Like Tree3Likes
 Old 06-12-2011, 06:30 PM   #1
rikyrick87's Avatar
Posts: 266   (View Stats)
rikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the worldrikyrick87 is the leader of the world
Groaned at 6 Times in 6 Posts
Default First Mod
Just put in a K&N Typhoon SRI, and new RMM inserts (from corksport.com)..I've had the car about 4 months and just now got enough scratch to spend on it haha. Anyways WOW, what a difference the K&N makes, added some nice i guess rumble to to engine and the RMM inserts are amazing. I'd def recommend them to anyone who wants more stability with out replacing the whole RMM. Anybody else have a K&N?...Thoughts on it?
K&N SRI COBB TIP: COBB AP(FREEKIN'): AutoTech Internals: CS Racepipe: JBR Stage 2 SSP: JBR Heavy Knob: JBR Trans and RMM.
rikyrick87 is offline   Reply With Quote
 Old 06-12-2011, 06:37 PM   #2
oh10speed3's Avatar
Posts: 1,119   (View Stats)
oh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the world
Groaned at 74 Times in 30 Posts
There are quite a few of us that have the K&N. I tried the CPE and the Cobb intakes prior to my K&N and they both gave me a check engine light. I have not had a single problem with my K&N. It was, however, a pain in the ass to install because it is hard to get everything to line up with the heat shield
//Stage 1 & Done\\
oh10speed3 is offline   Reply With Quote
The Following User Says Thank You to oh10speed3 For This Useful Post:
rikyrick87 (06-20-2011)
 Old 06-12-2011, 07:18 PM   #3
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
dizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the worlddizzydtrain is the leader of the world
Groans: 64
Glad you like, it only gets more fun after that. Any other plans?
Cp-e HPFP : JBR 80duro RMM : JBR Special Edition Heavy Shift Knob : JBR EGR Delete : Matt Damond OCC kit : Cobb AP : Cobb DP : Cobb BPV XLE : ETS TMIC : CP-e SRI : Cp-e TIP : Magnaflow CBE : Aeroforce Interceptor Dual Gauge : Blockhead vent pod :PERM Tuned : H&R Springs : TSW Nurburgring 18x8.5 w/ 235/45 Hankook Ventus V12 Evo : DDM 6000k Lows : DDM 3000k Fogs : Corksport LED light kit : 3M 35% color stable tint
dizzydtrain is offline   Reply With Quote
 Old 06-12-2011, 07:50 PM   #4
rikyrick87's Avatar
Yeah, eventually...Before buying the car i was always more of a truck guy. But I wanted something fun to drive so I landed on the MS3. I'm kind of just getting into the whole 'tuning' world and stuff. Not quite sure what all I want to do, but I do know what I don't want my car to be, haha. (If that makes sense?) I'm open to pretty much all suggestions but I mainly want to keep it a bit of a sleeper..Since most people I have talked to think the car is just slow and dopey looking.
 Old 06-12-2011, 08:03 PM   #5
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
DONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the world
Groans: 266
Groaned at 83 Times in 60 Posts
inserts suck, should have gotten a rmm.
Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next.
DONOTBUGME is offline   Reply With Quote
 Old 06-19-2011, 12:28 PM   #6
rikyrick87's Avatar
Any suggestions on what to put on next?
 Old 06-19-2011, 12:30 PM   #7
Groans: 64
Upgraded Fuel Pump and Cobb Ap. Pricey, yes. Best bang for the buck, easy to stock out, and any power mods down the road require the fp and will be made better in conjuction with the AP.
rikyrick87 likes this.
The Following User Says Thank You to dizzydtrain For This Useful Post:
 Old 06-19-2011, 12:31 PM   #8
SWAY's Avatar
Posts: 2,517   (View Stats)
SWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the world
Groans: 190
Groaned at 60 Times in 43 Posts
get the accessport
~2011 Liquid Silver MS3~ ---->> ZZB
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
SWAY is offline   Reply With Quote
The Following User Says Thank You to SWAY For This Useful Post:
rikyrick87 (06-19-2011)
 Old 06-21-2011, 10:03 AM   #9
rikyrick87's Avatar
Ok..I've been doing some research and have decided I'm going to get the AP, I just have to rob a liquor store first to get the money. But Thanks for the input guys.
Side Note: Have read a lot of people suggest getting a DP and Turbo Inlet, I'm guessing i should do this after the AP? ...like I said i'm very new to all this so I appreciate the help.
