-   -   Feedback for Upgrade Path (http://www.mazdaspeedforums.org/forum/f544/feedback-upgrade-path-207768/)
Kavik 12-20-2016 07:44 AM
I'm looking for feedback on my plans to upgrade my 2010 MS3. I plan to make the car more efficient, but I want my "zoom zoom" when I ask it to deliver since VA drivers are a pain in the ass to drive with. It's my DD but I'd like to increase its power. I mostly want to know what I should prioritize (currently listed in order I would have planned to buy and install), as in install parts X Y & Z before A B & C. Also after Line item #20 I plan on having PTuning in my area create a custom dyno tune on it.
1. Cobb Tuning Accessport V3 (first purchase, should be here this Thursday)
2. CorkSport HPFP Internals
3. CorkSport High Pressure Fuel Line
4. Damond Motorsports OCC Stage 1 w/ VTA Kit
5. Cobb Tuning XLE BPV
6. JBR Tru 3" Wide Path Silicon SRI w/ Dry Filter Wrap, because VA pollen/dust is high
7. JBR DISI Turbo inlet Pipe
8. JBR Bypass Valve Hose
9. JBR Intercooler Boost Tubes
10. Bosch 3Bar TMap Map Sensor with IAT w/ PnP Harness
11. GlowShift Tinted Digital Wideband Air/Fuel Gauge
12. NGK Iridium IX Spark Plugs (LTR7IX-11)
13. CorkSport Hood Scoop
14. JBR Motor Mounts (Trilogy)
15. ETS TMIC
16. ACT Heavy Duty Clutch w/ 6-Puck Race Disc & Streetlite Flywheel (can hear clutch engage and disengage, but no slipping yet so thinking previous owned dogged it a bit)
17. JBR Short Shift Plate Kit w/ Shifter Base Bushings
18. Cobb Tuning SS 3" Turboback Exhaust
19. CorkSport Camshafts
20. GrimmSpeed or CorkSport EBC Solenoid 3-Port (still on the fence on this one)
21. eLine (DrilledRotors.com) Black Edition Cross Drilled & Slotted Rotors Kit w/ Premium Ceramic Pads
22. StopTech Stainless Steel Front & Rear Brake Lines
That's all I can really think of wanting to upgrade over the future, I love criticism so if anyone thinks I'm overkill on it or lacking, please let me know. Again thanks for those that can help me out, this forum has been great to learn about this amazing car.
Bingo 12-20-2016 08:00 AM
Overall it looks decent to me, but I see a couple things.
#6 : you will need a MAF cal after you put on that intake.
#3 : not necessary.
#10 : not necessary on stock turbo as you shouldn't really push it past 20 psi.
#11 : not necessary with the AP, but if you want it for style, I believe that gauge comes with it's own wideband sensor. If that's the case, you'll need another O2 bung which (essentially) means a new downpipe. Therefore, a downpipe must come first, and until then you'll have the AP to read AFR anyway.
I would also add that if you're trying to upgrade brakes, toss some pads on there too, they'll make quite a difference.
Good luck.
