![]() | | #1 | ![]() |
![]() Join Date: Nov 2016 Location: Stafford, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 26
(Thread Starter) | Not Ranked : 0 score 1. Cobb Tuning Accessport V3 (first purchase, should be here this Thursday) 2. CorkSport HPFP Internals 3. CorkSport High Pressure Fuel Line 4. Damond Motorsports OCC Stage 1 w/ VTA Kit 5. Cobb Tuning XLE BPV 6. JBR Tru 3" Wide Path Silicon SRI w/ Dry Filter Wrap, because VA pollen/dust is high 7. JBR DISI Turbo inlet Pipe 8. JBR Bypass Valve Hose 9. JBR Intercooler Boost Tubes 10. Bosch 3Bar TMap Map Sensor with IAT w/ PnP Harness 11. GlowShift Tinted Digital Wideband Air/Fuel Gauge 12. NGK Iridium IX Spark Plugs (LTR7IX-11) 13. CorkSport Hood Scoop 14. JBR Motor Mounts (Trilogy) 15. ETS TMIC 16. ACT Heavy Duty Clutch w/ 6-Puck Race Disc & Streetlite Flywheel (can hear clutch engage and disengage, but no slipping yet so thinking previous owned dogged it a bit) 17. JBR Short Shift Plate Kit w/ Shifter Base Bushings 18. Cobb Tuning SS 3" Turboback Exhaust 19. CorkSport Camshafts 20. GrimmSpeed or CorkSport EBC Solenoid 3-Port (still on the fence on this one) 21. eLine (DrilledRotors.com) Black Edition Cross Drilled & Slotted Rotors Kit w/ Premium Ceramic Pads 22. StopTech Stainless Steel Front & Rear Brake Lines That's all I can really think of wanting to upgrade over the future, I love criticism so if anyone thinks I'm overkill on it or lacking, please let me know. Again thanks for those that can help me out, this forum has been great to learn about this amazing car. Last edited by Kavik; 12-20-2016 at 08:23 AM. |
![]() Join Date: Apr 2015 Location: Sterling Heights Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score Overall it looks decent to me, but I see a couple things. #6 : you will need a MAF cal after you put on that intake. #3 : not necessary. #10 : not necessary on stock turbo as you shouldn't really push it past 20 psi. #11 : not necessary with the AP, but if you want it for style, I believe that gauge comes with it's own wideband sensor. If that's the case, you'll need another O2 bung which (essentially) means a new downpipe. Therefore, a downpipe must come first, and until then you'll have the AP to read AFR anyway. I would also add that if you're trying to upgrade brakes, toss some pads on there too, they'll make quite a difference. Good luck.
__________________ Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks. Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A. |
| The Following 3 Users Say Thank You to Bingo For This Useful Post: |
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
Groans: 430
Do not have whatever shop that link was tune the car. Look into reputable tuners who have worked with this platform extensively. There are plenty around here still that can tune on dyno or remotely via email. Tuning this platform is quite a bit different than others, and many horror stories start with shops lacking experience in the platform attempting to tune it.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
![]() | | #4 | ![]() |
(Thread Starter) | Not Ranked : 0 score Guess I should have mentioned the Brake Kits come with Premium Ceramic Pads. Thanks for the input Bingo and yes the Wideband was more for style and my buddy with a Civic Si said its useful especially when you run larger intakes - but for functionality would Oil Pressure or Oil Temperature be a better Gauge to install? Was going to place it in the Driver side air vent with a VentPod. |
![]() | | #5 | ![]() |
![]() | | #6 | ![]() |
![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score The philosophy I started going by is to determine what your goals are in terms of driveability and power. Then upgrade with the right parts... not the most amount of parts. Your list looks pretty good.
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) |
| The Following User Says Thank You to BuddySpeed3 For This Useful Post: | Kavik (12-20-2016) |
![]() | | #7 | ![]() |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 879 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
Not everybody knows the ins and outs of our platform as well as our E-tuners here. Go with Freek, Hypnotic, Nishan, Stratified, and some others. (Stay away from Brentune and orange virus. Others can chime in on this matter.
