![]() | | #1 | ![]() |
![]() Join Date: Jun 2013 Location: Long Island, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
Groaned at 7 Times in 3 Posts
![]() Join Date: Sep 2015 Location: Brick, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,356
Groans: 50
Groaned at 7 Times in 6 Posts
__________________ 2011 Mazdaspeed3 w/ tech package Totaled/ R.I.P. | |
| The Following User Says Thank You to robbspeed For This Useful Post: | speedre (11-15-2015) |
![]() Join Date: Jun 2014 Location: Savannah , GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score Did you run it then check the oil? You don't have to fill the filter before hand. I never do. Sent from my SM-N920P using Tapatalk
__________________ UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC |
| The Following 2 Users Say Thank You to tmillner For This Useful Post: | ALPINEST4RS (11-20-2015), speedre (11-15-2015) |
![]() | | #4 | ![]() |
![]() Join Date: Nov 2011 Location: Houston Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 117
| Not Ranked : 0 score Its definitely recommended to fill the filter prior to install, but one time wont hurt the engine. Props to you for changing your own oil. There is quite a bit of satisfaction in saving money, and knowing the job was done with with (hopefully) quality parts. The drain plugs are o-rings should be changed with each oil change, but again, one time shouldn't hurt.
__________________ 2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks 2003 A4 1.8TQ APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars. |
| The Following User Says Thank You to texasboy21 For This Useful Post: | speedre (11-15-2015) |
![]() | | #5 | ![]() |
![]() Join Date: Sep 2012 Location: Phoenix, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
Groans: 89
| Not Ranked : 0 score Your fine. Most dealers and oil change places don't pre-charge the oil filter. As for oil level. Drain it, put in 5qts, run it for a few minutes, let it sit a few minutes, check level, add as needed. Most of these cars seem to take around 5.5qts.
__________________ 2007 MS6 GT: HTP 3" Full Intake, CS TMIC, AutoTech Internals, APv3, Forge Version 2 BPV(Blue+1 Shim), CP-E Catted DP, Whiteline RSB, CP-E Rear Diff mount, CP-E RMM, CS transmission mount insert, JBR Stage 2 OCC, JBR Boost tubes and recirc hose, Bilsteins B6's all around, Techna-Fit SS clutch and brake lines with ATE fluid, FreekTuned! |
| The Following User Says Thank You to Big Dog For This Useful Post: | speedre (11-15-2015) |
![]() | | #6 | ![]() |
![]() Join Date: Jul 2008 Location: Colusa Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
| Not Ranked : 0 score gen 2 has spin on filters? i dont get how you can pre-charge a cartridge filter |
![]() | | #7 | ![]() |
![]() Join Date: May 2010 Location: SLC, Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score I pre-charge my cartridge filter just like you'd check your compression. Turn the engine over for a few seconds with clutch and gas in. It won't bring oil pressure up to operating levels but it will push oil throughout the engine.
__________________ 2009 MGM MS3 - / HTP 3"/ COBB AP, FMIC, RMM, & DP / AT Internals / Manley Rods & Pistons / ARP studs & bolts / Koyorad radiator / DM OCCs / ACT Clutch / Bilstein B16 / CS Camber Plates, Camber Arms, & Seals / JBR .125 RSB, BSD, 51R Battery Box & Raider's AD / StopTech Brakes |
| The Following User Says Thank You to shamie For This Useful Post: | speedre (11-15-2015) |
![]() | | #8 | ![]() |
| Not Ranked : 0 score You don't need to pre charge the filter. Sent from my SM-N920P using Tapatalk
| The Following User Says Thank You to tmillner For This Useful Post: | ALPINEST4RS (11-20-2015) |
![]() | | #9 | ![]() |
Groans: 50
| Not Ranked : 0 score That's an interesting idea actually.
![]() | | #10 | ![]() |
(Thread Starter) | Not Ranked : 0 score I only drove it about a mile since the change but hadn't checked it. Did today and it was down to the min line so yea as you said guess it went to the filter. Thanks that was dumb of me, got another .7-.8ish in before it got to max line again.
![]() | | #11 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for the replies/advice everyone. Next time I'll add 5 qts, run car, then check dipstick again and add more accordingly. And replace O-rings. |
![]() | | #12 | ![]() |
![]() Join Date: Sep 2011 Location: Jacksonville FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score When you remove that oil filter on your next change, MAKE SURE the filter gasket comes off with it. You pre-lube the gasket for 2 reasons (and both are unlikely events): to keep it from binding when tightening down, and to keep it from sticking upon removal. If you put a new filter on over a stuck gasket, you will more likely have a leak/failure.
__________________ Traded in: 2012 MS3, CWP 2019 Dodge Charger Scat Pack 1986 Buick T-Type, square |
| The Following 2 Users Say Thank You to crankshaft For This Useful Post: | Easter Bunny (11-16-2015), speedre (11-17-2015) |
![]() | | #13 | ![]() |
![]() Join Date: Mar 2012 Location: Nashville, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 14 Times in 5 Posts
| Not Ranked : 0 score I keep seeing the "saves you money" comment, but it costs me $20 more to do it myself than if I get it done at the dealer. Not that I care, though. I like being in control and the dealer uses Kendall oil, which I know nothing about. |
![]() | | #14 | ![]() |
| Tachyonic Moderator ![]() ![]() Join Date: Nov 2013 Location: San Antonio, TX
Rep Power: 1969 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,076
Groans: 283
| i saved money. $28 for 6 quarts of T6 and a Wix filter.
