![]() | | #41 | ![]() |
![]() Join Date: Jan 2012 Location: Cape coral, FL
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score
__________________ Torque steer so hard, wheel falls off, that shit kray. |
![]() | | #42 | ![]() |
![]() Join Date: Jan 2012 Location: darlington, md
Rep Power: 160 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 288
Groaned at 4 Times in 2 Posts
Yes, its what its meant for. Take a look at this link it should answer all your questions http://www.accessecu.com/accessport/...20Bulletin.pdf
__________________ 2012 MS3-COBB AP, SRI, TIP, air box; Autotechs; CS TMIC, strut bar, lca bar, occ, boost tubes, flaps, hangers; Forge BPV v2; TWM full replacement; Cobb rmm; ebay dp; UR ABE; NGK 6510; DDM 5000K; Dizzy tune in progress |
| The Following User Says Thank You to Ryguy For This Useful Post: | juanms3 (08-18-2012) |
![]() | | #43 | ![]() |
![]() Join Date: Dec 2011 Location: Baltimore, MD
Rep Power: 381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 531
| Not Ranked : 0 score Yes, but if you have changed ANY hardware, even a simple intake upgrade, search and look for "low CDFP fuel pressure" or "low fuel pump pressure."
__________________ 2012 Black Mica MazdaSpeed3 Mods (in order of significance): Cobb AccessPort, Autotech CDFP upgrade (thanks Captain KR for your assisstance), Cobb SF SRI Intake, Ultimate Racing cat and resonator-less test pipe, Cobb Turbo Inlet Hose, Cobb Knob, Cobb 300g shifter weight Tune: My own (based on the v210 and v231 Cobb OTS maps but ramped way up) Street creds: - Fastest known K04/93 MS3/driver with only an AP, CDFP upgrade, intake, and tune | 13.37@106.83mph on stock Dunlops (2.04 sec 60' time, full curb weight, 75*F ambient temp) - Has gone an indicated 146mph on three occasions now. Yes I will help you tune your K04/pump gas car; I have much less experience than the major players but I also charge you $0 and can turn you around quickly. 4 satisfied customers and counting... |
![]() | | #44 | ![]() |
![]() Join Date: Aug 2011 Location: Columbus, Ohio
Rep Power: 90 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 50
If i have a Cobb AP and a Cobb SRI - are the stock plugs good, or do we need the Denso ITV 22's??
__________________ The Money Pit: 2011 MS3 - Mica Black - Tech Package - Cobb SRI, AP, Hella horns, JBR Heavy Shift Knob, Sure Shortcut! The Slut: 2009 Suzuki SV 650S - pair system mod, Sylvania UltraStar bulbs, rear fender delete, aftermarket ferrings, Yoshimura Exhaust, & ATRE God created turbo lag to give all motor cars a chance. STRATIFIED TUNED! zoom zoom bitches... |
![]() | | #45 | ![]() |
![]() Join Date: Jul 2012 Location: Tampa, FL
Rep Power: 1011 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,345
Groaned at 28 Times in 20 Posts
From my understanding if you're still running stock boost levels then stock plugs are fine. Sent from my iPhone using Tapatalk
__________________ ![]() 99 Miata________________________<3_______________________08 MS3 |
![]() | | #46 | ![]() |
I had some fucking KR problems in my 1st gen MS3, i installed the ITV 22's on a hunch, it fixed the problem. (If i remember quite right- thats how it went down lol) I think my boost would spike a lil bit upto 18, something to do with the stock plugs not being able to handle that? I could be talking out my ass right now tho lol Ive been thru so much trial and error w my old car, thats i cant remember it all!
![]() | | #47 | ![]() |
Well I changed it to the stage 1 map with 93 octane and the car feels weaker and gas pedal is still lighter!
![]() | | #48 | ![]() |
![]() Join Date: Mar 2012 Location: Annapolis MD
Rep Power: 25 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 4 Times in 1 Post
You do have to give the car time for the ECU to relearn fuel trims and shit.
__________________ 2008.5 CWP MS3 Cobb AP, FMIC, Forge BPV V2, Cobb TIP, Cobb SF SRI, JBR 88 RMM, JBR RSB, Ford Transmission fluid, for those magical shifts. | |
![]() | | #49 | ![]() |
| Not Ranked : 0 score roughly 50-100 miles of mixed driving, dont push the car realy hard until then !
![]() | | #50 | ![]() |
| Not Ranked : 0 score I figured, thanks. How are is your HPFP holding up? I am thinking about upgrading it before anything else!