 Old 06-21-2011, 10:15 AM   #10
J_Logik's Avatar
Posts: 129   (View Stats)
J_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the worldJ_Logik is the leader of the world
Groaned at 4 Times in 2 Posts
Definitely AP then the Fuel Pump everything after that is just, pure fun with very little headache. You just need to save that $$$ for the first two!
2010 VRM MS3
JBR RMM, AUTOTECH HPFP INTERNALS,
FORGE V2 BPV, DDM 6K LOWS, 8K FOGS, LED SWITCHBACK PARKING LIGHTS, RED CALIPERS
J_Logik is offline   Reply With Quote
The Following User Says NO Thank You to J_Logik For This Un-useful Post:
I Love Brownies (06-23-2011)
 Old 06-23-2011, 08:13 AM   #11
SWAY's Avatar
Groans: 190
good choice on the ap, after that i would get the fmic out the way dp is easier imo to get depending on your brand, im saving/waiting for new corksport fmic ill wait on dp
 Old 06-29-2011, 01:53 PM   #12
computergeek's Avatar
Posts: 272   (View Stats)
computergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the worldcomputergeek is the leader of the world
Groaned at 8 Times in 5 Posts
i got the SURE Aeros (SRI), Sidewinder (TIP/TIH) and test pipe (removes one cat) and had no issues... I just bought the AP and in learning how to tune that, and seeing what was going on with my car, i realized to get more power the very next thing is a upgraded HPFP or FP internals. I am going with the KMD internal. CP-e's shit is too expensive.
So with the Aeros, Sidewinder, testpipe, TIGs, AP and soon upgraded fuel pump... the sky will be the limit and i can safely adjust my boost levels to 18+ right now i am running a stage 1 sf+tih 93 with zero knock at 14-16psi. can't go any higher without the fuel pump.
Also being a person that has been modding for 10 years... save up and be patient and do it right the first time. In my early years i would spend twice as much because i wasn't patient. example: bought a catback and then a year later bought a turbo back exhaust. So my exhaust system ended up costing me 2K instead of 1500...
good luck!
jamesr242 likes this.
computergeek is offline   Reply With Quote
The Following User Says Thank You to computergeek For This Useful Post:
rikyrick87 (06-29-2011)
 Old 06-30-2011, 05:06 AM   #13
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
If you want KMD you better jump on that waiting list. Took me almost 3 months to get mine
 Old 06-30-2011, 07:08 AM   #14
MS3G35's Avatar
Posts: 1,536   (View Stats)
MS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the world
Groans: 80
My first mods were the Corksport SRI/TIP and Silicone boost tubes and by-pass hose. I think that was a great start. Next on my list is that pesky RMM. Then prob an AP. I would do the AP before the DP.
CS SRI, TIP, SBT & BPH, BPV, SECBE/CP-e RMM, Catted-DP, TMIC/JBR SSP s2, RSB, TMM/AT Internals/Cobb AP/H&R springs/NGK plugs/SPC camber arms/MB Weapon rims/Pending install: Sure TIGS
285whp/321wtq-93
E85 tune in progress
MS3G35 is offline   Reply With Quote
 Old 06-30-2011, 07:20 AM   #15
adlpb's Avatar
Groans: 669
Your first mod should have been the donation mod. $10 goes a long way here. After you upgrade your RMM go get fuel internals, not a DP.
devils2k15 likes this.
The Following User Says Thank You to adlpb For This Useful Post:
manelscout4life (07-15-2011)
 Old 06-30-2011, 07:53 AM   #16
MS3G35's Avatar
Groans: 80
Agreed do the fuel pump internals.
I'll see what I have in paypal when I get off work this evening.
285whp/321wtq-93
 Old 06-30-2011, 08:23 AM   #17
LakeSTLMS3's Avatar
Posts: 281   (View Stats)
LakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the world
Once your pump is upgraded you can do anything you want in any order really........dp, fmic/tmic, test pipe, etc
2011 Black Mica Genpu
COBB AP / Corksport SRI & TIP - LED fog kit - exhaust hangers / StreetUnit testpipe / OBX CBE / Ultimate Racing catted DP / CP-e TMIC - tow plate / Eibach Pro kit / KMD internals / Turbosmart dualport bov / ITV22 denso plugs / TRZ dogbone RMM / JBR 80duro TMM - 80duro PMM - heavy shift knob - SSP - shifter bushings - mud flaps - RSB - 5mm spacers - EGR block off - TB TIG and coolant bypass / RX-8 wheels 18x8 / 245/40/18 Pirelli's / Aeroforce gauges
Stratified!........