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken |
![]() | | #15 | ![]() |
![]() Join Date: Mar 2011 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
| Not Ranked : 0 score If you push the gas petal to the floor and turn the key, it will turn over but not fire. I try to do this after an oil change as well as fill the filter. The way I beat my car, it should pay to be nice to it once in a while
__________________ Max Bolted and Built Stock K04 |
![]() | | #16 | ![]() |
![]() Join Date: Jun 2014 Location: Rolling Meadows, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42
| Not Ranked : 0 score Mine takes 5.7 usually, wouldn't worry about it honestly. As for the crush washer on the drain plug, I've been reusing it for a year with no leaks whatsoever. Is it recommended to change it, absolutely. Is it a big deal if you don't, not really. Same with prefilling the filter, recommended for sure, not a huge deal if you forget. Just remember to check your oil after the 5qts and do the dip, wipe, dip because for some reason it will read on minimum even though next time you dip and pull it out it will read the correct level. Not sure why that is, probably some science shit. To sum up, always check the dipstick twice.
__________________ 2011 Mazdaspeed3 Mod List: FREEKTUNED ETS TMIC Autotech HPFP Internals CS Stage II SRI + TIP Tial QR UR Catback UR Catless Test Pipe Damond RMM Damond SSP |
| The Following 2 Users Say Thank You to csmaan12 For This Useful Post: | Easter Bunny (11-20-2015), speedre (11-17-2015) |
![]() | | #17 | ![]() |
![]() Join Date: Jan 2014 Location: Fort Worth, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 342
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score Shoot, I recheck my oil level probably 4 times before I call it good. I'm a bit OCD though. Sent from my iPhone using Tapatalk |
![]() | | #18 | ![]() |
| Not Ranked : 0 score My last beater burned oil at a rate of about a quart every 1000 miles. It took more than year with the MS3 to break the habit of checking the oil every week or two.
| The Following User Says Thank You to crankshaft For This Useful Post: | Easter Bunny (11-20-2015) |
![]() | | #19 | ![]() |
![]() Join Date: Apr 2014 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 191
James
__________________ Ye Olde Engine: Cobb Accessport, Autotech Internals, Cobb SRI, Corksport TIP Pending a Tune: CP-E TMIC, ATP Catless Downpipe Suspension: H&R Springs, Koni Yellows, Hotchkis Front and Rear Swaybars, Corksport Front and rear Endlinks, Whiteline front Control Arm Bushings | |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for the further input everyone, appreciate it. As for cost, most places I went to would charge $75-100 for synthetic oil change. Is the T6 oil good Shadow? I got Mobil 1 synthetic and Mobil 1 filter for $48, so $28 would be even more of a significant savings. Good to know csmaan! I haven't seen any leaks so far, I'll do it next time but good to know it wasn't the biggest miss in the world.
Last edited by speedre; 11-17-2015 at 06:55 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #21 | ![]() |
| Not Ranked : 0 score T6 is good stuff and our cars seem to like it, plus it's pretty cheap. Normally doesn't cost me more than $32 for the oil and filter.
![]() | | #22 | ![]() |
| Not Ranked : 0 score All I've ever run was t6 fwiw. From the research i found it has held up the best From my understanding you can get single quarts from walmart rather than buy 2 gallons Sent from my SM-N920P using Tapatalk
![]() | | #23 | ![]() |
![]() Join Date: Aug 2012 Location: Hartland, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,583
Groans: 42
| Not Ranked : 0 score You buy 2 gallons then save the remaining half-gallon for your next oil change. This is the cheapest way. |
| The Following 2 Users Say Thank You to ArmanRus For This Useful Post: | Easter Bunny (11-20-2015), speedre (11-17-2015) |
![]() | | #24 | ![]() |
| Feline Führer ![]() Join Date: Feb 2013 Location: Jacksonville, FL
Rep Power: 2280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,422
Groans: 49
| Not Ranked : 0 score Did you trip over your filled pail of old oil and spill it all over your driveway? If you didn't do this, you're doing your oil change wrong.
__________________ Official CatDickRacing Sales Rep - All products backordered. |
| The Following User Says Thank You to neganox For This Useful Post: | Easter Bunny (11-20-2015) |
![]() | | #25 | ![]() |
![]() Join Date: Oct 2012 Location: Austin, TX
Rep Power: 282 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 406
I'm more a fan of changing the oil IMMEDIATELY after I shut off the car. That way, when I attempt to spin off the filter (Genwon spin-on conversion for me) I get scathing hot oil on my hand then instinctively drop that filter into the scathing hot pan full of oil so it can then splash all over my shins.
