 Old 08-18-2012, 07:25 AM   #41
juanms3's Avatar
Posts: 31   (View Stats)
juanms3 is a jewel in the roughjuanms3 is a jewel in the roughjuanms3 is a jewel in the roughjuanms3 is a jewel in the rough
Originally Posted by Ryguy View Post
The stage one is designed for a factory car. Stage 0 is a factory tune and is a non performance map. Cobb ots maps tend to be more linear than the factory tune.
So it would be safe to load the first stage 1 map on my stock car?
Torque steer so hard, wheel falls off, that shit kray.
juanms3 is offline   Reply With Quote
 Old 08-18-2012, 09:45 AM   #42
Ryguy's Avatar
Posts: 546   (View Stats)
Ryguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the worldRyguy is the leader of the world
Yes, its what its meant for. Take a look at this link it should answer all your questions
http://www.accessecu.com/accessport/...20Bulletin.pdf
Ryguy is offline   Reply With Quote
The Following User Says Thank You to Ryguy For This Useful Post:
juanms3 (08-18-2012)
 Old 08-18-2012, 09:59 AM   #43
RIP: November 21, 2012
fortressofcomfort's Avatar
Posts: 862   (View Stats)
Yes, but if you have changed ANY hardware, even a simple intake upgrade, search and look for "low CDFP fuel pressure" or "low fuel pump pressure."
2012 Black Mica MazdaSpeed3
Street creds:
 Old 08-18-2012, 10:32 AM   #44
thomas_cory2000's Avatar
Posts: 676   (View Stats)
thomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the worldthomas_cory2000 is the leader of the world
If i have a Cobb AP and a Cobb SRI - are the stock plugs good, or do we need the Denso ITV 22's??
The Money Pit: 2011 MS3 - Mica Black - Tech Package - Cobb SRI, TIH, AP, Hella horns, CP-E Stage II RMM, JBR OCC, SSB, ATP Catless DP, UR catback exhaust, Autotech HPFP Internals, Turbo Smart Kompact bpv, Sure Shortcut, DIY clutch travel mod, DMM tuning HID 4300K fogs, & Freek tuned!
zoom zoom bitches...
thomas_cory2000 is offline   Reply With Quote
 Old 08-18-2012, 10:53 AM   #45
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
From my understanding if you're still running stock boost levels then stock plugs are fine.
 Old 08-18-2012, 10:58 AM   #46
I had some fucking KR problems in my 1st gen MS3, i installed the ITV 22's on a hunch, it fixed the problem. (If i remember quite right- thats how it went down lol) I think my boost would spike a lil bit upto 18, something to do with the stock plugs not being able to handle that? I could be talking out my ass right now tho lol Ive been thru so much trial and error w my old car, thats i cant remember it all!
 Old 08-18-2012, 11:23 AM   #47
juanms3's Avatar
Well I changed it to the stage 1 map with 93 octane and the car feels weaker and gas pedal is still lighter!
 Old 08-18-2012, 11:51 AM   #48
ArtClassShank's Avatar
Posts: 76   (View Stats)
ArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud ofArtClassShank has much to be proud of
Groaned at 4 Times in 1 Post
You do have to give the car time for the ECU to relearn fuel trims and shit.
2008.5 CWP MS3
Cobb AP, FMIC, Forge BPV V2, Cobb TIP, Cobb SF SRI, JBR 88 RMM, JBR RSB, Ford Transmission fluid, for those magical shifts.
ArtClassShank is offline   Reply With Quote
 Old 08-18-2012, 11:58 AM   #49
roughly 50-100 miles of mixed driving, dont push the car realy hard until then !
 Old 08-18-2012, 12:05 PM   #50
juanms3's Avatar
I figured, thanks. How are is your HPFP holding up? I am thinking about upgrading it before anything else!
 Old 08-18-2012, 12:18 PM   #51
dont know yet, my car is bone stock until i go to the stealership wed, i think i need a belt or pulley replaced. Thursday...I will put on my Cobb SRI, Reflash w the AP, shure short cut & JBR heavy shift knob...ill let u know then lol
 Old 08-19-2012, 11:38 AM   #52
I'm still on stock plugs and 18.5psi and it runs fine. I am also thinking of a one step colder plug too. At our levels I doubt it will make a lot of difference.
Street creds:
 Old 08-19-2012, 11:57 AM   #53
Eric28243's Avatar
Posts: 554   (View Stats)
Eric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the worldEric28243 is the leader of the world
Groaned at 6 Times in 6 Posts
65K miles on the plugs I bought the car with. I ran ITV22's for about 2k miles when one shit the bed. Now I'm back to 21psi to redline w/ 0 kr. If you do want plugs, I'd go with the NGK's over the Denso's though. Hmmm... Time to change my sig.
