-   -   First Mod (http://www.mazdaspeedforums.org/forum/f544/first-mod-83250/)
rikyrick87 06-12-2011 06:30 PM
First Mod
Just put in a K&N Typhoon SRI, and new RMM inserts (from corksport.com)..I've had the car about 4 months and just now got enough scratch to spend on it haha. Anyways WOW, what a difference the K&N makes, added some nice i guess rumble to to engine and the RMM inserts are amazing. I'd def recommend them to anyone who wants more stability with out replacing the whole RMM. Anybody else have a K&N?...Thoughts on it?
oh10speed3 06-12-2011 06:37 PM
There are quite a few of us that have the K&N. I tried the CPE and the Cobb intakes prior to my K&N and they both gave me a check engine light. I have not had a single problem with my K&N. It was, however, a pain in the ass to install because it is hard to get everything to line up with the heat shield
dizzydtrain 06-12-2011 07:18 PM
Glad you like, it only gets more fun after that. Any other plans?
rikyrick87 06-12-2011 07:50 PM
Yeah, eventually...Before buying the car i was always more of a truck guy. But I wanted something fun to drive so I landed on the MS3. I'm kind of just getting into the whole 'tuning' world and stuff. Not quite sure what all I want to do, but I do know what I don't want my car to be, haha. (If that makes sense?) I'm open to pretty much all suggestions but I mainly want to keep it a bit of a sleeper..Since most people I have talked to think the car is just slow and dopey looking.
DONOTBUGME 06-12-2011 08:03 PM
inserts suck, should have gotten a rmm.
rikyrick87 06-19-2011 12:28 PM
Any suggestions on what to put on next?
dizzydtrain 06-19-2011 12:30 PM
Upgraded Fuel Pump and Cobb Ap. Pricey, yes. Best bang for the buck, easy to stock out, and any power mods down the road require the fp and will be made better in conjuction with the AP.
SWAY 06-19-2011 12:31 PM
get the accessport
rikyrick87 06-21-2011 10:03 AM
Ok..I've been doing some research and have decided I'm going to get the AP, I just have to rob a liquor store first to get the money. But Thanks for the input guys.
Side Note: Have read a lot of people suggest getting a DP and Turbo Inlet, I'm guessing i should do this after the AP? ...like I said i'm very new to all this so I appreciate the help.
J_Logik 06-21-2011 10:15 AM
Definitely AP then the Fuel Pump everything after that is just, pure fun with very little headache. You just need to save that $$$ for the first two!
SWAY 06-23-2011 08:13 AM
good choice on the ap, after that i would get the fmic out the way dp is easier imo to get depending on your brand, im saving/waiting for new corksport fmic ill wait on dp
computergeek 06-29-2011 01:53 PM
i got the SURE Aeros (SRI), Sidewinder (TIP/TIH) and test pipe (removes one cat) and had no issues... I just bought the AP and in learning how to tune that, and seeing what was going on with my car, i realized to get more power the very next thing is a upgraded HPFP or FP internals. I am going with the KMD internal. CP-e's shit is too expensive.
So with the Aeros, Sidewinder, testpipe, TIGs, AP and soon upgraded fuel pump... the sky will be the limit and i can safely adjust my boost levels to 18+ right now i am running a stage 1 sf+tih 93 with zero knock at 14-16psi. can't go any higher without the fuel pump.
Also being a person that has been modding for 10 years... save up and be patient and do it right the first time. In my early years i would spend twice as much because i wasn't patient. example: bought a catback and then a year later bought a turbo back exhaust. So my exhaust system ended up costing me 2K instead of 1500...
good luck!
adlpb 06-30-2011 05:06 AM
If you want KMD you better jump on that waiting list. Took me almost 3 months to get mine
MS3G35 06-30-2011 07:08 AM
My first mods were the Corksport SRI/TIP and Silicone boost tubes and by-pass hose. I think that was a great start. Next on my list is that pesky RMM. Then prob an AP. I would do the AP before the DP.
adlpb 06-30-2011 07:20 AM
Your first mod should have been the donation mod. $10 goes a long way here. After you upgrade your RMM go get fuel internals, not a DP.
MS3G35 06-30-2011 07:53 AM
Agreed do the fuel pump internals.
I'll see what I have in paypal when I get off work this evening.
LakeSTLMS3 06-30-2011 08:23 AM
Once your pump is upgraded you can do anything you want in any order really........dp, fmic/tmic, test pipe, etc
Danish 06-30-2011 11:33 AM
ORLY?
Care to comment on this? I'm in the market, but I don't plan on racing the car so....
DONOTBUGME 06-30-2011 12:57 PM
Originally Posted by Danish (Post 916298)
ORLY?
search, but all you really have to do is compare them side to side to see
Danish 06-30-2011 03:40 PM
I've spent the last few weeks looking at options and landed on CS inserts to keep NVH down while maintaining next to stock appearances for dealership visits.
Just curious why you were so quick to shit on a viable option for those who see this platform as a fun DD and not a wannabe race car. Not everyone needs 75 duro :22:
adlpb 06-30-2011 03:54 PM
Just get the JBR RMM. You can get the 70dm. Don't waste your money on inserts. They don't work. It's a half assed mod.
