-   -   DP + stock catback fail (http://www.mazdaspeedforums.org/forum/f544/downpipe-stock-catback-fail-136485/)
Godzilla 01-27-2013 02:07 PM
Hey guys, I installed a CS 3'' DP with a stock 2.55'' catback. It seemed like a good idea at the time, but now I want to upgrade to a full 3'' turboback exhaust. Looks like the best option is buying another downpipe with 3'' connection, and buying a CS 3'' catback. Does anyone know of a good alternative without replacing the downpipe? Is it possible to cut a 2.55'' flange on the downpipe and weld a 3'' flange? Has anyone been through this before? Thanks!
Dmurray06 01-27-2013 02:10 PM
Corksport made a downpipe that didn't have a 3" connection?
I thought it was just the "race pipe" that went either way.
Menace1 01-27-2013 02:15 PM
The Canadians on here bay bash you!
it is doable, but I would recommend that you get your exhaust first and do a proper fitment and measurement so you only cut once.
they do have that option available for the downpipe.
Dmurray06 01-27-2013 02:23 PM
My bad.
CorkSport 01-29-2013 09:58 PM
Our catted downpipe replaces both stock parts and connects at the cat back connection in the stock exhaust and 80mm version. The non catted downpipe still uses the racepipe aka second cat delete.
-Derrick
DONOTBUGME 01-29-2013 10:08 PM
If you get the magnaflow exhaust it has stock 2.55 flange that connects to the downpipe then goes 3 inches back. The reason i know this is because I modified my Magnaflow to make it 3 inches all the way. If you check the gen 2 definitive exhaust thread you will see. Look for my post.
found the link,
http://www.mazdaspeedforums.org/foru...ml#post1630034
Godzilla 01-30-2013 01:14 AM
Thanks guys, will post the outcome. I have bigger problems now, the after cat O2 sensor is reading high voltage, and odds are that the aftermarket cat is not functioning properly. Did anyone have problems with Corksport catted downpipes?
CorkSport 01-30-2013 11:32 AM
Have you submitted a trouble ticket with us?
CorkSport Mazda Performance - Knowledgebase & Support Center
Derrick
Godzilla 01-31-2013 12:34 PM
Derrick, thanks for your reply. I will submit a ticket today - I wanted to first check if people had similar issues, and maybe I was missing an easy fix.
Dimenus 03-24-2013 02:06 PM
@Godzilla;, what did your problem end up being? I just put a in CS high flow cat and I'm throwing codes related to the back O2 sensor.
86AmishMs3 03-24-2013 02:10 PM
High flow cats usually throw codes as well.
Dimenus 03-24-2013 02:48 PM
CS's instructions do say that "No CEL" should exist. So i'm just trying to cover my bases.
Page generated in 0.18881 seconds with 11 queries
