juice // Pentosin Super DOT 4 Brake Fluid // Purple Effect Stock Rims // Falken Ziex ZE 329 // Plastidip'd Fog Light Bezels
Waiting for install: StopTech Rear Slotted Rotors + Performance Brake Pads, StopTech SS Brake Lines
Soon: Custom Tune by Stratified // Guardian Angel // BT, CorkSport Puppy or BNRs3???
Cujo is offline   Reply With Quote
The Following 3 Users Say Thank You to Cujo For This Useful Post:
dantes5823 (12-16-2011), i8urgti (12-15-2011), MS3inDC (12-16-2011)
 Old 12-15-2011, 06:11 AM   #3
j_dub99's Avatar
Posts: 11   (View Stats)
j_dub99 is a splendid one to beholdj_dub99 is a splendid one to beholdj_dub99 is a splendid one to beholdj_dub99 is a splendid one to beholdj_dub99 is a splendid one to beholdj_dub99 is a splendid one to beholdj_dub99 is a splendid one to behold
I'm always a fan of heel-toe-shifting to downshift. If you're not familiar with it, this is when you have the ball of your big toe on the brake and roll the right side of your foot over to the accelerator to 'blip' the engine before taking your foot off the clutch when you're in the lower gear. The premise is to match the revs of that lower gear and you can remove your foot off the clutch quickly instead of easing it out.
If you do it correctly, you should have no chnage in speed when you let your foot off the clutch. Blip too much and your car will accelerate slighly. Blip to little, and it will jerk slower. The good news is the peddles on an MS6 are very well aligned for this.
My two cents!
se@sick likes this.
j_dub99 is offline   Reply With Quote
The Following 2 Users Say Thank You to j_dub99 For This Useful Post:
alien_sporez (12-15-2011), predapio (12-15-2011)
 Old 12-15-2011, 06:25 AM   #4
My two cents!
Gotta go watch youtube videos,
First manual car so im inconsistent with driving and shifting its mostly 1-2 after that smooth as a rock
downshifting is going to be a pain :/
 Old 12-15-2011, 06:25 AM   #5
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Cut a hole in the floorboard and stick your feet out to stop, Flintstones style.
What a lovable bunch we are!!
The Following 13 Users Say Thank You to predapio For This Useful Post:
Abu Zib (12-15-2011), ArcticSpeed3 (12-19-2011), Cujo (12-15-2011), Dash08 (12-17-2011), emag remrofni (12-16-2011), faeker (12-16-2011), GoBackToSleep (12-17-2011), karl-hungus (12-15-2011), rikyrick87 (12-15-2011), Stingray69 (12-15-2011), SWAY (12-15-2011), TexasSpeed3 (12-16-2011), zpele (12-15-2011)
 Old 12-15-2011, 07:19 AM   #6
swampthigger's Avatar
Posts: 328   (View Stats)
swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger swampthigger
Groaned at 83 Times in 28 Posts
You must learn when to down shift and how much to "blip" the throttle to get smooth downshifts. I double clutch and downshift while matching the revs at 3,000 rpms...... PRACTICE, PRACTICE AND MORE PRACTICE!!
swampthigger is offline   Reply With Quote
 Old 12-15-2011, 08:56 AM   #7
wankular's Avatar
Posts: 4,343   (View Stats)
I would not even think about heel-toe-ing at this point until you get regular downshifting.
Normally I will only downshift down to 3rd when approaching a light, then throw it into neutral and coast to a stop. Maybe down to 2nd if I know the light is going to change.
Don't downshift to 1st ever unless you are under 5 mph, my car won't even let me force it into 1st if I'm above 5 mph.
And just keep practicing, this was my first manual car too. 3rd & 4th gear between 2800-4000 RPMs is a fun range to play around with.
2009 MS3 sport MGM
 Old 12-15-2011, 09:08 AM   #8
rikyrick87's Avatar
Posts: 266   (View Stats)
rikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the world
Groaned at 6 Times in 6 Posts
I always downshift...the first time i drove stick i put it in neutral and used the brakes, seconds after i did this my dad reached over from the passenger seat and slapped me in the head and told me 'thats not the way to do it..' so i just downshift, and like all these guys said once you figure it out, learn how to heal toe.
K&N SRI COBB TIP: COBB AP(FREEKIN'): AutoTech Internals: CS Racepipe: JBR Stage 2 SSP: JBR Heavy Knob: JBR Trans and RMM.
rikyrick87 is offline   Reply With Quote
The Following 2 Users Say Thank You to rikyrick87 For This Useful Post:
Abu Zib (12-15-2011), zpele (12-15-2011)
 Old 12-15-2011, 09:28 AM   #9
Pendarus's Avatar
Posts: 165   (View Stats)
Pendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the worldPendarus is the leader of the world
Groans: 52
This has some decent explanations of shifting techniques...probably not the best, but it gives you something to go by.