JS + MS3 06-30-2011 04:14 PM
inserts will fucking break later that's why
and it takes like 2 mins to swap it out for dealer visits
i don't race but i do have 75 duro, the vibration is not bad at all unless you turn on the AC. and i hate AC, so it's perfect for me
i would have gotten the JBR one, but it wasn't available back then
DONOTBUGME 06-30-2011 05:29 PM
I have the cpe 65 duro rmm, I wish now I would have gotten the 75. After 500 miles on slight vibes with the airon at idle. As for dealer visits how often do you go? I haven't been back since I drove it of the lot.
Pelotonracer2 06-30-2011 08:53 PM
And how much of a pain in the ass is it to R&R the fuel pump on these cars?
LakeSTLMS3 07-01-2011 08:55 AM
Not sure cuz I haven't upgraded mine yet. Just need some monies and then I'll pull the trigger. From what everyone says the pump is a simple swap and not to hard........now upgrading the internals is a different animal.
adlpb 07-01-2011 08:59 AM
Actually internals install is just a few steps more than the fuel pump install. Not worth an extra $350 in my opinion
dsmluck 07-01-2011 09:30 AM
I had the inserts. They made a difference in engine lash for maybe a month. My stock RMM still went bad. Went with a CP-E and never looked back. Inserts were a waste of money.
Its really easy actually. Go with KMD if you can. Great price and work really well. Fuck dropping 1k on a new pump when you can spend $330 on internals for the same result.
Yanahdi 07-01-2011 09:46 AM
OP, for a cheap mod I'd recommend JBR short shifter plate with knob. While you're there you might as well get his RMM.
I had the CS inserts as a hold over while I waited for SU RMM to come off backorder (JBR's wasn't out yet at the time). The CS inserts aren't bad for $30 but I can certainly tell a difference after installing the SU RMM, JBR's is almost certainly more robust and well reviewed here. ANY RMM is a vast improvement over inserts but for the price of them I can understand why you went that route.
I'm in roughly the same boat as you and AP then internals is my planned route from here.
JS + MS3 07-01-2011 09:50 AM
wait.... JBR short shifter plate and a heavy know are just some MUST items
don't think, just get it. :D
rikyrick87 07-01-2011 10:14 AM
Yeah, i basically got the inserts because I didn't know what I was doing when i bought them. I've been looking at RMM's for a little while and am prob picking one up in the next month. I also just got a Cobb TIP that my buddy bought me for my birthday so I'm putting that in this weekend. I'm def getting the AP and prob the fuel pump internals. Once that is done the sky (and my paychecks) will be the limit.
MS3G35 07-01-2011 03:34 PM
I just placed my order for the CP-E rmm from edgeautosport.com. Awesome price and he shipped the damn thing like not even 2 hrs later!
Heres a link ---> Edge Autosport
rikyrick87 07-02-2011 06:33 PM
Well today I installed my Cobb TIP. I totally should have ordered the TIP the same time I got my SRI. But anyways, everything went pretty smooth, until i got done putting everything back together and realized I forgot to tighten down the clamp on the turbo, so I had to redo some stuff but finally got it all worked out. I was able to notice immediately the fact that the car was a lot more responsive and seemed to really want to go at WOT, and shifting was much smoother. Overall it was a pretty decent experience and I've learned a lot about my car since I've started working on it. Next thing i have to buy now is the AP. But that will probably take a little while to get. I had planned on taking pictures during the install, but once I got working i totally forgot.
dereeek 07-03-2011 04:40 AM
These are the mods I did in order on my 2011: JBR short shifter with solid shifter base bushings, Cobb AP, Cobb Sri/Tip, forge bpv, cp-e rmm, Denso ITV22, Greddy oil catch can and than re-flashed the ECU to Stage1+SF+TIH 93 BT. also, i did a few little misc things like HIDS, shark fin, and had the res cut out for a little more sound.
My car transformed from awesome to :censored:awesome...
rikyrick87 07-07-2011 09:00 AM
Well i just got 800 and some bucks back from my state taxes, totally forgot about that so i guess now i can buy the AP. fuckin sweet. haha
rikyrick87 07-14-2011 04:03 PM
Well i got my AP the other day...now how in the hell do i use this thing?
adlpb 07-14-2011 04:06 PM
Read the guide/manual
GLORIFIEDBOZO 07-14-2011 04:26 PM
$800 for STATE taxes? Holy fuck, that's about what i get back for federal.
rikyrick87 07-14-2011 05:55 PM
Read it... Still don't really know what I'm doing with it though, I put in the Stage1 map to go with my SRI and TIP at 91oct... I guess what I'm asking for is what should i be monitoring and all that?
adlpb 07-14-2011 06:04 PM
You can do 3rd gear logs and monitor a setting of your choice. I think you go on data logs and start a log. To do a 3rd gear pull, start around 2600 rpms and go WOT till around 6500. Then stop the log. Go on your computer and download it. You can monitor while you drive as well, but it'll only let you see one at a time. It also lets you alert it when it's time to shift. There's plenty of things to play around with. And make sure you contact Cobb with the Serial# and download ATR.
rikyrick87 07-14-2011 06:11 PM
thanks man...like i said at the start of this thread, I'm new to all this crap so Im a little lost.
Page generated in 0.20143 seconds with 11 queries