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 | |
![]() | | #8 | ![]() |
(Thread Starter) | Not Ranked : 0 score Definitely need to keep drive-ability the focus since it is my primary vehicle and I want to notch the power up as much as possible to bring out the potential of the car and also have the ability to react (drivers in my area don't know what turn signals are and hit their brakes for no reason half the time (so need to dive around them, speed past, etc.). |
![]() | | #9 | ![]() |
However, I do completely understand that I would want someone that specializes in the Mazdaspeed platform so when I talk to them in person this Friday (was going to be in the area) I'll ask how many MS3's they've tuned and what they were tuned for... if I don't get the warm and fuzzy then I'll come and check out the e-tuners featured here. | |
![]() | | #10 | ![]() |
![]() | | #11 | ![]() |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
__________________ 2007 Mazdaspeed3 GT |
| The Following User Says Thank You to MD1032 For This Useful Post: | WetzMS3 (12-20-2016) |
![]() | | #12 | ![]() |
| Not Ranked : 0 score Lol! I was referring to the name OP gave on the post above my other post. Toan Nguyen.
![]() | | #13 | ![]() |
| Tachyonic Moderator ![]() ![]() Join Date: Nov 2013 Location: San Antonio, TX
Rep Power: 1969 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,076
Groans: 283
| Classic kiwi Sent from my Pixel XL
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken |
| The Following 2 Users Say Thank You to MS3Shadow For This Useful Post: | KiwiFlavor (12-20-2016), WetzMS3 (12-20-2016) |
![]() | | #14 | ![]() |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
Groans: 112
| Not Ranked : 0 score I've never heard of that tuner honestly.
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
![]() | | #15 | ![]() |
Groans: 143
| Not Ranked : 0 score I have no idea who that is. What kind of person are you looking for? What services do you need?
![]() | | #16 | ![]() |
Was just trying to prove a point to OP.
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 | ||
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | Kavik (12-20-2016) |
![]() | | #17 | ![]() |
Groans: 143
| Not Ranked : 0 score I hear Cobb offers some EFI classes that don't teach you anything about tuning Mazdaspeed3's for the low, low price of $150.
| The Following 4 Users Say Thank You to MD1032 For This Useful Post: |
![]() | | #18 | ![]() |
| The Following 2 Users Say Thank You to Kavik For This Useful Post: | KiwiFlavor (12-20-2016), MD1032 (12-20-2016) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score These are some great E-tuners on here.
![]() | | #20 | ![]() |
Groans: 112
| Not Ranked : 0 score I personally prefer Justin from freektune but they're plenty of other quality options on here.
| The Following User Says Thank You to Djohns For This Useful Post: | KiwiFlavor (12-20-2016) |
![]() | | #21 | ![]() |
![]() Join Date: Mar 2008 Location: Jacksonville, NC
Rep Power: 2469 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 810
Groans: 60
| Not Ranked : 0 score Replace the AP with Versatune..
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks |
| The Following 2 Users Say Thank You to SSinstaller For This Useful Post: | KiwiFlavor (12-20-2016), WetzMS3 (12-20-2016) |
![]() | | #22 | ![]() |
Groans: 283
| Only if he wants to self tune. AP is good if he does the Etunes and the AP itself is a good tool to monitor 6 parameters on one screen at CAN speeds. Sent from my Pixel XL
![]() | | #23 | ![]() |
![]() Join Date: Oct 2013 Location: Fort Myers, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 976
Groans: 438
If they made a VersaTuner app for Android, something I can connect an old nexus 6 to, fire up the program, connect cable like AP, and monitor at the CAN speed, my AP and ATR copy will be for sale in an instant.