Shifting Technique
When you're downshifting, if you want a smooth transition you must rev-match. Double clutching is not necessary in modern transmissions with synchros. Synchros in essence handle the double clutching for you...that's what they're there for...use them when you're just learning shifting techniques.
Basically you have 3 parts...the engine (engine speed)...the input on the trans (trans shaft speed)...then the output on the trans (wheel speed). On an upshift, the engine rpm naturally falls down so you don't need to worry about rev match as much. On a downshift, engine RPM should be increased to match what it should be at a particular wheel speed in the lower gear before the clutch is engaged. This way it puts MUCH less stress/wear on the clutch and drive train.
If you don't rev match, your clutch/trans is doing all the work to bring the engine RPM up to match the wheel speed. If you dump the clutch you get a hard jolt as the clutch grabs and spins up the engine...if you slip the clutch it is smoother, but obviously wears it out quicker. It's just better all around (for your comfort and the cars health) to rev match all the time.
The synchros will handle the matching of the trans shaft speed with the wheel speed, so you don't have to worry about double clutching...unless your synchros go out...then it gets interesting lol.
As far as when coming to a stop...what I do is dependent on how lazy i am at the time of the stoppage If I'm being super lazy I'll pop the car out of gear and coast...but if I wanna hear the engine and have a bit of fun then I downshift.
Pendarus is offline   Reply With Quote
 Old 12-15-2011, 10:38 AM   #10
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
if you're rolling to a stop there's no reason to clutch in and downshift through all the gears. when I'm coming to a stop I pop the tranny out of gear and brake to a stop, simple as that. downshifting will just wear your clutch out faster since it has to work more. you should, however, learn to properly downshift for when you need to accelerate and need a lower gear. as everyone else has said you have to rev match to do this properly.
The Following 2 Users Say Thank You to anavrinIV For This Useful Post:
fooqr (12-17-2011), rigor (12-16-2011)
 Old 12-15-2011, 11:42 AM   #11
Crarrs's Avatar
Posts: 1,662   (View Stats)
Groans: 98
Read this.
Technobabble: Your Mama Can't Drive > MotoIQ
2004 MSM TiGrey
 Old 12-15-2011, 11:50 AM   #12
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Eh, I rarely downshift when coming to a stop, mostly its to accelerate. However, if I need to downshift either way, I rev match to reduce clutch/synchro wear.
No reason to downshift to slow down, thats the brakes job, and I would rather wear the brakes than the clutch.
The Following 5 Users Say Thank You to G26 For This Useful Post:
breakfstincluded (12-15-2011), Cujo (12-16-2011), JBR (12-16-2011), PDigg (12-19-2011), rigor (12-16-2011)
 Old 12-15-2011, 02:39 PM   #13
So after a couple tries I can down shift from 6-5-4-3 but i have trouble going from 3-2
any tips? Like what Rpm to rev to before shifting?
Also going from 1-2 when do you shift (Rpm wise)
I haven't found the magical spot for smooth shifting
Everytime I shift my car jerks like an asshole
 Old 12-15-2011, 02:40 PM   #14
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
You need to upgrade your motor mounts if you want your engine to stop hitting the firewall. See my sig under JBR
The Following 2 Users Say Thank You to adlpb For This Useful Post:
JBR (12-16-2011), rigor (12-16-2011)
 Old 12-15-2011, 02:42 PM   #15
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
You completely stock?
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
 Old 12-15-2011, 02:46 PM   #16
Yeah,
picked up my car yesterday haha
Also,
My friend says get a Ap before any mods so I dont run to lean or rich?
^ (Not sure any light)
 Old 12-15-2011, 02:49 PM   #17
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
you will get jerking in the 1-2 zone. you will learn when to give gas to keep the rpms smooth.. upgraded engine mounts, as said above, will help loads with the bouncing engine syndrome..
i like to downshift, especially when driving hard, as it lets me stay in control longer and be ready for accelerations, but, also like everyone has said, you'll need to learn when to 'blip' the throttle as you downshift, before you let go of the clutch. this will definitely help with jerking. also, work on clutch modulation, i.e.: slowly and gently letting off the clutch as you work the accelerator.
you'll get it!
ap is before power mods, like intakes, exhaust, etc.. upgraded motor mounts will not put your engine in danger at all..