WetzMS3 12-20-2016 08:07 AM
3. CorkSport High Pressure Fuel Line NOT NEEDED UNLESS REPLACING BROKEN OEM HARD LINE
6. JBR Tru 3" Wide Path Silicon SRI w/ Dry Filter Wrap, because VA pollen/dust is high GET HTP 3" FULL INTAKE INSTEAD
7. JBR DISI Turbo inlet Pipe SEE #6
8. JBR Bypass Valve Hose NOT NEEDED
9. JBR Intercooler Boost Tubes NOT NEEDED, AND LESS EXPENSIVE OPTIONS EXIST VIA WEBSITES LIKE Intercooler Pipe Fabrication
10. Bosch 3Bar TMap Map Sensor with IAT w/ PnP Harness NOT NEEDED UNLESS YOU WANT MORE THAN 21.7 PSI OUT OF THE K04, WHICH IS ASKING A LOT OF A HAIRDRYER AT THAT POINT
11. GlowShift Tinted Digital Wideband Air/Fuel Gauge K
12. NGK Iridium IX Spark Plugs (LTR7IX-11) CONSLUT YOUR TUNER ABOUT HEAT RANGE. YOU'LL LIKELY BE FINE ON STOCK HEAT RANGE PLUGS
14. JBR Motor Mounts (Trilogy) PREPARE FOR YOUR TAINT HAIRS TO BE SHAKEN OFF
15. ETS TMIC
16. ACT Heavy Duty Clutch w/ 6-Puck Race Disc & Streetlite Flywheel (can hear clutch engage and disengage, but no slipping yet so thinking previous owned dogged it a bit) THIS CLUTCH IS OVERKILL FOR YOUR POWER GOAL. GREAT CLUTCH, BUT A LUK CLUTCH/FINDANZA FLYWHEEL WILL HOLD THE POWER YOU WANT, BE CHEAPER, AND EASIER TO DRIVE
17. JBR Short Shift Plate Kit w/ Shifter Base Bushings BAD FOR THE TRANSMISSION AND CABLES, JUST SHIFT FASTER
19. CorkSport Camshafts NOT AT ALL NEEDED FOR YOUR GOAL, AND A VERY VERY INVOLVED INSTALLATION PROCESS FOR NEW GUYS
20. GrimmSpeed or CorkSport EBC Solenoid 3-Port (still on the fence on this one) NOT REALLY NEEDED AND CAN BE ASSEMBLED BY YOURSELF FOR LESS THAN $30
21. eLine (DrilledRotors.com) Black Edition Cross Drilled & Slotted Rotors Kit CENTRIC BLANKS
Comments above in red.
Do not have whatever shop that link was tune the car. Look into reputable tuners who have worked with this platform extensively. There are plenty around here still that can tune on dyno or remotely via email. Tuning this platform is quite a bit different than others, and many horror stories start with shops lacking experience in the platform attempting to tune it.
Kavik 12-20-2016 08:11 AM
Guess I should have mentioned the Brake Kits come with Premium Ceramic Pads. Thanks for the input Bingo and yes the Wideband was more for style and my buddy with a Civic Si said its useful especially when you run larger intakes - but for functionality would Oil Pressure or Oil Temperature be a better Gauge to install? Was going to place it in the Driver side air vent with a VentPod.
Kavik 12-20-2016 08:19 AM
Thanks Wetz, looks like I can save a bit more money since I appear to have gone a bit overkill. I went with PTuning because a lot of their cars have been featured in Import Magazines they tuned and help design (besides being local).
BuddySpeed3 12-20-2016 08:34 AM
The philosophy I started going by is to determine what your goals are in terms of driveability and power. Then upgrade with the right parts... not the most amount of parts. Your list looks pretty good.
KiwiFlavor 12-20-2016 08:48 AM
Do they have any Speeds featured in said magazines? How do you know they can tune Speeds safely? So many "Pro tuners" and "speed shop" out there that are good at tuning other platforms and really horrible at ours.
Not everybody knows the ins and outs of our platform as well as our E-tuners here. Go with Freek, Hypnotic, Nishan, Stratified, and some others. (Stay away from Brentune and orange virus. Others can chime in on this matter.
Kavik 12-20-2016 08:54 AM
Definitely need to keep drive-ability the focus since it is my primary vehicle and I want to notch the power up as much as possible to bring out the potential of the car and also have the ability to react (drivers in my area don't know what turn signals are and hit their brakes for no reason half the time (so need to dive around them, speed past, etc.).
Kavik 12-20-2016 09:10 AM
This is from their Dyno info site "Our in house tuner, Toan Nguyen, is an EFI University certified tuner with years of experience tuning various vehicles such as his personal S2000 (AEM V2 EMS) and our Time Attack tC (Haltech Powersport 1000). We can’t forget to mention that he’s also tuned many of our employee’s vehicles too (Hondata KPro RSX, Megasquirt MS3X 240sx, Megasquirt PnP Pro SC300, Cobb AP Fiesta ST, EcuTek FR-S) so we can safely trust in the quality of his work! Some of our most common tunes include the WRX/STI, Mazdaspeed 3’s, and FR-S/BRZ but he’s done everything from 500AWHP drag Evo 8’s, drift setup 240sx’s and our SC300, track setup turbo S2000’s, and even 2JZ swapped resto-mod’s just to name a few. Toan works hard to maximize every aspect of the tune so that nothing is left on the table."