'08 Polar White Saturn SKY Redline - "The RAWRmobile"
BorgWarner EFR 6758 + IWG Mani, forge v2 BPV, Energy Full Suspension Bushings, GMPP 3-Bars, Vibrant Racing Catted HiFlow Downpipe, WERKS Boost Tubes, Intake, Power-Steering Relocation Kit, Radiator Hoses, and Race FMIC, Koni Yellows + Eibach Pro-Kit's, RPi GT CBE, HP Tuner SquishyTooned on E40, RK Sport Rotors/Pads, DDMWorks 2-gauge Pillarpod and Armrest, Prosport HALO Electronic Wideband and Boost Gauges, Spec Stage 2+ Clutch + Fidanza Single-Mass FryWhee, XTUNERS Gauge Cluster, GM Roadster.com HID/LED Full Exterior and Interior Light Conversion
Dyno: Uhh... fast as hell?
'08.0 Cosmic Blue MS3 - "The Daily" STOCKED OUT (almost)
COBB SRI/TIP - COBB AP SquishyTooned on E40 - COBB XLE BPV - HKS Hi-Power CBE - ITV22s - Corksport RMM Inserts - JBR Shifter Bushings and SSP - PTP Fuel Pump - PG + Treadstone - 35% Tint - ebaY Double-Penetrator - MS3 Vent Kit Install
Dyno: 319 / 331
CWP_MS3 is my mackdaddy
Eric28243 is offline   Reply With Quote
 Old 08-19-2012, 02:00 PM   #54
Standsideways's Avatar
Posts: 363   (View Stats)
Standsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the worldStandsideways is the leader of the world
its about every 50-75 actual hp added you'd want to go 1 colder.
Standsideways is offline   Reply With Quote
The Following User Says Thank You to Standsideways For This Useful Post:
fortressofcomfort (08-19-2012)
 Old 08-27-2012, 09:21 PM   #55
juanms3's Avatar
Ok so its been a week and I know I driven more then 100 miles but the car still feels the same, light gas pedal and weak as shit. 2nd gear feels weird...
 Old 08-28-2012, 11:25 AM   #56
Rich990's Avatar
Posts: 274   (View Stats)
Rich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the worldRich990 is the leader of the world
Im at 5500 ft altitude and with the stage1 map I gained 42whp peak to peak and at 6100rpm gained nearly 100whp/100wtq.
Yeah the stock map is major fail at altitude.
I'm in south Africa by the way, and the runs were done on the same dyno, albeit some months apart.
2007 Velocity Red MS6
Go... BNR S3v2 / COBB APv3 / Snow Performance WMI + DO7 / nator'd DP / test pipe / HTP 3" SRI & TIP / 3 bar MAP / Autotech HPFP / NGK LTR7 / Stratified 3 port / Custom 3" TMIC / EGR delete / CP-E RMM / Turbine Tech FDM / CP-E RDM / Whiteline RSB / H&R springs / Powerbrake GT rotors / Endless MX72 Brakepads
Parts stockpile... Wiseco 88mm's / Manley H beams
Turbo stockpile... Borg Warner S200SX 7670 / GTX3071 / K04
Ex: 2007 Black Mica MS3 - stage 2 mods - 280 whp, 306 tq (321 whp / 358 tq before "stockout", on BNR S2 + meth)
Ex: 2010 Velocity Red MS3 - Stage 1 mods + Meth... 260 whp, 306 tq, stock exhaust
5500 ft altitude FTL
MSF in South Africa
Rich990 is offline   Reply With Quote
The Following User Says Thank You to Rich990 For This Useful Post:
fortressofcomfort (09-04-2012)
 Old 09-10-2012, 09:35 AM   #57
killer-ms3's Avatar
Posts: 1,187   (View Stats)
killer-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the worldkiller-ms3 is the leader of the world
Groans: 32
Reading all these threads terrorized me into getting a fuel pump as my first mod. Then going AP and such
killer-ms3 is offline   Reply With Quote
 Old 09-10-2012, 03:46 PM   #58
bislag's Avatar
Posts: 395   (View Stats)
bislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the worldbislag is the leader of the world
Don't forget you need something to monitor the fuel pressure when you do. Either get the AP at the same time, or pick up a cheap gauge to use until you do.
bislag is offline   Reply With Quote
 Old 09-10-2012, 03:58 PM   #59
SilkBraahJJ's Avatar
Posts: 79   (View Stats)
SilkBraahJJ has a reputation beyond reputeSilkBraahJJ has a reputation beyond reputeSilkBraahJJ has a reputation beyond reputeSilkBraahJJ has a reputation beyond reputeSilkBraahJJ has a reputation beyond reputeSilkBraahJJ has a reputation beyond reputeSilkBraahJJ has a reputation beyond reputeSilkBraahJJ has a reputation beyond reputeSilkBraahJJ has a reputation beyond reputeSilkBraahJJ has a reputation beyond reputeSilkBraahJJ has a reputation beyond repute
If he has an Android phone he can use the Torque App to monitor the fuel pressure. You can get a Bluetooth OBDII sensor on Ebay for pretty cheap.
LSM 2012 Speed 3 W/Tech
SilkBraahJJ is offline   Reply With Quote
Page generated in 0.38883 seconds with 31 queries
