Like Tree3Likes
 Old 11-17-2015, 10:31 AM   #81
Insiatent's Avatar
Posts: 97   (View Stats)
Insiatent has a spectacular aura aboutInsiatent has a spectacular aura aboutInsiatent has a spectacular aura about
Hmm maybe i wont be fine with the intake after all, it might just be me because i tend to get paranoid when i mod a vehicle, but after 500km, i think i may actually lost quite a lot of mpg, like the mpg counter screen show wrong result or something, it drops 1km each 5-800m i travel, on highway with granny foot, and may feel a power loss, but its probably just me.
I should get my obd bluetooth dongle this week, is there a way to be sure with this thing?
Insiatent is offline   Reply With Quote
 Old 11-17-2015, 10:42 AM   #82
Gizmo's Avatar
Gizmo is a name known to allGizmo is a name known to allGizmo is a name known to allGizmo is a name known to allGizmo is a name known to allGizmo is a name known to all
Your best investment would be access port, you can find a second hand version 2 one on the sales board if you become a vip member which also worth it. Access port will allow you to see all your ecu parameters, and down the road allow you or and tuner to tune your car. Even tuning your car can with just a intake might get you back some mpg and get you the most out of the intake.
Otherwise obd bluetooth dongle and a app on your phone can give you some of the parameters you might be looking for, but they tend to have bad read rate, so your scope of data is not very accurate, and no where near as good as a access port.
Perfromace Bits
JBR Chromoly 88A RMM/JBR Powerpath Stage 2/JBR SSP/Access Port V2/Dizzy Tuning 91 tune/ CorkSport HPFP Internals
Ricer Bits
RallyArmor Mudflaps Black-Red/Eonon GA7163
Gizmo is offline   Reply With Quote
 Old 11-17-2015, 11:02 AM   #83
SpeedBen's Avatar
Posts: 22   (View Stats)
SpeedBen is an unknown quantity at this point
Salut!
If I was you I would go full stock for the winter and get your parts/budget during winter and install everything at spring time.
One thing I learned about the gen2 is that it's a hit or miss in regards to the stock fuel pump. You will read some cases on this board where people have a put a SRI and data logged via an AP and they had no values < 1800 psi. On the other hand there have been some cases where people had the exact same build and logged values < 1800...same parts, different values.
This is why most people recommend to upgrade to HPFP/AP as you need to log your fuel pressure. Is it mandatory? No...but are you willing to take the risk? Up to you
Au plaisir!
SpeedBen is offline   Reply With Quote
 Old 11-17-2015, 11:40 AM   #84
Insiatent's Avatar
Nah i wouldnt take the risk.
At first i wanted to get a hpfp, but first ill check fuel pressure with the obd2 dongle, it may not be very accurate but it will tell me if i am close to danger zone right? (1200 and minus?)
If its the case then hpfp is next on list, if its fine then AP, hows that sound?
But like you said, i wont get bunch of mods untill next years, only wanted sri and AP
 Old 11-17-2015, 12:40 PM   #85
broda's Avatar
Posts: 375   (View Stats)
broda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the worldbroda is the leader of the world
For Gen2 it's below 1600 at WOT is the danger zone.
broda is offline   Reply With Quote
 Old 11-17-2015, 01:53 PM   #86
Insiatent's Avatar
Thats still a lot of pressure, how come its too low?
 Old 11-17-2015, 01:59 PM   #87
alan1592's Avatar
Posts: 110   (View Stats)
alan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant futurealan1592 has a brilliant future
Anything bellow 1600 is low.
2006 Mazdaspeed 6, AccessPORT V2, CP-E CAI, Catless DP, and Solid MM's.
alan1592 is offline   Reply With Quote
 Old 11-19-2015, 02:42 PM   #88
Insiatent's Avatar
So i got my dongle and made a quick test.
Normal driving: 500-1300 psi fuel rail (depend on speed and climbing)
14-15 AFR
WOT : 1700-1800 psi and 11-12 AFR
 Old 11-19-2015, 07:16 PM   #89
Insiatent's Avatar
Oh and 29 AFR on deceleration, thats normal right?