However, I do completely understand that I would want someone that specializes in the Mazdaspeed platform so when I talk to them in person this Friday (was going to be in the area) I'll ask how many MS3's they've tuned and what they were tuned for... if I don't get the warm and fuzzy then I'll come and check out the e-tuners featured here.
KiwiFlavor 12-20-2016 09:13 AM
@WetzMS3;, @MD1032;, @Djohns; you guys familiar with that name?
MD1032 12-20-2016 09:28 AM
What name? Jesus Tim...
KiwiFlavor 12-20-2016 09:30 AM
Lol! I was referring to the name OP gave on the post above my other post. Toan Nguyen.
MS3Shadow 12-20-2016 09:57 AM
Classic kiwi
Sent from my Pixel XL
Djohns 12-20-2016 11:35 AM
I've never heard of that tuner honestly.
MD1032 12-20-2016 11:36 AM
Originally Posted by KiwiFlavor (Post 3097962)
Toan Nguyen.
I have no idea who that is. What kind of person are you looking for? What services do you need?
KiwiFlavor 12-20-2016 11:38 AM
Was just trying to prove a point to OP.
MD1032 12-20-2016 11:43 AM
I hear Cobb offers some EFI classes that don't teach you anything about tuning Mazdaspeed3's for the low, low price of $150.
Kavik 12-20-2016 12:05 PM
And that's why I come here to get expert advice ;) so with the e-tuners available here - any preferences?
KiwiFlavor 12-20-2016 12:07 PM
These are some great E-tuners on here.
Djohns 12-20-2016 12:14 PM
I personally prefer Justin from freektune but they're plenty of other quality options on here.
SSinstaller 12-20-2016 01:02 PM
Replace the AP with Versatune..
MS3Shadow 12-20-2016 02:53 PM
Only if he wants to self tune.
AP is good if he does the Etunes and the AP itself is a good tool to monitor 6 parameters on one screen at CAN speeds.
g00s3y 12-20-2016 03:48 PM
The only real reason I have my v3 still over VT. Compact package, easy monitoring, no extra laptop/tablet needed.
If they made a VersaTuner app for Android, something I can connect an old nexus 6 to, fire up the program, connect cable like AP, and monitor at the CAN speed, my AP and ATR copy will be for sale in an instant.
sheston 12-20-2016 06:27 PM
Wow, I guess we're back to the being nice people forum?
I agree with @WetzMS3; also. Some of the items depend on how long you think it will take to get them all. If you're tight for money, I'd change the order to get the biggest bang first, then smooth it out with the other items. IMHO #s 4 and 5 could be skipped or wait til the end, in addition to what the others said
zenit 12-20-2016 08:26 PM
Every now and then, we need to be nice to people who don't get butthurt about their n00bness and initial posts. Keeps information fresh and allows us a chance to flex mental muscles about current knowledge of mazdaspeed platform mods.
1. Cobb Tuning Accessport V3 (first purchase, should be here this Thursday) - You'll get versa tune eventually- if you're serious.
2. CorkSport HPFP Internals - Sure, used Autotechs are cheaper, but they'll work. AFAIK- no major difference between these and autotechs, aside from price point
3. CorkSport High Pressure Fuel Line -Nope.
4. Damond Motorsports OCC Stage 1 w/ VTA Kit -Okay. IMO, this is low priority.
5. Cobb Tuning XLE BPV -IMO low priority until you crank boost (+21psi on stock manifold)
6. JBR Tru 3" Wide Path Silicon SRI w/ Dry Filter Wrap, because VA pollen/dust is high -Intake is highly recommended, even if you're targeting lower boost/load. Makes life easier on the turbo due to lower pressure ratios. Not a fan of the manufacturter or of the silicone. Clean/replace your filter > Dry Wrap.
7. JBR DISI Turbo inlet Pipe ^see above
8. JBR Bypass Valve Hose not necessary
9. JBR Intercooler Boost Tubes Not necessary
10. Bosch 3Bar TMap Map Sensor with IAT w/ PnP Harness Not necessary until you upgrade turbo, but if you find one cheap, grab it, you'll eventually want more power (and boost).