![]() | | #51 | ![]() |
dont know yet, my car is bone stock until i go to the stealership wed, i think i need a belt or pulley replaced. Thursday...I will put on my Cobb SRI, Reflash w the AP, shure short cut & JBR heavy shift knob...ill let u know then lol
![]() | | #52 | ![]() |
| Not Ranked : 0 score I'm still on stock plugs and 18.5psi and it runs fine. I am also thinking of a one step colder plug too. At our levels I doubt it will make a lot of difference.
![]() | | #53 | ![]() |
| "Sorry, gotta work." ![]() Join Date: May 2011 Location: Durham, NC
Rep Power: 178 ![]() Thanks: 1,112
Groaned at 6 Times in 6 Posts
65K miles on the plugs I bought the car with. I ran ITV22's for about 2k miles when one shit the bed. Now I'm back to 21psi to redline w/ 0 kr. If you do want plugs, I'd go with the NGK's over the Denso's though. Hmmm... Time to change my sig.
__________________ '08 Polar White Saturn SKY Redline BorgWarner EFR 6758, Energy Suspension Bushings and Diff Mount, WERKS EFR Manifold, 3-Bar MAP Sensors, FSB, Catted HiFlow Downpipe, Charge Pipes, Power-Steering Relocation Kit, Silicone Radiator Hose Kit, BC Coilover Kit, Single Valve Springs, FMIC, RPi GT CBE, HP Tuner, DDMWorks 2-gauge Pillarpod and Armrest, Prosport Electronic Wideband and Boost Gauges, xtuners.com Gauge Cluster, HID/LED Full Headlight and Interior Conversion Still waiting...'08.0 Cosmic Blue MS3 - "The Daily" COBB SRI/TIP - COBB AP SquishyTooned on E40 - COBB XLE BPV - HKS Hi-Power CBE - ITV22s - Corksport RMM Inserts - JBR Shifter Bushings and SSP - PTP Fuel Pump - PG + Treadstone - 35% Tint - ebaY Double-Penetrator - MS3 Vent Kit Install STOCKED OUT! (almost) ![]() Shane5747: Eric, can you ship your semen to me? |
![]() | | #54 | ![]() |
| Track Fiend ![]() Join Date: Jan 2012 Location: Canada
Rep Power: 162 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 586
| Not Ranked : 0 score |
| The Following User Says Thank You to Standsideways For This Useful Post: | fortressofcomfort (08-19-2012) |
![]() | | #55 | ![]() |
Ok so its been a week and I know I driven more then 100 miles but the car still feels the same, light gas pedal and weak as shit. 2nd gear feels weird...
![]() | | #56 | ![]() |
![]() Join Date: May 2011 Location: Johannesburg, South Africa
Rep Power: 77 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
Im at 5500 ft altitude and with the stage1 map I gained 42whp peak to peak and at 6100rpm gained nearly 100whp/100wtq. Yeah the stock map is major fail at altitude. I'm in south Africa by the way, and the runs were done on the same dyno, albeit some months apart.
__________________ 2007 Black Mica MS3 Go... COBB AP / Snow Performance WMI / 3" Catless Turboback / Custom 3" CAI / Custom 2.5" TIP/ Autotech HPFP / NGK LTR7 / Custom FMIC / Torque Solutions 75 Duro RMM / Powerbrake GT Brake upgrade Show... JL Audio 12W3V3-4 / Reference Audio 1200.1 / PAC AOEM MAZ2 / 6000k HID / Yellow Fogs / Coming soon... BNR Stage2 / 3bar MAP/ Stratified 3 port / freektune Currently 275 whp, 306 tq Ex: 2010 Velocity Red MS3.... Sold because buying a house is more important Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust 5500 ft altitude FTL MSF in South Africa |
| The Following User Says Thank You to Rich990 For This Useful Post: | fortressofcomfort (09-04-2012) |
![]() | | #57 | ![]() |
| Bro Bro Bro Bro Bro ![]() Join Date: Aug 2012 Location: Pembroke Pines, Florida
Rep Power: 114 ![]() Thanks: 49
Groaned at 21 Times in 2 Posts
Reading all these threads terrorized me into getting a fuel pump as my first mod. Then going AP and such
![]() | | #58 | ![]() |
![]() Join Date: Jul 2012 Location: Aberdeen, MD
Rep Power: 211 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 190
| Not Ranked : 0 score Don't forget you need something to monitor the fuel pressure when you do. Either get the AP at the same time, or pick up a cheap gauge to use until you do.
__________________ 2011 Speed3 w/Tech Package JBR 88 Duro RMM, JBR RSB, Autotech Internals, Corksport SRI/TIP, CX Racing FMIC, M2 Catless DP, Autolite XP5263 Plugs, HKS BPV because ricecar |
![]() | | #59 | ![]() |
![]() Join Date: Jul 2012 Location: Tampa, FL.
Rep Power: 35 ![]() Thanks: 43
__________________ LSM 2012 Speed 3 W/Tech | |