__________________ All good things must come to an end... | |
![]() | | #24 | ![]() |
![]() Join Date: Mar 2011 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| Not Ranked : 0 score Wow, I guess we're back to the being nice people forum? I agree with @WetzMS3; also. Some of the items depend on how long you think it will take to get them all. If you're tight for money, I'd change the order to get the biggest bang first, then smooth it out with the other items. IMHO #s 4 and 5 could be skipped or wait til the end, in addition to what the others said
__________________ Max Bolted and Built Stock K04 |
| The Following User Says Thank You to sheston For This Useful Post: | WetzMS3 (12-20-2016) |
![]() | | #25 | ![]() |
![]() Join Date: Apr 2013 Location: Evanston, IL
Rep Power: 1329 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 938
Groans: 57
Groaned at 7 Times in 6 Posts
| Not Ranked : 0 score Every now and then, we need to be nice to people who don't get butthurt about their n00bness and initial posts. Keeps information fresh and allows us a chance to flex mental muscles about current knowledge of mazdaspeed platform mods.
__________________ "you, sir, are the most knowledge slow guy I know. Stop fucking around and drive faster." -feejay "if anyone else acts a fool, we'll punish them to Roberts oil hut to discuss string alignment technique" -wetzel | |
| The Following 2 Users Say Thank You to zenit For This Useful Post: | Kavik (12-21-2016), KiwiFlavor (12-21-2016) |
![]() | | #26 | ![]() |
Groans: 60
It's going to get really expensive paying for etunes as these parts are added over time.
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks | |
![]() | | #27 | ![]() |
Groans: 283
The Cobb AP is great at what it does. And it can also do hybrid tunes while VersaTune is a bit more actively updated, it's only can do Load based tunes for now. And those etunes don't have to be expensive. Anyone can do OTS+ tunes for about $50. Sent from my Pixel XL
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
| The Following 2 Users Say Thank You to MS3Shadow For This Useful Post: | Kavik (12-21-2016), KiwiFlavor (12-21-2016) |
![]() | | #28 | ![]() |
Groans: 57
| Not Ranked : 0 score Some people are okay with that.
| The Following User Says Thank You to zenit For This Useful Post: | KiwiFlavor (12-21-2016) |
![]() | | #29 | ![]() |
| Not Ranked : 0 score OP for number 22 on your list, these will be good too Cross Drilled Brake Lines - $72.95 : KaleCoAuto.com, Your home for the rare, unusual, and hard to find auto parts.
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | Kavik (12-21-2016) |
![]() | | #30 | ![]() |
Groans: 143
I finally read the OP. @Kavik; you actually have a reasonably well put together list there. Let me write down my recommendations: You need: 1) As much seat time as humanly possible. Attend as many autocrosses, track events, and driving schools as you possibly can. 2) Tuning (Versatune or Cobb), HPFP internals, MAP sensor 3) Motor mounts, except use the Damond Trilogy, not the JBR trilogy (trust me, worth the money) 4) Test pipe 5) Intake (recommend HTP 3") 6) E85 tune 7) Some kind of shock upgrade, eg Koni Yellow, Bilstein B6, as the stockers are short-lived 8) Real tires. I recommend Michelin Pilot Super Sport. Things you might want, but don't need: 1) 3" TBE (makes the turbo spool significantly faster) 2) Some MAC solenoid-based EBCS kit, eg Cobb, Grimmspeed, JBR (the valves are all the same) Things you don't really need: 1) Clutch - unless it's slipping, don't bother. The stock clutch is great. I do recommend the ACT when it eventually dies, though 2) Intercooler - E85 will make all of your knock problems go away anyway 3) Brakes - stock brakes are good enough. Leave them for now. 4) Spark plugs - the stock ones are awesome. Keep using them and change every 60k miles according to the FSM. 5) Plus all the other shit you mentioned like the cams...