__________________ 2008 Mazdaspeed3 GT JBR TRU 3.5 Aluminum WP // Corksport TBE // JBR OCC Stage 2 // AP v3 (Tweaked [by me] E40 Tune) // Autotech Internals // Stratified EBCS // TWM Full Replacement w/ Type R Knob // CP-e Stage 2 RMM // JBR/Damond Full EGR Delete // Synchronic DV // NGK 6510s // FMIC [TR8 w/ JBR Pipes] // CorkSport Adjustable Struts/Lowering Springs // Progress RSB Jet Black Wax (06/24/2017) Better compression than Silaramic (02/20/2016) | |
![]() | | #26 | ![]() |
Groans: 283
sent from my Nexus 6P
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
![]() | | #27 | ![]() |
| Not Ranked : 0 score No matter what precaution I take, I always manage to get some oil on the floor. Drip pans, rags, towels....hell I could line the whole fucking garage with plastic, and still manage a spot somewhere. and that's taking into consideration that the MS3 is one of the cleanest and easiest changes I've owned (aside from a Ford Exploder that I didn't even need to jack up). Exploder #2 : the plug was on the side of the pan so upon removal the oil spewed out and splashed off of the suspension parts. My wife's Murano: I need to remove the front wheel, and a splash guard to access the filter - then I need to wedge a funnel under the filter. My daughter's CRV: the filter is on the side of the block so that oil goes EVERYWHERE. I change that shit in the street....there's no containing it.
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score I used the auto shop on my military base, so I had the car on a lift and they gave me a rolling tank with a tray on top to catch the oil with...there was a good 3 ft between the oil drain plug. That was definitely a rude and hot awakening..needless to say I'm glad I took my uniform top off...
![]() | | #29 | ![]() |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
Auto hobby shop is where its at!!! I am there atleast once a week. $5/hr for lift and tools. Cant beat it
I have never changed the crush washer in 4 years lmao. No leak at all.
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned Last edited by blackms3_71; 11-17-2015 at 08:42 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score That was my 1st time there, totally worth it! Really wish I had access to that back when I was doing all my bolt on mods... |
![]() | | #31 | ![]() |
| Not Ranked : 0 score It's wedged so hard on the drain plug that I'd probably damage the bolt if I tried to replace it with a new one so I don't even bother. Seals fine so screw it, I'm leaving it on.
![]() | | #32 | ![]() |
![]() Join Date: Jun 2015 Location: Newark, Delaware
| Not Ranked : 0 score I miss being military, I used to live in the auto skills centers lmao. People probably still talk about my rx7 build at Ft Campbell because it was in the bay for a full month while I swapped it. I've been wishing someone would open one for civilian use here in Delaware, I heard phili has one but they charge triple what I was used to. As far as crush washers, I've only changed a few for oil drain (every time with brake lines though). What I found and been using for years on various cars is the magnetic drain plug, it's kind of a nice warning indicator if something is about to fail. Added pic of my old rx7 in the Fort Campbell diy auto skills center "north" |
![]() | | #33 | ![]() |
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score This is a hell of a thread for an oil change.
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
| The Following User Says Thank You to HawkeyeGeoff For This Useful Post: | Easter Bunny (11-20-2015) |
![]() | | #34 | ![]() |
Groans: 50
| Not Ranked : 0 score Right? I think he knew how to change his oil like a week ago.
![]() | | #35 | ![]() |
| Raider is mah Homie ![]() Join Date: Jan 2011 Location: Towson, Maryland
Rep Power: 7524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54,831
Groans: 2,978
| Not Ranked : 0 score dont waste your money on Mobil 1 next time, its not actually synthetic, its a blend. Use either Rottella T6 which is cheaper or Amsoil which is comparable in price to Mobil 1 but is actually a full synthetic and vastly superior oil
__________________ ![]() I hugged rfinkle2 | |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score a few others recommended either Penzoil platinum or castrol syntec for synthetic. much difference between all these?
![]() | | #37 | ![]() |
Groans: 50
| Not Ranked : 0 score Check out the oil change and U.O.A. threads that are already established.
| The Following User Says Thank You to robbspeed For This Useful Post: | Easter Bunny (11-23-2015) |
![]() | | #38 | ![]() |
| Not Ranked : 0 score Change your crush washer, use a pair of pliers to get it off. I do it every day Sent from my SM-N920P using Tapatalk
![]() | | #39 | ![]() |
I see no point. Been 4 years and not a drop of oil leaked out
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned | |
| The Following User Says Thank You to blackms3_71 For This Useful Post: | Easter Bunny (11-23-2015) |
![]() | | #40 | ![]() |
| Transmission Oil change question | maxspeed | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-03-2013 12:50 PM |
| Oil change question | smandrews | MazdaSpeed 6 - Engine, Transmission & Driveline | 11 | 12-16-2011 11:02 AM |
| Man buys truck with change, LOTS of change | Haltech | Automotive News | 1 | 08-14-2008 09:15 AM |
| WD My Book Home 750GB eSATA/USB/FW Ext Hard Drive $179.99 Free Shipping at Dell Home | Haltech | Hot Deals Section | 0 | 04-15-2008 10:50 AM |