11. GlowShift Tinted Digital Wideband Air/Fuel Gauge -not necessary, especially if you have an AP for monitoring.
12. NGK Iridium IX Spark Plugs (LTR7IX-11) -not necessary until you're plugs are not working.
13. CorkSport Hood Scoop -I, uh. well. Rice?
14. JBR Motor Mounts (Trilogy) -Do further research on these.
15. ETS TMIC -for the love of god, don't buy this new. get a 2-3inch TMIC used. IMO: Tune for an E mix > fancy incooler setup.
16. ACT Heavy Duty Clutch w/ 6-Puck Race Disc & Streetlite Flywheel (can hear clutch engage and disengage, but no slipping yet so thinking previous owned dogged it a bit) - Do you like pain? Stick with the stock clutch as long as you can.
17. JBR Short Shift Plate Kit w/ Shifter Base Bushings -do research on this.
18. Cobb Tuning SS 3" Turboback Exhaust -meh. Rice?
19. CorkSport Camshafts -let someone else be the guinea pig. CS has history with camshafts, and there are multiple vendors offering different cams these days.
20. GrimmSpeed or CorkSport EBC Solenoid 3-Port (still on the fence on this one) -not necessary.
21. eLine (DrilledRotors.com) Black Edition Cross Drilled & Slotted Rotors Kit w/ Premium Ceramic Pads - sure if your current rotors/pads are kaput. Don't do brakes until you need to need to.
22. StopTech Stainless Steel Front & Rear Brake Lines -do you need to replace the lines? Sure. Otherwise don't screw with them.
Overarching theme ^ spend less money on mods, more on track time.
SSinstaller 12-20-2016 08:34 PM
IMO, the AP is on life support. There are plenty of options for real time monitoring that dont lock you into the cobb tuning cash grab.
It's going to get really expensive paying for etunes as these parts are added over time.
MS3Shadow 12-20-2016 08:54 PM
What are the other of those "plenty of options" that doesn't require another device and that can monitor 6 things at once?
The Cobb AP is great at what it does. And it can also do hybrid tunes while VersaTune is a bit more actively updated, it's only can do Load based tunes for now.
And those etunes don't have to be expensive. Anyone can do OTS+ tunes for about $50.
zenit 12-20-2016 08:55 PM
Some people are okay with that.
KiwiFlavor 12-21-2016 05:15 AM
OP for number 22 on your list, these will be good too
Cross Drilled Brake Lines - $72.95 : KaleCoAuto.com, Your home for the rare, unusual, and hard to find auto parts.
MD1032 12-21-2016 05:48 AM
You can buy bluetooth and USB OBD adapters that will also read at CAN speeds, just need a device that can display it.
I finally read the OP. @Kavik; you actually have a reasonably well put together list there. Let me write down my recommendations:
You need:
1) As much seat time as humanly possible. Attend as many autocrosses, track events, and driving schools as you possibly can.
2) Tuning (Versatune or Cobb), HPFP internals, MAP sensor
3) Motor mounts, except use the Damond Trilogy, not the JBR trilogy (trust me, worth the money)
4) Test pipe
5) Intake (recommend HTP 3")
6) E85 tune
7) Some kind of shock upgrade, eg Koni Yellow, Bilstein B6, as the stockers are short-lived
8) Real tires. I recommend Michelin Pilot Super Sport.
Things you might want, but don't need:
1) 3" TBE (makes the turbo spool significantly faster)
2) Some MAC solenoid-based EBCS kit, eg Cobb, Grimmspeed, JBR (the valves are all the same)
Things you don't really need:
1) Clutch - unless it's slipping, don't bother. The stock clutch is great. I do recommend the ACT when it eventually dies, though
2) Intercooler - E85 will make all of your knock problems go away anyway
3) Brakes - stock brakes are good enough. Leave them for now.
4) Spark plugs - the stock ones are awesome. Keep using them and change every 60k miles according to the FSM.
5) Plus all the other shit you mentioned like the cams...
Kavik 12-21-2016 07:51 AM
Greatly appreciate the feedback from everyone, so after everyone's input and little more research I've come up with the following which will fit my power needs and keep my daily driving from being too harsh (60 miles a day for work, sometimes in stop and go highway traffic - fellow VA speed owners will understand the horror of I-95).