By the way, those number are good right? They looks fine to me.
 Old 11-20-2015, 07:24 AM   #90
Jeff23spl's Avatar
Posts: 2,238   (View Stats)
when you release the pedal, pressure and gaz injection decrease. When you completly lift off, you shut down any injection so yes it is all normal...
You need to read the pressure on a constant load/pedal because if for any reason the throtle is released, a lower pressure will be commanded and you may think it is a bad pump when it just do the commanded job.
The same happend when a protections turns on and call the throttle to close, it also command the pressure to drop...
The Cobb AP return a better view when logging more parameter to make sure the pressure drop isn't commanded.
But usually, when you need a pump, you will see at first a very low AFR or rich mixture under wot. It is unusual to see a rich mixture with a lack of gaz pressure but with our pcm there is a protection mode that flood the engine when pressure is too low from a failling pump. Not sure if it really works at protecting it but it could be a sign of a failing pump.
Probably when you go further with more air flow and less fuel, you will get lean conditions, like other car will do.
Anyway AFR below 10 should rings the bell to investigate further. There could be other issues but all of them should be checked...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 11-20-2015, 07:43 AM   #91
Insiatent's Avatar
Alright thanks for info.
So at this point im still fine, even with a sri, afr wont go under 11.5 under wot, though like you said, dongle wont be very accurate, i guess i should go for an AP first instead of hpfp at this point.
 Old 11-20-2015, 02:33 PM   #92
Jeff23spl's Avatar
the reading will be accurate but it is the sampling rate that is slow enough to miss something important. A log with the AP will catch a lot more...
Wife drive 2010 CX7
 Old 11-20-2015, 07:47 PM   #93
Insiatent's Avatar
Alright i get it, mine does a tick rate of about 3 per second.
 Old 02-18-2016, 09:58 AM   #94
Insiatent's Avatar
Ok so its been a while and snow is gonna melt in not too long.
I wanna achieve 300whp, no heavy mods, as far as i know i will need.
Cobb AP, OST map untill everything is in, then freektune.
HPFP
CAI and TIP
ITV22 spark plug
And a downpipe, will run 91 fuel.
But my question is, from what ive read, the power gain from a full downpipe is very minimal, and i could get pretty much all that gain with just a racepipe/testpipe, and with minimal cost, and less hassle to install. Is that true?
 Old 02-18-2016, 11:30 AM   #95
Jeff23spl's Avatar
I would be surprise that you can make that much while keeping the first cat. IMO, it is the most restrictive point on the exaust line.
Also, i'm not expert but the 91 fuel would probably need something else to safely reach your goal with a k04. Something like w/meth...E85 etc...
Wife drive 2010 CX7
Vansquish (02-18-2016)
 Old 02-18-2016, 11:34 AM   #96
broda's Avatar
Yeah, you're not reaching 300whp with those mods and 91 octane without using E85. Also I think most people would recommend sticking with stock heat range spark plugs as well.
The Following User Says Thank You to broda For This Useful Post:
 Old 02-18-2016, 12:29 PM   #97
Speedling6's Avatar
Posts: 155   (View Stats)
Speedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond repute
HPFP
CAI and TIP
ITV22 spark plug
You're on the right track, just a few notes (sorry if i restate something)
1. At the very least do HPFP and AP at the same time.
2. Ditch the CAI. Because the air your car is sucking in is going to be heated back up by the turbo anyway, your gains going CAI vs SRI are going to be negligible. In addition you can get a bigger SRI than you can a CAI because of space. (I'd recomend JBR or HTP because they replace both the intake and TIP with one pipe.
3. As was stated keep stock heat range plugs.
4. Look into an intercooler upgrade.
After all that with a DP you should at least be close to your goal, and if not you would have to consider a WMI system (which would definitely get you there) or getting less restricted exhaust side.