The Following User Says Thank You to tddvrrn For This Useful Post:
 Old 12-15-2011, 02:55 PM   #18
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
Originally Posted by Noodlesincup View Post
Yeah,
Also,
whos that girl in your avi, i must know
The Following 4 Users Say Thank You to dooderek For This Useful Post:
breakfstincluded (12-15-2011), Easter Bunny (12-19-2011), Pu Manchu (12-16-2011), rigor (12-16-2011)
 Old 12-15-2011, 02:55 PM   #19
adlpb's Avatar
Groans: 669
Yeah,
Also,
YOUR AVATAR....
EDIT: damnit put the other one back you son of a bitch
 Old 12-15-2011, 02:57 PM   #20
2011speed's Avatar
Posts: 1,497   (View Stats)
2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world
rev match brotha.
blip the throttle when you down shift
2013 Velocity red Mazdaspeed 3 tech. BT
2011 Velocity red Mazdaspeed 3-SOLD.
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
 Old 12-15-2011, 02:57 PM   #21
Lol
I changed it around like 4 times
what one?
 Old 12-15-2011, 02:58 PM   #22
2zz mr-s
dooderek's Avatar
Groans: 239
skinny white girl photo. blank panties
The Following User Says Thank You to dooderek For This Useful Post:
adlpb (12-15-2011)
 Old 12-15-2011, 02:59 PM   #23
adlpb's Avatar
Groans: 669
Post previous avatars and we will point it out.
 Old 12-15-2011, 03:39 PM   #24
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
I just down shift hold clutch in, give gas and slowly release.
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
 Old 12-15-2011, 03:47 PM   #25
MSFer87's Avatar
Posts: 1,162   (View Stats)
MSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the worldMSFer87 is the leader of the world
Groans: 83
After watching a lot of Option Auto videos from Japan I'm pretty sure you can learn a good heel-toe technique from there (that or maybe I just enjoy them). I was under the impression heel toeing was better for coming into a corner because your braking and down shifting to an optimal gear simultaneously. From a roll just blip the throttle like the other said to the appropriate RPM level of the gear you selected, and try to judge where the RPM level would be in that gear.
-#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo
-1970 Chevelle - Needs full resto
MSFer87 is offline   Reply With Quote
 Old 12-15-2011, 04:20 PM   #26
wankular's Avatar
Downshift that avatar. It's going too fast for me to concentrate!
To downshift into 2nd you have to be going pretty slow or rev it to like 4-5000 RPM. When I first started I misinterpreted "blip" as quickly tapping the gas but I was doing it too quick and not high enough so the RPMs would drop too fast and I would still buck. If you're still bucking you're not revving high enough.
2009 MS3 sport MGM
The Following 3 Users Say Thank You to wankular For This Useful Post:
breakfstincluded (12-15-2011), rikyrick87 (12-16-2011), wolly6973 (12-16-2011)
 Old 12-15-2011, 04:35 PM   #27
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
To a complete stop:
Stay in high gear until you hit 1,000 rpm and push in the clutch. Downshifting is pointless and just uses up your clutch.
The Following 2 Users Say Thank You to Mizzle For This Useful Post:
breakfstincluded (12-15-2011), rigor (12-16-2011)
 Old 12-15-2011, 04:59 PM   #28
oh_yeams6's Avatar
Posts: 104   (View Stats)
oh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond repute
Groaned at 9 Times in 7 Posts
Heel and toe FTW!
BUT...I have a buddy who swears by putting the car into say 3rd if going 50mph, and very slowly letting out the clutch, which then engine brakes/downshifts all at once. Is that bad??
oh_yeams6 is offline   Reply With Quote
 Old 12-15-2011, 05:51 PM   #29
Originally Posted by oh_yeams6 View Post
Heel and toe FTW!
Slowly letting out clutch = slipping and burning up the friction disc.
I heel-toe like a tap dancer on crack.
breakfstincluded (12-15-2011), Dash08 (12-17-2011), oh_yeams6 (12-15-2011)
 Old 12-15-2011, 09:48 PM   #30
I got you bro
rfinkle2, GODO and poncho like this.
The Following 6 Users Say Thank You to Noodlesincup For This Useful Post:
2k4_8 (12-17-2011), ArcticSpeed3 (12-19-2011), Dash08 (12-17-2011), Easter Bunny (12-19-2011), rfinkle2 (12-16-2011), zxhoya (12-17-2011)
 Old 12-15-2011, 10:25 PM   #31
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Groans: 261
Coming to a stop I think about what saves gas and brakes the most.
Assuming there's no one behind me I stay in whatever gear I was in to let it slow down.
Of course if staying in gear would slow me down would prevent me from getting to the stop without using more gas I kick it in neutral so I can maintain momentum.
But when I can get away with it I always stay in gear, unless of course I would expect to stall.
Also staying in gear is somewhat of a safety precaution in case someone from on coming traffic veers over and otherwise you'd have to shift in to move away.