1. CS HPFP Internals
2. HTP 3.0" Full Intake System
3. Cobb SS 3" Turboback Exhaust
4. Cobb XLE BPV
Get 1 - 4 installed and set with a custom E85 e-Tune by either Freektune or Stratified
Then finish with...
5. Damond Motorsports OCC Stage 1 Kit w/ VTA
Then replace as needed the brakes/rotors/tires/shocks/clutch and if my power needs increase, come back here to ask for more recommendations.
Rotors/Brakes: eLine Cross Drilled and Slotted w/ Premium Ceramic Pads & StopTech STAINLESS STEEL Brake Lines
Shocks: Koni Yellows
Tires: Michelin Pilot Sport A/S 3+ (live in a townhouse, no room to store separate types)
Clutch: LuK 10-064 Kit w/ Fidanza Flywheel
Also if it matters, I plan to run Shell T6 Rotella 5W40 Full Synth Oil with Napa Gold Oil Filters when I do my first oil change with it - didn't research any other fluids, could use recommendations for those whenever they need to be flushed and replaced with.
KiwiFlavor 12-21-2016 07:53 AM
Originally Posted by Kavik (Post 3098100)
Rotors/Brakes: eLine Cross Drilled and Slotted w/ Premium Ceramic Pads & Cross Drilled Brake Lines (red)
Per @WetzMS3; suggestion
Kavik 12-21-2016 08:03 AM
Yeah... I'm going to admit I'm going for more of the aesthetic looks on this one, always liked the drilled/slotted look. I did look over @WetzMS3; suggestion and read of Centric Blank's superior metallurgy makeup of their rotors.
So with that said... instead of the Blanks, would the Centric C-TEK Drilled/Slotted be better than the eLine?
KiwiFlavor 12-21-2016 08:05 AM
Btw... Please do not follow my suggestion on that brake line.. Unless you want to stick your foot out the door everytime you want to stop.
Kavik 12-21-2016 08:11 AM
But you said they would be a good choice... back to the stainless.
Oh, ha, I got it - started to actually look at other parts on the site.
KiwiFlavor 12-21-2016 08:13 AM
I was just trolling. Any holes in brake lines are bad dude.. lol
Kavik 12-21-2016 08:18 AM
Figured it was some cooling sleeve for the lines on the outside lol. Well I certainly fell for that one.
MD1032 12-21-2016 08:58 AM
FWIW I use stock brake lines and stock rotors with Hawk HP+ pads and anyone who has been in my car can attest to the fact that it stops a lot better than most other setups. I don't understand why you feel the need to use the drilled rotors. They are going to be more prone to cracking and will give you less braking force relative to a solid rotor.
Personally I do not like the Koni Yellows, and they aren't going to do much for you when you're using shit all-season tires like those Michelins.
I also hold the unpopular opinion that oil catch cans are useless on properly working stock engine cars. I use a bone stock PCV setup on my car and have (unsurprisingly) never had any problems with it.
No matter what oil you use, do yourself a favor and have oil analysis performed on it every single oil change. You will see problems long before they manifest in a catastrophic fashion.
Kavik 12-21-2016 09:18 AM
I'll have to see if a shop near me offers oil analysis. Is there even an All-Season tire worth having (obviously not for track) or would I be stuck having to get separate sets of Summer & Winter Tires?
Hansonjw 12-21-2016 09:32 AM
Stafford sucks. Moved there in high school and lived there 10 years. Fucking miss Wawa tho.
I would put more emphasis on wheel/tire/suspension. Ditch the crap other people have already stated. After basic bolt ons I would do an upgraded turbo. You can get a bnr bundle for a decent price. Plan on injector seals, pcv valve, occ, and cleaning your valves.
Based on your list looks like you have just a bit more research and reading to do.
Kavik 12-21-2016 10:09 AM
Jobs with the Government is what keeps me in the area, yeah I'm reading through all the threads I can to try and learn what I can. Just trying to create a goal to work towards with my MS3 and make sure I don't mess-up along the way.
MS3Shadow 12-21-2016 10:44 AM
I don't know if your shop can do oil analysis.
We usually use Blackstone Labs for our used oil.
Link here: blackstone-labs.com
Page generated in 0.23343 seconds with 11 queries