E85 tuned - VD 348whp/396tq
Future Mods:
Koni yellows - OCC - BNR S3 - FMIC - JBR big intake - Cobb 3port - Bosch 3 bar - GA - retune from Lex
LakeSTLMS3 is offline   Reply With Quote
 Old 06-30-2011, 11:33 AM   #18
Danish's Avatar
Posts: 595   (View Stats)
Danish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the worldDanish is the leader of the world
Groaned at 249 Times in 46 Posts
ORLY?
Care to comment on this? I'm in the market, but I don't plan on racing the car so....
Danish is offline   Reply With Quote
 Old 06-30-2011, 12:57 PM   #19
DONOTBUGME's Avatar
Groans: 266
Originally Posted by Danish View Post
ORLY?
search, but all you really have to do is compare them side to side to see
 Old 06-30-2011, 03:40 PM   #20
Danish's Avatar
I've spent the last few weeks looking at options and landed on CS inserts to keep NVH down while maintaining next to stock appearances for dealership visits.
Just curious why you were so quick to shit on a viable option for those who see this platform as a fun DD and not a wannabe race car. Not everyone needs 75 duro
 Old 06-30-2011, 03:54 PM   #21
adlpb's Avatar
Groans: 669
Just get the JBR RMM. You can get the 70dm. Don't waste your money on inserts. They don't work. It's a half assed mod.
JS + MS3 (06-30-2011)
 Old 06-30-2011, 04:14 PM   #22
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groans: 98
Groaned at 72 Times in 51 Posts
inserts will fucking break later that's why
and it takes like 2 mins to swap it out for dealer visits
i don't race but i do have 75 duro, the vibration is not bad at all unless you turn on the AC. and i hate AC, so it's perfect for me
i would have gotten the JBR one, but it wasn't available back then
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
 Old 06-30-2011, 05:29 PM   #23
DONOTBUGME's Avatar
Groans: 266
I have the cpe 65 duro rmm, I wish now I would have gotten the 75. After 500 miles on slight vibes with the airon at idle. As for dealer visits how often do you go? I haven't been back since I drove it of the lot.
The Following User Says Thank You to DONOTBUGME For This Useful Post:
 Old 06-30-2011, 08:53 PM   #24
Pelotonracer2's Avatar
Posts: 54   (View Stats)
Pelotonracer2 is a glorious beacon of lightPelotonracer2 is a glorious beacon of lightPelotonracer2 is a glorious beacon of lightPelotonracer2 is a glorious beacon of lightPelotonracer2 is a glorious beacon of light
And how much of a pain in the ass is it to R&R the fuel pump on these cars?
2011 Velocity Red Mica Mazda Speed3 w/Tech package. Stage 1 Cobb AP, Corksport counter weight, SURE SRI, Corksport adjustable shiftplate, Ultimate Racing ABE (purely for the sound), Corksport springs, Black 18x8 Konig Deception wheels.
Pelotonracer2 is offline   Reply With Quote
 Old 07-01-2011, 08:55 AM   #25
LakeSTLMS3's Avatar
Not sure cuz I haven't upgraded mine yet. Just need some monies and then I'll pull the trigger. From what everyone says the pump is a simple swap and not to hard........now upgrading the internals is a different animal.
Stratified!........
Future Mods:
 Old 07-01-2011, 08:59 AM   #26
adlpb's Avatar
Groans: 669
Actually internals install is just a few steps more than the fuel pump install. Not worth an extra $350 in my opinion
 Old 07-01-2011, 09:30 AM   #27
dsmluck's Avatar
Posts: 1,193   (View Stats)
dsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the world
Groans: 60
I had the inserts. They made a difference in engine lash for maybe a month. My stock RMM still went bad. Went with a CP-E and never looked back. Inserts were a waste of money.
Its really easy actually. Go with KMD if you can. Great price and work really well. Fuck dropping 1k on a new pump when you can spend $330 on internals for the same result.
2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune
1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked*
2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph
2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph
Last edited by dsmluck; 07-01-2011 at 09:30 AM. Reason: MSF Database - Automerged Doublepost
dsmluck is offline   Reply With Quote
The Following User Says Thank You to dsmluck For This Useful Post:
JS + MS3 (07-01-2011)
 Old 07-01-2011, 09:46 AM   #28
Yanahdi's Avatar
Posts: 198   (View Stats)
Yanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the world
OP, for a cheap mod I'd recommend JBR short shifter plate with knob. While you're there you might as well get his RMM.