And I should double check on it, but with momentum rolling you on hand, you save more gas in gear instead of being in neutral. Maybe it's a DI thing...
Nice tits, heel and toe is for turns, probably for you to learn a bit later.
 Old 12-16-2011, 02:50 AM   #32
Vinnie's Avatar
Posts: 714   (View Stats)
Vinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the world
Groans: 76
dude i can't concentrate on anything... wtf your avatars are the best. better than water baloons breaking on tits, and chick in the red dress takin panties off.who's the current spinning one?
the answers already been said.heel toe or just let the car slow down in same gear and around 1 or 1.5k just neutral it.
'12 speed 3 CWP w/tech: DIZZY Tuned by Phate!,cobb AP,Autotech internals, cp-e nano, cp-e TIP, JBR 88 dogbone, JBR SSP/bushings, JBR rear sway bar, UR test pipe
RIP '08 speed 3 silver cp-e 75 duro RMM, cp-e intake, cp-e TIP, Jbarone SSP and bushings.
Vinnie is offline   Reply With Quote
 Old 12-16-2011, 04:34 AM   #33
dastpe's Avatar
Posts: 1,644   (View Stats)
once you get one gear at a time down, learn to do 4-3, 5-3, 5-2, etc...this is nice when approaching a tight corner. 3-2 is personally tricky, but i have found if you make it 3-nuetral-2 rather than a diagonal motion its a lot smoother.
 Old 12-16-2011, 05:55 AM   #34
Vouch,
Now I have no problems going from 6-5-4-3
but 3-2 is a pain
is there a certain rpm I should blimp too?
On a side note just placed an order for JBR ChromeMolly RMM
^^ my modding begins
The Following 2 Users Say Thank You to Noodlesincup For This Useful Post:
rikyrick87 (12-16-2011), zxhoya (12-17-2011)
 Old 12-16-2011, 05:58 AM   #35
adlpb's Avatar
Groans: 669
Vouch,
but 3-2 is a pain
We can't tell you a specific rpm number because it depends on your speed. I downshift to 2nd on lower speed turns. Most green light turns I use 3rd. But I know what you're talking about...3-2 give you a bog even if you have the right value.
BTW, you never gave us the name of said female above
 Old 12-16-2011, 06:12 AM   #36
Mistersix's Avatar
Posts: 2,585   (View Stats)
the problem with 3-2 downshift is you need more revs than the previous down shift. just blip the throttle a split second longer and it will match up better.
dont worry about the brakes for now. get up to speed and coast to a stop and rev match each gear as the rpms fall. one foot on the clutch one foot one the gas. each gear needs a bit more throttle to match up correctly as you work your way from 6th to 2nd. 2nd needing the most throttle.
this will give you a better feel for throttle input. once you've got that then start bringing the brakes in to play.
 Old 12-16-2011, 06:55 AM   #37
dastpe's Avatar
Originally Posted by adlpb View Post
We can't tell you a specific rpm number because it depends on your shift. I downshift to 2nd on lower speed turns. Most green light turns I use 3rd. But I know what you're talking about...3-2 give you a bog even if you have the right value.
^-what he said. also remember not to force it into gear, just keep a small amount of pressure on the gear, and when you reach the correct RPM (match the revs) it will just drop in. i also believe that if you can drive this manual well, you can drive any manual well
 Old 12-16-2011, 06:56 AM   #38
adlpb's Avatar
Groans: 669
I meant to say "speed" not "shift" in the first sentence...morning fail
 Old 12-16-2011, 07:00 AM   #39
MS3inDC's Avatar
Posts: 3,070   (View Stats)
Groans: 29
If you need to ask, then don't even worry about downshifting until you need to accelerate...
And heel-toe suggestions for street driving is laughable...
My $.02...
Drive like a normal person... take a race driving course... practice heel-toe downshifting on the track, when it is actually necessary...
MS3inDC is offline   Reply With Quote
 Old 12-16-2011, 07:09 AM   #40
To be honest I have no idea what her name is,
all I know is shes hot as hell
Neutral Afrs? GH07MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 06-03-2011 04:03 PM
Revving when coasting in neutral Domino81 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 03-10-2011 08:35 PM
Trouble moving left or right when in neutral position doctorres112 2010 MS3 - Engine, Transmission & Driveline 13 12-16-2010 05:53 PM
Wheels spin in neutral? erod550 MazdaSpeed 3 - Engine, Transmission & Driveline 10 05-26-2010 04:52 PM
2008 MS3 shifter neutral positioner spring joe149 MazdaSpeed 3 - Engine, Transmission & Driveline 15 05-16-2009 10:59 PM
Page generated in 0.56698 seconds with 45 queries
