-   -   Exhaust Hanging (http://www.mazdaspeedforums.org/forum/f544/exhaust-hanging-88996/)
Airman3454 08-16-2011 05:17 PM
Exhaust Hanging
So being as OCD as I am I have noticed that my exhaust tips are hanging at different angles of each other. I have tried bending the mounting hangars and swapping the hangers on each side but to no avail.
What have you all done to make your exhausts even? I have the CS CBE.
Should I just purchase a new matching set of the hangers or what?
cesaros 08-16-2011 05:22 PM
just yank on it till it's streight.
do you have a lazy eye? that might make them look uneven.
Airman3454 08-16-2011 05:30 PM
No lazy eye. One sits perfect the other is too low..
E.Tinker 08-16-2011 06:16 PM
Are you sure?
Because one looks perfect and the other one looks too high to me.
Airman3454 08-16-2011 08:03 PM
ha
rghispanic88 08-16-2011 08:22 PM
i cant see under the car as im driving it, so it doesnt bother me
TWOptSL0W 08-16-2011 08:44 PM
not sure what the hanger setup is on the pu's but you could slide a ziptie in the two holes of the hanger to close up the center hole and raise that side if you are looking at the hanger sideways, it will go through the o's and close the [] ---> (o[]o)
Airman3454 08-16-2011 08:48 PM
good idea. I will try that tomorrow. I am almost just tempted to order some CS hangers.
Airman3454 09-05-2011 09:05 PM
Ordered some of those CS hangers. The issue is still there but not nearly as bad...
spoof3r 09-05-2011 09:09 PM
Did those cause more vibrations in the car? Eliminate any exhaust rattling? I have some awful exhaust rattling and I'm just not sure what to do about it. I was thinking new exhaust hangers, but I really have no idea. What are your thoughts?
I_Heart_Haters 09-05-2011 09:11 PM
:worthless:
Airman3454 09-07-2011 07:10 PM
I will take some pictures tomorrow after work..
dizzydtrain 09-07-2011 07:13 PM
They are supposed to eliminate/reduce exhaust movement and vibrations.
Airman3454 09-08-2011 04:44 PM
Took a pic of the exhaust after coming home today.
What else can I do?
Jake5713 09-08-2011 05:19 PM
mine looks like this as well drives me nuts
@CorkSport
any suggestions other than buying more parts?
Airman3454 09-08-2011 05:29 PM
I asked a buddy of mine and he said to put a standard rubber hanger on the exhaust and then use 2 zip tiess to tighten the grommet...
Page generated in 0.17775 seconds with 11 queries
