-   -   Emissions Testinf Dilemma (http://www.mazdaspeedforums.org/forum/f544/emissions-testinf-dilemma-124041/)
Airman3454 09-08-2012 05:04 PM
Emissions Testing Issues
I recently found that I am pcsing to a new duty station where there is mandatory emissions testing and I have a few questions.
I am running a stage 2 map with DP, Racepipe, catback, intake, and an egr delete. I am tuned through ATR and have the corresponding cel's disabled. When I take the car to get tested, will I be able to leave the map on my ECU or will I have to load the stock map?
If the stock map is loaded I have no doubt that I will be throwing multiple cel's
Any input is appreciated!
Brian
zmarko 09-08-2012 05:18 PM
Depends on the local laws. It would help if you gave us the location where you're moving and maybe someone that lives there can chime in on the laws there.
But most likely just flashing back to the stock map won't help (even IF you didn't throw any CEL's). Many places that require emissions testing have visual inspections also, and if you've got mods on there (especially ones that remove/delete/bypass CATS), you'll fail.
Best to have someone chime in from where you're moving to though.
NCZ13 09-08-2012 05:20 PM
If youre coming to cali youll need the cats installed. Pretty sure the same goes for any of the states that follows californias emissions laws.
Airman3454 09-08-2012 05:26 PM
I will be moving to fort Campbell,Tn. I still have the stock cat for the Racepipe but I doubt they would pick up an EGR delete.
I guess my question should be could I drive the car and baby it and hope it doesn't throw a CEL?
zmarko 09-08-2012 05:37 PM
If I were you, I'd start googling what county you'll be living in, and see exactly what their emissions testing laws are. Looking at a map, it's enough in the "boonies" that there may be no emissions testing at all (however there still may be a physical inspection of the emissions equipment). Find out what side of the state line you'll be living, get the county, and start googling for emissions testing.
Airman3454 09-08-2012 06:12 PM
Looks like Kentucky doesn't have any emissions testing. Thank the lord!
08cosmic3 09-08-2012 06:19 PM
I'm in KY and there is no testing what so ever. We have an active NATOR chapter, TN/KY Nator and we meet most of the time in Clarskville TN. We have a Facebook site also.
http://www.mazdaspeedforums.org/forum/f571/
https://www.facebook.com/groups/206647016088166/
PL ENDO 09-08-2012 06:26 PM
Brian
i guess your going to cali. if so good luck:sad6:
Airman3454 09-08-2012 06:39 PM
I'll def check it out. Thanks!
RamiLP 09-08-2012 08:42 PM
Usually when u buy a new vehicle you don't have to get an emission test for the 1st 5 years.
skeeter149 09-08-2012 08:56 PM
and doesn't the cell toggle on atr just defeat the readiness and the computer will show it as not ready? cobb said something about this just can't recall exactly
CaptObvious75 09-08-2012 09:05 PM
you may be screwed. the etests we have to do here are pretty strict. If you have no cat, you'll fail based on how stupid high your emissions results will be. I have heard that the egr delete may lower some values of the test, but will raise some others. I think Nox is the most effected by the egr but im probably wrong
Page generated in 0.18240 seconds with 11 queries