Speedling6 is offline   Reply With Quote
 Old 02-18-2016, 12:36 PM   #98
GEE1989's Avatar
Posts: 182   (View Stats)
GEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant futureGEE1989 has a brilliant future
+1 on this
Sent from my SM-G920P using Tapatalk
08 MS3
Corksport turbo, built motor, meth injection, and FREEKTUNED
GEE1989 is offline   Reply With Quote
 Old 02-18-2016, 04:44 PM   #99
Insiatent's Avatar
Sounds good, thanks, and woops i meant sri and not cai, i already have a cobb sri
Theres no such e85 in québec. :\
But about the DP, would it really worth a full dp upgrade with stock k04?
 Old 02-18-2016, 06:33 PM   #100
GEE1989's Avatar
Hell yea it'd be worth it. It adds a good bit of power after you tune it plus it give the car a mean growl
08 MS3
 Old 02-18-2016, 06:45 PM   #101
Insiatent's Avatar
Alright thanks, i will forget the test pipe and get a downpipe.
What about a cheaper, ebay and catless dp?
Like this one Stainless Racing Turbo Downpipe Exhaust 07 13 Mazda 3 MPS 2 3 Turbo MAZDASPEED3 | eBay
Are they known to not fit right, break easily or something?
 Old 02-18-2016, 07:31 PM   #102
blue speed's Avatar
Posts: 237   (View Stats)
blue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond repute
Groaned at 4 Times in 1 Post
Check out Ultimate Racing DP and RP they are in Canada.
Cobb shifter weight, CBE, RSB, knob Corksport BPV, boost tubes, SRI, TIP ,Ex hangers,80 Duro RMM & TMM insert CP-E TMIC, UR test pipe & catted DP, Hypertech, Autotechs. JBR Coolant bypass, intake gasket, air filter & BP hose.Konig wheels. Sure, FSB bushings.
blue speed is offline   Reply With Quote
 Old 02-18-2016, 08:40 PM   #103
broda's Avatar
eBay downpipes are hit or miss. Some people have no problems with them and others aren't worth a damn.
 Old 02-19-2016, 05:37 AM   #104
jm211's Avatar
Posts: 944   (View Stats)
jm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the world
Groans: 52
Custom Tune, 3.5 inch intake, top mount IC upgrade, HPFP, test pipe.
This should get you very close with 91 octane only.
Colder plugs ONLY IF your tuner is exhausting all efforts to reduce kr without pulling too much timing.
Black Mica 2006 Speed6 GT | 62,000 Miles
Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1
ms6db.com I'm Registered. Are You?
jm211 is offline   Reply With Quote
 Old 02-19-2016, 06:52 AM   #105
GEE1989's Avatar
Numbers are numbers though. Doing that will make your car a blast to drive and that's what really matters
08 MS3
The Following User Says Thank You to GEE1989 For This Useful Post:
Dustintomi (02-19-2016)
 Old 02-19-2016, 07:13 AM   #106
Jeff23spl's Avatar
Exact, peoples takes goal looking at other cars but numbers are just numbers, especially if you mix Mustang dyno WHP with Dynojet or VD...
i don't want to start a debate on it but just mention it is different units of measure where it makes a goal harder or easier to reach.
Then trying to do everything at once it isn't always the best, someone can take is time and install parts in the correct order to upgrade it more and more...
You can probably just start with the AP and HPFP to release some HP if you don't want the DP yet.
Then a DP with a shelf tune for a more significant upgrade.
Then a new and larger SRI than the stock 2.64'' ID + TIH
IC upgrade, (read and pick the one that suit your best needs between tmic or fmic)
W/M + a tune
3 way EBC
Than your k04 may start smoking and instead of replacing it, you could enlarge it
It often a never ending story....
Wife drive 2010 CX7
 Old 02-19-2016, 07:32 AM   #107
GEE1989's Avatar
W/M + a tune
3 way EBC
Haha you said my story pretty well. If you want reliable go little by little and have every mod tuned. I started with intake, hpfp internals, rmm and ap. When I got that I said this will be good enough for what I want....... then I got used to it and got turbo back exhaust and tmic. Not too long after that was tuned, bye bye turbo. Stock turbo went. So I got the corksport turbo. Had that all tuned then timing chain failed, skipped timing, went zoom zoom boom. So just be prepared to spend some serious money. Im not saying this will happen to everyone but I'm just saying as you keep adding mods...... shit happens!!!