__________________ 2007 Mazdaspeed3 GT | |
| The Following 2 Users Say Thank You to MD1032 For This Useful Post: | Kavik (12-21-2016), KiwiFlavor (12-21-2016) |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Greatly appreciate the feedback from everyone, so after everyone's input and little more research I've come up with the following which will fit my power needs and keep my daily driving from being too harsh (60 miles a day for work, sometimes in stop and go highway traffic - fellow VA speed owners will understand the horror of I-95). 1. CS HPFP Internals 2. HTP 3.0" Full Intake System 3. Cobb SS 3" Turboback Exhaust 4. Cobb XLE BPV Get 1 - 4 installed and set with a custom E85 e-Tune by either Freektune or Stratified Then finish with... 5. Damond Motorsports OCC Stage 1 Kit w/ VTA Then replace as needed the brakes/rotors/tires/shocks/clutch and if my power needs increase, come back here to ask for more recommendations. Rotors/Brakes: eLine Cross Drilled and Slotted w/ Premium Ceramic Pads & StopTech STAINLESS STEEL Brake Lines Shocks: Koni Yellows Tires: Michelin Pilot Sport A/S 3+ (live in a townhouse, no room to store separate types) Clutch: LuK 10-064 Kit w/ Fidanza Flywheel Also if it matters, I plan to run Shell T6 Rotella 5W40 Full Synth Oil with Napa Gold Oil Filters when I do my first oil change with it - didn't research any other fluids, could use recommendations for those whenever they need to be flushed and replaced with. Last edited by Kavik; 12-21-2016 at 08:23 AM. Reason: Cuz Kiwi |
![]() | | #32 | ![]() |
Per @WetzMS3; suggestion
![]() | | #33 | ![]() |
So with that said... instead of the Blanks, would the Centric C-TEK Drilled/Slotted be better than the eLine? Last edited by Kavik; 12-21-2016 at 08:07 AM. Reason: Typo fix and question added. | |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Btw... Please do not follow my suggestion on that brake line.. Unless you want to stick your foot out the door everytime you want to stop.
![]() | | #35 | ![]() |
Oh, ha, I got it - started to actually look at other parts on the site. Last edited by Kavik; 12-21-2016 at 08:14 AM. Reason: for the lolz | |
![]() | | #36 | ![]() |
| Not Ranked : 0 score I was just trolling. Any holes in brake lines are bad dude.. lol
![]() | | #37 | ![]() |
| The Following User Says Thank You to Kavik For This Useful Post: | KiwiFlavor (12-21-2016) |
![]() | | #38 | ![]() |
Groans: 143
| Not Ranked : 0 score FWIW I use stock brake lines and stock rotors with Hawk HP+ pads and anyone who has been in my car can attest to the fact that it stops a lot better than most other setups. I don't understand why you feel the need to use the drilled rotors. They are going to be more prone to cracking and will give you less braking force relative to a solid rotor. Personally I do not like the Koni Yellows, and they aren't going to do much for you when you're using shit all-season tires like those Michelins. I also hold the unpopular opinion that oil catch cans are useless on properly working stock engine cars. I use a bone stock PCV setup on my car and have (unsurprisingly) never had any problems with it. No matter what oil you use, do yourself a favor and have oil analysis performed on it every single oil change. You will see problems long before they manifest in a catastrophic fashion.
| The Following 3 Users Say Thank You to MD1032 For This Useful Post: |
![]() | | #39 | ![]() |
![]() | | #40 | ![]() |
![]() Join Date: Feb 2014 Location: Omaha, NE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Stafford sucks. Moved there in high school and lived there 10 years. Fucking miss Wawa tho. I would put more emphasis on wheel/tire/suspension. Ditch the crap other people have already stated. After basic bolt ons I would do an upgraded turbo. You can get a bnr bundle for a decent price. Plan on injector seals, pcv valve, occ, and cleaning your valves. Based on your list looks like you have just a bit more research and reading to do. |
| The Following User Says Thank You to Hansonjw For This Useful Post: | Kavik (12-21-2016) |
| Question about SRI/TIP in upgrade path | shane5747 | 2010 MS3 - Turbo Induction | 28 | 01-29-2016 02:33 PM |
| 2010 ms3 suggested upgrade path | Hungsohlo | Mazdaspeed3/6 General Discussion | 1 | 05-11-2015 09:03 AM |
| Upgrade path | leadf1nger | Gen2 MS3 General Discussion | 5 | 08-12-2013 07:59 AM |
| What's next in my upgrade path? | ABSpeed3 | Mazdaspeed3/6 General Discussion | 17 | 11-29-2011 09:38 AM |
| endlink upgrade needed w/ ASB upgrade? | red07 | MazdaSpeed 3/6 - Suspension & Brakes | 12 | 11-26-2008 01:34 AM |