I had the CS inserts as a hold over while I waited for SU RMM to come off backorder (JBR's wasn't out yet at the time). The CS inserts aren't bad for $30 but I can certainly tell a difference after installing the SU RMM, JBR's is almost certainly more robust and well reviewed here. ANY RMM is a vast improvement over inserts but for the price of them I can understand why you went that route.
I'm in roughly the same boat as you and AP then internals is my planned route from here.
Yanahdi is offline   Reply With Quote
The Following User Says Thank You to Yanahdi For This Useful Post:
 Old 07-01-2011, 09:50 AM   #29
JS + MS3's Avatar
Groans: 98
wait.... JBR short shifter plate and a heavy know are just some MUST items
don't think, just get it.
2010 Mazdaspeed3
 Old 07-01-2011, 10:14 AM   #30
rikyrick87's Avatar
Yeah, i basically got the inserts because I didn't know what I was doing when i bought them. I've been looking at RMM's for a little while and am prob picking one up in the next month. I also just got a Cobb TIP that my buddy bought me for my birthday so I'm putting that in this weekend. I'm def getting the AP and prob the fuel pump internals. Once that is done the sky (and my paychecks) will be the limit.
 Old 07-01-2011, 03:34 PM   #31
MS3G35's Avatar
Groans: 80
I just placed my order for the CP-E rmm from edgeautosport.com. Awesome price and he shipped the damn thing like not even 2 hrs later!
Heres a link ---> Edge Autosport
285whp/321wtq-93
 Old 07-02-2011, 06:33 PM   #32
rikyrick87's Avatar
Well today I installed my Cobb TIP. I totally should have ordered the TIP the same time I got my SRI. But anyways, everything went pretty smooth, until i got done putting everything back together and realized I forgot to tighten down the clamp on the turbo, so I had to redo some stuff but finally got it all worked out. I was able to notice immediately the fact that the car was a lot more responsive and seemed to really want to go at WOT, and shifting was much smoother. Overall it was a pretty decent experience and I've learned a lot about my car since I've started working on it. Next thing i have to buy now is the AP. But that will probably take a little while to get. I had planned on taking pictures during the install, but once I got working i totally forgot.
 Old 07-03-2011, 04:40 AM   #33
dereeek's Avatar
Posts: 2,053   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 386
These are the mods I did in order on my 2011: JBR short shifter with solid shifter base bushings, Cobb AP, Cobb Sri/Tip, forge bpv, cp-e rmm, Denso ITV22, Greddy oil catch can and than re-flashed the ECU to Stage1+SF+TIH 93 BT. also, i did a few little misc things like HIDS, shark fin, and had the res cut out for a little more sound.
My car transformed from awesome to awesome...
dereeek is offline   Reply With Quote
 Old 07-07-2011, 09:00 AM   #34
rikyrick87's Avatar
Well i just got 800 and some bucks back from my state taxes, totally forgot about that so i guess now i can buy the AP. fuckin sweet. haha
 Old 07-14-2011, 04:03 PM   #35
rikyrick87's Avatar
Well i got my AP the other day...now how in the hell do i use this thing?
 Old 07-14-2011, 04:06 PM   #36
adlpb's Avatar
Groans: 669
Read the guide/manual
 Old 07-14-2011, 04:26 PM   #37
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
$800 for STATE taxes? Holy fuck, that's about what i get back for federal.
 Old 07-14-2011, 05:55 PM   #38
rikyrick87's Avatar
Read it... Still don't really know what I'm doing with it though, I put in the Stage1 map to go with my SRI and TIP at 91oct... I guess what I'm asking for is what should i be monitoring and all that?
 Old 07-14-2011, 06:04 PM   #39
adlpb's Avatar
Groans: 669
You can do 3rd gear logs and monitor a setting of your choice. I think you go on data logs and start a log. To do a 3rd gear pull, start around 2600 rpms and go WOT till around 6500. Then stop the log. Go on your computer and download it. You can monitor while you drive as well, but it'll only let you see one at a time. It also lets you alert it when it's time to shift. There's plenty of things to play around with. And make sure you contact Cobb with the Serial# and download ATR.
 Old 07-14-2011, 06:11 PM   #40
rikyrick87's Avatar
thanks man...like i said at the start of this thread, I'm new to all this crap so Im a little lost.
Page generated in 0.57996 seconds with 36 queries