08 MS3
 Old 02-19-2016, 07:40 AM   #108
GEE1989's Avatar
Im not saying this to deter you from modding but I was prepared to spend money if shit went south. Rebuilding isnt cheap. I don't know what you're budget is or anything but just be smart and make sure you do regular maintenance and get shit tuned!!!! E tune is 200. Factor that into every mod you get
08 MS3
 Old 02-19-2016, 08:27 AM   #109
Insiatent's Avatar
Yeah thanks! I have been saying 300whp but heck it doesnt have to be exactly there, dont want heavy mods like i said, its still my DD cars, even for winters... Id rather avoid using meth inj.
For now ill focus on hpfp and AP.
 Old 02-19-2016, 08:38 AM   #110
GEE1989's Avatar
It'll be a nice fun car to daily drive that's for sure. You might want to look at getting one of these oil feed banjo bolts that's supposed to help with the k04 from smoking. I haven't used it but maybe some other members could vouch for this?
08 MS3
 Old 02-19-2016, 08:38 AM   #111
GEE1989's Avatar
08 MS3
 Old 02-19-2016, 09:09 AM   #112
Dommo14's Avatar
Posts: 694   (View Stats)
Dommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the worldDommo14 is the leader of the world
It took me 20 minutes to learn to drive a manual. The only tricky part is starting on a hill in traffic... once you get moving its pretty easy.
Dommo14 is offline   Reply With Quote
 Old 02-19-2016, 10:42 AM   #113
Insiatent's Avatar
Attachment 221939
Will check thanks
And by the way, i got used to manual a while ago now XD
 Old 02-19-2016, 10:44 AM   #114
GEE1989's Avatar
Once you learn you'll never want a car that's not manual
08 MS3
 Old 02-19-2016, 10:46 AM   #115
Insiatent's Avatar
True, now i dont want to go back to auto, ever.
 Old 02-19-2016, 12:15 PM   #116
Jeff23spl's Avatar
The k04 spin very fast and make a lot of heat when you try to take it up to 300whp so is lifespan decrease a bit quicker...
There is a lot of thread about it and about few option to help.
PS please stop using ''winter driving'' as an excuse. I DD mine too in the same conditions with a BT and meth :-)
Wife drive 2010 CX7
 Old 02-19-2016, 12:53 PM   #117
Insiatent's Avatar
Yeah, your right, i could consider meth but not untill a while
 Old 02-19-2016, 03:35 PM   #118
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Comes in reconsidering first mod, leaves considering meth. Typical.
Speedling6 likes this.
 Old 02-19-2016, 03:40 PM   #119
Speedling6's Avatar
Thats how we do, son.
Sent from my SM-N920V using Tapatalk
2006 Black Mica Mazdaspeed 6 GT
Power: JBR Tru 3" aluminium wide path intake; CP-e TMIC; Autotech HPFP internals
Tuning: Cobb Acessport V3; Custom FREEKTUNE
Support: Corksport RMM; Corksport Rear Diff Brace; Sure Jugg
 Old 02-19-2016, 03:45 PM   #120
GEE1989's Avatar
Knowledge is power lol
08 MS3
07 MS3 GT Car Manual thatkidrjay Mazdaspeed3/6 General Discussion 6 05-15-2015 12:02 PM
Manual Transaxle service manual Identification SpecialK Mazdaspeed3/6 General Discussion 5 11-29-2013 11:36 AM
My first manual :) Seven20Seven Gen2 MS3 General Discussion 44 06-05-2011 09:58 AM
Manual Transmission rebuild manual Doc-1 MazdaSpeed 3 - Engine, Transmission & Driveline 5 07-07-2009 08:57 PM
Page generated in 0.55451 seconds with 32 queries
